insufficient memory error
after a while my computer gets this error, and i need to restart. ive tried following the rules on teh homepage but its hard
WinXP Unload DLLs: Go to Start - Run - type in "REGEDIT" without quotes and press enter. The Registry Editor opens up. Now use the lefthand explorer pane to find this key: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer" Still in the lefthand pane, right click on the Explorer folder and choose "New - KEY". Give it a name of "AlwaysUnloadDLL" (without quotes and capital letters are important). Inside that key change the default string to 1 and close regedit and reboot.
i dont get the last part
thanks,
nick
EDIT:if its easier, you can im me at realslimnick727
Ok your going to have to give us some iformation..The error, exaclty how shown (caps and punctuation to). What are your comp's specs..? like CPU.. RAM.. etc./
im not too sure. thanks for the reply, but i was aksing for help with the instructions-i dont get the last part with the changing of it to 1.what do i change? the one? thanks, nick
Ok, the next time you get that error, write it down exactly as it appears. Then come post it here so we might know what the problem is. Once you give us the exact error, then we will need to know something about your computer.. like what type of processor, how much ram, virtual memory…etc..etc as to be able to tell you how to fix it.
