PSU selection
Right, I have selected two 550-560W of PSUs and they are Corsair VX550 and Silverstone ST56F. For now, I'm kind of stuck in between these two because I do not know which one will suits best for my future system. Both of the prices are more or less the same range and in terms of specification and others. I am not so sure what should I look out for, so I hope any one of you might give me a little advice on this? Thanks
Similar. I prefer the Corsair. Depends a lot on your other hardware.
If you are going SLi or Crossfire I would not recommend either.
If you are just going to use a single graphics card then no problem.
The Corsair offers the 6+2 option for PCI_E.
The issue with either SLI or Crossfire is you would want/need more wattage plus 4 X PCI_E or a modular PSU.
http://www.newegg.com/Product/Product.aspx…N82E16817139004
http://www.silverstonetek.com/products/p_s…6f&area=usa
