spy-agent.bc
The "missing" .dll file identified is a standard part of Microsoft installations and is considered "safe".
Not having it is known to interfere with VPN and Visual Basic operations.
Download and install the missing .dll safely from this location:
http://www.dll-files.com/dllindex/dll-files.shtml?msvbvm60
Then Run HJT and post the Log file in the thread you have already started over at Malware Removal.
I'm presuming you've already done the preliminaries in getting ready for help in the HJT Forum.
If not, please follow the instructions below:
Directions to post a HJT Log
You can do a few things to get partially cleaned up and better ready to receive assistance over in the Malware Removal Forum, where you will ultimately need to go for expert assistance.
Please download, update, and run Spybot Search & Destroy and Ad-Aware SE Personal (both are free)
Download SpyBot Search & Destroy
Download (Free Version) Ad-Aware Personal
(The (Free) download is the fourth column)
If you need instructions for the above download, installation, update and run, read here:
How to install and setup SpyBot S & D and Ad-Aware
Next:
To get rid of Temp and Temporary Internet Files where this kind of malware hides and gets its first toe-hold in a machine:
Download, install and Run CleanUp! 4.51
http://www.stevengould.org
Next:
Run the following Online scans and post their Report back into this Forum Thread
Run Panda ActiveScan
Panda Active Scan
Run AVG Ewido Online Scan
Next:
Create a New Folder on your C:\ Drive and Rename is to appear as follows –> C:\HiJackThis\
Go here to download HiJackThis.exe (fifth button down in the left-hand column)
Download HiJackThis.exe Here
Save HighJackThis.exe into your newly created Folder C:\HiJackThis\
Please run HiJackThis, by double clicking on HiJackThis.exe
Select "Run a system scan and save a log file"
HJT will scan your machine and create a NotePad Log of the HJT Scan.
In NotePad, Select Edit - Select All and then Copy
Paste the HiJackThis Log into the Malware Removal Forum as a New Topic, here:
http://forums.tomcoyote.org/index.php?showforum=27
Write a brief description of the problems you have encountered and give a link to this thread, so that the Expert will know what you've done up to this point.
Also include the link to this Forum where you will be posting your Panda ActiveScan and AVG Ewido Reports, since the Trusted Advisor that will respond to you over in the Malware Removal Forum will benefit from these reports.
Best Regards
