i have 2 main problems, first is the annoying pop up with the following messege:
Notice: if your computer has errors in the registry or file system, it could cause unpredictable or erratic behaviour, freeze and crash. fixing these errors can increase your computer's perfomance and prevent data loss.
would you like to install systemDoctor to check your computer for free? (recommended)
this keeps poping up and i cant get rid of it…
second is that i seem to have got something that terminates all burn operations plus programs like movie maker etc,i have also tried and failed to resolve this problem…
hope you can help,here is my log:
Logfile of HijackThis v1.99.1
Scan saved at 11:14:37 AM, on 8/29/2006
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
The Ewido program’s detection rate is excellent. After the Trial has expired, the auto updates and real time protection stop but you can still update it manually and run scans anytime you want.
First download ewido anti-spyware from HERE and save that file to your
desktop. This is a 30 day trial of the program
Once you have downloaded ewido anti-spyware, locate the icon on the desktop
and double-click it to launch the set up program.
Once the setup is complete you will need run ewido and update the definition
files.
On the main screen select the icon "Update" then select the "
Update now" link.
Next select the "Start Update" button, the update will start and a
progress bar will show the updates being installed.
Once the update has completed select the "Scanner" icon at the top of
the screen, then select the "Settings" tab.
Once in the Settings screen click on "Recommended actions" and then
select "Quarantine".
Under "Reports"
Select "Automatically generate report after every scan"
Un-Select "Only if threats were found"
Close ewido anti-spyware, Do Not run a scan just yet, we will shortly.
Reboot your computer into SafeMode. You can do this by restarting
your computer and continually tapping the F8 key until a menu appears.
Use your up arrow key to highlight SafeMode then hit enter. IMPORTANT: Do not open any other windows or
programs while ewido is scanning, it may interfere with the scanning proccess:
Lauch ewido-anti-spyware by double-clicking the icon on your desktop.
Select the "Scanner" icon at the top and then the "Scan" tab
then click on "Complete System Scan".
ewido will now begin the scanning process, be patient this may take a little
time. Once the scan is complete do the following:
If you have any infections you will prompted, then select "Apply all
actions"
Next select the "Reports" icon at the top.
Select the "Save report as" button in the lower left hand of the
screen and save it to a text file on your system (make sure to remember where
you saved that file, this is important).
Please post(reply) with the ewido report and let me know if you removed System Doctor.
hi, i followed the tutorial but failed to remove the problem. the messege requesting me to install system doctor still pops up.
here is that ewibo report:
ewido anti-spyware - Scan Report
+ Created at: 4:53:53 AM 8/30/2006
+ Scan result:
HKLM\SOFTWARE\Classes\CLSID\{468EE850-6E40-412A-981A-2BFD9C76E335} -> Adware.ContextuAd : Cleaned with backup (quarantined).
C:\Software\Download Accelerator\downloadaccelerator.rar/File\DAP.exe -> Adware.Dap : Cleaned with backup (quarantined).
C:\Program Files\Microsoft AntiSpyware\Quarantine\755B650A-AF84-4EED-B836-2D8CAB\A77ECF9C-AFC7-41FC-9D64-F66F16/NHUninstaller.exe -> Adware.NavExcel : Cleaned with backup (quarantined).
C:\Program Files\Microsoft AntiSpyware\Quarantine\755B650A-AF84-4EED-B836-2D8CAB\A77ECF9C-AFC7-41FC-9D64-F66F16/NHUpdater.exe -> Adware.NavExcel : Cleaned with backup (quarantined).
C:\Program Files\Microsoft AntiSpyware\Quarantine\755B650A-AF84-4EED-B836-2D8CAB\A77ECF9C-AFC7-41FC-9D64-F66F16/NHelper.dll -> Adware.NavExcel : Cleaned with backup (quarantined).
:mozilla.152:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.260:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.262:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.263:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@2o7[2].txt -> TrackingCookie.2o7 : Cleaned with backup (quarantined).
:mozilla.214:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
:mozilla.215:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@adtech[2].txt -> TrackingCookie.Adtech : Cleaned with backup (quarantined).
:mozilla.283:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Bluestreak : Cleaned with backup (quarantined).
:mozilla.236:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Burstnet : Cleaned with backup (quarantined).
:mozilla.169:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.170:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.171:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.172:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.173:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.174:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.175:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.176:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
:mozilla.177:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Casalemedia : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@centrport[2].txt -> TrackingCookie.Centrport : Cleaned with backup (quarantined).
:mozilla.274:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Com : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@com[1].txt -> TrackingCookie.Com : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k [removed][2].txt -> TrackingCookie.Euroclick : Cleaned with backup (quarantined).
:mozilla.277:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.278:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.279:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.83:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k [removed][2].txt -> TrackingCookie.Falkag : Cleaned with backup (quarantined).
:mozilla.280:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Googleadservices : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@hotlog[1].txt -> TrackingCookie.Hotlog : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k [removed][2].txt -> TrackingCookie.Onestat : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k [removed][1].txt -> TrackingCookie.Overture : Cleaned with backup (quarantined).
:mozilla.189:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Pointroll : Cleaned with backup (quarantined).
:mozilla.190:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Pointroll : Cleaned with backup (quarantined).
:mozilla.191:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Pointroll : Cleaned with backup (quarantined).
:mozilla.192:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Pointroll : Cleaned with backup (quarantined).
:mozilla.98:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Questionmarket : Cleaned with backup (quarantined).
:mozilla.99:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Questionmarket : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@questionmarket[2].txt -> TrackingCookie.Questionmarket : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k [removed][2].txt -> TrackingCookie.Reliablestats : Cleaned with backup (quarantined).
:mozilla.101:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Revenue : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@revenue[1].txt -> TrackingCookie.Revenue : Cleaned with backup (quarantined).
:mozilla.133:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Spylog : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@spylog[2].txt -> TrackingCookie.Spylog : Cleaned with backup (quarantined).
:mozilla.128:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Starware : Cleaned with backup (quarantined).
:mozilla.62:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Tacoda : Cleaned with backup (quarantined).
:mozilla.63:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Tacoda : Cleaned with backup (quarantined).
:mozilla.64:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Tacoda : Cleaned with backup (quarantined).
:mozilla.65:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Tacoda : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@tacoda[1].txt -> TrackingCookie.Tacoda : Cleaned with backup (quarantined).
:mozilla.52:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Tradedoubler : Cleaned with backup (quarantined).
:mozilla.150:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Tribalfusion : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@tribalfusion[1].txt -> TrackingCookie.Tribalfusion : Cleaned with backup (quarantined).
:mozilla.37:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Yadro : Cleaned with backup (quarantined).
:mozilla.210:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.211:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.212:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.213:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k [removed][1].txt -> TrackingCookie.Yieldmanager : Cleaned with backup (quarantined).
:mozilla.38:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
:mozilla.7:C:\Documents and Settings\Rafael K Ngoda\Application Data\Mozilla\Firefox\Profiles\wo6s6bbn.default\cookies.txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
C:\Documents and Settings\Rafael K Ngoda\Cookies\rafael k ngoda@zedo[1].txt -> TrackingCookie.Zedo : Cleaned with backup (quarantined).
C:\Program Files\Registry Mechanic\RegMech.exe -> Trojan.Agent.sk : Cleaned with backup (quarantined).
::Report end
StartupList report, 8/30/2006, 2:47:10 PM
StartupList version: 1.52.2
Started from : C:\Documents and Settings\Rafael K Ngoda\Desktop\hijackthis\HijackThis.EXE
Detected: Windows XP SP2 (WinNT 5.01.2600)
Detected: Internet Explorer v6.00 SP2 (6.00.2900.2180)
* Using default options
* Including empty and uninteresting sections
* Showing rarely important sections
load=*INI section not found*
run=*INI section not found*
Load/Run keys from Registry:
HKLM\..\Windows NT\CurrentVersion\WinLogon: load=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\WinLogon: run=*Registry value not found*
HKLM\..\Windows\CurrentVersion\WinLogon: load=*Registry key not found*
HKLM\..\Windows\CurrentVersion\WinLogon: run=*Registry key not found*
HKCU\..\Windows NT\CurrentVersion\WinLogon: load=*Registry value not found*
HKCU\..\Windows NT\CurrentVersion\WinLogon: run=*Registry value not found*
HKCU\..\Windows\CurrentVersion\WinLogon: load=*Registry key not found*
HKCU\..\Windows\CurrentVersion\WinLogon: run=*Registry key not found*
HKCU\..\Windows NT\CurrentVersion\Windows: load=
HKCU\..\Windows NT\CurrentVersion\Windows: run=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\Windows: load=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\Windows: run=*Registry value not found*
HKLM\..\Windows NT\CurrentVersion\Windows: AppInit_DLLs=*Registry value not found*
Shell & screensaver key from C:\WINDOWS\SYSTEM.INI:
Shell=*INI section not found*
SCRNSAVE.EXE=*INI section not found*
drivers=*INI section not found*
Shell & screensaver key from Registry:
Shell=Explorer.exe
SCRNSAVE.EXE=*Registry value not found*
drivers=*Registry value not found*
Policies Shell key:
HKCU\..\Policies: Shell=*Registry value not found*
HKLM\..\Policies: Shell=*Registry value not found*
Checking for EXPLORER.EXE instances:
C:\WINDOWS\Explorer.exe: PRESENT!
C:\Explorer.exe: not present
C:\WINDOWS\Explorer\Explorer.exe: not present
C:\WINDOWS\System\Explorer.exe: not present
C:\WINDOWS\System32\Explorer.exe: not present
C:\WINDOWS\Command\Explorer.exe: not present
C:\WINDOWS\Fonts\Explorer.exe: not present
Checking for superhidden extensions:
.lnk: HIDDEN! (arrow overlay: yes)
.pif: HIDDEN! (arrow overlay: yes)
.exe: not hidden
.com: not hidden
.bat: not hidden
.hta: not hidden
.scr: not hidden
.shs: HIDDEN!
.shb: HIDDEN!
.vbs: not hidden
.vbe: not hidden
.wsh: not hidden
.scf: HIDDEN! (arrow overlay: NO!)
.url: HIDDEN! (arrow overlay: yes)
.js: not hidden
.jse: not hidden
Verifying REGEDIT.EXE integrity:
- Regedit.exe found in C:\WINDOWS
- .reg open command is normal (regedit.exe %1)
- Company name OK: 'Microsoft Corporation'
- Original filename OK: 'REGEDIT.EXE'
- File description: 'Registry Editor'
Registry check passed
Enumerating Browser Helper Objects:
(no name) - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}
(no name) - C:\PROGRA~1\SPYBOT~1\SDHelper.dll - {53707962-6F74-2D53-2644-206D7942484F}
(no name) - C:\PROGRA~1\SPYWAR~1\tools\iesdsg.dll - {5C8B2A36-3DB1-42A4-A3CB-D426709BBFEB}
(no name) - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43}
(no name) - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll - {9030D464-4C02-4ABF-8ECC-5164760863C6}
(no name) - C:\Program Files\MSN Apps\ST\01.03.0000.1005\en-xu\stmain.dll - {9394EDE7-C8B5-483E-8773-474BF36AF6E4}
(no name) - C:\PROGRA~1\SPYWAR~1\tools\iesdpb.dll - {B56A7D7D-6927-48C8-A975-17DF180C71AC}
(no name) - C:\Program Files\MSN Apps\MSN Toolbar\MSN Toolbar\01.02.5000.1021\en-us\msntb.dll - {BDBD1DAD-C946-4A17-ADC1-64B5B4FF55D0}
Autorun entries from Registry:
HKCU\Software\Microsoft\Windows\CurrentVersion\policies\Explorer\Run
HKLM\Software\Microsoft\Windows\CurrentVersion\policies\Explorer\Run
*No values found*
End of report, 44,023 bytes
Report generated in 1.121 seconds
Command line options:
/verbose - to add additional info on each section
/complete - to include empty sections and unsuspicious data
/full - to include several rarely-important sections
/force9x - to include Win9x-only startups even if running on WinNT
/forcent - to include WinNT-only startups even if running on Win9x
/forceall - to include all Win9x and WinNT startups, regardless of platform
/history - to list version history only
here is the uninstall list:
2006 FIFA World Cup ™
AC3Filter (remove only)
Adobe Photoshop 5.5
Adobe Reader 7.0.8
ALPS Touch Pad Driver
aMSN
avast! Antivirus
AVG Free Edition
AviSynth 2.5
BurstCopy v2.700
BySoft StayAlive Pro 3.0
Cadifra UML Editor 1.0
CD/DVD Drive Acoustic Silencer
CoreVorbis Audio Decoder (remove only)
DAEMON Tools
Datasets for Data Analysis Plus® for Excel
DC++ 0.667
Dev-C++ 5 beta 9 release (4.9.9.2)
DivX Player
DVD Decrypter (Remove Only)
DVD Shrink 3.2
DVDx 2.3
EA SPORTS online 2006
ewido anti-spyware 4.0
File Recover 6.0
Free WMA to MP3 Converter 1.08
GetDataBack for NTFS
Google Earth
Google Gmail Notifier
HijackThis 1.99.1
hp deskjet 450 printer Uninstaller
Intel® Extreme Graphics 2 Driver
Intel® PRO Network Adapters and Drivers
InterVideo WinDVD for Toshiba
iTunes
J2SE Runtime Environment 5.0 Update 6
Java 2 Runtime Environment, SE v1.4.2_03
Java 2 Runtime Environment, SE v1.4.2_05
Java 2 SDK, SE v1.4.2_03
Java Launcher 3.10
JCreator LE 3.00
LANster 0.99.4b
LiveUpdate 2.5 (Symantec Corporation)
Macromedia Flash Player
Macromedia Flash Player 8
MAGView Reader 4.12
McAfee AntiSpyware
McAfee SecurityCenter
McAfee VirusScan Enterprise
Microsoft .NET Framework 1.1
Microsoft .NET Framework 2.0
Microsoft ActiveSync 3.7
Microsoft Device Emulator version 1.0 - ENU
Microsoft Document Explorer 2005
Microsoft Office FrontPage 2003
Microsoft Office OneNote 2003
Microsoft Office Professional Edition 2003
Microsoft Office Visio Professional 2003
Microsoft Office Visio Viewer 2003 (English)
Microsoft SQL Server 2005 Mobile [ENU] Developer Tools
Microsoft User-Mode Driver Framework Feature Pack 1.0.0 (Pre-Release 5348)
Microsoft Visual Studio 2005 Professional Edition - ENU
Microsoft® Winter Fun Pack 2004 for Windows® XP
mIRC
MSN Music Assistant
MSN Toolbar
MSXML 6.0 Parser
Native Instruments - Traktor 1.06
Nero 7 Ultra Edition
Nimo Codecs Pack v5.0 (Remove Only)
Nokia Connectivity Cable DKU-2 Drivers
Nokia PC Suite 6.1
Norton WMI Update
Pacestar UML Diagrammer
PCSpim
Picasa 2
ProxyDesigner
QuickTime
Real Alternative 1.37
RealPlayer
RealTunnel
Registry Mechanic 5.2
Remove DivX Pro Codec
Rhapsody Player Engine
Roger Wilco
Security Update for Step By Step Interactive Training (KB898458)
Security Update for Windows Media Player (KB911564)
Security Update for Windows Media Player 10 (KB911565)
Security Update for Windows XP (KB890046)
Security Update for Windows XP (KB893756)
Security Update for Windows XP (KB896358)
Security Update for Windows XP (KB896422)
Security Update for Windows XP (KB896423)
Security Update for Windows XP (KB896424)
Security Update for Windows XP (KB896428)
Security Update for Windows XP (KB899587)
Security Update for Windows XP (KB899591)
Security Update for Windows XP (KB900725)
Security Update for Windows XP (KB901017)
Security Update for Windows XP (KB901214)
Security Update for Windows XP (KB902400)
Security Update for Windows XP (KB904706)
Security Update for Windows XP (KB905414)
Security Update for Windows XP (KB905749)
Security Update for Windows XP (KB905915)
Security Update for Windows XP (KB908519)
Security Update for Windows XP (KB911562)
Security Update for Windows XP (KB911567)
Security Update for Windows XP (KB911927)
Security Update for Windows XP (KB912919)
Security Update for Windows XP (KB913446)
Security Update for Windows XP (KB914388)
Security Update for Windows XP (KB914389)
Security Update for Windows XP (KB916281)
Security Update for Windows XP (KB917159)
Security Update for Windows XP (KB917344)
Security Update for Windows XP (KB918439)
Security Update for Windows XP (KB921883)
SendFile
Serials 2005
SigmaTel AC97 Audio Drivers
Softros LAN Messenger
SoundMasker v4.0
Spybot - Search & Destroy 1.4
Spyware Doctor 3.8
StrongDC++ 1.00 RC10
TOSHIBA ConfigFree
TOSHIBA Console
TOSHIBA Controls
TOSHIBA Display Service for Ext.Monitor
TOSHIBA Manuals
TOSHIBA PC Diagnostic Tool
TOSHIBA Power Saver
TOSHIBA Software Modem
TOSHIBA TouchPad On/Off Utility V2.05.00
TOSHIBA Utilities
TOSHIBA Zooming Utility
Touch and Launch
Update for Windows XP (KB894391)
Update for Windows XP (KB898461)
Update for Windows XP (KB900485)
Update for Windows XP (KB908531)
Update for Windows XP (KB910437)
USB Video/Audio Device Driver
vanBasco's Karaoke Player
VideoLAN VLC media player 0.8.1
WinAce Archiver
Winamp (remove only)
Windows Defender
Windows Defender Signatures
Windows Installer 3.1 (KB893803)
Windows Live Messenger
Windows Live Sign-in Assistant
Windows Media Format 11 runtime
Windows Media Player 11
Windows XP Hotfix - KB834707
Windows XP Hotfix - KB873339
Windows XP Hotfix - KB885250
Windows XP Hotfix - KB885835
Windows XP Hotfix - KB885836
Windows XP Hotfix - KB885884
Windows XP Hotfix - KB886185
Windows XP Hotfix - KB887472
Windows XP Hotfix - KB887742
Windows XP Hotfix - KB888113
Windows XP Hotfix - KB888302
Windows XP Hotfix - KB890175
Windows XP Hotfix - KB890859
Windows XP Hotfix - KB891781
Windows XP Hotfix - KB893066
Yahoo! Messenger
Yahoo! Toolbar
Zip'N'All
I cannot find "System Doctor", in the logs that you provided. I have found that "Drive Cleaner" may be one cause. One person also disabled a browser add-on "digman.dll" and that cleared up the problem. But let's see if SpySweeper will clear it up before we spend more time locating the culprit since another post indicated SpySweeper worked.
I noticed that you have McAfee Antispyware installed. I want you to disable the McAfee Antispyware and then download and run the SpySweeper trial.
Please to the following:
Disable McAfee AntiSpyware http://malektips.com/mcafee_antispyware_0006.html
1. From McAfee AntiSpyware, click "Change Settings".
2. When the settings dialog box appears, click the "Auto-Protect" tab.
3. Uncheck "Enable Auto-Protect".
4. Click "OK" to close the dialog box.
Download the trial version of Spy Sweeper from Here
Install it using the Standard Install option. (You will be asked for your e-mail address, it is safe to give it. If you receive alerts from your firewall, allow all activities for Spy Sweeper)
If you are taken to the internet page, just close the page.
You will be prompted to check for updated definitions, please do so.
(This may take several minutes)
Click on Options > Sweep Options and check Sweep all Folders on Selected drives. Check Local Disc C. Under What to Sweep, check every box.
Click on Sweep and allow it to fully scan your system.If you are prompted to restart the computer, do so immediately. This is a necessary step to kill the infection!
When the sweep has finished, click Remove. Click Select All and then Next
From 'Results', select the Session Log tab. Click Save to File and save the log somewhere convenient.
Exit Spy Sweeper.
Empty Recycle Bin
Reboot and "copy/paste" a new HJT log as well as the Results from Spy Sweeper file into this thread.
Also please let me know if you are still receiving the pop-ups.
i am still recieving the pop ups but not as often as before for some reason
here is that log:
8:12 PM: Removal process completed. Elapsed time 00:00:32
8:11 PM: Quarantining All Traces: webtrends cookie
8:11 PM: Removal process initiated
8:01 PM: Traces Found: 1
8:01 PM: Full Sweep has completed. Elapsed time 00:46:33
8:01 PM: File Sweep Complete, Elapsed Time: 00:40:22
7:51 PM: Warning: Stream read error
7:50 PM: Warning: Failed to access drive E:
7:50 PM: Warning: Failed to access drive D:
7:21 PM: Starting File Sweep
7:21 PM: Cookie Sweep Complete, Elapsed Time: 00:00:04
7:21 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k [removed][2].txt (ID = 3669)
7:21 PM: Found Spy Cookie: webtrends cookie
7:21 PM: Starting Cookie Sweep
7:20 PM: Registry Sweep Complete, Elapsed Time:00:00:49
7:20 PM: Starting Registry Sweep
7:20 PM: Memory Sweep Complete, Elapsed Time: 00:04:48
7:15 PM: Starting Memory Sweep
7:15 PM: Sweep initiated using definitions version 691
7:15 PM: Spy Sweeper 5.0.5.1286 started
7:15 PM: | Start of Session, Thursday, August 31, 2006 |
7:15 PM: | End of Session, Thursday, August 31, 2006 |
7:14 PM: There is a problem reaching the server. The cause may be in your connection, or on the server. Please try again later.
7:07 PM: There is a problem reaching the server. The cause may be in your connection, or on the server. Please try again later.
6:43 PM: There is a problem reaching the server. The cause may be in your connection, or on the server. Please try again later.
6:33 PM: There is a problem reaching the server. The cause may be in your connection, or on the server. Please try again later.
Operation: File Access
Target:
Source: C:\WINDOWS\EXPLORER.EXE
6:28 PM: Tamper Detection
6:22 PM: Removal process completed. Elapsed time 00:00:22
6:22 PM: Quarantining All Traces: tribalfusion cookie
6:22 PM: Quarantining All Traces: tacoda cookie
6:22 PM: Quarantining All Traces: reliablestats cookie
6:22 PM: Quarantining All Traces: revenue.net cookie
6:22 PM: Quarantining All Traces: realmedia cookie
6:22 PM: Quarantining All Traces: rambler cookie
6:22 PM: Quarantining All Traces: mp3downloadhq cookie
6:22 PM: Quarantining All Traces: 2o7.net cookie
6:22 PM: Quarantining All Traces: go.com cookie
6:22 PM: Quarantining All Traces: burstnet cookie
6:22 PM: Quarantining All Traces: a cookie
6:22 PM: Quarantining All Traces: adtech cookie
6:22 PM: Quarantining All Traces: yieldmanager cookie
6:22 PM: Quarantining All Traces: navexcel navhelper
6:22 PM: Quarantining All Traces: screensavers
6:21 PM: Removal process initiated
6:18 PM: Traces Found: 21
6:18 PM: Full Sweep has completed. Elapsed time 00:24:57
6:18 PM: File Sweep Complete, Elapsed Time: 00:21:31
6:17 PM: Warning: Failed to access drive E:
6:17 PM: Warning: Failed to access drive D:
6:06 PM: C:\Program Files\Microsoft AntiSpyware\Quarantine\755B650A-AF84-4EED-B836-2D8CAB\61266099-F030-445E-B2F5-5EC345 (ID = 70374)
6:06 PM: Found Adware: navexcel navhelper
5:57 PM: C:\Program Files\Screensavers.com (4 subtraces) (ID = 2147486931)
5:57 PM: Found Adware: screensavers
Target:
Source: C:\WINDOWS\SYSTEM32\CIDAEMON.EXE
5:57 PM: Tamper Detection
5:56 PM: Starting File Sweep
5:56 PM: Cookie Sweep Complete, Elapsed Time: 00:00:04
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k [removed][1].txt (ID = 2337)
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@tribalfusion[1].txt (ID = 3589)
5:56 PM: Found Spy Cookie: tribalfusion cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@tacoda[2].txt (ID = 6444)
5:56 PM: Found Spy Cookie: tacoda cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k [removed][1].txt (ID = 3254)
5:56 PM: Found Spy Cookie: reliablestats cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k [removed][2].txt (ID = 2729)
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@revenue[2].txt (ID = 3257)
5:56 PM: Found Spy Cookie: revenue.net cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@realmedia[1].txt (ID = 3235)
5:56 PM: Found Spy Cookie: realmedia cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@rambler[1].txt (ID = 3225)
5:56 PM: Found Spy Cookie: rambler cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@mp3downloadhq[2].txt (ID = 3014)
5:56 PM: Found Spy Cookie: mp3downloadhq cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@metacafe.122.2o7[1].txt (ID = 1958)
5:56 PM: Found Spy Cookie: 2o7.net cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@go[1].txt (ID = 2728)
5:56 PM: Found Spy Cookie: go.com cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@burstnet[2].txt (ID = 2336)
5:56 PM: Found Spy Cookie: burstnet cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@a[1].txt (ID = 2027)
5:56 PM: Found Spy Cookie: a cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k ngoda@adtech[2].txt (ID = 2155)
5:56 PM: Found Spy Cookie: adtech cookie
5:56 PM: c:\documents and settings\rafael k ngoda\cookies\rafael k [removed][2].txt (ID = 3751)
5:56 PM: Found Spy Cookie: yieldmanager cookie
5:56 PM: Starting Cookie Sweep
5:56 PM: Registry Sweep Complete, Elapsed Time:00:00:26
5:55 PM: Starting Registry Sweep
5:55 PM: Memory Sweep Complete, Elapsed Time: 00:02:33
5:53 PM: Starting Memory Sweep
5:53 PM: Sweep initiated using definitions version 691
5:53 PM: Spy Sweeper 5.0.5.1286 started
5:53 PM: | Start of Session, Thursday, August 31, 2006 |
5:53 PM: | End of Session, Thursday, August 31, 2006 |
5:52 PM: There is a problem reaching the server. The cause may be in your connection, or on the server. Please try again later.
Keylogger Shield: On
BHO Shield: On
IE Security Shield: On
Alternate Data Stream (ADS) Execution Shield: On
Startup Shield: On
Common Ad Sites Shield: Off
Hosts File Shield: On
Spy Communication Shield: On
ActiveX Shield: On
Windows Messenger Service Shield: On
IE Favorites Shield: On
Spy Installation Shield: On
Memory Shield: On
IE Hijack Shield: On
IE Tracking Cookies Shield: Off
5:49 PM: Shield States
5:49 PM: Spyware Definitions: 691
5:48 PM: Spy Sweeper 5.0.5.1286 started
5:48 PM: | Start of Session, Thursday, August 31, 2006 |
and here is the HJT log:
Scan saved at 10:32:47 PM, on 8/31/2006
You may receive pop-up asking if you will allow script to run when you perform the following instructions. Please allow the script to run.
Save the file to your desktop and double click l2mfix.exe. Click the Install button to extract the files and follow the prompts, then open the newly added l2mfix folder on your desktop. Double click l2mfix.bat and select option #1 for Run Find Log by typing 1 and then pressing enter. This will scan your computer and it may appear nothing is happening, then, after a minute or 2, notepad will open with a log. Copy the contents of that log and paste it into this thread.
IMPORTANT: Do NOT run option #2 OR any other files in the l2mfix folder until you are asked to do so!
If you receive, while running option #1, an error similar like: ''C:\windows\system32\cmd.exe
C:\windows\system32\autoexec.nt the system file is not suitable for running ms-dos and microsoft windows applications. choose close to terminate the application.."…then please use option 5 or the web page link in the l2mfix folder to solve this error condition. do not run the fix portion without fixing this first.
STEP 2.
You are using Download Accelerator – DAP Be informed that it delivers popup/popunder ads, and tracks your internet usage. You can find safer alternatives here: http://www.spywareinfo.com/downloads.php?cat=dlman#dlman
I suggest you remove it. Go to Start > Settings > Control Panel > Add/Remove Programs and remove it.
Disable SpySweeper:
You have SpySweeper installed. While this is a great program, we need to temporarily disable (not uninstall) the program because it might stop our fix.
Right click on the SpySweeper icon in your System Tray (near the clock).
From the pop up menu, left click on Shields, this will open the program at the same time.
Click the "Internet Explorer" tab and uncheck the following:
IE Favorites Shield
IE Security Shield
Broswer Helper Object (BHO) Shield
IE Hijack Shield
Click the "Windows System Shields" and uncheck the following:
Memory Shield
Click the "Startup Programs" tab and uncheck the Startup Items Shield
After all of the fixes are complete it is very important that you enable SpySweeper again.
Scan with HijackThis. Place a check against each of the following (if it exists): R3 - Default URLSearchHook is missing
O2 - BHO: DAPHelper Class - {0000CC75-ACF3-4cac-A0A9-DD3868E06852} - C:\Program Files\DAP\DAPBHO.dll
O3 - Toolbar: DAP Bar - {62999427-33FC-4baf-9C9C-BCE6BD127F08} - C:\Program Files\DAP\DAPIEBar.dll
O9 - Extra button: Run DAP - {669695BC-A811-4A9D-8CDF-BA8C795F261C} - C:\PROGRA~1\DAP\DAP.EXE
O18 - Filter: text/html - (no CLSID) - (no file)
Close all windows or browsers except for Hijackthis. Click on Fix Checked when finished and exit HijackThis.
Reboot into Safe Mode: please see here if you are not sure how to do this.
Using Windows Explorer, locate the following files/folders, and delete them: C:\Program Files\DAP\<=folder Exit Explorer, and reboot as normal afterwards.
Post back a fresh HijackThis log and we will take another look.
hello Susan528,
i think you managed to work magic with the pop up problem…i havent recieved it in a long time….. the other problem,the program termination thing occured becuse i had the first nero 7 ultra edition which has a million and one bugs..
it removed the [HKEY_CLASSES_ROOT\Interface\{0000000C-0000-0000-C000-000000000046}] from the registry which caused some other programs to terminate when started. after repopulating the registry with the Regsvr32.exe %Windir%\System32\Ole32.dll comand,everything else started working right.
i think we are looking pretty good.
here is the L2MFIX report:
L2MFIX find log 051206
These are the registry keys present
Winlogon/notify:
Windows Registry Editor Version 5.00
Shell Extension key:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved]
"{00022613-0000-0000-C000-000000000046}"="Multimedia File Property Sheet"
"{176d6597-26d3-11d1-b350-080036a75b03}"="ICM Scanner Management"
"{1F2E5C40-9550-11CE-99D2-00AA006E086C}"="NTFS Security Page"
"{3EA48300-8CF6-101B-84FB-666CCB9BCD32}"="OLE Docfile Property Page"
"{40dd6e20-7c17-11ce-a804-00aa003ca9f6}"="Shell extensions for sharing"
"{41E300E0-78B6-11ce-849B-444553540000}"="PlusPack CPL Extension"
"{42071712-76d4-11d1-8b24-00a0c9068ff3}"="Display Adapter CPL Extension"
"{42071713-76d4-11d1-8b24-00a0c9068ff3}"="Display Monitor CPL Extension"
"{42071714-76d4-11d1-8b24-00a0c9068ff3}"="Display Panning CPL Extension"
"{4E40F770-369C-11d0-8922-00A024AB2DBB}"="DS Security Page"
"{513D916F-2A8E-4F51-AEAB-0CBC76FB1AF8}"="Compatibility Page"
"{56117100-C0CD-101B-81E2-00AA004AE837}"="Shell Scrap DataHandler"
"{59099400-57FF-11CE-BD94-0020AF85B590}"="Disk Copy Extension"
"{59be4990-f85c-11ce-aff7-00aa003ca9f6}"="Shell extensions for Microsoft Windows Network objects"
"{5DB2625A-54DF-11D0-B6C4-0800091AA605}"="ICM Monitor Management"
"{675F097E-4C4D-11D0-B6C1-0800091AA605}"="ICM Printer Management"
"{764BF0E1-F219-11ce-972D-00AA00A14F56}"="Shell extensions for file compression"
"{77597368-7b15-11d0-a0c2-080036af3f03}"="Web Printer Shell Extension"
"{7988B573-EC89-11cf-9C00-00AA00A14F56}"="Disk Quota UI"
"{853FE2B1-B769-11d0-9C4E-00C04FB6C6FA}"="Encryption Context Menu"
"{85BBD920-42A0-1069-A2E4-08002B30309D}"="Briefcase"
"{88895560-9AA2-1069-930E-00AA0030EBC8}"="HyperTerminal Icon Ext"
"{BD84B380-8CA2-1069-AB1D-08000948F534}"="Fonts"
"{DBCE2480-C732-101B-BE72-BA78E9AD5B27}"="ICC Profile"
"{F37C5810-4D3F-11d0-B4BF-00AA00BBB723}"="Printers Security Page"
"{f81e9010-6ea4-11ce-a7ff-00aa003ca9f6}"="Shell extensions for sharing"
"{f92e8c40-3d33-11d2-b1aa-080036a75b03}"="Display TroubleShoot CPL Extension"
"{7444C717-39BF-11D1-8CD9-00C04FC29D45}"="Crypto PKO Extension"
"{7444C719-39BF-11D1-8CD9-00C04FC29D45}"="Crypto Sign Extension"
"{7007ACC7-3202-11D1-AAD2-00805FC1270E}"="Network Connections"
"{992CFFA0-F557-101A-88EC-00DD010CCC48}"="Network Connections"
"{E211B736-43FD-11D1-9EFB-0000F8757FCD}"="Scanners & Cameras"
"{FB0C9C8A-6C50-11D1-9F1D-0000F8757FCD}"="Scanners & Cameras"
"{905667aa-acd6-11d2-8080-00805f6596d2}"="Scanners & Cameras"
"{3F953603-1008-4f6e-A73A-04AAC7A992F1}"="Scanners & Cameras"
"{83bbcbf3-b28a-4919-a5aa-73027445d672}"="Scanners & Cameras"
"{F0152790-D56E-4445-850E-4F3117DB740C}"="Remote Sessions CPL Extension"
"{60254CA5-953B-11CF-8C96-00AA00B8708C}"="Shell extensions for Windows Script Host"
"{2206CDB2-19C1-11D1-89E0-00C04FD7A829}"="Microsoft Data Link"
"{DD2110F0-9EEF-11cf-8D8E-00AA0060F5BF}"="Tasks Folder Icon Handler"
"{797F1E90-9EDD-11cf-8D8E-00AA0060F5BF}"="Tasks Folder Shell Extension"
"{D6277990-4C6A-11CF-8D87-00AA0060F5BF}"="Scheduled Tasks"
"{2559a1f7-21d7-11d4-bdaf-00c04f60b9f0}"="Set Program Access and Defaults"
"{5F327514-6C5E-4d60-8F16-D07FA08A78ED}"="Auto Update Property Sheet Extension"
"{0DF44EAA-FF21-4412-828E-260A8728E7F1}"="Taskbar and Start Menu"
"{2559a1f0-21d7-11d4-bdaf-00c04f60b9f0}"="Search"
"{2559a1f1-21d7-11d4-bdaf-00c04f60b9f0}"="Help and Support"
"{2559a1f2-21d7-11d4-bdaf-00c04f60b9f0}"="Help and Support"
"{2559a1f3-21d7-11d4-bdaf-00c04f60b9f0}"="Run…"
"{2559a1f4-21d7-11d4-bdaf-00c04f60b9f0}"="Internet"
"{2559a1f5-21d7-11d4-bdaf-00c04f60b9f0}"="E-mail"
"{D20EA4E1-3957-11d2-A40B-0C5020524152}"="Fonts"
"{D20EA4E1-3957-11d2-A40B-0C5020524153}"="Administrative Tools"
"{596AB062-B4D2-4215-9F74-E9109B0A8153}"="Previous Versions Property Page"
"{9DB7A13C-F208-4981-8353-73CC61AE2783}"="Previous Versions"
"{875CB1A1-0F29-45de-A1AE-CFB4950D0B78}"="Audio Media Properties Handler"
"{40C3D757-D6E4-4b49-BB41-0E5BBEA28817}"="Video Media Properties Handler"
"{E4B29F9D-D390-480b-92FD-7DDB47101D71}"="Wav Properties Handler"
"{87D62D94-71B3-4b9a-9489-5FE6850DC73E}"="Avi Properties Handler"
"{A6FD9E45-6E44-43f9-8644-08598F5A74D9}"="Midi Properties Handler"
"{c5a40261-cd64-4ccf-84cb-c394da41d590}"="Video Thumbnail Extractor"
"{5E6AB780-7743-11CF-A12B-00AA004AE837}"="Microsoft Internet Toolbar"
"{22BF0C20-6DA7-11D0-B373-00A0C9034938}"="Download Status"
"{91EA3F8B-C99B-11d0-9815-00C04FD91972}"="Augmented Shell Folder"
"{6413BA2C-B461-11d1-A18A-080036B11A03}"="Augmented Shell Folder 2"
"{F61FFEC1-754F-11d0-80CA-00AA005B4383}"="BandProxy"
"{7BA4C742-9E81-11CF-99D3-00AA004AE837}"="Microsoft BrowserBand"
"{30D02401-6A81-11d0-8274-00C04FD5AE38}"="Search Band"
"{169A0691-8DF9-11d1-A1C4-00C04FD75D13}"="In-pane search"
"{07798131-AF23-11d1-9111-00A0C98BA67D}"="Web Search"
"{AF4F6510-F982-11d0-8595-00AA004CD6D8}"="Registry Tree Options Utility"
"{01E04581-4EEE-11d0-BFE9-00AA005B4383}"="&Address"
"{A08C11D2-A228-11d0-825B-00AA005B4383}"="Address EditBox"
"{00BB2763-6A77-11D0-A535-00C04FD7D062}"="Microsoft AutoComplete"
"{7376D660-C583-11d0-A3A5-00C04FD706EC}"="TridentImageExtractor"
"{6756A641-DE71-11d0-831B-00AA005B4383}"="MRU AutoComplete List"
"{6935DB93-21E8-4ccc-BEB9-9FE3C77A297A}"="Custom MRU AutoCompleted List"
"{7e653215-fa25-46bd-a339-34a2790f3cb7}"="Accessible"
"{acf35015-526e-4230-9596-becbe19f0ac9}"="Track Popup Bar"
"{00BB2764-6A77-11D0-A535-00C04FD7D062}"="Microsoft History AutoComplete List"
"{03C036F1-A186-11D0-824A-00AA005B4383}"="Microsoft Shell Folder AutoComplete List"
"{00BB2765-6A77-11D0-A535-00C04FD7D062}"="Microsoft Multiple AutoComplete List Container"
"{ECD4FC4E-521C-11D0-B792-00A0C90312E1}"="Shell Band Site Menu"
"{3CCF8A41-5C85-11d0-9796-00AA00B90ADF}"="Shell DeskBarApp"
"{ECD4FC4C-521C-11D0-B792-00A0C90312E1}"="Shell DeskBar"
"{ECD4FC4D-521C-11D0-B792-00A0C90312E1}"="Shell Rebar BandSite"
"{DD313E04-FEFF-11d1-8ECD-0000F87A470C}"="User Assist"
"{EF8AD2D1-AE36-11D1-B2D2-006097DF8C11}"="Global Folder Settings"
"{EFA24E61-B078-11d0-89E4-00C04FC9E26E}"="Favorites Band"
"{0A89A860-D7B1-11CE-8350-444553540000}"="Shell Automation Inproc Service"
"{E7E4BC40-E76A-11CE-A9BB-00AA004AE837}"="Shell DocObject Viewer"
"{A5E46E3A-8849-11D1-9D8C-00C04FC99D61}"="Microsoft Browser Architecture"
"{FBF23B40-E3F0-101B-8488-00AA003E56F8}"="InternetShortcut"
"{3C374A40-BAE4-11CF-BF7D-00AA006946EE}"="Microsoft Url History Service"
"{FF393560-C2A7-11CF-BFF4-444553540000}"="History"
"{7BD29E00-76C1-11CF-9DD0-00A0C9034933}"="Temporary Internet Files"
"{7BD29E01-76C1-11CF-9DD0-00A0C9034933}"="Temporary Internet Files"
"{CFBFAE00-17A6-11D0-99CB-00C04FD64497}"="Microsoft Url Search Hook"
"{A2B0DD40-CC59-11d0-A3A5-00C04FD706EC}"="IE4 Suite Splash Screen"
"{67EA19A0-CCEF-11d0-8024-00C04FD75D13}"="CDF Extension Copy Hook"
"{131A6951-7F78-11D0-A979-00C04FD705A2}"="ISFBand OC"
"{9461b922-3c5a-11d2-bf8b-00c04fb93661}"="Search Assistant OC"
"{3DC7A020-0ACD-11CF-A9BB-00AA004AE837}"="The Internet"
"{871C5380-42A0-1069-A2EA-08002B30309D}"="Internet Name Space"
"{EFA24E64-B078-11d0-89E4-00C04FC9E26E}"="Explorer Band"
"{9E56BE60-C50F-11CF-9A2C-00A0C90A90CE}"="Sendmail service"
"{9E56BE61-C50F-11CF-9A2C-00A0C90A90CE}"="Sendmail service"
"{88C6C381-2E85-11D0-94DE-444553540000}"="ActiveX Cache Folder"
"{E6FB5E20-DE35-11CF-9C87-00AA005127ED}"="WebCheck"
"{ABBE31D0-6DAE-11D0-BECA-00C04FD940BE}"="Subscription Mgr"
"{F5175861-2688-11d0-9C5E-00AA00A45957}"="Subscription Folder"
"{08165EA0-E946-11CF-9C87-00AA005127ED}"="WebCheckWebCrawler"
"{E3A8BDE6-ABCE-11d0-BC4B-00C04FD929DB}"="WebCheckChannelAgent"
"{E8BB6DC0-6B4E-11d0-92DB-00A0C90C2BD7}"="TrayAgent"
"{7D559C10-9FE9-11d0-93F7-00AA0059CE02}"="Code Download Agent"
"{E6CC6978-6B6E-11D0-BECA-00C04FD940BE}"="ConnectionAgent"
"{D8BD2030-6FC9-11D0-864F-00AA006809D9}"="PostAgent"
"{7FC0B86E-5FA7-11d1-BC7C-00C04FD929DB}"="WebCheck SyncMgr Handler"
"{352EC2B7-8B9A-11D1-B8AE-006008059382}"="Shell Application Manager"
"{0B124F8F-91F0-11D1-B8B5-006008059382}"="Installed Apps Enumerator"
"{CFCCC7A0-A282-11D1-9082-006008059382}"="Darwin App Publisher"
"{e84fda7c-1d6a-45f6-b725-cb260c236066}"="Shell Image Verbs"
"{66e4e4fb-f385-4dd0-8d74-a2efd1bc6178}"="Shell Image Data Factory"
"{00E7B358-F65B-4dcf-83DF-CD026B94BFD4}"="Autoplay for SlideShow"
"{3F30C968-480A-4C6C-862D-EFC0897BB84B}"="GDI+ file thumbnail extractor"
"{9DBD2C50-62AD-11d0-B806-00C04FD706EC}"="Summary Info Thumbnail handler (DOCFILES)"
"{EAB841A0-9550-11cf-8C16-00805F1408F3}"="HTML Thumbnail Extractor"
"{eb9b1153-3b57-4e68-959a-a3266bc3d7fe}"="Shell Image Property Handler"
"{CC6EEFFB-43F6-46c5-9619-51D571967F7D}"="Web Publishing Wizard"
"{add36aa8-751a-4579-a266-d66f5202ccbb}"="Print Ordering via the Web"
"{6b33163c-76a5-4b6c-bf21-45de9cd503a1}"="Shell Publishing Wizard Object"
"{58f1f272-9240-4f51-b6d4-fd63d1618591}"="Get a Passport Wizard"
"{7A9D77BD-5403-11d2-8785-2E0420524153}"="User Accounts"
"{BD472F60-27FA-11cf-B8B4-444553540000}"="Compressed (zipped) Folder Right Drag Handler"
"{888DCA60-FC0A-11CF-8F0F-00C04FD7D062}"="Compressed (zipped) Folder SendTo Target"
"{f39a0dc0-9cc8-11d0-a599-00c04fd64433}"="Channel File"
"{f3aa0dc0-9cc8-11d0-a599-00c04fd64434}"="Channel Shortcut"
"{f3ba0dc0-9cc8-11d0-a599-00c04fd64435}"="Channel Handler Object"
"{f3da0dc0-9cc8-11d0-a599-00c04fd64437}"="Channel Menu"
"{f3ea0dc0-9cc8-11d0-a599-00c04fd64438}"="Channel Properties"
"{692F0339-CBAA-47e6-B5B5-3B84DB604E87}"="Extensions Manager Folder"
"{63da6ec0-2e98-11cf-8d82-444553540000}"="FTP Folders Webview"
"{883373C3-BF89-11D1-BE35-080036B11A03}"="Microsoft DocProp Shell Ext"
"{A9CF0EAE-901A-4739-A481-E35B73E47F6D}"="Microsoft DocProp Inplace Edit Box Control"
"{8EE97210-FD1F-4B19-91DA-67914005F020}"="Microsoft DocProp Inplace ML Edit Box Control"
"{0EEA25CC-4362-4A12-850B-86EE61B0D3EB}"="Microsoft DocProp Inplace Droplist Combo Control"
"{6A205B57-2567-4A2C-B881-F787FAB579A3}"="Microsoft DocProp Inplace Calendar Control"
"{28F8A4AC-BBB3-4D9B-B177-82BFC914FA33}"="Microsoft DocProp Inplace Time Control"
"{8A23E65E-31C2-11d0-891C-00A024AB2DBB}"="Directory Query UI"
"{9E51E0D0-6E0F-11d2-9601-00C04FA31A86}"="Shell properties for a DS object"
"{163FDC20-2ABC-11d0-88F0-00A024AB2DBB}"="Directory Object Find"
"{F020E586-5264-11d1-A532-0000F8757D7E}"="Directory Start/Search Find"
"{0D45D530-764B-11d0-A1CA-00AA00C16E65}"="Directory Property UI"
"{62AE1F9A-126A-11D0-A14B-0800361B1103}"="Directory Context Menu Verbs"
"{ECF03A33-103D-11d2-854D-006008059367}"="MyDocs Copy Hook"
"{ECF03A32-103D-11d2-854D-006008059367}"="MyDocs Drop Target"
"{4a7ded0a-ad25-11d0-98a8-0800361b1103}"="MyDocs Properties"
"{750fdf0e-2a26-11d1-a3ea-080036587f03}"="Offline Files Menu"
"{10CFC467-4392-11d2-8DB4-00C04FA31A66}"="Offline Files Folder Options"
"{AFDB1F70-2A4C-11d2-9039-00C04F8EEB3E}"="Offline Files Folder"
"{143A62C8-C33B-11D1-84FE-00C04FA34A14}"="Microsoft Agent Character Property Sheet Handler"
"{ECCDF543-45CC-11CE-B9BF-0080C87CDBA6}"="DfsShell"
"{60fd46de-f830-4894-a628-6fa81bc0190d}"="%DESC_PublishDropTarget%"
"{7A80E4A8-8005-11D2-BCF8-00C04F72C717}"="MMC Icon Handler"
"{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}"=".CAB file viewer"
"{32714800-2E5F-11d0-8B85-00AA0044F941}"="For &People…"
"{8DD448E6-C188-4aed-AF92-44956194EB1F}"="Windows Media Player Play as Playlist Context Menu Handler"
"{CE3FB1D1-02AE-4a5f-A6E9-D9F1B4073E6C}"="Windows Media Player Burn Audio CD Context Menu Handler"
"{F1B9284F-E9DC-4e68-9D7E-42362A59F0FD}"="Windows Media Player Add to Playlist Context Menu Handler"
"{1D2680C9-0E2A-469d-B787-065558BC7D43}"="Fusion Cache"
"{C4213067-97B3-4929-9B98-B5600FBBBA13}"="TouchED"
"{BDEADF00-C265-11D0-BCED-00A0C90AB50F}"="Web Folders"
"{42042206-2D85-11D3-8CFF-005004838597}"="Microsoft Office HTML Icon Handler"
"{00020D75-0000-0000-C000-000000000046}"="Microsoft Office Outlook Desktop Icon Handler"
"{0006F045-0000-0000-C000-000000000046}"="Microsoft Office Outlook Custom Icon Handler"
"{99A0CC20-1134-11D3-833F-0000E83E0F26}"="ZipNAll for Window"
"{F0CB00CD-5A07-4D91-97F5-A8C92CDA93E4}"="Shell Extensions for RealOne Player"
"{e57ce731-33e8-4c51-8354-bb4de9d215d1}"="Universal Plug and Play Devices"
"{8FF88D21-7BD0-11D1-BFB7-00AA00262A11}"="WinAce Archiver 2.6 Context Menu Shell Extension"
"{8FF88D25-7BD0-11D1-BFB7-00AA00262A11}"="WinAce Archiver 2.6 DragDrop Shell Extension"
"{8FF88D27-7BD0-11D1-BFB7-00AA00262A11}"="WinAce Archiver 2.6 Context Menu Shell Extension"
"{8FF88D23-7BD0-11D1-BFB7-00AA00262A11}"="WinAce Archiver 2.6 Property Sheet Shell Extension"
"{0DE61CCE-8443-11D9-9CEC-0050BA012D9B}"="LaunchShellMenu extension"
"{21569614-B795-46b1-85F4-E737A8DC09AD}"="Shell Search Band"
"{EFA24E62-B078-11d0-89E4-00C04FC9E26E}"="History Band"
"{B9E1D2CB-CCFF-4AA6-9579-D7A4754030EF}"="iTunes"
"{CC1E0C36-712E-46CE-A390-1F66F5094335}"="BurstCopy"
"{506F4668-F13E-4AA1-BB04-B43203AB3CC0}"="{506F4668-F13E-4AA1-BB04-B43203AB3CC0}"
"{D66DC78C-4F61-447F-942B-3FB6980118CF}"="{D66DC78C-4F61-447F-942B-3FB6980118CF}"
"{640167b4-59b0-47a6-b335-a6b3c0695aea}"="Portable Media Devices"
"{35786D3C-B075-49b9-88DD-029876E11C01}"="Portable Devices"
"{D6791A63-E7E2-4fee-BF52-5DED8E86E9B8}"="Portable Devices Menu"
"{40950107-FEA6-4d53-A65F-B2DCBA57DD58}"="Nokia Phone Browser"
"{FBFE7864-D495-41f0-B7DC-4BB601CC295E}"="Contact View"
"{e82a2d71-5b2f-43a0-97b8-81be15854de8}"="ShellLink for Application References"
"{E37E2028-CE1A-4f42-AF05-6CEABC4E5D75}"="Shell Icon Handler for Application References"
"{FC9FB64A-1EB2-4CCF-AF5E-1A497A9B5C2D}"="Messenger Sharing Folders"
"{B41DB860-8EE4-11D2-9906-E49FADC173CA}"="WinRAR shell extension"
"{7C9D5882-CB4A-4090-96C8-430BFE8B795B}"="Webroot Spy Sweeper Context Menu Integration"
"{B327765E-D724-4347-8B16-78AE18552FC3}"="NeroDigitalIconHandler"
"{7F1CF152-04F8-453A-B34C-E609530A9DC8}"="NeroDigitalPropSheetHandler"
HKEY ROOT CLASSIDS:
Files Found are not all bad files:
netapi32.dll Fri Jul 14 2006 5:31:40p A…. 332,288 324.50 K
sirenacm.dll Fri Jun 16 2006 2:34:44p A…. 48,936 47.79 K
wrlogo~1.dll Fri Jul 7 2006 4:53:54p A…. 208,896 204.00 K
wrlzma.dll Fri Jul 7 2006 4:53:50p A…. 20,992 20.50 K
4 items found: 4 files, 0 directories.
Total of file sizes: 611,112 bytes 596.79 K
Locate .tmp files:
No matches found.
Directory Listing of system files:
Volume in drive C has no label.
Volume Serial Number is ACD7-7451
Scan saved at 9:42:47 PM, on 9/1/2006
STEP 1.
Please show all files for your system. You will need to reverse this process when all steps are done.
Submit File to Jotti
Please click on Jotti
Use the "Browse" button and locate the following file on your computer: C:\WINDOWS\System32\actskn43.ocx
Click the "Submit" button.
Please copy and post (reply) with the results
If Jotti's service load is too high, you can use the following scanner instead:
http://www.virustotal.com/xhtml/index_en.html
Please also check the properties of those files (right-click and select properties from the popupmenu). Look if you can find some company information, etc.
Glad we could be of assistance. This topic is now closed. If you wish it reopened, please send us an email (Click for address) with a link to your thread.
Do not bother contacting us if you are not the topic starter. A valid, working link to the closed topic is required along with the user name used. If the user name does not match the one in the thread linked, the email will be deleted.
Make sure you use proper prevention to keep from having problems occur to your computer in the future.
