TJT-Log
Logfile of HijackThis v1.99.1
Scan saved at 3:06:31 AM, on 8/5/2006
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
C:\WINDOWS\system32\RunDLL32.exe
C:\Program Files\Executive Software\DiskeeperLite\DKService.exe
C:\Program Files\ewido anti-malware\ewidoctrl.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\system32\WgaTray.exe
C:\WINDOWS\system32\wpabaln.exe
C:\Program Files\Steam\steam.exe
c:\program files\steam\steamapps\ganssr\counter-strike source\hl2.exe
C:\Program Files\Xfire\Xfire.exe
C:\Program Files\Ventrilo\Ventrilo.exe
C:\Documents and Settings\Ryan\Start Menu\Programs\HijackThis.exe
C:\PROGRA~1\MOZILL~1\FIREFOX.EXE
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://windowsupdate.microsoft.com/
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [NvMediaCenter] RunDLL32.exe NvMCTray.dll,NvTaskbarInit
O4 - HKCU\..\Run: [Steam] "C:\Program Files\Steam\Steam.exe" -silent
O4 - Startup: Adobe Gamma.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/…b?1153357347480
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Diskeeper - Executive Software International, Inc. - C:\Program Files\Executive Software\DiskeeperLite\DKService.exe
O23 - Service: ewido security suite control - ewido networks - C:\Program Files\ewido anti-malware\ewidoctrl.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
Hello and Welcome rgg to TomCoyote,
Don't see much in your hijackthis log. Let's start with some scans please.
STEP 1.
SpySweeper
Download the trial version of Spy Sweeper from Here
Install it using the Standard Install option. (You will be asked for your e-mail address, it is safe to give it. If you receive alerts from your firewall, allow all activities for Spy Sweeper)
If you are taken to the internet page, just close the page.
You will be prompted to check for updated definitions, please do so.
(This may take several minutes)
Click on Options > Sweep Options and check Sweep all Folders on Selected drives. Check Local Disc C. Under What to Sweep, check every box.
Click on Sweep and allow it to fully scan your system.If you are prompted to restart the computer, do so immediately. This is a necessary step to kill the infection!
When the sweep has finished, click Remove. Click Select All and then Next
From 'Results', select the Session Log tab. Click Save to File and save the log somewhere convenient.
STEP 2.
Panda Active Scan
Please go to Panda ActiveScan.
Once you are on the Panda site click the Scan your PC button
A new window will open…click the Check Now button
  • Enter your Country
  • Enter your State/Province
  • Enter your e-mail address and click send
  • Select either Home User or Company
  • Click the big Scan Now button
  • If it wants to install an ActiveX component allow it
  • It will start downloading the files it requires for the scan (Note: It may take a couple of minutes)
  • When download is complete, click on Local Disks to start the scan
  • When the scan completes, if anything malicious is detected, click the See Report button, then Save Report and save it to a convenient location.
Empty Recycle Bin
Reboot
Post results from SpySweeper, ewido the contents of the Panda scan report, along with a new HijackThis Log, by using Add Reply.
