[Resolved]Hijackthis Log
28 min read
The fact that your account is not recognized as an admin account may explain some of the troubles we have had with the tool.
A. Does the Account have Administrative Privileges
To see if your account has administrative privileges, go to START|RUN|CONTROL PANEL and double click on the "Users" category. This will show you all the user accounts on your machine and what their privileges are.
B. Open IE, from thr toolbar choose Tools, then Internet Options, then Security. Now, click on Default Level and click on OK. Restart your system. Finally try another scan with Kaspersky.
If none of the above gets the scan to perform its function:
Download Dr.Web CureIt to the desktop:
ftp://ftp.drweb.com/pub/drweb/cureit/drweb-cureit.exe
Next, please reboot your computer in Safe Mode by doing the following:
1) Restart your computer
2) After hearing your computer beep once during startup, but before the Windows icon appears, press F8.
3) Instead of Windows loading as normal, a menu should appear
4) Select the first option, to run Windows in Safe Mode.
For additional help in booting into Safe Mode, see the following site:
• http://www.pchell.com/support/safemode.shtml
  • Doubleclick the drweb-cureit.exe file and Allow to run the express scan
  • This will scan the files currently running in memory and when something is found, click the yes button when it asks you if you want to cure it. This is only a short scan.
  • Once the short scan has finished, mark the drives that you want to scan.
  • Select all drives. A red dot shows which drives have been chosen.
  • Click the green arrow at the right, and the scan will start.
  • Click 'Yes to all' if it asks if you want to cure/move the file.
  • When the scan has finished, look if you can click next icon next to the files found: [external image: Posted Image]
  • If so, click it and then click the next icon right below and select Move incurable as you'll see in next image:
    This will move it to the %userprofile%\DoctorWeb\quarantaine-folder if it can't be cured. (this in case if we need samples)
  • After selecting, in the Dr.Web CureIt menu on top, click file and choose save report list
  • Save the report to your desktop. The report will be called DrWeb.csv
  • Close Dr.Web Cureit.
  • Reboot your computer!! Because it could be possible that files in use will be moved/deleted during reboot.
  • After reboot, post the contents of the log from Dr.Web you saved previously in your next reply.
And I must go to bed. I have been at this since about 10 AM my time and it is now 0220 hrs. People make mistakes when they get tired.
Hoping to see some results tomorrow.
Trevuren
Out of curiosity, is it normal for that scan to take two and a half hours?? :blink:
Anyways, here is the Kapersky Online Scanner Log:
KASPERSKY ONLINE SCANNER REPORT
Friday, August 03, 2007 4:05:29 AM
Operating System: Microsoft Windows XP Professional, Service Pack 2 (Build 2600)
Kaspersky Online Scanner version: 5.0.83.0
Kaspersky Anti-Virus database last update: 3/08/2007
Kaspersky Anti-Virus database records: 371455
Scan Settings:
Scan using the following antivirus database: extended
Scan Archives: true
Scan Mail Bases: true
Scan Target - My Computer:
C:\
D:\
E:\
Scan Statistics:
Total number of scanned objects: 100547
Number of viruses found: 28
Number of infected objects: 166 / 0
Number of suspicious objects: 0
Duration of the scan process: 02:25:49
Infected Object Name / Virus Name / Last Action
C:\Documents and Settings\All Users\Application Data\Microsoft\Crypto\RSA\MachineKeys\3ad391678a806ec4d691e83aaa393b6f_24adf822-76f7-4481-b30b-ff1b40f8687f Object is locked skipped
C:\Documents and Settings\All Users\Application Data\Microsoft\eHome\logs\ehRecvr.log Object is locked skipped
C:\Documents and Settings\All Users\Application Data\Microsoft\Network\Downloader\qmgr0.dat Object is locked skipped
C:\Documents and Settings\All Users\Application Data\Microsoft\Network\Downloader\qmgr1.dat Object is locked skipped
C:\Documents and Settings\All Users\Application Data\QSLLPSVCShare Object is locked skipped
C:\Documents and Settings\Chase\Cookies\index.dat Object is locked skipped
C:\Documents and Settings\Chase\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped
C:\Documents and Settings\Chase\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped
C:\Documents and Settings\Chase\Local Settings\History\History.IE5\index.dat Object is locked skipped
C:\Documents and Settings\Chase\Local Settings\History\History.IE5\MSHist012007080320070804\index.dat Object is locked skipped
C:\Documents and Settings\Chase\Local Settings\Temp\~DFD852.tmp Object is locked skipped
C:\Documents and Settings\Chase\Local Settings\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped
C:\Documents and Settings\Chase\ntuser.dat Object is locked skipped
C:\Documents and Settings\Chase\ntuser.dat.LOG Object is locked skipped
C:\Documents and Settings\LocalService\Cookies\index.dat Object is locked skipped
C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped
C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped
C:\Documents and Settings\LocalService\Local Settings\History\History.IE5\index.dat Object is locked skipped
C:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped
C:\Documents and Settings\LocalService\NTUSER.DAT Object is locked skipped
C:\Documents and Settings\LocalService\ntuser.dat.LOG Object is locked skipped
C:\Documents and Settings\NetworkService\Cookies\index.dat Object is locked skipped
C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped
C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped
C:\Documents and Settings\NetworkService\Local Settings\History\History.IE5\index.dat Object is locked skipped
C:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped
C:\Documents and Settings\NetworkService\NTUSER.DAT Object is locked skipped
C:\Documents and Settings\NetworkService\ntuser.dat.LOG Object is locked skipped
C:\Program Files\ACSPMonitor\hk.dll Infected: not-a-virus:Monitor.Win32.ActualSpy.30 skipped
C:\Program Files\Citrix\GoToMyPC\g2host.log Object is locked skipped
C:\Program Files\Citrix\GoToMyPC\g2svc.log Object is locked skipped
C:\Program Files\Hijackthis\backups\backup-20070802-152045-873.dll Infected: not-a-virus:AdWare.Win32.BHO.cw skipped
C:\Program Files\TrustIn Contextual\trustincontext.dll Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\QooBox\Quarantine\C\Program Files\codec_setup.exe.vir/stream/data0006 Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\QooBox\Quarantine\C\Program Files\codec_setup.exe.vir/stream Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\QooBox\Quarantine\C\Program Files\codec_setup.exe.vir NSIS: infected - 2 skipped
C:\QooBox\Quarantine\C\Program Files\Common Files\Yazzle1162OinAdmin.exe.vir Infected: Trojan-Downloader.Win32.PurityScan.eg skipped
C:\QooBox\Quarantine\C\WINDOWS\inetloader.dll.vir Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\advpackb.dll.vir Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\audiodevs.dll.vir Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\byxurst.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.io skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\cbxvutu.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.jp skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\drvheg.dll.vir Infected: Trojan.Win32.Agent.qt skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\ducmbbhi.exe.vir Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\duvvxdgy.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\egoiraqu.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\ekxvoeio.exe.vir Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\fccbawx.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.io skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\fccdbxy.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.jp skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\giguaelj.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\hlpsrv.exe.vir Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\ixbhqqdk.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\knqjximj.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\kvbxgvgy.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\lgjxxcnr.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\mbegbeph.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\msasxbpy.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\okqeytlm.exe.vir Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\phodxgjy.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.hb skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\rpjkueee.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\sledryqr.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\sqhneuoe.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\sqrbuwef.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\thtykggq.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.hb skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\tuvwurq.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.jp skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\uwcctjrn.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\vnsvifbu.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\winnwn32.dll.vir Infected: Trojan.Win32.Dialer.qn skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\xgiosmvd.exe.vir Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\QooBox\Quarantine\C\WINDOWS\system32\xxywwts.dll.vir Infected: not-a-virus:AdWare.Win32.Virtumonde.jp skipped
C:\QooBox\Quarantine\C\WINDOWS\wjejmlav.dll.vir Infected: not-a-virus:AdWare.Win32.BHO.cw skipped
C:\QooBox\Quarantine\C\WINDOWS\xpupdate.exe.vir Infected: Trojan.Win32.Agent.qt skipped
C:\QooBox\Quarantine\catchme2007-08-02_133624.70.zip/efcdaxv.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.jp skipped
C:\QooBox\Quarantine\catchme2007-08-02_133624.70.zip/pmkhh.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.kr skipped
C:\QooBox\Quarantine\catchme2007-08-02_133624.70.zip ZIP: infected - 2 skipped
C:\System Volume Information\MountPointManagerRemoteDatabase Object is locked skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP278\A0312945.exe Infected: not-a-virus:AdTool.Win32.MyWebSearch skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP282\A0330779.exe Infected: not-a-virus:AdTool.Win32.MyWebSearch skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP289\A0344111.exe/WISE0008.BIN Infected: not-a-virus:RemoteAdmin.Win32.WinVNC-based.b skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP289\A0344111.exe/WISE0009.BIN Infected: not-a-virus:RemoteAdmin.Win32.WinVNC-based.b skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP289\A0344111.exe WiseSFX: infected - 2 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP291\A0344203.exe/WISE0008.BIN Infected: not-a-virus:RemoteAdmin.Win32.WinVNC-based.b skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP291\A0344203.exe/WISE0009.BIN Infected: not-a-virus:RemoteAdmin.Win32.WinVNC-based.b skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP291\A0344203.exe WiseSFX: infected - 2 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP292\A0352340.exe Infected: not-virus:BadJoke.Win32.JepRuss skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361557.exe Infected: not-a-virus:Monitor.Win32.Ardamax.k skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361573.exe Infected: Backdoor.Win32.Ciadoor.ar skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361592.exe Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361593.exe Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361594.exe Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361807.exe Infected: not-virus:BadJoke.Win32.JepRuss skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361809.exe/Stream/data0001 Infected: not-a-virus:Monitor.Win32.ActualSpy.30 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361809.exe/Stream/data0006 Infected: not-a-virus:Monitor.Win32.ActualSpy.30 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361809.exe/Stream/data0007 Infected: not-a-virus:Monitor.Win32.ActualSpy.30 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361809.exe/Stream/data0008 Infected: not-a-virus:Monitor.Win32.ActualSpy.30 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361809.exe/Stream/data0014 Infected: not-a-virus:Monitor.Win32.ActualSpy.30 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361809.exe/Stream Infected: not-a-virus:Monitor.Win32.ActualSpy.30 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP295\A0361809.exe Inno: infected - 6 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362456.exe Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362457.exe Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362471.exe Infected: Trojan-Downloader.Win32.Small.eqn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362472.exe Infected: Trojan.Win32.Dialer.qn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362473.exe Infected: Trojan-Downloader.Win32.LoadAdv.gen skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362474.exe Infected: Trojan-Downloader.Win32.Small.eqn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362475.exe/data.rar/keygen.exe Infected: not-a-virus:AdWare.Win32.Virtumonde.jp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362475.exe/data.rar/patch.exe Infected: Trojan.Win32.Dialer.qn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362475.exe/data.rar/crack.exe Infected: Trojan-Downloader.Win32.LoadAdv.gen skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362475.exe/data.rar/install.exe Infected: Trojan-Downloader.Win32.Small.eqn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362475.exe/data.rar Infected: Trojan-Downloader.Win32.Small.eqn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0362475.exe RarSFX: infected - 5 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0363427.exe Infected: Trojan-Downloader.Win32.Agent.bls skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0365424.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0365425.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0365426.exe Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP296\A0367424.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP297\A0373502.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP297\A0373503.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP297\A0373504.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP297\A0373505.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP297\A0373509.exe Infected: Trojan.Win32.Dialer.qn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP297\A0373510.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP299\A0379575.exe Infected: Trojan.Win32.Agent.qt skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP301\A0380199.exe Infected: not-a-virus:AdTool.Win32.MyWebSearch skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0380302.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0380303.exe Infected: Trojan-Downloader.Win32.Alphabet.h skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0380304.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0380305.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0380306.dll Infected: Trojan.Win32.Agent.qt skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0381912.exe Infected: Trojan-Downloader.Win32.PurityScan.ej skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0383911.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0383912.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0383913.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0383927.exe Infected: Trojan-Downloader.Win32.Alphabet.h skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0384917.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0384918.exe/stream/data0006 Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0384918.exe/stream Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0384918.exe NSIS: infected - 2 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0386911.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0388918.exe/stream/data0006 Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0388918.exe/stream Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0388918.exe NSIS: infected - 2 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0390911.exe Infected: Trojan.Win32.Agent.qt skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0390932.exe/stream/data0006 Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0390932.exe/stream Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0390932.exe NSIS: infected - 2 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0391925.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0391928.exe/stream/data0006 Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0391928.exe/stream Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0391928.exe NSIS: infected - 2 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0391934.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP302\A0391942.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393081.exe Infected: Trojan-Downloader.Win32.PurityScan.eg skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393083.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393084.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393085.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393086.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393087.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393088.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393089.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393090.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393091.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393092.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393093.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393094.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393095.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393096.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393097.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393098.exe Infected: Trojan-Dropper.Win32.Agent.bmk skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393099.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.io skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393100.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.jp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393101.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.io skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393102.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.jp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393105.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393106.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393107.exe Infected: Trojan-Downloader.Win32.Tiny.id skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393108.dll Infected: Trojan.Win32.Dialer.qn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393113.exe Infected: Trojan-Clicker.Win32.Small.mv skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393114.dll Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393116.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.jp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393117.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.kr skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393119.exe Infected: Trojan-Downloader.Win32.PurityScan.ej skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393201.DLL Infected: not-a-virus:AdTool.Win32.MyWebSearch.as skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393204.DLL Infected: not-a-virus:AdTool.Win32.MyWebSearch.as skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP303\A0393206.DLL Infected: not-a-virus:AdTool.Win32.MyWebSearch.i skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP305\A0393335.dll Infected: not-a-virus:AdWare.Win32.BHO.cw skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP305\A0393338.exe/stream/data0006 Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP305\A0393338.exe/stream Infected: Trojan-Downloader.Win32.Zlob.bxn skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP305\A0393338.exe NSIS: infected - 2 skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP305\A0393340.dll Infected: Trojan.Win32.Agent.qt skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP305\A0393343.dll Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP305\A0393344.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.hb skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP305\A0393345.dll Infected: Trojan-Downloader.Win32.Small.ddp skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP305\A0393346.dll Infected: not-a-virus:AdWare.Win32.Virtumonde.hb skipped
C:\System Volume Information\_restore{129201FA-B0AC-49B3-96B2-DEB8B91E727B}\RP308\change.log Object is locked skipped
C:\WINDOWS\CSC\000001 Object is locked skipped
C:\WINDOWS\Debug\PASSWD.LOG Object is locked skipped
C:\WINDOWS\ModemLog_Conexant HDA D110 MDC V.92 Modem.txt Object is locked skipped
C:\WINDOWS\Registration\{02D4B3F1-FD88-11D1-960D-00805FC79235}.{64C5506F-7127-4ECD-BE75-284B1AC664E6}.crmlog Object is locked skipped
C:\WINDOWS\SchedLgU.Txt Object is locked skipped
C:\WINDOWS\SoftwareDistribution\EventCache\{77C62B5D-2C51-4D08-A571-6EEE11B45DF1}.bin Object is locked skipped
C:\WINDOWS\SoftwareDistribution\ReportingEvents.log Object is locked skipped
C:\WINDOWS\Sti_Trace.log Object is locked skipped
C:\WINDOWS\system32\CatRoot2\edb.log Object is locked skipped
C:\WINDOWS\system32\CatRoot2\tmp.edb Object is locked skipped
C:\WINDOWS\system32\config\AppEvent.Evt Object is locked skipped
C:\WINDOWS\system32\config\DEFAULT Object is locked skipped
C:\WINDOWS\system32\config\default.LOG Object is locked skipped
C:\WINDOWS\system32\config\Media Ce.evt Object is locked skipped
C:\WINDOWS\system32\config\SAM Object is locked skipped
C:\WINDOWS\system32\config\SAM.LOG Object is locked skipped
C:\WINDOWS\system32\config\SecEvent.Evt Object is locked skipped
C:\WINDOWS\system32\config\SECURITY Object is locked skipped
C:\WINDOWS\system32\config\SECURITY.LOG Object is locked skipped
C:\WINDOWS\system32\config\SOFTWARE Object is locked skipped
C:\WINDOWS\system32\config\software.LOG Object is locked skipped
C:\WINDOWS\system32\config\SysEvent.Evt Object is locked skipped
C:\WINDOWS\system32\config\SYSTEM Object is locked skipped
C:\WINDOWS\system32\config\system.LOG Object is locked skipped
C:\WINDOWS\system32\drivers\sptd.sys Object is locked skipped
C:\WINDOWS\system32\gotomon.log Object is locked skipped
C:\WINDOWS\system32\h323log.txt Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\INDEX.BTR Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\INDEX.MAP Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\MAPPING.VER Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\MAPPING1.MAP Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\MAPPING2.MAP Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\OBJECTS.DATA Object is locked skipped
C:\WINDOWS\system32\wbem\Repository\FS\OBJECTS.MAP Object is locked skipped
C:\WINDOWS\temp\Perflib_Perfdata_570.dat Object is locked skipped
C:\WINDOWS\wiadebug.log Object is locked skipped
C:\WINDOWS\wiaservc.log Object is locked skipped
C:\WINDOWS\WindowsUpdate.log Object is locked skipped
C:\_OTMoveIt\MovedFiles\Program Files\xkvqzghe\befgjoze.dll Infected: Trojan.Win32.Agent.atq skipped
C:\_OTMoveIt\MovedFiles\WINDOWS\system32\beglrhsg\beglrhsg1.exe Infected: not-a-virus:FraudTool.Win32.UltimateDefender.c skipped
C:\_OTMoveIt\MovedFiles\WINDOWS\system32\beglrhsg\beglrhsg2.exe Infected: not-a-virus:FraudTool.Win32.UltimateDefender.c skipped
C:\_OTMoveIt\MovedFiles\WINDOWS\system32\beglrhsg\beglrhsg3.exe Infected: not-a-virus:FraudTool.Win32.UltimateDefender.c skipped
Scan process completed.
Good Report :thumbup: Only a few unwanted items that are not already quarantined or safe in your system restore cache which we will cleen out during the final cleanup procedures.
A.
We will use OTMoveIt again:
Please double-click OTMoveIt.exe to start the tool.
  • Copy the file paths below to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose copy):
  • Return to OTMoveIt, right click on the "Paste List of Files/Folders to be moved" window
  • Choose Paste.
  • Click the red Moveit! button.
  • Copy everything on the Results window to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose copy), and paste it on your next reply.
  • Close OTMoveIt
If a file or folder cannot be moved immediately you may be asked to reboot the machine to finish the move process. If you are asked to reboot the machine choose Yes.
B. Once these deletions have been performed successfully, using OTMoveIT again, locate the Clean up buttom near the top of the tool and click on it. This remove some of the tools that were used during our marathon cleanup and remove itself at the same time. (Nifty tool really)
C. Your log looks clean. If you have no more malware-related problems that you are aware of, just give me the OK and we can start the final but essential cleanup procedures and recommendations.
Trevuren
Congratulations, your log looks CLEAN
There are a few things you must do once you are completely clean:
1. Re-hide your System Files and Folders to prevent any future accidents.
Reconfigure Windows XP to hide hidden files:
  • Click Start. Open My Computer.
  • Select the Tools menu and click Folder Options. Select the View Tab.
  • Under the Hidden files and folders heading deselect "Show hidden files and folders".
  • Check the "Hide protected operating system files (recommended)" option.
  • Click Yes to confirm. Click OK.
2. Time for some housekeeping
Please download the OTMoveIt by OldTimer
  • Save it to your desktop.
  • Run the tool by clicking on the icon.
  • Click the Cleanup button.
  • The tools that we used as well as this one will be removed from your system.
2. Please download ATF Cleaner by Atribune.
This program is for XP and Windows 2000 onlyDouble-click ATF-Cleaner.exe to run the program.
Under Main choose: Select All
Click the Empty Selected button.
If you use Firefox browserClick Firefox at the top and choose: Select All
NOTE: If you would like to keep your saved passwords, please click No at the prompt.
If you use Opera browserClick Opera at the top and choose: Select All
Click Exit on the Main menu to close the program.
For Technical Support, double-click the e-mail address located at the bottom of each menu.
3. Now Set a New Restore Point to prevent possible reinfection from an old one. Some of the malware you picked up could have been saved in System Restore. Since System Restore is a protected directory, your tools can not access it to delete these bad files which sometimes can reinfect your system. Setting a new restore point AFTER cleaning your system will help prevent this and enable your computer to "roll-back" to a clean working state.
The easiest and safest way to do this is:
  • Go to Start > Programs > Accessories > System Tools and click "System Restore".
  • Choose the radio button marked "Create a Restore Point" on the first screen then click "Next". Give the R.P. a name then click "Create". The new point will be stamped with the current date and time. Keep a log of this so you can find it easily should you need to use System Restore.
  • Then go to Start > Run and type: Cleanmgr
  • Click "OK".
  • Click the "More Options" Tab.
  • Click "Clean Up" in the System Restore section to remove all previous restore points except the newly created one.
Here are some tips to reduce the potential for spyware infection in the future:
Make sure you keep your Windows OS current by visiting Windows update
regularly to download and install any critical updates and service packs. With out these you are leaving the backdoor open.
I strongly recommend installing the following applications:
  • Spywareblaster <= SpywareBlaster will prevent spyware from being installed.
  • Spywareguard <= SpywareGuard offers realtime protection from spyware installation attempts.
  • How to use Ad-Aware to remove Spyware <= If you suspect that you have spyware installed on your computer, here are instructions on how to download, install and then use Ad-Aware.
  • How to use Spybot to remove Spyware <= If you suspect that you have spyware installed on your computer, here are instructions on how to download, install and then use Spybot. Similar to Ad-Aware, I strongly recommend both to catch most spyware.
To protect yourself further:
  • Spyad <= IE/Spyad places over 4000 websites and domains in the IE Restricted list which will severely impair attempts to infect your system. It basically prevents any downloads (Cookies etc) from the sites listed, although you will still be able to connect to the sites.
  • MVPS Hosts file <= The MVPS Hosts file replaces your current HOSTS file with one containing well know ad sites etc. Basically, this prevents your coputer from connecting to those sites by redirecting them to 127.0.0.1 which is your local computer
  • Google Toolbar <= Get the free google toolbar to help stop pop up windows.
And also see TonyKlein's good advice
So how did I get infected in the first place?
Regards,
Trevuren
Once again, thanks for all the help. My computer's running pretty good, I'm running SpyEraser and Ad-Aware, just to be sure it's all gone.
Since this issue appears to be resolved … this Topic has been closed. Glad we could be of assistance.
If you're the topic starter, and need this topic reopened, please contact a staff member with the address of the thread.
Everyone else please begin a New Topic.
Coyote's Installed programs for prevention:
http://forums.tomcoyote.org/index.php?showtopic=31418
The help you receive here is free. If you wish to show your appreciation, then you may donate to help keep us online.
Visit the CoyoteStore http://TomCoyote.org/coyotestore.php
