Windows Explorer stops working
What happened in this thread
The computer randomly said, “Windows Explorer has stopped working,” then restarted it. SFC found corrupt files it could not repair. The poster wondered if these files caused the crashes. [1]
A helper suggested disabling added right-click menu extensions. The poster tried this, but later said Explorer still had the same problem. The excerpts do not confirm a resolution. [2] [3] [4]
General guidance: For similar crashes, check whether they happen while browsing files or using a right-click menu. Also check whether SFC reports files it cannot repair. These clues may help narrow the cause; neither alone proves what caused it.
AI summary of this archived thread. Check the linked posts; old advice may be out of date.
Still have this problem? Ask a person at Geeks to Go → It's free.
Hello,
I have been experiencing issues with windows explorer. I posted in the virus, spyware, and maleware removal section but it did not correct the issue so I am posting here. The computer randomly tells me Windows Explorer has stopped working and will restart. I did a sfc/scannow command and it created a CBS log which informed me that some files were corrupt and could not be repaired. I am not sure if it is what's needed to fix this issue but if it is, I will post it. Thanks
Are you kidding? You helped clear up some stuff I didn't even know was wrong. I just figured this issue was more of a hardware problem than a virus or malware problem so I posted here. I didn't know you can fix this too!
The log is too long to post here so I will attach it.
I probably can't… but I felt safe to say that the Tech Team would like to see the report. :)
A couple of the repairs that were made appear to be related to Internet Explorer.  Do you notice any difference since running?
When you were running… did is ask for your Operating system disk before saying that the repair failed?
Some times, Windows Explorer problems are caused by shell extensions that "add function"  to the right click Context menu. Try running ShellExView and disable the ones that were added. They are highlighted  in pink. Just right click and Disable.
