i'm not entirely sure how the machine is running. i have experienced some weird hangs just moving things around on the desktop while working on these issues. It also seems to run hot, often the fan running hard and the machine making a lot of noise for no apparent reason. But my wife has reported that she feels the machine is running better.
I presume when you give the all-clear that I will go into this machine and apply the precautions that you recommended for my machine?
here are the logs:
========== FILES ==========
C:\Users\anniecoggan\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\HUWN3ZGM\im-jealous-of-payton-turner-brian-kaspr[1].htm moved successfully.
Restore point Set: OTL Restore Point
User: anniecoggan
->Temp folder emptied: 20247656 bytes
->Temporary Internet Files folder emptied: 279092009 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 370044898 bytes
->Flash cache emptied: 8109 bytes
User: Default
->Temporary Internet Files folder emptied: 0 bytes
->Flash cache emptied: 0 bytes
User: Public
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 .tmp files removed: 0 bytes
%systemroot%\System32 (64bit) .tmp files removed: 0 bytes
Windows Temp folder emptied: 16334 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 128 bytes
%systemroot%\sysnative\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment folder emptied: 0 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 638.00 mb
OTL by OldTimer - Version 3.2.69.0 log created on 06032013_143810
Files\Folders moved on Reboot…
C:\Users\anniecoggan\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
C:\Users\anniecoggan\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
PendingFileRenameOperations files…
Registry entries deleted on Reboot…
OTL logfile created on: 6/3/2013 2:57:12 PM - Run 3
OTL by OldTimer - Version 3.2.69.0 Folder = C:\Users\anniecoggan\Desktop
64bit- Home Premium Edition Service Pack 1 (Version = 6.1.7601) - Type = NTWorkstation
Internet Explorer (Version = 9.10.9200.16576)
Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
3.80 Gb Total Physical Memory | 2.15 Gb Available Physical Memory | 56.61% Memory free
7.60 Gb Paging File | 5.87 Gb Available in Paging File | 77.19% Paging File free
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files (x86)
Drive C: | 575.36 Gb Total Space | 442.60 Gb Free Space | 76.93% Space Free | Partition Type: NTFS
Drive D: | 20.52 Gb Total Space | 2.98 Gb Free Space | 14.55% Space Free | Partition Type: NTFS
Drive F: | 99.34 Mb Total Space | 77.65 Mb Free Space | 78.17% Space Free | Partition Type: FAT32
Computer Name: ANNIECOGGAN-HP | User Name: anniecoggan | Logged in as Administrator.
Boot Mode: Normal | Scan Mode: Current user | Include 64bit Scans
PRC - C:\Users\anniecoggan\Desktop\OTL.exe (OldTimer Tools)
PRC - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe (Adobe Systems Incorporated)
PRC - C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\acrobat_sl.exe (Adobe Systems Incorporated)
PRC - C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\acrotray.exe (Adobe Systems Inc.)
PRC - C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe (Malwarebytes Corporation)
PRC - C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamgui.exe (Malwarebytes Corporation)
PRC - C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamscheduler.exe (Malwarebytes Corporation)
PRC - C:\Users\anniecoggan\AppData\Roaming\Dropbox\bin\Dropbox.exe (Dropbox, Inc.)
PRC - C:\Program Files (x86)\SafeConnect\scManager.sys (Impulse Point, LLC)
PRC - C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPMSGSVC.exe (Hewlett-Packard Development Company, L.P.)
PRC - C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPWMISVC.exe (Hewlett-Packard Development Company, L.P.)
PRC - C:\Program Files (x86)\Norton Internet Security\Engine\18.7.2.3\ccsvchst.exe (Symantec Corporation)
PRC - C:\Program Files (x86)\Microsoft\BingBar\SeaPort.EXE (Microsoft Corporation)
PRC - C:\Program Files (x86)\DigitalPersona\Bin\DPAgent.exe (DigitalPersona, Inc.)
PRC - C:\Program Files (x86)\Hewlett-Packard\Media\Webcam\YCMMirage.exe (CyberLink)
PRC - C:\Program Files\Hewlett-Packard\HP Wireless Assistant\DelayedAppStarter.exe ()
PRC - C:\Program Files (x86)\CinemaNow\CinemaNow Media Manager\CinemaNowSvc.exe (CinemaNow, Inc.)
PRC - C:\Program Files (x86)\Intel\Intel® Management Engine Components\UNS\UNS.exe (Intel Corporation)
PRC - C:\Program Files (x86)\Intel\Intel® Management Engine Components\LMS\LMS.exe (Intel Corporation)
PRC - C:\ProgramData\Macrovision\FLEXnet Connect\6\ISUSPM.exe (Acresso Corporation)
========== Modules (No Company Name) ==========
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\PresentationFramewo#\af525b4bec3b9941b7be8ffbf813da80\PresentationFramework.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\30e3a21202000677d0a9270572251477\System.Windows.Forms.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\PresentationCore\7eac0dbe9aa20b55e37235f8ee030e6b\PresentationCore.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\WindowsBase\716959df79685a1eae0fc14275a32b0f\WindowsBase.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Configuration\764f15e86c82662e977bd418bd6318c1\System.Configuration.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Management\302207b4fa3083899fd8ab4db98cecc5\System.Management.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\PresentationFramewo#\d7d20811a7ce7cc589153648cbb1ce5c\PresentationFramework.Aero.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Runtime.Remo#\90b89f6e8032310e9ac72a309fd49e83\System.Runtime.Remoting.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Data\dd20416f723ee13ffb4173ec1afc4ec4\System.Data.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Drawing\eead6629e384a5b69f9ae35284b7eeed\System.Drawing.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Xml\f687c43e9fdec031988b33ae722c4613\System.Xml.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\System\369f8bdca364e2b4936d18dea582912c\System.ni.dll ()
MOD - C:\Windows\assembly\NativeImages_v2.0.50727_32\mscorlib\7150b9136fad5b79e88f6c7f9d3d2c39\mscorlib.ni.dll ()
MOD - C:\Windows\assembly\GAC_MSIL\HP.ActiveSupportLibrary\2.0.0.1__01a974bc1760f423\HP.ActiveSupportLibrary.dll ()
MOD - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\zlib1.dll ()
MOD - C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libxml2.dll ()
MOD - C:\Windows\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll ()
MOD - C:\Program Files\Hewlett-Packard\HP Wireless Assistant\DelayedAppStarter.exe ()
MOD - C:\Program Files (x86)\Common Files\LightScribe\QtGui4.dll ()
MOD - C:\Program Files (x86)\Common Files\LightScribe\QtCore4.dll ()
MOD - C:\Program Files (x86)\Common Files\LightScribe\plugins\imageformats\qjpeg4.dll ()
MOD - C:\Program Files (x86)\Hewlett-Packard\HP Advisor\Pillars\PCAlerts\PCAlertsPillar.dll ()
MOD - C:\Program Files (x86)\Hewlett-Packard\HP Advisor\Pillars\ECenter\ECLibrary.dll ()
MOD - C:\Program Files (x86)\Hewlett-Packard\HP Advisor\MessagingServer.dll ()
MOD - C:\Program Files (x86)\Hewlett-Packard\HP Advisor\RemotingClient.dll ()
MOD - C:\Program Files (x86)\Hewlett-Packard\HP Advisor\MessagingClients.dll ()
MOD - C:\Program Files (x86)\Hewlett-Packard\HP Advisor\MessagingInterface.dll ()
MOD - C:\Program Files (x86)\Hewlett-Packard\HP Advisor\MessagingMessages.dll ()
MOD - C:\Program Files (x86)\Hewlett-Packard\HP Advisor\Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.Logging.dll ()
========== Services (SafeList) ==========
SRV:
64bit: - (hpsrv) – C:\Windows\SysNative\hpservice.exe (Hewlett-Packard Company)
SRV:
64bit: - (STacSV) – C:\Program Files\IDT\WDM\stacsv64.exe (IDT, Inc.)
SRV:
64bit: - (AESTFilters) – C:\Program Files\IDT\WDM\AESTSr64.exe (Andrea Electronics Corporation)
SRV:
64bit: - (EvtEng) – C:\Program Files\Intel\WiFi\bin\EvtEng.exe (Intel® Corporation)
SRV:
64bit: - (MyWiFiDHCPDNS) – C:\Program Files\Intel\WiFi\bin\PanDhcpDns.exe ()
SRV:
64bit: - (RegSrvc) – C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe (Intel® Corporation)
SRV:
64bit: - (DpHost) – C:\Program Files\DigitalPersona\Bin\DpHostW.exe (DigitalPersona, Inc.)
SRV:
64bit: - (HP Wireless Assistant Service) – C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWA_Service.exe (Hewlett-Packard Company)
SRV:
64bit: - (vcsFPService) – C:\Windows\SysNative\vcsFPService.exe (Validity Sensors, Inc.)
SRV:
64bit: - (WinDefend) – C:\Program Files\Windows Defender\MpSvc.dll (Microsoft Corporation)
SRV - (MozillaMaintenance) – C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe (Mozilla Foundation)
SRV - (AdobeFlashPlayerUpdateSvc) – C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe (Adobe Systems Incorporated)
SRV - (AdobeARMservice) – C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe (Adobe Systems Incorporated)
SRV - (MBAMService) – C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe (Malwarebytes Corporation)
SRV - (MBAMScheduler) – C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamscheduler.exe (Malwarebytes Corporation)
SRV - (HP Support Assistant Service) – C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\HPSA_Service.exe (Hewlett-Packard Company)
SRV - (SkypeUpdate) – C:\Program Files (x86)\Skype\Updater\Updater.exe (Skype Technologies)
SRV - (SCManager) – C:\Program Files (x86)\SafeConnect\scManager.sys (Impulse Point, LLC)
SRV - (HPWMISVC) – C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPWMISVC.exe (Hewlett-Packard Development Company, L.P.)
SRV - (NIS) – C:\Program Files (x86)\Norton Internet Security\Engine\18.7.2.3\ccSvcHst.exe (Symantec Corporation)
SRV - (BBSvc) – C:\Program Files (x86)\Microsoft\BingBar\BBSvc.EXE (Microsoft Corporation.)
SRV - (SeaPort) – C:\Program Files (x86)\Microsoft\BingBar\SeaPort.EXE (Microsoft Corporation)
SRV - (FLEXnet Licensing Service) – C:\Program Files (x86)\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe (Macrovision Europe Ltd.)
SRV - (CinemaNow Service) – C:\Program Files (x86)\CinemaNow\CinemaNow Media Manager\CinemaNowSvc.exe (CinemaNow, Inc.)
SRV - (NOBU) – C:\Program Files (x86)\Symantec\Norton Online Backup\NOBuAgent.exe (Symantec Corporation)
SRV - (UNS) – C:\Program Files (x86)\Intel\Intel® Management Engine Components\UNS\UNS.exe (Intel Corporation)
SRV - (LMS) – C:\Program Files (x86)\Intel\Intel® Management Engine Components\LMS\LMS.exe (Intel Corporation)
SRV - (GameConsoleService) – C:\Program Files (x86)\HP Games\HP Game Console\GameConsoleService.exe (WildTangent, Inc.)
SRV - (clr_optimization_v4.0.30319_32) – C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe (Microsoft Corporation)
SRV - (vcsFPService) – C:\Windows\SysWOW64\vcsFPService.exe (Validity Sensors, Inc.)
SRV - (SwitchBoard) – C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe (Adobe Systems Incorporated)
SRV - (clr_optimization_v2.0.50727_32) – C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe (Microsoft Corporation)
DRV:
64bit: - (MBAMProtector) – C:\Windows\SysNative\drivers\mbam.sys (Malwarebytes Corporation)
DRV:
64bit: - (RdpVideoMiniport) – C:\Windows\SysNative\drivers\rdpvideominiport.sys (Microsoft Corporation)
DRV:
64bit: - (TsUsbFlt) – C:\Windows\SysNative\drivers\TsUsbFlt.sys (Microsoft Corporation)
DRV:
64bit: - (GEARAspiWDM) – C:\Windows\SysNative\drivers\GEARAspiWDM.sys (GEAR Software Inc.)
DRV:
64bit: - (USBAAPL64) – C:\Windows\SysNative\drivers\usbaapl64.sys (Apple, Inc.)
DRV:
64bit: - (Fs_Rec) – C:\Windows\SysNative\drivers\fs_rec.sys (Microsoft Corporation)
DRV:
64bit: - (SynTP) – C:\Windows\SysNative\drivers\SynTP.sys (Synaptics Incorporated)
DRV:
64bit: - (NETwNs64) – C:\Windows\SysNative\drivers\NETwNs64.sys (Intel Corporation)
DRV:
64bit: - (hpdskflt) – C:\Windows\SysNative\drivers\hpdskflt.sys (Hewlett-Packard Company)
DRV:
64bit: - (Accelerometer) – C:\Windows\SysNative\drivers\Accelerometer.sys (Hewlett-Packard Company)
DRV:
64bit: - (SymEvent) – C:\Windows\SysNative\drivers\SYMEVENT64x86.SYS (Symantec Corporation)
DRV:
64bit: - (SymNetS) – C:\Windows\SysNative\drivers\NISx64\1207020.003\symnets.sys (Symantec Corporation)
DRV:
64bit: - (SRTSP) – C:\Windows\SysNative\drivers\NISx64\1207020.003\srtsp64.sys (Symantec Corporation)
DRV:
64bit: - (SRTSPX) – C:\Windows\SysNative\drivers\NISx64\1207020.003\srtspx64.sys (Symantec Corporation)
DRV:
64bit: - (SymEFA) – C:\Windows\SysNative\drivers\NISx64\1207020.003\symefa64.sys (Symantec Corporation)
DRV:
64bit: - (amdsata) – C:\Windows\SysNative\drivers\amdsata.sys (Advanced Micro Devices)
DRV:
64bit: - (amdxata) – C:\Windows\SysNative\drivers\amdxata.sys (Advanced Micro Devices)
DRV:
64bit: - (STHDA) – C:\Windows\SysNative\drivers\stwrt64.sys (IDT, Inc.)
DRV:
64bit: - (SymDS) – C:\Windows\SysNative\drivers\NISx64\1207020.003\symds64.sys (Symantec Corporation)
DRV:
64bit: - (SymIRON) – C:\Windows\SysNative\drivers\NISx64\1207020.003\ironx64.sys (Symantec Corporation)
DRV:
64bit: - (HpSAMD) – C:\Windows\SysNative\drivers\HpSAMD.sys (Hewlett-Packard Company)
DRV:
64bit: - (sdbus) – C:\Windows\SysNative\drivers\sdbus.sys (Microsoft Corporation)
DRV:
64bit: - (igfx) – C:\Windows\SysNative\drivers\igdkmd64.sys (Intel Corporation)
DRV:
64bit: - (clwvd) – C:\Windows\SysNative\drivers\clwvd.sys (Windows ® Win 7 DDK provider)
DRV:
64bit: - (HECIx64) – C:\Windows\SysNative\drivers\HECIx64.sys (Intel Corporation)
DRV:
64bit: - (wdkmd) – C:\Windows\SysNative\drivers\WDKMD.sys (Intel Corporation)
DRV:
64bit: - (iaStor) – C:\Windows\SysNative\drivers\iaStor.sys (Intel Corporation)
DRV:
64bit: - (NETw5s64) – C:\Windows\SysNative\drivers\NETw5s64.sys (Intel Corporation)
DRV:
64bit: - (RTL8167) – C:\Windows\SysNative\drivers\Rt64win7.sys (Realtek )
DRV:
64bit: - (Impcd) – C:\Windows\SysNative\drivers\Impcd.sys (Intel Corporation)
DRV:
64bit: - (IntcDAud) – C:\Windows\SysNative\drivers\IntcDAud.sys (Intel® Corporation)
DRV:
64bit: - (RSUSBSTOR) – C:\Windows\SysNative\drivers\RtsUStor.sys (Realtek Semiconductor Corp.)
DRV:
64bit: - (amdsbs) – C:\Windows\SysNative\drivers\amdsbs.sys (AMD Technologies Inc.)
DRV:
64bit: - (LSI_SAS2) – C:\Windows\SysNative\drivers\lsi_sas2.sys (LSI Corporation)
DRV:
64bit: - (stexstor) – C:\Windows\SysNative\drivers\stexstor.sys (Promise Technology)
DRV:
64bit: - (SrvHsfV92) – C:\Windows\SysNative\drivers\VSTDPV6.SYS (Conexant Systems, Inc.)
DRV:
64bit: - (SrvHsfWinac) – C:\Windows\SysNative\drivers\VSTCNXT6.SYS (Conexant Systems, Inc.)
DRV:
64bit: - (SrvHsfHDA) – C:\Windows\SysNative\drivers\VSTAZL6.SYS (Conexant Systems, Inc.)
DRV:
64bit: - (yukonw7) – C:\Windows\SysNative\drivers\yk62x64.sys (Marvell)
DRV:
64bit: - (netw5v64) – C:\Windows\SysNative\drivers\netw5v64.sys (Intel Corporation)
DRV:
64bit: - (ebdrv) – C:\Windows\SysNative\drivers\evbda.sys (Broadcom Corporation)
DRV:
64bit: - (b06bdrv) – C:\Windows\SysNative\drivers\bxvbda.sys (Broadcom Corporation)
DRV:
64bit: - (b57nd60a) – C:\Windows\SysNative\drivers\b57nd60a.sys (Broadcom Corporation)
DRV:
64bit: - (hcw85cir) – C:\Windows\SysNative\drivers\hcw85cir.sys (Hauppauge Computer Works, Inc.)
DRV - (NAVEX15) – C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\NIS_18.0.0.128\Definitions\VirusDefs\20130603.003\ex64.sys (Symantec Corporation)
DRV - (NAVENG) – C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\NIS_18.0.0.128\Definitions\VirusDefs\20130603.003\eng64.sys (Symantec Corporation)
DRV - (BHDrvx64) – C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\NIS_18.0.0.128\Definitions\BASHDefs\20130515.001\BHDrvx64.sys (Symantec Corporation)
DRV - (EraserUtilRebootDrv) – C:\Program Files (x86)\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys (Symantec Corporation)
DRV - (IDSVia64) – C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\NIS_18.0.0.128\Definitions\IPSDefs\20130531.001\IDSviA64.sys (Symantec Corporation)
DRV - (eeCtrl) – C:\Program Files (x86)\Common Files\Symantec Shared\EENGINE\eeCtrl64.sys (Symantec Corporation)
DRV - (WIMMount) – C:\Windows\SysWOW64\drivers\wimmount.sys (Microsoft Corporation)
IE:
64bit: - HKLM\..\SearchScopes,DefaultScope =
IE:
64bit: - HKLM\..\SearchScopes\{128EE17C-FF60-4948-AEBA-DD2367F2ACE5}: "URL" = http://search.yahoo.com/search?p={searchTe…amp;type=HPNTDF
IE:
64bit: - HKLM\..\SearchScopes\{4FAFA62D-9B7A-4774-8E76-9E7E1991EB8F}: "URL" = http://en.wikipedia.org/wiki/Special:Searc…h={searchTerms}
IE:
64bit: - HKLM\..\SearchScopes\{9578F476-6197-4B1A-A816-DF55DF9BACD2}: "URL" =
http://www.bing.com/search?q={searchTerms}…rc=IE-SearchBox
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
IE - HKLM\..\SearchScopes,DefaultScope =
IE - HKLM\..\SearchScopes\{128EE17C-FF60-4948-AEBA-DD2367F2ACE5}: "URL" = http://search.yahoo.com/search?p={searchTe…amp;type=HPNTDF
IE - HKLM\..\SearchScopes\{9578F476-6197-4B1A-A816-DF55DF9BACD2}: "URL" =
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = http://g.msn.com/HPNOT/1
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page =
http://www.google.com/
IE - HKCU\..\SearchScopes,DefaultScope = {9578F476-6197-4B1A-A816-DF55DF9BACD2}
IE - HKCU\..\SearchScopes\{128EE17C-FF60-4948-AEBA-DD2367F2ACE5}: "URL" = http://search.yahoo.com/search?p={searchTe…amp;type=HPNTDF
IE - HKCU\..\SearchScopes\{9578F476-6197-4B1A-A816-DF55DF9BACD2}: "URL" =
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = *.local
FF - prefs.js..browser.search.defaultengine: "Google"
FF - prefs.js..browser.search.defaultenginename: "Google"
FF - prefs.js..browser.search.order.1: ""
FF - prefs.js..browser.search.selectedEngine: "Google"
FF - prefs.js..browser.search.suggest.enabled: false
FF - prefs.js..browser.startup.homepage: "
http://www.google.com/"
FF - prefs.js..extensions.enabledAddons: %7B972ce4c6-7e08-4474-a285-3208198ce6fd%7D:21.0
FF - prefs.js..extensions.enabledItems: [removed]:5.0.0.4375
FF - prefs.js..extensions.enabledItems: {BBDA0591-3099-440a-AA10-41764D9DB4DB}:2.0
FF - prefs.js..extensions.enabledItems: {2D3F3651-74B9-4795-BDEC-6DA2F431CB62}:5.6
FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}:6.0.24
FF - prefs.js..network.proxy.no_proxies_on: "*.local"
FF - prefs.js..network.proxy.type: 0
FF - user.js - File not found
FF:
64bit: - HKLM\Software\MozillaPlugins\@adobe.com/FlashPlayer: C:\Windows\system32\Macromed\Flash\NPSWF64_11_7_700_202.dll File not found
FF:
64bit: - HKLM\Software\MozillaPlugins\@microsoft.com/GENUINE: disabled File not found
FF:
64bit: - HKLM\Software\MozillaPlugins\@Microsoft.com/NpCtrl,version=1.0: c:\Program Files\Microsoft Silverlight\5.1.20125.0\npctrl.dll ( Microsoft Corporation)
FF:
64bit: - HKLM\Software\MozillaPlugins\@microsoft.com/OfficeAuthz,version=14.0: C:\PROGRA~1\MICROS~2\Office14\NPAUTHZ.DLL (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@adobe.com/FlashPlayer: C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_7_700_202.dll ()
FF - HKLM\Software\MozillaPlugins\@adobe.com/ShockwavePlayer: C:\Windows\SysWOW64\Adobe\Director\np32dsw.dll (Adobe Systems, Inc.)
FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=: File not found
FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=1.0: C:\Program Files (x86)\iTunes\Mozilla Plugins\npitunes.dll ()
FF - HKLM\Software\MozillaPlugins\@microsoft.com/GENUINE: disabled File not found
FF - HKLM\Software\MozillaPlugins\@Microsoft.com/NpCtrl,version=1.0: c:\Program Files (x86)\Microsoft Silverlight\5.1.20125.0\npctrl.dll ( Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/OfficeAuthz,version=14.0: C:\PROGRA~2\MICROS~3\Office14\NPAUTHZ.DLL (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/SharePoint,version=14.0: C:\PROGRA~2\MICROS~3\Office14\NPSPWRAP.DLL (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3502.0922: C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3508.1109: C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3555.0308: C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
FF - HKLM\Software\MozillaPlugins\Adobe Acrobat: C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\Air\nppdf32.dll (Adobe Systems Inc.)
FF - HKLM\Software\MozillaPlugins\Adobe Reader: C:\Program Files (x86)\Adobe\Reader 11.0\Reader\AIR\nppdf32.dll (Adobe Systems Inc.)
FF - HKCU\Software\MozillaPlugins\@hulu.com/Hulu Desktop: C:\Windows\..\Users\Default\AppData\Local\HuluDesktop\instances\0.9.13.1\npHDPlg.dll ()
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{BBDA0591-3099-440a-AA10-41764D9DB4DB}: C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\NIS_18.0.0.128\IPSFFPlgn\ [2012/02/13 12:17:59 | 000,000,000 | —D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\{2D3F3651-74B9-4795-BDEC-6DA2F431CB62}: C:\ProgramData\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\NIS_18.0.0.128\coFFPlgn_2011_7_13_2 [2013/06/03 14:44:02 | 000,000,000 | —D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\[removed]: C:\Program Files (x86)\DigitalPersona\Bin\FirefoxExt\ [2011/08/27 10:44:39 | 000,000,000 | —D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Firefox 21.0\extensions\\Components: C:\Program Files (x86)\Mozilla Firefox\components [2013/05/20 20:04:18 | 000,000,000 | —D | M]
FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Firefox 21.0\extensions\\Plugins: C:\Program Files (x86)\Mozilla Firefox\plugins [2013/05/20 20:04:14 | 000,000,000 | —D | M]
FF - HKEY_CURRENT_USER\software\mozilla\Mozilla Firefox 21.0\extensions\\Components: C:\Program Files (x86)\Mozilla Firefox\components [2013/05/20 20:04:18 | 000,000,000 | —D | M]
FF - HKEY_CURRENT_USER\software\mozilla\Mozilla Firefox 21.0\extensions\\Plugins: C:\Program Files (x86)\Mozilla Firefox\plugins [2013/05/20 20:04:14 | 000,000,000 | —D | M]
[2011/01/23 16:15:19 | 000,000,000 | —D | M] (No name found) – C:\Users\anniecoggan\AppData\Roaming\Mozilla\Extensions
[2013/05/18 20:28:45 | 000,000,000 | —D | M] (No name found) – C:\Users\anniecoggan\AppData\Roaming\Mozilla\Firefox\Profiles\7f0urn48.default\extensions
[2013/05/20 20:04:20 | 000,000,000 | —D | M] (No name found) – C:\Program Files (x86)\Mozilla Firefox\extensions
[2013/05/20 20:04:12 | 000,000,000 | —D | M] (Skype extension) – C:\Program Files (x86)\Mozilla Firefox\extensions\{82AF8DCA-6DE9-405D-BD5E-43525BDAD38A}
[2013/05/20 20:04:18 | 000,000,000 | —D | M] (No name found) – C:\Program Files (x86)\Mozilla Firefox\browser\extensions
[2013/05/20 20:04:18 | 000,000,000 | —D | M] (Default) – C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
O1 HOSTS File: ([2009/06/10 17:00:26 | 000,000,824 | —- | M]) - C:\Windows\SysNative\drivers\etc\hosts
O2:
64bit: - BHO: (Java™ Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll File not found
O2 - BHO: (Symantec NCO BHO) - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files (x86)\Norton Internet Security\Engine\18.7.2.3\coieplg.dll (Symantec Corporation)
O2 - BHO: (Symantec Intrusion Prevention) - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files (x86)\Norton Internet Security\Engine\18.7.2.3\ips\ipsbho.dll (Symantec Corporation)
O2 - BHO: (Adobe PDF Conversion Toolbar Helper) - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O2 - BHO: (Skype Plug-In) - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
O2 - BHO: (Bing Bar Helper) - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files (x86)\Microsoft\BingBar\BingExt.dll (Microsoft Corporation.)
O2 - BHO: (HP Network Check Helper) - {E76FD755-C1BA-4DCB-9F13-99BD91223ADE} - C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\HPNetworkCheckPlugin.dll (Hewlett-Packard)
O2 - BHO: (SmartSelect Class) - {F4971EE7-DAA0-4053-9964-665D8EE6A077} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O3 - HKLM\..\Toolbar: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O3 - HKLM\..\Toolbar: (Norton Toolbar) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton Internet Security\Engine\18.7.2.3\coieplg.dll (Symantec Corporation)
O3 - HKLM\..\Toolbar: (Bing Bar) - {8dcb7100-df86-4384-8842-8fa844297b3f} - C:\Program Files (x86)\Microsoft\BingBar\BingExt.dll (Microsoft Corporation.)
O3 - HKCU\..\Toolbar\WebBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O3 - HKCU\..\Toolbar\WebBrowser: (Norton Toolbar) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files (x86)\Norton Internet Security\Engine\18.7.2.3\coieplg.dll (Symantec Corporation)
O4:
64bit: - HKLM..\Run: [AdobeAAMUpdater-1.0] C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe (Adobe Systems Incorporated)
O4:
64bit: - HKLM..\Run: [HotKeysCmds] C:\Windows\SysNative\hkcmd.exe (Intel Corporation)
O4:
64bit: - HKLM..\Run: [HPWirelessAssistant] C:\Program Files\Hewlett-Packard\HP Wireless Assistant\DelayedAppStarter.exe ()
O4:
64bit: - HKLM..\Run: [IgfxTray] C:\Windows\SysNative\igfxtray.exe (Intel Corporation)
O4:
64bit: - HKLM..\Run: [IntelWireless] C:\Program Files\Common Files\Intel\WirelessCommon\iFrmewrk.exe (Intel® Corporation)
O4:
64bit: - HKLM..\Run: [Persistence] C:\Windows\SysNative\igfxpers.exe (Intel Corporation)
O4:
64bit: - HKLM..\Run: [SmartMenu] C:\Program Files\Hewlett-Packard\HP MediaSmart\SmartMenu.exe ()
O4:
64bit: - HKLM..\Run: [SysTrayApp] C:\Program Files\IDT\WDM\sttray64.exe (IDT, Inc.)
O4 - HKLM..\Run: [Acrobat Assistant 8.0] C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\Acrotray.exe (Adobe Systems Inc.)
O4 - HKLM..\Run: [Adobe Acrobat Speed Launcher] C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\Acrobat_sl.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [AdobeCS5ServiceManager] C:\Program Files (x86)\Common Files\Adobe\CS5ServiceManager\CS5ServiceManager.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [APSDaemon] C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe (Apple Inc.)
O4 - HKLM..\Run: [HP Quick Launch] C:\Program Files (x86)\Hewlett-Packard\HP Quick Launch\HPMSGSVC.exe (Hewlett-Packard Development Company, L.P.)
O4 - HKLM..\Run: [Norton Online Backup] C:\Program Files (x86)\Symantec\Norton Online Backup\NOBuClient.exe (Symantec Corporation)
O4 - HKLM..\Run: [SwitchBoard] C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe (Adobe Systems Incorporated)
O4 - HKCU..\Run: [HPAdvisorDock] C:\Program Files (x86)\Hewlett-Packard\HP Advisor\Dock\HPAdvisorDock.exe ()
O4 - HKCU..\Run: [ISUSPM] C:\ProgramData\Macrovision\FLEXnet Connect\6\ISUSPM.exe (Acresso Corporation)
O4 - Startup: C:\Users\anniecoggan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Dropbox.lnk = C:\Users\anniecoggan\AppData\Roaming\Dropbox\bin\Dropbox.exe (Dropbox, Inc.)
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktopChanges = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorAdmin = 5
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorUser = 3
O8:
64bit: - Extra context menu item: Append Link Target to Existing PDF - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:
64bit: - Extra context menu item: Append to Existing PDF - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:
64bit: - Extra context menu item: Convert Link Target to Adobe PDF - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8:
64bit: - Extra context menu item: Convert to Adobe PDF - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Append Link Target to Existing PDF - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Append to Existing PDF - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert Link Target to Adobe PDF - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert to Adobe PDF - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O9 - Extra Button: @C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\HPNetworkCheckPlugin.dll,-103 - {25510184-5A38-4A99-B273-DCA8EEF6CD08} - C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\NCLauncherFromIE.exe (Hewlett-Packard)
O9 - Extra 'Tools' menuitem : @C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\HPNetworkCheckPlugin.dll,-102 - {25510184-5A38-4A99-B273-DCA8EEF6CD08} - C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\NCLauncherFromIE.exe (Hewlett-Packard)
O9 - Extra Button: Skype Plug-In - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
O9 - Extra 'Tools' menuitem : Skype Plug-In - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
O10:
64bit: - NameSpace_Catalog5\Catalog_Entries64\000000000007 [] - C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000007 [] - C:\Program Files (x86)\Bonjour\mdnsNSP.dll (Apple Inc.)
O13
64bit: - gopher Prefix: missing
O13 - gopher Prefix: missing
O16 - DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5}
http://download.eset.com/special/eos/OnlineScanner.cab (OnlineScanner Control)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{3567351F-2F22-4A5B-8903-4DDDDA37BB2F}: DhcpNameServer = 192.168.1.1
O18:
64bit: - Protocol\Handler\livecall - No CLSID value found
O18:
64bit: - Protocol\Handler\msnim - No CLSID value found
O18:
64bit: - Protocol\Handler\skype4com - No CLSID value found
O18:
64bit: - Protocol\Handler\skype-ie-addon-data - No CLSID value found
O18:
64bit: - Protocol\Handler\wlmailhtml - No CLSID value found
O18:
64bit: - Protocol\Handler\wlpg - No CLSID value found
O18 - Protocol\Handler\ms-help - No CLSID value found
O18 - Protocol\Handler\skype4com {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files (x86)\Common Files\Skype\Skype4COM.dll (Skype Technologies)
O18 - Protocol\Handler\skype-ie-addon-data {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
O20:
64bit: - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20:
64bit: - HKLM Winlogon: UserInit - (C:\Windows\system32\userinit.exe) - C:\Windows\SysNative\userinit.exe (Microsoft Corporation)
O20:
64bit: - HKLM Winlogon: UserInit - (C:\Program Files (x86)\DigitalPersona\Bin\DPAgent.exe) - C:\Program Files (x86)\DigitalPersona\Bin\DPAgent.exe (DigitalPersona, Inc.)
O20 - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\SysWow64\explorer.exe (Microsoft Corporation)
O20 - HKLM Winlogon: UserInit - (userinit.exe) - C:\Windows\SysWow64\userinit.exe (Microsoft Corporation)
O20:
64bit: - Winlogon\Notify\igfxcui: DllName - (igfxdev.dll) - C:\Windows\SysNative\igfxdev.dll (Intel Corporation)
O21:
64bit: - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - No CLSID value found.
O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - No CLSID value found.
O33 - MountPoints2\{41e8c530-6824-11e0-9667-99ae6480590b}\Shell - "" = AutoRun
O33 - MountPoints2\{41e8c530-6824-11e0-9667-99ae6480590b}\Shell\AutoRun\command - "" = H:\LaunchU3.exe -a
O34 - HKLM BootExecute: (autocheck autochk *)
O35:
64bit: - HKLM\..comfile [open] – "%1" %*
O35:
64bit: - HKLM\..exefile [open] – "%1" %*
O35 - HKLM\..comfile [open] – "%1" %*
O35 - HKLM\..exefile [open] – "%1" %*
O37:
64bit: - HKLM\…com [@ = comfile] – "%1" %*
O37:
64bit: - HKLM\…exe [@ = exefile] – "%1" %*
O37 - HKLM\…com [@ = comfile] – "%1" %*
O37 - HKLM\…exe [@ = exefile] – "%1" %*
O38 - SubSystems\\Windows: (ServerDll=winsrv:UserServerDllInitialization,3)
O38 - SubSystems\\Windows: (ServerDll=winsrv:ConServerDllInitialization,2)
O38 - SubSystems\\Windows: (ServerDll=sxssrv,4)
[2013/06/03 14:56:21 | 000,000,000 | —D | C] – C:\Users\anniecoggan\AppData\Local\{E84B50E1-4443-4256-966A-DECA1103BB50}
[2013/06/02 16:20:16 | 000,000,000 | —D | C] – C:\Users\anniecoggan\Desktop\whatthetech
[2013/06/02 10:10:22 | 000,000,000 | —D | C] – C:\Program Files (x86)\ESET
[2013/06/02 10:01:54 | 000,000,000 | —D | C] – C:\Users\anniecoggan\AppData\Local\{1CAD4F3F-94F1-4D71-84A9-37C4FB29F6C2}
[2013/05/30 09:45:41 | 000,000,000 | —D | C] – C:\Users\anniecoggan\AppData\Roaming\Malwarebytes
[2013/05/30 09:45:32 | 000,000,000 | —D | C] – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes' Anti-Malware
[2013/05/30 09:45:32 | 000,000,000 | —D | C] – C:\ProgramData\Malwarebytes
[2013/05/30 09:45:31 | 000,025,928 | —- | C] (Malwarebytes Corporation) – C:\Windows\SysNative\drivers\mbam.sys
[2013/05/30 09:45:31 | 000,000,000 | —D | C] – C:\Program Files (x86)\Malwarebytes' Anti-Malware
[2013/05/28 16:17:14 | 000,000,000 | —D | C] – C:\Windows\ERUNT
[2013/05/28 16:17:07 | 000,000,000 | —D | C] – C:\JRT
[2013/05/23 11:35:10 | 000,000,000 | —D | C] – C:\Users\anniecoggan\Documents\teaching
[2013/05/23 07:01:49 | 000,000,000 | —D | C] – C:\_OTL
[2013/05/22 10:46:30 | 000,602,112 | —- | C] (OldTimer Tools) – C:\Users\anniecoggan\Desktop\OTL.exe
[2013/05/20 20:04:12 | 000,000,000 | —D | C] – C:\Program Files (x86)\Mozilla Firefox
[2013/05/19 18:07:00 | 000,024,416 | R— | C] (Adobe Systems Inc.) – C:\Windows\SysNative\AdobePDFUI.dll
[2013/05/19 18:04:36 | 000,000,000 | —D | C] – C:\_AcroTemp
[2013/05/18 21:11:35 | 001,054,720 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\MsSpellCheckingFacility.exe
[2013/05/18 21:11:35 | 000,719,360 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\mshtmlmedia.dll
[2013/05/18 21:11:35 | 000,226,304 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\elshyph.dll
[2013/05/18 21:11:35 | 000,185,344 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\elshyph.dll
[2013/05/18 21:11:35 | 000,163,840 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\msrating.dll
[2013/05/18 21:11:35 | 000,150,528 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\iexpress.exe
[2013/05/18 21:11:35 | 000,138,752 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\wextract.exe
[2013/05/18 21:11:35 | 000,082,432 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\inseng.dll
[2013/05/18 21:11:35 | 000,071,680 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\RegisterIEPKEYs.exe
[2013/05/18 21:11:34 | 001,441,280 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\inetcpl.cpl
[2013/05/18 21:11:34 | 001,400,416 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\ieapfltr.dat
[2013/05/18 21:11:34 | 000,690,688 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\jscript.dll
[2013/05/18 21:11:34 | 000,629,248 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\ieapfltr.dll
[2013/05/18 21:11:34 | 000,391,168 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\ieui.dll
[2013/05/18 21:11:34 | 000,361,984 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\html.iec
[2013/05/18 21:11:34 | 000,232,960 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\url.dll
[2013/05/18 21:11:34 | 000,137,216 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\ieUnatt.exe
[2013/05/18 21:11:34 | 000,125,440 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\occache.dll
[2013/05/18 21:11:34 | 000,117,248 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\iepeers.dll
[2013/05/18 21:11:34 | 000,110,592 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\IEAdvpack.dll
[2013/05/18 21:11:34 | 000,109,056 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\iesysprep.dll
[2013/05/18 21:11:34 | 000,079,872 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\mshtmled.dll
[2013/05/18 21:11:34 | 000,073,728 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\SetIEInstalledDate.exe
[2013/05/18 21:11:34 | 000,069,120 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\icardie.dll
[2013/05/18 21:11:34 | 000,061,952 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\tdc.ocx
[2013/05/18 21:11:34 | 000,061,440 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\iesetup.dll
[2013/05/18 21:11:34 | 000,057,344 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\pngfilt.dll
[2013/05/18 21:11:34 | 000,048,640 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\mshtmler.dll
[2013/05/18 21:11:34 | 000,033,280 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\iernonce.dll
[2013/05/18 21:11:34 | 000,023,040 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\licmgr10.dll
[2013/05/18 21:11:34 | 000,011,776 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\msfeedssync.exe
[2013/05/18 21:11:31 | 003,958,784 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\jscript9.dll
[2013/05/18 21:11:31 | 001,509,376 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\inetcpl.cpl
[2013/05/18 21:11:31 | 001,400,416 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\ieapfltr.dat
[2013/05/18 21:11:31 | 000,905,728 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\mshtmlmedia.dll
[2013/05/18 21:11:31 | 000,855,552 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\jscript.dll
[2013/05/18 21:11:31 | 000,762,368 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\ieapfltr.dll
[2013/05/18 21:11:31 | 000,603,136 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\msfeeds.dll
[2013/05/18 21:11:31 | 000,599,552 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\vbscript.dll
[2013/05/18 21:11:31 | 000,452,096 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\dxtmsft.dll
[2013/05/18 21:11:31 | 000,441,856 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\html.iec
[2013/05/18 21:11:31 | 000,281,600 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\dxtrans.dll
[2013/05/18 21:11:31 | 000,235,008 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\url.dll
[2013/05/18 21:11:31 | 000,216,064 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\msls31.dll
[2013/05/18 21:11:31 | 000,197,120 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\msrating.dll
[2013/05/18 21:11:31 | 000,173,568 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\ieUnatt.exe
[2013/05/18 21:11:31 | 000,167,424 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\iexpress.exe
[2013/05/18 21:11:31 | 000,149,504 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\occache.dll
[2013/05/18 21:11:31 | 000,144,896 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\wextract.exe
[2013/05/18 21:11:31 | 000,136,192 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\iepeers.dll
[2013/05/18 21:11:31 | 000,135,680 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\IEAdvpack.dll
[2013/05/18 21:11:31 | 000,102,912 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\inseng.dll
[2013/05/18 21:11:31 | 000,097,280 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\mshtmled.dll
[2013/05/18 21:11:31 | 000,092,160 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\SetIEInstalledDate.exe
[2013/05/18 21:11:31 | 000,089,600 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\RegisterIEPKEYs.exe
[2013/05/18 21:11:31 | 000,081,408 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\icardie.dll
[2013/05/18 21:11:31 | 000,067,072 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\iesetup.dll
[2013/05/18 21:11:31 | 000,062,976 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\pngfilt.dll
[2013/05/18 21:11:31 | 000,051,712 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\ie4uinit.exe
[2013/05/18 21:11:31 | 000,051,200 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\imgutil.dll
[2013/05/18 21:11:31 | 000,039,936 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\iernonce.dll
[2013/05/18 21:11:31 | 000,027,648 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\licmgr10.dll
[2013/05/18 21:11:31 | 000,013,824 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\mshta.exe
[2013/05/18 21:11:31 | 000,012,800 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\msfeedssync.exe
[2013/05/18 21:11:30 | 000,526,336 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\ieui.dll
[2013/05/18 21:11:30 | 000,136,704 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\iesysprep.dll
[2013/05/18 21:11:30 | 000,077,312 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\tdc.ocx
[2013/05/18 21:11:30 | 000,048,640 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\mshtmler.dll
[2013/05/18 20:48:17 | 002,776,576 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\msmpeg2vdec.dll
[2013/05/18 20:48:17 | 002,284,544 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\msmpeg2vdec.dll
[2013/05/18 20:48:17 | 000,221,184 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\UIAnimation.dll
[2013/05/18 20:48:17 | 000,187,392 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\UIAnimation.dll
[2013/05/18 20:48:16 | 000,465,920 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\WMPhoto.dll
[2013/05/18 20:48:16 | 000,417,792 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\WMPhoto.dll
[2013/05/18 20:48:13 | 002,565,120 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\d3d10warp.dll
[2013/05/18 20:48:13 | 000,522,752 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\XpsGdiConverter.dll
[2013/05/18 20:48:13 | 000,364,544 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\XpsGdiConverter.dll
[2013/05/18 20:48:13 | 000,194,560 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\d3d10_1.dll
[2013/05/18 20:48:13 | 000,010,752 | -H– | C] (Microsoft Corporation) – C:\Windows\SysWow64\api-ms-win-downlevel-advapi32-l1-1-0.dll
[2013/05/18 20:48:13 | 000,010,752 | -H– | C] (Microsoft Corporation) – C:\Windows\SysNative\api-ms-win-downlevel-advapi32-l1-1-0.dll
[2013/05/18 20:48:13 | 000,009,728 | -H– | C] (Microsoft Corporation) – C:\Windows\SysWow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
[2013/05/18 20:48:13 | 000,009,728 | -H– | C] (Microsoft Corporation) – C:\Windows\SysNative\api-ms-win-downlevel-shlwapi-l1-1-0.dll
[2013/05/18 20:48:13 | 000,003,584 | -H– | C] (Microsoft Corporation) – C:\Windows\SysWow64\api-ms-win-downlevel-advapi32-l2-1-0.dll
[2013/05/18 20:48:13 | 000,003,584 | -H– | C] (Microsoft Corporation) – C:\Windows\SysNative\api-ms-win-downlevel-advapi32-l2-1-0.dll
[2013/05/18 20:48:13 | 000,003,072 | -H– | C] (Microsoft Corporation) – C:\Windows\SysWow64\api-ms-win-downlevel-version-l1-1-0.dll
[2013/05/18 20:48:13 | 000,003,072 | -H– | C] (Microsoft Corporation) – C:\Windows\SysNative\api-ms-win-downlevel-version-l1-1-0.dll
[2013/05/18 20:48:13 | 000,002,560 | -H– | C] (Microsoft Corporation) – C:\Windows\SysWow64\api-ms-win-downlevel-normaliz-l1-1-0.dll
[2013/05/18 20:48:13 | 000,002,560 | -H– | C] (Microsoft Corporation) – C:\Windows\SysNative\api-ms-win-downlevel-normaliz-l1-1-0.dll
[2013/05/18 20:48:12 | 001,887,232 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\d3d11.dll
[2013/05/18 20:48:12 | 001,682,432 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\XpsPrint.dll
[2013/05/18 20:48:12 | 001,504,768 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\d3d11.dll
[2013/05/18 20:48:12 | 001,238,528 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\d3d10.dll
[2013/05/18 20:48:12 | 001,158,144 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\XpsPrint.dll
[2013/05/18 20:48:12 | 000,648,192 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\d3d10level9.dll
[2013/05/18 20:48:12 | 000,363,008 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\dxgi.dll
[2013/05/18 20:48:12 | 000,333,312 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\d3d10_1core.dll
[2013/05/18 20:48:12 | 000,296,960 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\d3d10core.dll
[2013/05/18 20:48:12 | 000,005,632 | -H– | C] (Microsoft Corporation) – C:\Windows\SysWow64\api-ms-win-downlevel-shlwapi-l2-1-0.dll
[2013/05/18 20:48:12 | 000,005,632 | -H– | C] (Microsoft Corporation) – C:\Windows\SysNative\api-ms-win-downlevel-shlwapi-l2-1-0.dll
[2013/05/18 20:48:12 | 000,005,632 | -H– | C] (Microsoft Corporation) – C:\Windows\SysWow64\api-ms-win-downlevel-ole32-l1-1-0.dll
[2013/05/18 20:48:12 | 000,005,632 | -H– | C] (Microsoft Corporation) – C:\Windows\SysNative\api-ms-win-downlevel-ole32-l1-1-0.dll
[2013/05/18 20:48:12 | 000,004,096 | -H– | C] (Microsoft Corporation) – C:\Windows\SysWow64\api-ms-win-downlevel-user32-l1-1-0.dll
[2013/05/18 20:48:12 | 000,004,096 | -H– | C] (Microsoft Corporation) – C:\Windows\SysNative\api-ms-win-downlevel-user32-l1-1-0.dll
[2013/05/18 20:48:12 | 000,003,072 | -H– | C] (Microsoft Corporation) – C:\Windows\SysWow64\api-ms-win-downlevel-shell32-l1-1-0.dll
[2013/05/18 20:48:12 | 000,003,072 | -H– | C] (Microsoft Corporation) – C:\Windows\SysNative\api-ms-win-downlevel-shell32-l1-1-0.dll
[2013/05/18 20:48:11 | 003,928,064 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\d2d1.dll
[2013/05/18 20:48:11 | 001,643,520 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\DWrite.dll
[2013/05/18 20:48:11 | 001,424,384 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\WindowsCodecs.dll
[2013/05/18 20:48:11 | 000,245,248 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\WindowsCodecsExt.dll
[2013/05/18 20:44:46 | 000,000,000 | —D | C] – C:\Program Files (x86)\Common Files\Java
[2013/05/18 20:44:19 | 000,263,584 | —- | C] (Oracle Corporation) – C:\Windows\SysWow64\javaws.exe
[2013/05/18 20:43:42 | 000,174,496 | —- | C] (Oracle Corporation) – C:\Windows\SysWow64\javaw.exe
[2013/05/18 20:43:42 | 000,174,496 | —- | C] (Oracle Corporation) – C:\Windows\SysWow64\java.exe
[2013/05/18 20:43:42 | 000,095,648 | —- | C] (Oracle Corporation) – C:\Windows\SysWow64\WindowsAccessBridge-32.dll
[2013/05/18 14:24:48 | 000,000,000 | —D | C] – C:\Users\anniecoggan\Desktop\desktop stuff
[2013/05/18 13:41:40 | 000,000,000 | —D | C] – C:\Windows\CheckSur
[2013/05/15 15:14:52 | 000,265,064 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\drivers\dxgmms1.sys
[2013/05/15 15:14:52 | 000,144,384 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\cdd.dll
[2013/05/15 15:14:26 | 001,930,752 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\authui.dll
[2013/05/15 15:14:26 | 000,197,120 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\shdocvw.dll
[2013/05/15 15:14:25 | 001,796,096 | —- | C] (Microsoft Corporation) – C:\Windows\SysWow64\authui.dll
[2013/05/15 15:14:25 | 000,111,448 | —- | C] (Microsoft Corporation) – C:\Windows\SysNative\consent.exe
[2013/06/03 14:51:24 | 000,023,248 | -H– | M] () – C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0
[2013/06/03 14:51:24 | 000,023,248 | -H– | M] () – C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0
[2013/06/03 14:43:49 | 000,067,584 | –S- | M] () – C:\Windows\bootstat.dat
[2013/06/03 14:43:39 | 3062,255,616 | -HS- | M] () – C:\hiberfil.sys
[2013/06/03 14:35:26 | 000,000,830 | —- | M] () – C:\Windows\tasks\Adobe Flash Player Updater.job
[2013/06/03 12:41:35 | 000,340,332 | —- | M] () – C:\Users\anniecoggan\Desktop\year of the rabbit sketch.jpg
[2013/06/03 07:44:24 | 000,645,039 | —- | M] () – C:\Users\anniecoggan\Desktop\GarsonYu.jpg
[2013/06/02 10:03:54 | 000,000,426 | —- | M] () – C:\Windows\BRWMARK.INI
[2013/06/02 10:03:54 | 000,000,034 | —- | M] () – C:\Windows\SysWow64\BD7820N.DAT
[2013/05/30 09:54:45 | 000,001,113 | —- | M] () – C:\Users\Public\Desktop\Malwarebytes Anti-Malware.lnk
[2013/05/30 09:00:28 | 000,031,232 | —- | M] () – C:\Users\anniecoggan\Desktop\Your YLighting Order #YL-261011.msg
[2013/05/30 08:48:14 | 000,067,815 | —- | M] () – C:\Users\anniecoggan\Desktop\Coggan and Crawford Architecture Design - G2145058.pdf
[2013/05/30 07:05:10 | 000,879,774 | —- | M] () – C:\Users\anniecoggan\Desktop\Edward Hopper.jpg
[2013/05/29 09:40:19 | 000,304,876 | —- | M] () – C:\Users\anniecoggan\Desktop\knoll lux fabric.jpg
[2013/05/29 08:46:28 | 000,102,559 | —- | M] () – C:\Users\anniecoggan\Desktop\uncomfortable workshop.jpg
[2013/05/28 16:58:16 | 000,744,030 | —- | M] () – C:\Windows\SysNative\PerfStringBackup.INI
[2013/05/28 16:58:16 | 000,627,354 | —- | M] () – C:\Windows\SysNative\perfh009.dat
[2013/05/28 16:58:16 | 000,107,638 | —- | M] () – C:\Windows\SysNative\perfc009.dat
[2013/05/23 12:07:03 | 000,141,006 | —- | M] () – C:\Users\anniecoggan\Desktop\116_3_Eval.pdf
[2013/05/23 09:31:27 | 000,200,531 | —- | M] () – C:\Users\anniecoggan\Desktop\Martin-flooring 130523.pdf
[2013/05/22 10:46:31 | 000,602,112 | —- | M] (OldTimer Tools) – C:\Users\anniecoggan\Desktop\OTL.exe
[2013/05/21 11:43:59 | 000,000,356 | —- | M] () – C:\Windows\tasks\HPCeeScheduleForanniecoggan.job
[2013/05/20 20:23:50 | 000,002,048 | —- | M] () – C:\Users\anniecoggan\Application Data\Microsoft\Internet Explorer\Quick Launch\Mozilla Firefox.lnk
[2013/05/19 17:47:20 | 000,002,019 | —- | M] () – C:\Users\Public\Desktop\Adobe Reader XI.lnk
[2013/05/19 07:43:48 | 000,063,256 | —- | M] () – C:\Users\anniecoggan\Desktop\windows update fail 130519.pdf
[2013/05/18 21:30:48 | 000,001,253 | —- | M] () – C:\Users\anniecoggan\Desktop\Downloads - Shortcut.lnk
[2013/05/18 21:11:35 | 001,054,720 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\MsSpellCheckingFacility.exe
[2013/05/18 21:11:35 | 000,719,360 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\mshtmlmedia.dll
[2013/05/18 21:11:35 | 000,226,304 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\elshyph.dll
[2013/05/18 21:11:35 | 000,185,344 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\elshyph.dll
[2013/05/18 21:11:35 | 000,163,840 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\msrating.dll
[2013/05/18 21:11:35 | 000,150,528 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\iexpress.exe
[2013/05/18 21:11:35 | 000,138,752 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\wextract.exe
[2013/05/18 21:11:35 | 000,082,432 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\inseng.dll
[2013/05/18 21:11:35 | 000,071,680 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\RegisterIEPKEYs.exe
[2013/05/18 21:11:34 | 001,441,280 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\inetcpl.cpl
[2013/05/18 21:11:34 | 001,400,416 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\ieapfltr.dat
[2013/05/18 21:11:34 | 000,690,688 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\jscript.dll
[2013/05/18 21:11:34 | 000,629,248 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\ieapfltr.dll
[2013/05/18 21:11:34 | 000,391,168 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\ieui.dll
[2013/05/18 21:11:34 | 000,361,984 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\html.iec
[2013/05/18 21:11:34 | 000,232,960 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\url.dll
[2013/05/18 21:11:34 | 000,137,216 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\ieUnatt.exe
[2013/05/18 21:11:34 | 000,125,440 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\occache.dll
[2013/05/18 21:11:34 | 000,117,248 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\iepeers.dll
[2013/05/18 21:11:34 | 000,110,592 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\IEAdvpack.dll
[2013/05/18 21:11:34 | 000,109,056 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\iesysprep.dll
[2013/05/18 21:11:34 | 000,079,872 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\mshtmled.dll
[2013/05/18 21:11:34 | 000,073,728 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\SetIEInstalledDate.exe
[2013/05/18 21:11:34 | 000,069,120 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\icardie.dll
[2013/05/18 21:11:34 | 000,061,952 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\tdc.ocx
[2013/05/18 21:11:34 | 000,061,440 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\iesetup.dll
[2013/05/18 21:11:34 | 000,057,344 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\pngfilt.dll
[2013/05/18 21:11:34 | 000,048,640 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\mshtmler.dll
[2013/05/18 21:11:34 | 000,033,280 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\iernonce.dll
[2013/05/18 21:11:34 | 000,025,185 | —- | M] () – C:\Windows\SysWow64\ieuinit.inf
[2013/05/18 21:11:34 | 000,023,040 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\licmgr10.dll
[2013/05/18 21:11:34 | 000,011,776 | —- | M] (Microsoft Corporation) – C:\Windows\SysWow64\msfeedssync.exe
[2013/05/18 21:11:32 | 000,089,600 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\RegisterIEPKEYs.exe
[2013/05/18 21:11:31 | 003,958,784 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\jscript9.dll
[2013/05/18 21:11:31 | 001,509,376 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\inetcpl.cpl
[2013/05/18 21:11:31 | 001,400,416 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\ieapfltr.dat
[2013/05/18 21:11:31 | 000,905,728 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\mshtmlmedia.dll
[2013/05/18 21:11:31 | 000,855,552 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\jscript.dll
[2013/05/18 21:11:31 | 000,762,368 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\ieapfltr.dll
[2013/05/18 21:11:31 | 000,603,136 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\msfeeds.dll
[2013/05/18 21:11:31 | 000,599,552 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\vbscript.dll
[2013/05/18 21:11:31 | 000,452,096 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\dxtmsft.dll
[2013/05/18 21:11:31 | 000,441,856 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\html.iec
[2013/05/18 21:11:31 | 000,281,600 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\dxtrans.dll
[2013/05/18 21:11:31 | 000,235,008 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\url.dll
[2013/05/18 21:11:31 | 000,216,064 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\msls31.dll
[2013/05/18 21:11:31 | 000,197,120 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\msrating.dll
[2013/05/18 21:11:31 | 000,173,568 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\ieUnatt.exe
[2013/05/18 21:11:31 | 000,167,424 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\iexpress.exe
[2013/05/18 21:11:31 | 000,149,504 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\occache.dll
[2013/05/18 21:11:31 | 000,144,896 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\wextract.exe
[2013/05/18 21:11:31 | 000,136,192 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\iepeers.dll
[2013/05/18 21:11:31 | 000,135,680 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\IEAdvpack.dll
[2013/05/18 21:11:31 | 000,102,912 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\inseng.dll
[2013/05/18 21:11:31 | 000,097,280 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\mshtmled.dll
[2013/05/18 21:11:31 | 000,092,160 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\SetIEInstalledDate.exe
[2013/05/18 21:11:31 | 000,081,408 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\icardie.dll
[2013/05/18 21:11:31 | 000,067,072 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\iesetup.dll
[2013/05/18 21:11:31 | 000,062,976 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\pngfilt.dll
[2013/05/18 21:11:31 | 000,051,712 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\ie4uinit.exe
[2013/05/18 21:11:31 | 000,051,200 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\imgutil.dll
[2013/05/18 21:11:31 | 000,039,936 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\iernonce.dll
[2013/05/18 21:11:31 | 000,027,648 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\licmgr10.dll
[2013/05/18 21:11:31 | 000,025,185 | —- | M] () – C:\Windows\SysNative\ieuinit.inf
[2013/05/18 21:11:31 | 000,013,824 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\mshta.exe
[2013/05/18 21:11:31 | 000,012,800 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\msfeedssync.exe
[2013/05/18 21:11:30 | 000,526,336 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\ieui.dll
[2013/05/18 21:11:30 | 000,136,704 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\iesysprep.dll
[2013/05/18 21:11:30 | 000,077,312 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\tdc.ocx
[2013/05/18 21:11:30 | 000,048,640 | —- | M] (Microsoft Corporation) – C:\Windows\SysNative\mshtmler.dll
[2013/05/18 20:43:33 | 000,095,648 | —- | M] (Oracle Corporation) – C:\Windows\SysWow64\WindowsAccessBridge-32.dll
[2013/05/18 20:43:32 | 000,866,720 | —- | M] (Oracle Corporation) – C:\Windows\SysWow64\npdeployJava1.dll
[2013/05/18 20:43:32 | 000,788,896 | —- | M] (Oracle Corporation) – C:\Windows\SysWow64\deployJava1.dll
[2013/05/18 20:43:32 | 000,263,584 | —- | M] (Oracle Corporation) – C:\Windows\SysWow64\javaws.exe
[2013/05/18 20:43:32 | 000,174,496 | —- | M] (Oracle Corporation) – C:\Windows\SysWow64\javaw.exe
[2013/05/18 20:43:32 | 000,174,496 | —- | M] (Oracle Corporation) – C:\Windows\SysWow64\java.exe
[2013/05/14 14:21:25 | 000,692,104 | —- | M] (Adobe Systems Incorporated) – C:\Windows\SysWow64\FlashPlayerApp.exe
[2013/05/14 14:21:25 | 000,071,048 | —- | M] (Adobe Systems Incorporated) – C:\Windows\SysWow64\FlashPlayerCPLApp.cpl
[2013/05/08 11:48:09 | 000,850,398 | —- | M] () – C:\Users\anniecoggan\Documents\Annie Coggan transcript request.jpg
[2013/06/03 12:41:34 | 000,340,332 | —- | C] () – C:\Users\anniecoggan\Desktop\year of the rabbit sketch.jpg
[2013/06/03 07:44:21 | 000,645,039 | —- | C] () – C:\Users\anniecoggan\Desktop\GarsonYu.jpg
[2013/05/30 09:45:33 | 000,001,113 | —- | C] () – C:\Users\Public\Desktop\Malwarebytes Anti-Malware.lnk
[2013/05/30 09:00:28 | 000,031,232 | —- | C] () – C:\Users\anniecoggan\Desktop\Your YLighting Order #YL-261011.msg
[2013/05/30 08:48:13 | 000,067,815 | —- | C] () – C:\Users\anniecoggan\Desktop\Coggan and Crawford Architecture Design - G2145058.pdf
[2013/05/30 07:05:07 | 000,879,774 | —- | C] () – C:\Users\anniecoggan\Desktop\Edward Hopper.jpg
[2013/05/29 09:40:16 | 000,304,876 | —- | C] () – C:\Users\anniecoggan\Desktop\knoll lux fabric.jpg
[2013/05/29 08:46:26 | 000,102,559 | —- | C] () – C:\Users\anniecoggan\Desktop\uncomfortable workshop.jpg
[2013/05/23 12:07:02 | 000,141,006 | —- | C] () – C:\Users\anniecoggan\Desktop\116_3_Eval.pdf
[2013/05/23 09:31:27 | 000,200,531 | —- | C] () – C:\Users\anniecoggan\Desktop\Martin-flooring 130523.pdf
[2013/05/19 17:47:19 | 000,002,441 | —- | C] () – C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Reader XI.lnk
[2013/05/19 17:47:19 | 000,002,019 | —- | C] () – C:\Users\Public\Desktop\Adobe Reader XI.lnk
[2013/05/19 07:43:48 | 000,063,256 | —- | C] () – C:\Users\anniecoggan\Desktop\windows update fail 130519.pdf
[2013/05/18 21:30:48 | 000,001,253 | —- | C] () – C:\Users\anniecoggan\Desktop\Downloads - Shortcut.lnk
[2013/05/18 21:11:34 | 000,025,185 | —- | C] () – C:\Windows\SysWow64\ieuinit.inf
[2013/05/18 21:11:31 | 000,025,185 | —- | C] () – C:\Windows\SysNative\ieuinit.inf
[2013/05/08 11:51:52 | 000,850,398 | —- | C] () – C:\Users\anniecoggan\Documents\Annie Coggan transcript request.jpg
[2012/08/06 14:35:01 | 000,000,126 | —- | C] () – C:\Windows\QUICKEN.INI
[2011/06/14 18:19:51 | 000,000,056 | -H– | C] () – C:\ProgramData\ezsidmv.dat
[2011/02/09 16:29:07 | 000,001,854 | —- | C] () – C:\Users\anniecoggan\AppData\Roaming\GhostObjGAFix.xml
[2011/01/21 15:27:16 | 000,000,104 | —- | C] () – C:\Users\anniecoggan\Default Programs - Shortcut.lnk
========== ZeroAccess Check ==========
[2009/07/14 00:55:00 | 000,000,227 | RHS- | M] () – C:\Windows\assembly\Desktop.ini
[HKEY_CURRENT_USER\Software\Classes\clsid\{42aedc87-2188-41fd-b9a3-0c966feabec1}\InProcServer32] /64
[HKEY_CURRENT_USER\Software\Classes\Wow6432node\clsid\{42aedc87-2188-41fd-b9a3-0c966feabec1}\InProcServer32]
[HKEY_CURRENT_USER\Software\Classes\clsid\{fbeb8a05-beee-4442-804e-409d6c4515e9}\InProcServer32] /64
[HKEY_CURRENT_USER\Software\Classes\Wow6432node\clsid\{fbeb8a05-beee-4442-804e-409d6c4515e9}\InProcServer32]
[HKEY_LOCAL_MACHINE\Software\Classes\clsid\{42aedc87-2188-41fd-b9a3-0c966feabec1}\InProcServer32] /64
"" = C:\Windows\SysNative\shell32.dll – [2013/02/27 01:52:56 | 014,172,672 | —- | M] (Microsoft Corporation)
"ThreadingModel" = Apartment
[HKEY_LOCAL_MACHINE\Software\Wow6432Node\Classes\clsid\{42aedc87-2188-41fd-b9a3-0c966feabec1}\InProcServer32]
"" = %SystemRoot%\system32\shell32.dll – [2013/02/27 00:55:05 | 012,872,704 | —- | M] (Microsoft Corporation)
[HKEY_LOCAL_MACHINE\Software\Classes\clsid\{5839FCA9-774D-42A1-ACDA-D6A79037F57F}\InProcServer32] /64
"" = C:\Windows\SysNative\wbem\fastprox.dll – [2009/07/13 21:40:51 | 000,909,312 | —- | M] (Microsoft Corporation)
"ThreadingModel" = Free
[HKEY_LOCAL_MACHINE\Software\Wow6432Node\Classes\clsid\{5839FCA9-774D-42A1-ACDA-D6A79037F57F}\InProcServer32]
"" = %systemroot%\system32\wbem\fastprox.dll – [2010/11/20 08:19:02 | 000,606,208 | —- | M] (Microsoft Corporation)
[HKEY_LOCAL_MACHINE\Software\Classes\clsid\{F3130CDB-AA52-4C3A-AB32-85FFC23AF9C1}\InProcServer32] /64
"" = C:\Windows\SysNative\wbem\wbemess.dll – [2009/07/13 21:41:56 | 000,505,856 | —- | M] (Microsoft Corporation)
"ThreadingModel" = Both
[HKEY_LOCAL_MACHINE\Software\Wow6432Node\Classes\clsid\{F3130CDB-AA52-4C3A-AB32-85FFC23AF9C1}\InProcServer32]
