Bookedspace, Multiple Trojans, Rootkits On Xp
We're running XP SP2. We had AVG Free on the computer but did something silly and started getting lots of pop-ups. I think someone clicked on a fake pop-up pretending to be a microsoft virus cleaner and installed a trojan.
We started getting continuous pop-ups and the computer will often shut-down while running a full-system scan with a number of different spyware detectors. I was unable to run the PandaSoftware online update. The computer rebooted while trying to do the scan. I've had the same problem with Ad-Aware and other spyware scanners. Sometimes the system will just reboot when trying to do a scan, while I'm connected to the internet.
Running in safe mode allows me to run an Ad-Aware full system scan. The scan showed BOOKEDSPACE objects in the Quarantine after cleaning.
An AVG Anti-Spyware scan shows some of the following:
Trojan.Tibs.w
Downloader.Agent.bnn
Worm.Zhelatin.cx
Downloader.Agent.bnr
Downloader.Small.cib
Downloader.Tibs.kv
Adware.RK
Whenever I'm connected to the internet, a netstat -n in the command line shows tons of random connections to outside ip addresses that I don't recognize.
I've also run AVG Anti Rootkit Free and it found the following:
C:\WINDOWS\system32\windev-17c5-56ad.sys Hidden Driver File
C:\WINDOWS\system32\windev-17c5-56ad.sys Hidden File
C:\WINDOWS\system32\windev-peers.ini Hidden File
I ran Deckard's System Scanner which includes a hijackthis log. Here is my log file:
Deckard's System Scanner v20070426.43
Run by [removed] on 2007-05-11 at 08:51:39
Computer is in Normal Mode.
– System Restore ————————————————————–
Successfully created a Deckard's System Scanner Restore Point.
– Last 5 Restore Point(s) –
59: 2007-05-11 14:51:43 UTC - RP845 - Deckard's System Scanner Restore Point
58: 2007-05-11 09:44:22 UTC - RP844 - System Checkpoint
57: 2007-05-10 09:00:22 UTC - RP843 - Software Distribution Service 2.0
56: 2007-05-10 00:11:14 UTC - RP842 - System Checkpoint
55: 2007-05-08 22:31:40 UTC - RP841 - System Checkpoint
– First Restore Point –
1: 2007-03-10 08:54:31 UTC - RP787 - System Checkpoint
Backed up registry hives.
Performed disk cleanup.
– HijackThis (run as Ash.exe) ————————————————-
Logfile of HijackThis v1.99.1
Scan saved at 8:52:40 AM, on 5/11/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16441)
C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
C:\Program Files\TightVNC\WinVNC.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\Java\jre1.5.0_11\bin\jusched.exe
C:\Program Files\Samsung\SmarThru\PORTCTRL.EXE
C:\PROGRA~1\Grisoft\AVG7\avgcc.exe
C:\WINDOWS\soundman.exe
C:\Program Files\Picasa2\PicasaMediaDetector.exe
C:\PROGRA~1\Sony\SONICS~1\SsAAD.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Adobe\Adobe Version Cue CS2\ControlPanel\VersionCueCS2Tray.exe
C:\Program Files\Adobe\Adobe Acrobat 7.0\Distillr\Acrotray.exe
C:\Program Files\Common Files\Sony Shared\AVLib\SSScsiSV.exe
C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe
C:\Program Files\TrojanHunter 4.6\THGuard.exe
C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\acrobat_sl.exe
C:\Documents and Settings\Ash\Desktop\dss.exe
C:\spyware\SPYWAR~1\HIJACK~1\Ash.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Microsoft Internet Explorer presented by Comcast
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = :0
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Adobe Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: AcroIEToolbarHelper Class - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.5.0_11\bin\jusched.exe"
O4 - HKLM\..\Run: [GW Port Controller] C:\Program Files\Samsung\SmarThru\PORTCTRL.EXE
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVG7\avgcc.exe /STARTUP
O4 - HKLM\..\Run: [SoundMan] soundman.exe
O4 - HKLM\..\Run: [Picasa Media Detector] C:\Program Files\Picasa2\PicasaMediaDetector.exe
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [WinVNC] "C:\Program Files\TightVNC\WinVNC.exe" -servicehelper
O4 - HKLM\..\Run: [SsAAD.exe] C:\PROGRA~1\Sony\SONICS~1\SsAAD.exe
O4 - HKLM\..\Run: [Adobe Version Cue CS2] "C:\Program Files\Adobe\Adobe Version Cue CS2\ControlPanel\VersionCueCS2Tray.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 7.0] "C:\Program Files\Adobe\Adobe Acrobat 7.0\Distillr\Acrotray.exe"
O4 - HKLM\..\Run: [!AVG Anti-Spyware] "C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe" /minimized
O4 - HKLM\..\Run: [THGuard] "C:\Program Files\TrojanHunter 4.6\THGuard.exe"
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O4 - Global Startup: Adobe Gamma.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Adobe Acrobat Speed Launcher.lnk = ?
O8 - Extra context menu item: Convert link target to Adobe PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert to existing PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O11 - Options group: [INTERNATIONAL] International*
O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://acs.pandasoftware.com/activescan/as5free/asinst.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{E72A1F1C-9523-45BA-9479-658A56D20972}: NameServer = 205.171.3.65,205.171.2.65
O20 - AppInit_DLLs: C:\WINDOWS\system32\perfc000.dat
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Adobe Version Cue CS2 - Unknown owner - C:\Program Files\Adobe\Adobe Version Cue CS2\bin\VersionCueCS2.exe" -win32service (file missing)
O23 - Service: Ati HotKey Poller - Unknown owner - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: AVG Anti-Spyware Guard - Anti-Malware Development a.s. - C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
O23 - Service: AVG E-mail Scanner (AVGEMS) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPodService - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: MSCSPTISRV - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\MSCSPTISRV.exe
O23 - Service: PACSPTISVR - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\PACSPTISVR.exe
O23 - Service: Sony SPTI Service (SPTISRV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SPTISRV.exe
O23 - Service: SonicStage SCSI Service (SSScsiSV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SSScsiSV.exe
O23 - Service: VNC Server (winvnc) - Unknown owner - C:\Program Files\TightVNC\WinVNC.exe" -service (file missing)
– File Associations ———————————————————–
All associations okay.
– Drivers: 0-Boot, 1-System, 2-Auto, 3-Demand, 4-Disabled ———————
R1 VIAPFD - c:\windows\system32\drivers\viapfd.sys
Hello aaaaathatsfiveas and Welcome to TomCoyote,
Please download ATF Cleaner by Atribune.
This program is for XP and Windows 2000 only
  • Double-click ATF-Cleaner.exe to run the program.
  • Under Main choose: Select All
  • Click the Empty Selected button.
If you use Firefox browser
  • Click Firefox at the top and choose:Select All
  • NOTE: If you would like to keep your saved passwords, please click
  • No at the prompt.
If you use Opera browser
  • Click Opera at the top and choose: Select All
  • NOTE:If you would like to keep your saved passwords, please click No at the prompt.
Click Exit on the Main menu to close the program.
For Technical Support, double-click the e-mail address located at the bottom of each menu.
Combofix Beta
  • Download ComboFix.exe
    and save to your desktop:
    Note: It is important that it is saved directly to your desktop
  • Close any open browsers.
  • Double click on combofix.exe and follow the prompts.
    When it's finished it will produce a log.
  • Post the C:\ComboFix.txt into your next reply.
Note:
Do not mouseclick combofix's window whilst it's running.
That may cause the program to freeze/hang.
Please post (reply) with the results from the Combofix.
Susan528 - I'm sorry I didn't reply faster. I started following instructions from a helper at TechSupportForums. If I am unsuccessful I will start your instructions and repost here. So sorry that I didn't say so earlier. Jeff
This topic is now closed. If you wish it reopened, please send us an email
(Click for address) with a link to your thread.
Do not bother contacting us if you are not the topic starter. A valid, working link to the closed topic is required along with the user name used. If the user name does not match the one in the thread linked, the email will be deleted.
Also follow the recommendations in Tony Klein's article
So how did I get infected in the first place?
