This is L2MFIX log
L2Mfix 1.03d
Running From:
C:\DOCUME~1\Sekar\Desktop\l2mfix2\l2mfix
RegDACL 5.1 - Permissions Manager for Registry keys for Windows NT 4 and above
Copyright © 1999-2001 Frank Heyne Software (
http://www.heysoft.de)
This program is Freeware, use it on your own risk!
Access Control List for Registry key HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify:
(NI) ALLOW Full access NT AUTHORITY\SYSTEM
(IO) ALLOW Full access NT AUTHORITY\SYSTEM
(ID-NI) ALLOW Read BUILTIN\Users
(ID-IO) ALLOW Read BUILTIN\Users
(ID-NI) ALLOW Read BUILTIN\Power Users
(ID-IO) ALLOW Read BUILTIN\Power Users
(ID-NI) ALLOW Full access BUILTIN\Administrators
(ID-IO) ALLOW Full access BUILTIN\Administrators
(ID-NI) ALLOW Full access NT AUTHORITY\SYSTEM
(ID-IO) ALLOW Full access NT AUTHORITY\SYSTEM
(ID-IO) ALLOW Full access CREATOR OWNER
Setting registry permissions:
Denying C(CI) access for predefined group "Administrators"
- adding new ACCESS DENY entry
Registry Permissions set too:
(CI) DENY –C——- BUILTIN\Administrators
Setting up for Reboot
Starting Reboot!
C:\Documents and Settings\Sekar\Desktop\l2mfix2\l2mfix
System Rebooted!
Running From:
killing explorer and rundll32.exe
Command Line Process Viewer/Killer/Suspender for Windows NT/2000/XP V2.03
Copyright© 2002-2003 [removed]
Killing PID 1268 'explorer.exe'
Killing PID 1588 'rundll32.exe'
Scanning First Pass. Please Wait!
First Pass Completed
Second Pass Scanning
Second pass Completed!
Backing Up: C:\WINDOWS\system32\cpmmdlg.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\imitpki.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\dcnlobby.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\mowebdvd.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\khdcz1.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\fjntext.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\dEtaclen.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\sqndmail.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\rCsman.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\i4060edseh060.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\iismsnap.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\rphx32.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\dfnhupnp.dll
1 file(s) copied.
1 file(s) copied.
Backing Up: C:\WINDOWS\system32\guard.tmp
1 file(s) copied.
deleting: C:\WINDOWS\system32\cpmmdlg.dll
Successfully Deleted: C:\WINDOWS\system32\cpmmdlg.dll
deleting: C:\WINDOWS\system32\imitpki.dll
Successfully Deleted: C:\WINDOWS\system32\imitpki.dll
deleting: C:\WINDOWS\system32\dcnlobby.dll
Successfully Deleted: C:\WINDOWS\system32\dcnlobby.dll
deleting: C:\WINDOWS\system32\mowebdvd.dll
Successfully Deleted: C:\WINDOWS\system32\mowebdvd.dll
deleting: C:\WINDOWS\system32\khdcz1.dll
Successfully Deleted: C:\WINDOWS\system32\khdcz1.dll
deleting: C:\WINDOWS\system32\fjntext.dll
Successfully Deleted: C:\WINDOWS\system32\fjntext.dll
deleting: C:\WINDOWS\system32\dEtaclen.dll
Successfully Deleted: C:\WINDOWS\system32\dEtaclen.dll
deleting: C:\WINDOWS\system32\sqndmail.dll
Successfully Deleted: C:\WINDOWS\system32\sqndmail.dll
deleting: C:\WINDOWS\system32\rCsman.dll
Successfully Deleted: C:\WINDOWS\system32\rCsman.dll
deleting: C:\WINDOWS\system32\i4060edseh060.dll
Successfully Deleted: C:\WINDOWS\system32\i4060edseh060.dll
deleting: C:\WINDOWS\system32\iismsnap.dll
Successfully Deleted: C:\WINDOWS\system32\iismsnap.dll
deleting: C:\WINDOWS\system32\rphx32.dll
Successfully Deleted: C:\WINDOWS\system32\rphx32.dll
deleting: C:\WINDOWS\system32\dfnhupnp.dll
Successfully Deleted: C:\WINDOWS\system32\dfnhupnp.dll
deleting: C:\WINDOWS\system32\guard.tmp
Successfully Deleted: C:\WINDOWS\system32\guard.tmp
Desktop.ini sucessfully removed
Zipping up files for submission:
adding: cpmmdlg.dll (deflated 48%)
adding: imitpki.dll (deflated 48%)
adding: dcnlobby.dll (deflated 48%)
adding: mowebdvd.dll (deflated 48%)
adding: khdcz1.dll (deflated 48%)
adding: fjntext.dll (deflated 48%)
adding: dEtaclen.dll (deflated 48%)
adding: sqndmail.dll (deflated 48%)
adding: rCsman.dll (deflated 48%)
adding: i4060edseh060.dll (deflated 48%)
adding: iismsnap.dll (deflated 48%)
adding: rphx32.dll (deflated 48%)
adding: dfnhupnp.dll (deflated 48%)
adding: guard.tmp (deflated 4%)
adding: echo.reg (deflated 11%)
adding: clear.reg (deflated 56%)
adding: desktop.ini (stored 0%)
adding: readme.txt (deflated 51%)
adding: direct.txt (deflated 7%)
adding: report.txt (deflated 77%)
adding: lo2.txt (deflated 85%)
adding: test2.txt (deflated 37%)
adding: test3.txt (deflated 37%)
adding: test5.txt (deflated 37%)
adding: test.txt (deflated 86%)
adding: xfind.txt (deflated 83%)
adding: backregs/notibac.reg (deflated 87%)
adding: backregs/shell.reg (deflated 55%)
adding: backregs/AC60C63C-1A3D-440D-9FF3-3F37A7925801.reg (deflated 70%)
adding: backregs/8353F7A8-8E62-49A0-9123-24B8D31A84C0.reg (deflated 70%)
adding: backregs/39C51E56-A1EB-4184-AEBF-2D68C56B6353.reg (deflated 70%)
adding: backregs/16B79DDB-75D8-4960-91CD-4ACA4164F02A.reg (deflated 70%)
adding: backregs/DDF9D1E9-F3DD-4E96-9AEF-23D4A8043B8E.reg (deflated 70%)
Restoring Registry Permissions:
Revoking access for predefined group "Administrators"
Inherited ACE can not be revoked here!
Registry permissions set too:
Restoring Sedebugprivilege:
Granting SeDebugPrivilege to Administrators … successful
Restoring Windows Update Certificates.:
deleting local copy: cpmmdlg.dll
deleting local copy: imitpki.dll
deleting local copy: dcnlobby.dll
deleting local copy: mowebdvd.dll
deleting local copy: khdcz1.dll
deleting local copy: fjntext.dll
deleting local copy: dEtaclen.dll
deleting local copy: sqndmail.dll
deleting local copy: rCsman.dll
deleting local copy: i4060edseh060.dll
deleting local copy: iismsnap.dll
deleting local copy: rphx32.dll
deleting local copy: dfnhupnp.dll
deleting local copy: guard.tmp
The following Is the Current Export of the Winlogon notify key:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\crypt32chain]
"Asynchronous"=dword:00000000
"Impersonate"=dword:00000000
"DllName"=hex(2):63,00,72,00,79,00,70,00,74,00,33,00,32,00,2e,00,64,00,6c,00,\
6c,00,00,00
"Logoff"="ChainWlxLogoffEvent"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\cryptnet]
"DllName"=hex(2):63,00,72,00,79,00,70,00,74,00,6e,00,65,00,74,00,2e,00,64,00,\
6c,00,6c,00,00,00
"Logoff"="CryptnetWlxLogoffEvent"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\cscdll]
"DLLName"="cscdll.dll"
"Logon"="WinlogonLogonEvent"
"Logoff"="WinlogonLogoffEvent"
"ScreenSaver"="WinlogonScreenSaverEvent"
"Startup"="WinlogonStartupEvent"
"Shutdown"="WinlogonShutdownEvent"
"StartShell"="WinlogonStartShellEvent"
"Asynchronous"=dword:00000001
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\ScCertProp]
"DLLName"="wlnotify.dll"
"Logon"="SCardStartCertProp"
"Logoff"="SCardStopCertProp"
"Lock"="SCardSuspendCertProp"
"Unlock"="SCardResumeCertProp"
"Enabled"=dword:00000001
"Impersonate"=dword:00000001
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\Schedule]
"DllName"=hex(2):77,00,6c,00,6e,00,6f,00,74,00,69,00,66,00,79,00,2e,00,64,00,\
6c,00,6c,00,00,00
"StartShell"="SchedStartShell"
"Logoff"="SchedEventLogOff"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\sclgntfy]
"Logoff"="WLEventLogoff"
"DllName"=hex(2):73,00,63,00,6c,00,67,00,6e,00,74,00,66,00,79,00,2e,00,64,00,\
6c,00,6c,00,00,00
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\SensLogn]
"DLLName"="WlNotify.dll"
"Lock"="SensLockEvent"
"Logon"="SensLogonEvent"
"Logoff"="SensLogoffEvent"
"Safe"=dword:00000001
"MaxWait"=dword:00000258
"StartScreenSaver"="SensStartScreenSaverEvent"
"StopScreenSaver"="SensStopScreenSaverEvent"
"Startup"="SensStartupEvent"
"Shutdown"="SensShutdownEvent"
"StartShell"="SensStartShellEvent"
"PostShell"="SensPostShellEvent"
"Disconnect"="SensDisconnectEvent"
"Reconnect"="SensReconnectEvent"
"Unlock"="SensUnlockEvent"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\termsrv]
6c,00,6c,00,00,00
"Logoff"="TSEventLogoff"
"Logon"="TSEventLogon"
"PostShell"="TSEventPostShell"
"Shutdown"="TSEventShutdown"
"StartShell"="TSEventStartShell"
"Startup"="TSEventStartup"
"Reconnect"="TSEventReconnect"
"Disconnect"="TSEventDisconnect"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\wlballoon]
"Logon"="RegisterTicketExpiredNotificationEvent"
"Logoff"="UnregisterTicketExpiredNotificationEvent"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\wzcnotif]
"DLLName"="wzcdlg.dll"
"Logon"="WZCEventLogon"
"Logoff"="WZCEventLogoff"
The following are the files found:
Registry Entries that were Deleted:
Please verify that the listing looks ok.
If there was something deleted wrongly there are backups in the backreg folder.
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved]
"{AC60C63C-1A3D-440D-9FF3-3F37A7925801}"=-
"{8353F7A8-8E62-49A0-9123-24B8D31A84C0}"=-
"{39C51E56-A1EB-4184-AEBF-2D68C56B6353}"=-
"{16B79DDB-75D8-4960-91CD-4ACA4164F02A}"=-
"{DDF9D1E9-F3DD-4E96-9AEF-23D4A8043B8E}"=-
[-HKEY_CLASSES_ROOT\CLSID\{AC60C63C-1A3D-440D-9FF3-3F37A7925801}]
[-HKEY_CLASSES_ROOT\CLSID\{8353F7A8-8E62-49A0-9123-24B8D31A84C0}]
[-HKEY_CLASSES_ROOT\CLSID\{39C51E56-A1EB-4184-AEBF-2D68C56B6353}]
[-HKEY_CLASSES_ROOT\CLSID\{16B79DDB-75D8-4960-91CD-4ACA4164F02A}]
[-HKEY_CLASSES_ROOT\CLSID\{DDF9D1E9-F3DD-4E96-9AEF-23D4A8043B8E}]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\User Agent\Post Platform]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\User Agent\Post Platform]
Desktop.ini Contents:
[.ShellClassInfo]
CLSID={645FF040-5081-101B-9F08-00AA002F954E}
and this is HJT Log
Logfile of HijackThis v1.99.1
Scan saved at 12:37:26 PM, on 8/21/2005
Platform: Windows XP (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 (6.00.2600.0000)
C:\WINDOWS\system32\ZONELABS\vsmon.exe
C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
C:\Program Files\a2\a2guard.exe
C:\WINDOWS\explorer.exe
C:\WINDOWS\system32\NOTEPAD.EXE
C:\Program Files\Internet Explorer\IEXPLORE.EXE
E:\free Softwares\Freewares\AnitiVirus\HijackThis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = www.google.com
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = www.google.com
O3 - Toolbar: &Radio; - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O4 - HKLM\..\Run: [msnappau] :"C:\Program Files\MSN Apps\Updater\01.02.0002.1001\en-us\msnappau.exe"
O4 - HKLM\..\Run: [Zone Labs Client] "C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe"
O4 - HKLM\..\Run: [NeroCheck] C:\WINDOWS\System32\\NeroCheck.exe
O4 - HKCU\..\Run: [a-squared] "C:\Program Files\a2\a2guard.exe"
O8 - Extra context menu item: &Dictionary; -
http://files.db3nf.com/scripts/ie.htm
O8 - Extra context menu item: &Encyclopedia; -
http://files.db3nf.com/scripts/ie-e.htm
O8 - Extra context menu item: + &Download; Express: download this file - C:\Program Files\Download Express\Add_Url.htm
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\YAHOO!\MESSEN~1\YPAGER.EXE
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\YAHOO!\MESSEN~1\YPAGER.EXE
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
O16 - DPF: ChatSpace Full Java Client 3.1.0.229 -
http://surechat.com:9000/Java/cfs31229.cab
O16 - DPF: Yahoo! Chat - http://us.chat1.yimg.com/us.yimg.com/i/cha…t/c381/chat.cab
O16 - DPF: {0246ECA8-996F-11D1-BE2F-00A0C9037DFE} (TDServer Control) -
http://www.xpres-net.com/wfplayer/tdserver.cab
O16 - DPF: {BB21F850-63F4-4EC9-BF9D-565BD30C9AE9} (ASquaredScanForm Element) -
http://www.windowsecurity.com/trojanscan/axscan.cab
O16 - DPF: {E504EE6E-47C6-11D5-B8AB-00D0B78F3D48} (Yahoo! Webcam Viewer Wrapper) - http://chat.yahoo.com/cab/yvwrctl.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{F2354439-A2EC-4C5E-B60F-467E897E309E}: NameServer = 192.168.11.1,202.56.250.5,202.56.240.5
O23 - Service: SuperProServer - Unknown owner - C:\Documents and Settings\Sekar\Desktop\Tally6.3\spnsrvnt.exe (file missing)
O23 - Service: TrueVector Internet Monitor (vsmon) - Zone Labs LLC - C:\WINDOWS\system32\ZONELABS\vsmon.exe
waiting,
- Mogun.
