Computer will only boot in safe mode [Closed]
21 min read
I finally turned my computer on to do this today and have gotten the BSOD twice before I can get anything accomplished. I attempted to do a scan disk and got another BSOD
Hi ericaps
We Need to Diagnose Your BlueScreen
  • When you boot your machine, press F8 to list the startup options, exactly as you would if you were trying to enter Safe Mode
  • Select "Disable Automatic Restart on System Failure", as shown here:
  • When your system BSODs, write down the STOP error code, as well as any written out error message back here. The STOP error will always appear, but the message may not. You are looking for this:
Please post me the error(s).
there was not a message where you have the top box only the bottom one it says Technical information: *** STOP:0x0000007e (0xC0000005, 0x82686598, 0x8B76FB8C, 0x8B76F888)
Hi ericaps
Download SysInternals AutoRuns from Microsoft TechNet and SAVE to your My Documents folder.
Download the zip file below and extract the batch file to your desktop. 2x-click on desktop batch file icon and let it run. It will gather mini dumps and system information. You will see the black cmd screen appear with status info. It may take 3 - 5 minutes to finish. Your only interaction with it should be to "Accept" AutoRuns if/when asked to do so.
Upon completion, go to your documents folder and zip up the newly created folder named . Attach it to your next post.
Hi ericaps ;)
Im having trouble finding the file that it creates after it is done.
Hi ericaps ;)
Welcome back :)
I am really unsure if I did this last step correctly
Ok no problem.
I have a question
Please let me know if you have updated your driver some time ago. :wavey:
