[Resolved] TR/Crypt.XPACK.Gen Removal
17 min read
Getting any error messages? Avira - I think it is your using - has been known to use slow & erratic servers. You could try again in a couple of hours or so. Has this problem only just occurred?My AV wont connect to the server to update the virus DB……. Dont know if this is related or not though.
Please do this:What is the safest way to remove all of the tools I have Dl'd??
Remove Combofix
The following will implement some cleanup procedures as well as reset System Restore points:
Click Start > Run and copy/paste the following bolded text into the Run box and click OK:
ComboFix /u
OTCleanIt
Download OTCleanIt here & save it to your desktop.
Right-click on OTCleanIt.exe then choose Run as Administrator to run the tool. Click on CleanUp!.
You will receive a prompt that it needs to restart the computer to remove the files. Click Yes.
It will restart your computer automatically. If it doesn't, please restart your computer manually.
You can also delete the following from your desktop:
MBR.exe
DDS.scr
Any logs that may have been saved to your desktop
You can either delete or keep ATF-Cleaner. It's a handy tool for cleaning out your temporary folders.
No problem at allThanks for all the help you have been outstanding.
Yes.. you can make a donation Here if you like.Does the site operate on donations? How is it supported?
Here's some recommendations to help keep your computer safe in the future:
Microsoft Windows Update
Microsoft releases patches for Windows and Office products regularly to patch up Windows and Office products loopholes and fix any bugs found. Install the updates immediately if they are found.
To update Windows
Go to Start > All Programs > Windows Update
To update Office
Open up any Office program.
Go to Help > Check for Updates
Malwarebytes' Anti-Malware
Malwarebytes' Anti-Malware is a new and powerful anti-malware tool. It is totally free but for real-time protection you will have to pay a small one-time fee.
You can download it here & find a tutorial here.
SpywareBlaster
Download and install Javacools SpywareBlaster from here
SpywareBlaster adds a list of ActiveX controls, tracking cookies and sites which will be blocked in either Internet Explorer or Firefox browsers. You need to manually check for updates regularly.
Download and Install a HOSTS File
A HOSTS file is a big list of bad web sites. The list has a specific format, a specific name, (name is just HOSTS with no file extension), and a specific location. Your machine always looks at that file in that location before connecting to a web site to verify the address. So the HOSTS listing can be used to "short circuit" a request to a bad website by giving it the address of your own machine.
Download BlueTack's HOSTS Manager here, using Internet Explorer (Firefox won't work):
- A short distance down the page in the centre, click on the Download button
- Agree to the license
- On the next page, to the right side of where it says Download Estimates, right click on the underlined word Hosts Manager choose Save Target As and download the installer Hosts20setup.exe to your desktop
- Double click the Installer on your desktop and let it Install the Hosts Manager
- After the installation is complete, click on the Hosts Manager icon on your desktop. (You can delete the other Hosts Switch icon from your desktop)
- When the Hosts Manager comes up, click the small down arrows on the right side of the bar labeled Options and Tools,
- Click Disable DNS Service. This is important
- In the Left Pane, click Download
- It will load 80,000 lines or more. When it finishes, also in the left pane, click Replace, and then click Save
If you have a separate party firewall or Winpatrol, you may have to give permissions at various times to Unlock the present default HOSTS file and install the new one.
Install WinPatrol
Download it here
You can find information about how WinPatrol works here
Install a Third party Firewall
As the term conveys, a firewall is an extra layer of security installed onto computers, which restricts access to systems from the outside world. Firewalls protect against hackers and malicious intruders. You can download a free firewall from one of these excellent vendors:
1)Webroot Desktop Firewall (Registration is needed to download the firewall)
2)PC Tools Firewall Plus
3)Netchina S3 2008
4)ZoneAlarm (uncheck ZoneAlarm Spy Blocker during installation if you choose this one)
Read some information here on how to prevent Malware.
Hopefully these steps will help keep your computer clean.
Stand Up and Be Counted —> Malware Complaints <— where you can make difference!
The site offers people who have been (or are) victims of malware the opportunity to document their story and, in that way, launch a complaint against the malware and the makers of the malware.
Thank you for that. The site appreciates ALL donations & as you say every little helpsAgain thankyou for all your help I will definetely be recommending the site to others in need.
I have made a small donation by the way as well. I am only sorry it couldn't be more but in these hard times every little helps.
Good luck & safe surfing.
Since this issue appears to be resolved … this Topic has been closed. Glad we could be of assistance.
If you're the topic starter, and need this topic reopened, please contact a staff member with the address of the thread.
Everyone else please begin a New Topic.
