PC Slow (10-15+ mins) Startup, Longer for Desktop Access [Solved]
69 min read
Hi there,
I am having major trouble starting up my computer properly. It takes more than 10-15 minutes to log into Windows (XP) and even longer than that for the PC to have all functions running at a decent speed (with the Explorer bar at the bottom loaded up and working, access to My Documents / My Computer working, etc.).
I also got an email recently from my ISP (Comcast) saying they suspect a computer using my home wireless network (there are 4 of us at my house) is infected by a bot. I ran a full scan using Symantec Endpoint Protection, Malwarebytes and did a cleanup scan using CCleaner. No viruses/malware were detected.
Any help looking over my HijackThis log for problems is much appreciated!
My PC info:
MS Windows XP Professional SP3
AMD Athlon 64 X2 Dual Core 4800+
2 GB RAM, Nvidia GeForce 7900 GS
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 8:55:18 AM, on 9/5/2012
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
C:\DOCUME~1\Basilio\LOCALS~1\temp\vpninst\INSTAL~1.EXE
C:\WINDOWS\system32\msiexec.exe
C:\WINDOWS\system32\devldr32.exe
C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\ccSvcHst.exe
C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
C:\Program Files\PC Connectivity Solution\Transports\NclUSBSrv.exe
C:\WINDOWS\system32\SNDVOL32.EXE
C:\WINDOWS\explorer.exe
C:\Program Files\Nero\Nero 7\Core\nero.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
C:\Program Files\Handbrake\Handbrake.exe
C:\Program Files\Handbrake\HandBrakeCLI.exe
C:\Program Files\MP3Gain\MP3GainGUI.exe
C:\Program Files\Google\Chrome\Application\chrome.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\Trend Micro\HijackThis\HiJackThis.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=127.0.0.1:6092
R3 - URLSearchHook: Vuze Remote Toolbar - {ba14329e-9550-4989-b3f2-9732e92d17cc} - C:\Program Files\Vuze_Remote\prxtbVuz0.dll
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Increase performance and video formats for your HTML5 - {326E768D-4182-46FD-9C16-1449A49795F4} - C:\Program Files\DivX\DivX Plus Web Player\ie\DivXHTML5\DivXHTML5.dll
O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\bin\IPS\IPSBHO.DLL
O2 - BHO: Java™ Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O2 - BHO: SkypeIEPluginBHO - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll
O2 - BHO: Vuze Remote - {ba14329e-9550-4989-b3f2-9732e92d17cc} - C:\Program Files\Vuze_Remote\prxtbVuz0.dll
O2 - BHO: Java™ Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: Vuze Remote Toolbar - {ba14329e-9550-4989-b3f2-9732e92d17cc} - C:\Program Files\Vuze_Remote\prxtbVuz0.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [UserFaultCheck] %systemroot%\system32\dumprep 0 -u
O4 - HKCU\..\Run: [NokiaSuite.exe] C:\Program Files\Nokia\Nokia Suite\NokiaSuite.exe -tray
O4 - HKUS\S-1-5-18\..\Run: [DWQueuedReporting] "C:\PROGRA~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" -t (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [DWQueuedReporting] "C:\PROGRA~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" -t (User 'Default user')
O8 - Extra context menu item: &Download All using 4shared Desktop - C:\Program Files\4shared\down_all.htm
O8 - Extra context menu item: Convert link target to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert to existing PDF - res://C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O8 - Extra context menu item: I&M Chat - C:\Program Files\Nokia Siemens Networks\Communication Suite\scripts\call_imscript.htm
O8 - Extra context menu item: V&oice Call - C:\Program Files\Nokia Siemens Networks\Communication Suite\scripts\call_voicescript.htm
O8 - Extra context menu item: Vi&deo Call - C:\Program Files\Nokia Siemens Networks\Communication Suite\scripts\call_videoscript.htm
O9 - Extra button: Skype Click to Call - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
O16 - DPF: {1E54D648-B804-468d-BC78-4AFFED8E262F} (System Requirements Lab) - http://www.nvidia.com/content/DriverDownlo…sreqlab_nvd.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/…b?1240165719013
O16 - DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} (OnlineScanner Control) - http://download.eset.com/special/eos/OnlineScanner.cab
O16 - DPF: {784797A8-342D-4072-9486-03C8D0F2F0A1} (Battlefield Heroes Updater) - https://www.battlefieldheroes.com/static/up…er_5.0.67.0.cab
O16 - DPF: {8C28EFD7-767B-11D1-844B-0060972DC2AC} - https://brioportal.adcom.its.nyu.edu:7411/H…htNoHelp.en.cab
O18 - Protocol: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files\Skype\Toolbars\Internet Explorer\skypeieplugin.dll
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
O18 - Filter hijack: text/html - {a1577fde-3b33-480e-8b53-47a8cfaf1853} - (no file)
O20 - Winlogon Notify: SEP - C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\WinLogoutNotifier.dll (file missing)
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\System32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\System32\browseui.dll
O23 - Service: Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) - Adobe Systems Incorporated - C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Cisco Systems, Inc. Installer service (CiscoVpnInstallService) - Unknown owner - C:\DOCUME~1\Basilio\LOCALS~1\temp\vpninst\INSTAL~1.EXE
O23 - Service: Google Update Service (gupdate1c9e6304563b6d2) (gupdate1c9e6304563b6d2) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Update Service (gupdatem) (gupdatem) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: Mozilla Maintenance Service (MozillaMaintenance) - Mozilla Foundation - C:\Program Files\Mozilla Maintenance Service\maintenanceservice.exe
O23 - Service: Symantec Endpoint Protection (SepMasterService) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\ccSvcHst.exe
O23 - Service: ServiceLayer - Nokia - C:\Program Files\PC Connectivity Solution\ServiceLayer.exe
O23 - Service: Skype C2C Service - Skype Technologies S.A. - C:\Documents and Settings\All Users\Application Data\Skype\Toolbars\Skype C2C Service\c2c_service.exe
O23 - Service: Skype Updater (SkypeUpdate) - Skype Technologies - C:\Program Files\Skype\Updater\Updater.exe
O23 - Service: Symantec Management Client (SmcService) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\Smc.exe
O23 - Service: Symantec Network Access Control (SNAC) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\snac.exe
Hello and Posted Image
My name is patndoris. I will be glad to take a look at your log and help you with solving any malware problems. It will be very helpful if you follow these guidelines:
  • Malware logs are often lengthy and can take a lot of time to research and interpret. Please be patient while I review your logs.
  • Please note that there is no "Quick Fix" to modern malware infections and we may need to use several different approaches to get your system clean.
  • Please make sure to carefully read any instruction that I give you. If you're not sure, or if something unexpected happens, do NOT continue! Stop and ask!
  • Please follow my instructions carefully and in the order they are posted. You may also find it helpful to print out the instructions you receive.
  • Please do not run any scans or install/uninstall any applications or delete anything without being directed to do so.
  • Remember, absence of symptoms does not mean the infection is all gone. Please stick with me till you're given the "all clear".
  • Please do not use the Attachment feature for any log file. Do a Copy/Paste of the entire contents of the log file and submit it inside your post.
  • Please reply within 3 days. If I do not hear back from you in that time frame, I will post a reminder for you. Topics with no reply in 4 days are closed!
Run Hijack This
  • Double click on the icon on your desktop to launch Hijack This
  • Click on the Scan button
  • When the scan has finished, please put a check in the box next to the following item:
  • Make sure all other windows, including your browser are closed, and then click on the Fix Checked button
If you are not prompted to do so, please reboot your computer after the fix has completed.
Then I'd like to get a couple more diagnostic scans. Since you received a notice from your ISP we are definitely going to run a couple more tools, but I'd like to get a better look to be sure we get everything.
HijackThis has largely been replaced by other tools. Since being acquired by TrendMicro, HijackThis has not been regularly updated. Many infections are now able to hide partly, or completely from a HijackThis scan. DDS includes all the scan locations of HijackThis and more.
Download and Run DDS by sUBs
We need to see some information about what is happening in your machine. Please perform the following scan:
  • Download DDS by sUBs from one of the following links. Save it to your desktop.
    • DDS.com
    • DDS.pif
  • Double click on the DDS icon, allow it to run.
  • A small box will open, with an explaination about the tool. No input is needed, the scan is running.
  • Notepad will open with the results.
  • Follow the instructions that pop up for posting the results.
  • Close the program window, and delete the program from your desktop.
Please note: You may have to disable any script protection running if the scan fails to run. After downloading the tool, disconnect from the internet and disable all antivirus protection. Run the scan, enable your A/V and reconnect to the internet.
Information on A/V control HERE
Please read carefully and follow these steps. There is a difference between what you see in one of the images below and what I need you to do.
We are only creating a log - I do NOT want you to "cure" or try to fix anything in this step. It is very important that you don't choose Cure when presented with that option.
  • Download TDSSKiller and save it to your Desktop.
  • Extract its contents to your desktop.
  • Once extracted, open the TDSSKiller folder and doubleclick on TDSSKiller.exe to run the application, then on Start Scan.
    🖼Click to load external image (Posted Image)
  • If an infected file is detected, the default action will be Cure but I want you to choose SKIP instead , click on Continue.
  • If a suspicious file is detected, the default action will be Skip, click on Continue.
  • It may ask you to reboot the computer to complete the process. Click on Reboot Now.
  • If no reboot is require, click on Report. A log file should appear. Please copy and paste the contents of that file here.
  • If a reboot is required, the report can also be found in your root directory, (usually C:\ folder) in the form of "TDSSKiller.[Version]_[Date]_[Time]_log.txt". Please copy and paste the contents of that file here.
Hi Patndoris, Thank you very much for replying to my inquiry! I am sorry I responded so slowly; I hadn't checked the thread over the weekend. I will do exactly as you say above and let you know the results; it will likely be by this Tuesday (9/11) evening. Thanks again for taking the time out to do this.
Hi Patndoris, I've followed the first part of your instructions, which involve using the DDS program. As the program instructs, I am posting the contents of the text file below. I also have the "Attach.txt" file it created - do let me know if you want me to attach that file as well (it says in the DDS instructions to only post it if you request it). I will now move on down through your instructions! Thanks for your help through this process; I really appreciate it. ———————– . DDS (Ver_2011-08-26.01) - NTFSx86 Internet Explorer: 8.0.6001.18702 BrowserJavaVersion: 1.6.0_31 Run by [removed] at 0:19:27 on 2012-09-12 Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.2047.1368 [GMT -4:00] . AV: *Enabled/Updated* {FB06448E-52B8-493A-90F3-E43226D3305C} . ============== Running Processes =============== . C:\WINDOWS\system32\svchost -k DcomLaunch svchost.exe C:\WINDOWS\System32\svchost.exe -k netsvcs C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup svchost.exe svchost.exe C:\WINDOWS\Explorer.EXE svchost.exe C:\WINDOWS\system32\devldr32.exe C:\WINDOWS\system32\ctfmon.exe C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\ccSvcHst.exe C:\Program Files\Skype\Updater\Updater.exe C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\Smc.exe C:\WINDOWS\system32\SearchIndexer.exe C:\WINDOWS\System32\svchost.exe -k imgsvc C:\WINDOWS\system32\SearchProtocolHost.exe . ============== Pseudo HJT Report =============== . uStart Page = hxxp://www.google.com/ mStart Page = hxxp://www.yahoo.com uInternet Settings,ProxyOverride = ;*.local uURLSearchHooks: Vuze Remote Toolbar: {ba14329e-9550-4989-b3f2-9732e92d17cc} - c:\program files\vuze_remote\prxtbVuz2.dll BHO: {02478D38-C3F9-4efb-9B51-7695ECA05670} - No File BHO: Adobe PDF Reader Link Helper: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelper.dll BHO: Adobe PDF Link Helper: {18df081c-e8ad-4283-a596-fa578c2ebdc3} - c:\program files\common files\adobe\acrobat\activex\AcroIEHelperShim.dll BHO: DivX Plus Web Player HTML5 : {326e768d-4182-46fd-9c16-1449a49795f4} - c:\program files\divx\divx plus web player\ie\divxhtml5\DivXHTML5.dll BHO: Symantec Intrusion Prevention: {6d53ec84-6aae-4787-aeee-f4628f01010c} - c:\program files\symantec\symantec endpoint protection\12.1.1000.157.105\bin\ips\IPSBHO.DLL BHO: Java™ Plug-In SSV Helper: {761497bb-d6f0-462c-b6eb-d4daf1d92d43} - c:\program files\java\jre6\bin\ssv.dll BHO: Windows Live Sign-in Helper: {9030d464-4c02-4abf-8ecc-5164760863c6} - c:\program files\common files\microsoft shared\windows live\WindowsLiveLogin.dll BHO: Adobe PDF Conversion Toolbar Helper: {ae7cd045-e861-484f-8273-0445ee161910} - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll BHO: Skype Browser Helper: {ae805869-2e5c-4ed4-8f7b-f1f7851a4497} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.2.4204.1700\swg.dll BHO: Vuze Remote Toolbar: {ba14329e-9550-4989-b3f2-9732e92d17cc} - c:\program files\vuze_remote\prxtbVuz2.dll BHO: Java™ Plug-In 2 SSV Helper: {dbc80044-a445-435b-bc74-9c25c1c588a9} - c:\program files\java\jre6\bin\jp2ssv.dll BHO: JQSIEStartDetectorImpl Class: {e7e6f031-17ce-4c07-bc86-eabfe594f69c} - c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll TB: Vuze Remote Toolbar: {ba14329e-9550-4989-b3f2-9732e92d17cc} - c:\program files\vuze_remote\prxtbVuz2.dll TB: Adobe PDF: {47833539-d0c5-4125-9fa8-0819e2eaac93} - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll EB: Adobe PDF: {182ec0be-5110-49c8-a062-beb1d02a220b} - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll EB: {32683183-48a0-441b-a342-7c2a440a9478} - No File uRun: [ctfmon.exe] c:\windows\system32\ctfmon.exe uRun: [] mRun: [Adobe ARM] "c:\program files\common files\adobe\arm\1.0\AdobeARM.exe" mRun: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k mRun: [UserFaultCheck] %systemroot%\system32\dumprep 0 -u dRun: [DWQueuedReporting] "c:\progra~1\common~1\micros~1\dw\dwtrig20.exe" -t IE: &Download All using 4shared Desktop - c:\program files\4shared\down_all.htm IE: Convert link target to Adobe PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIECapture.html IE: Convert link target to existing PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIEAppend.html IE: Convert selected links to Adobe PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html IE: Convert selected links to existing PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html IE: Convert selection to Adobe PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIECapture.html IE: Convert selection to existing PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIEAppend.html IE: Convert to Adobe PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIECapture.html IE: Convert to existing PDF - c:\program files\adobe\acrobat 7.0\acrobat\AcroIEFavClient.dll/AcroIEAppend.html IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office12\EXCEL.EXE/3000 IE: I&M Chat IE: V&oice Call IE: Vi&deo Call IE: {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe IE: {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - c:\program files\yahoo!\messenger\YahooMessenger.exe IE: {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~2\office11\REFIEBAR.DLL Trusted Zone: nyu.edu\ezproxy.library DPF: {17492023-C23A-453E-A040-C7C580BBF700} - hxxp://download.microsoft.com/download/C/0/C/C0CBBA88-A6F2-48D9-9B0E-1719D1177202/LegitCheckControl.cab DPF: {1E54D648-B804-468d-BC78-4AFFED8E262F} - hxxp://www.nvidia.com/content/DriverDownload/srl/3.0.0.4/srl_bin/sysreqlab_nvd.cab DPF: {33564D57-9980-0010-8000-00AA00389B71} - hxxp://download.microsoft.com/download/D/0/D/D0DD87DA-994F-4334-8B55-AF2E4D98ED0C/wmv9dmo.cab DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} - hxxp://update.microsoft.com/windowsupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1240165719013 DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} - hxxp://download.eset.com/special/eos/OnlineScanner.cab DPF: {784797A8-342D-4072-9486-03C8D0F2F0A1} - hxxps://www.battlefieldheroes.com/static/updater/BFHUpdater_5.0.67.0.cab DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_31-windows-i586.cab DPF: {8C28EFD7-767B-11D1-844B-0060972DC2AC} - hxxps://brioportal.adcom.its.nyu.edu:7411/Hyperion/zeroadmin/component/Brio.InsightNoHelp.en.cab DPF: {C7DB51B4-BCF7-4923-8874-7F1A0DC92277} - hxxp://office.microsoft.com/officeupdate/content/opuc4.cab DPF: {CAFEEFAC-0016-0000-0031-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_31-windows-i586.cab DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} - hxxp://java.sun.com/update/1.6.0/jinstall-1_6_0_31-windows-i586.cab TCP: DhcpNameServer = 75.75.75.75 75.75.76.76 TCP: Interfaces\{BF0D4ABC-38D1-42AD-B00A-4D0D35994E94} : DhcpNameServer = 75.75.75.75 75.75.76.76 Handler: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - c:\program files\skype\toolbars\internet explorer\skypeieplugin.dll Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - c:\progra~1\common~1\skype\SKYPE4~1.DLL Notify: SEP - c:\program files\symantec\symantec endpoint protection\12.1.1000.157.105\bin\WinLogoutNotifier.dll SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - c:\windows\system32\WPDShServiceObj.dll SEH: Windows Desktop Search Namespace Manager: {56f9679e-7826-4c84-81f3-532071a8bcc5} - c:\program files\windows desktop search\MSNLNamespaceMgr.dll SEH: Microsoft AntiMalware ShellExecuteHook: {091eb208-39dd-417d-a5dd-7e2c2d8fb9cb} - c:\progra~1\wifd1f~1\MpShHook.dll . ================= FIREFOX =================== . FF - ProfilePath - c:\documents and settings\basilio\application data\mozilla\firefox\profiles\3lkkb686.default\ FF - prefs.js: browser.search.selectedEngine - Bing FF - prefs.js: network.proxy.type - 4 FF - component: c:\documents and settings\basilio\application data\mozilla\firefox\profiles\3lkkb686.default\extensions\{ba14329e-9550-4989-b3f2-9732e92d17cc}\components\RadioWMPCoreGecko19.dll FF - component: c:\documents and settings\basilio\application data\mozilla\firefox\profiles\3lkkb686.default\extensions\[removed]\components\RadioWMPCoreGecko19.dll FF - plugin: c:\documents and settings\basilio\application data\facebook\npfbplugin_1_0_1.dll FF - plugin: c:\documents and settings\basilio\application data\facebook\npfbplugin_1_0_3.dll FF - plugin: c:\documents and settings\basilio\application data\move networks\plugins\npqmp071505000011.dll FF - plugin: c:\program files\adobe\reader 10.0\reader\air\nppdf32.dll FF - plugin: c:\program files\divx\divx ovs helper\npovshelper.dll FF - plugin: c:\program files\divx\divx plus web player\npdivx32.dll FF - plugin: c:\program files\google\google earth\plugin\npgeplugin.dll FF - plugin: c:\program files\google\google updater\2.4.2432.1652\npCIDetect14.dll FF - plugin: c:\program files\google\update\1.3.21.115\npGoogleUpdate3.dll FF - plugin: c:\program files\java\jre6\bin\new_plugin\npdeployJava1.dll FF - plugin: c:\program files\java\jre6\bin\plugin2\npdeployJava1.dll FF - plugin: c:\program files\java\jre6\bin\plugin2\npjp2.dll FF - plugin: c:\program files\microsoft silverlight\5.1.10411.0\npctrlui.dll FF - plugin: c:\program files\mozilla firefox\plugins\npdeployJava1.dll FF - plugin: c:\program files\nokia\nokia suite\npNokiaSuiteEnabler.dll FF - plugin: c:\program files\pando networks\media booster\npPandoWebPlugin.dll FF - plugin: c:\windows\system32\macromed\flash\NPSWF32_11_4_402_265.dll . —- FIREFOX POLICIES —- FF - user.js: yahoo.ytff.general.dontshowhpoffer - true ============= SERVICES / DRIVERS =============== . R0 SymDS;Symantec Data Store;c:\windows\system32\drivers\sep\0c0103e8\009d.105\x86\SymDS.sys [2011-10-30 340088] R0 SymEFA;Symantec Extended File Attributes;c:\windows\system32\drivers\sep\0c0103e8\009d.105\x86\SymEFA.sys [2011-10-30 758904] R1 BHDrvx86;BHDrvx86;c:\documents and settings\all users\application data\symantec\symantec endpoint protection\12.1.1000.157.105\data\definitions\bashdefs\20120823.013\BHDrvx86.sys [2012-8-2 821920] R1 SymIRON;Symantec Iron Driver;c:\windows\system32\drivers\sep\0c0103e8\009d.105\x86\Ironx86.sys [2011-10-30 137336] R2 cpuz135;cpuz135;c:\windows\system32\drivers\cpuz135_x32.sys [2011-11-5 21992] R2 SkypeUpdate;Skype Updater;c:\program files\skype\updater\Updater.exe [2012-7-3 160944] R3 IDSxpx86;IDSxpx86;c:\documents and settings\all users\application data\symantec\symantec endpoint protection\12.1.1000.157.105\data\definitions\ipsdefs\20120908.001\IDSXpx86.sys [2012-9-11 373728] R3 NAVENG;NAVENG;c:\documents and settings\all users\application data\symantec\symantec endpoint protection\12.1.1000.157.105\data\definitions\virusdefs\20120903.017\NAVENG.SYS [2012-9-3 92704] R3 NAVEX15;NAVEX15;c:\documents and settings\all users\application data\symantec\symantec endpoint protection\12.1.1000.157.105\data\definitions\virusdefs\20120903.017\NAVEX15.SYS [2012-9-3 1601184] S0 rglfgg;rglfgg; [x] S1 sensorsview;sensorsview;\??\c:\program files\sensorsviewpro41\drv\sensorsview32.sys –> c:\program files\sensorsviewpro41\drv\sensorsview32.sys [?] S2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\microsoft.net\framework\v4.0.30319\mscorsvw.exe [2010-3-18 130384] S2 gupdate1c9e6304563b6d2;Google Update Service (gupdate1c9e6304563b6d2);c:\program files\google\update\GoogleUpdate.exe [2009-6-5 133104] S2 SepMasterService;Symantec Endpoint Protection;c:\program files\symantec\symantec endpoint protection\12.1.1000.157.105\bin\ccSvcHst.exe [2011-10-30 137224] S2 Skype C2C Service;Skype C2C Service;c:\documents and settings\all users\application data\skype\toolbars\skype c2c service\c2c_service.exe [2012-7-5 3048136] S2 xdgjddwbvrch;xdgjddwbvrch;\??\c:\windows\system32\drivers\bwpszulejjafpe.sys –> c:\windows\system32\drivers\bwpszulejjafpe.sys [?] S3 AdobeFlashPlayerUpdateSvc;Adobe Flash Player Update Service;c:\windows\system32\macromed\flash\FlashPlayerUpdateService.exe [2012-4-13 250568] S3 audiobridge;Virtual Audio Bridge;c:\windows\system32\drivers\aubridge.sys [2007-7-23 22528] S3 DrvAgent32;DrvAgent32;c:\windows\system32\drivers\DrvAgent32.sys [2011-11-5 23456] S3 EraserUtilDrv11220;EraserUtilDrv11220;\??\c:\program files\common files\symantec shared\eengine\eraserutildrv11220.sys –> c:\program files\common files\symantec shared\eengine\EraserUtilDrv11220.sys [?] S3 EraserUtilRebootDrv;EraserUtilRebootDrv;\??\c:\program files\common files\symantec shared\eengine\eraserutilrebootdrv.sys –> c:\program files\common files\symantec shared\eengine\EraserUtilRebootDrv.sys [?] S3 gupdatem;Google Update Service (gupdatem);c:\program files\google\update\GoogleUpdate.exe [2009-6-5 133104] S3 iscFlash;iscFlash;\??\c:\windows\system32\drivers\iscflash.sys –> c:\windows\system32\drivers\iscflash.sys [?] S3 MotDev;Motorola Inc. USB Device;c:\windows\system32\drivers\motodrv.sys [2010-4-19 42752] S3 MozillaMaintenance;Mozilla Maintenance Service;c:\program files\mozilla maintenance service\maintenanceservice.exe [2012-4-25 113120] S3 pbfilter;pbfilter;c:\program files\peerblock\pbfilter.sys [2010-3-2 14424] S3 SyDvCtrl;SyDvCtrl;c:\program files\symantec\symantec endpoint protection\12.1.1000.157.105\bin\SyDvCtrl32.sys [2011-10-30 23984] S3 vsdatant;vsdatant;\??\c:\windows\system32\vsdatant.sys –> c:\windows\system32\vsdatant.sys [?] S3 WPFFontCache_v0400;Windows Presentation Foundation Font Cache 4.0.0.0;c:\windows\microsoft.net\framework\v4.0.30319\wpf\WPFFontCache_v0400.exe [2010-3-18 753504] S4 nvUpdatusService;NVIDIA Update Service Daemon;c:\program files\nvidia corporation\nvidia updatus\daemonu.exe [2011-11-5 2253120] S4 WinDefend;Windows Defender;c:\program files\windows defender\MsMpEng.exe [2006-11-3 13592] . =============== Created Last 30 ================ . . ==================== Find3M ==================== . 2012-08-31 06:18:24 73416 —-a-w- c:\windows\system32\FlashPlayerCPLApp.cpl 2012-08-31 06:18:24 696520 —-a-w- c:\windows\system32\FlashPlayerApp.exe 2012-07-06 13:58:51 78336 —-a-w- c:\windows\system32\browser.dll 2012-07-04 14:05:18 139784 —-a-w- c:\windows\system32\drivers\rdpwd.sys 2012-07-03 17:46:44 22344 —-a-w- c:\windows\system32\drivers\mbam.sys 2012-07-03 13:40:15 1866112 —-a-w- c:\windows\system32\win32k.sys 2012-07-02 17:49:33 916992 —-a-w- c:\windows\system32\wininet.dll 2012-07-02 17:49:32 43520 —-a-w- c:\windows\system32\licmgr10.dll 2012-07-02 17:49:32 1469440 ——w- c:\windows\system32\inetcpl.cpl 2012-07-02 12:05:43 385024 —-a-w- c:\windows\system32\html.iec 2012-07-01 18:53:14 22 —-a-w- c:\windows\system32\syoepk_lib0.dll . ============= FINISH: 0:20:27.23 ===============
Hi Patndoris, I completed the TDSSKiller part of your instructions, and after a scan, it detected one "suspicious" file that I skipped, when it asked me what I wanted to do. I was not required to reboot my computer. Below I have pasted the log from TDSSKiller. Thanks again for all your help. —————————- 00:31:00.0156 1844 TDSS rootkit removing tool 2.8.8.0 Aug 24 2012 13:27:48 00:31:00.0625 1844 ============================================================ 00:31:00.0625 1844 Current date / time: 2012/09/12 00:31:00.0625 00:31:00.0625 1844 SystemInfo: 00:31:00.0625 1844 00:31:00.0625 1844 OS Version: 5.1.2600 ServicePack: 3.0 00:31:00.0625 1844 Product type: Workstation 00:31:00.0625 1844 ComputerName: TEMUJIN 00:31:00.0625 1844 UserName: Basilio 00:31:00.0625 1844 Windows directory: C:\WINDOWS 00:31:00.0625 1844 System windows directory: C:\WINDOWS 00:31:00.0625 1844 Processor architecture: Intel x86 00:31:00.0625 1844 Number of processors: 2 00:31:00.0625 1844 Page size: 0x1000 00:31:00.0625 1844 Boot type: Normal boot 00:31:00.0625 1844 ============================================================ 00:31:01.0187 1844 Drive \Device\Harddisk1\DR1 - Size: 0x2E93E36000 (186.31 Gb), SectorSize: 0x200, Cylinders: 0x5F01, SectorsPerTrack: 0x3F, TracksPerCylinder: 0xFF, Type 'K0', Flags 0x00000050 00:31:01.0203 1844 Drive \Device\Harddisk2\DR2 - Size: 0x950B056000 (596.17 Gb), SectorSize: 0x200, Cylinders: 0x13001, SectorsPerTrack: 0x3F, TracksPerCylinder: 0xFF, Type 'K0', Flags 0x00000050 00:31:01.0203 1844 ============================================================ 00:31:01.0203 1844 \Device\Harddisk1\DR1: 00:31:01.0203 1844 MBR partitions: 00:31:01.0203 1844 \Device\Harddisk1\DR1\Partition1: MBR, Type 0x7, StartLBA 0x3F, BlocksNum 0xFFFAC05 00:31:01.0203 1844 \Device\Harddisk2\DR2: 00:31:01.0203 1844 MBR partitions: 00:31:01.0203 1844 \Device\Harddisk2\DR2\Partition1: MBR, Type 0x7, StartLBA 0x3F, BlocksNum 0xFFFAC05 00:31:01.0203 1844 ============================================================ 00:31:01.0234 1844 C: <-> \Device\Harddisk2\DR2\Partition1 00:31:01.0265 1844 F: <-> \Device\Harddisk1\DR1\Partition1 00:31:01.0281 1844 ============================================================ 00:31:01.0281 1844 Initialize success 00:31:01.0281 1844 ============================================================ 00:31:11.0953 0772 ============================================================ 00:31:11.0953 0772 Scan started 00:31:11.0953 0772 Mode: Manual; 00:31:11.0953 0772 ============================================================ 00:31:12.0125 0772 ================ Scan system memory ======================== 00:31:14.0031 0772 System memory - ok 00:31:14.0031 0772 ================ Scan services ============================= 00:31:14.0109 0772 Abiosdsk - ok 00:31:14.0109 0772 abp480n5 - ok 00:31:14.0171 0772 [ 8FD99680A539792A30E97944FDAECF17 ] ACPI C:\WINDOWS\system32\DRIVERS\ACPI.sys 00:31:14.0171 0772 ACPI - ok 00:31:14.0187 0772 [ 9859C0F6936E723E4892D7141B1327D5 ] ACPIEC C:\WINDOWS\system32\drivers\ACPIEC.sys 00:31:14.0187 0772 ACPIEC - ok 00:31:14.0203 0772 [ 233235123F3D73228EC3D2BBA0E7143D ] ACS C:\WINDOWS\system32\acs.exe 00:31:14.0218 0772 ACS - ok 00:31:14.0265 0772 [ B2B64AF436FACCFA854DD397027C5360 ] AdobeFlashPlayerUpdateSvc C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe 00:31:14.0265 0772 AdobeFlashPlayerUpdateSvc - ok 00:31:14.0281 0772 adpu160m - ok 00:31:14.0296 0772 [ 8BED39E3C35D6A489438B8141717A557 ] aec C:\WINDOWS\system32\drivers\aec.sys 00:31:14.0312 0772 aec - ok 00:31:14.0343 0772 [ 2C5C22990156A1063E19AD162191DC1D ] AegisP C:\WINDOWS\system32\DRIVERS\AegisP.sys 00:31:14.0343 0772 AegisP - ok 00:31:14.0359 0772 [ 1E44BC1E83D8FD2305F8D452DB109CF9 ] AFD C:\WINDOWS\System32\drivers\afd.sys 00:31:14.0375 0772 AFD - ok 00:31:14.0375 0772 Aha154x - ok 00:31:14.0375 0772 aic78u2 - ok 00:31:14.0390 0772 aic78xx - ok 00:31:14.0515 0772 [ DD8520280304B6145A6BE31008748C7C ] ALCXWDM C:\WINDOWS\system32\drivers\ALCXWDM.SYS 00:31:14.0578 0772 ALCXWDM - ok 00:31:14.0609 0772 [ A9A3DAA780CA6C9671A19D52456705B4 ] Alerter C:\WINDOWS\system32\alrsvc.dll 00:31:14.0609 0772 Alerter - ok 00:31:14.0625 0772 [ 8C515081584A38AA007909CD02020B3D ] ALG C:\WINDOWS\System32\alg.exe 00:31:14.0625 0772 ALG - ok 00:31:14.0640 0772 AliIde - ok 00:31:14.0671 0772 [ 033448D435E65C4BD72E70521FD05C76 ] AmdPPM C:\WINDOWS\system32\DRIVERS\AmdPPM.sys 00:31:14.0671 0772 AmdPPM - ok 00:31:14.0671 0772 amsint - ok 00:31:14.0671 0772 apheewidwfjpxeqv - ok 00:31:14.0734 0772 [ 7EF47644B74EBE721CC32211D3C35E76 ] Apple Mobile Device C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe 00:31:14.0734 0772 Apple Mobile Device - ok 00:31:14.0765 0772 [ D8849F77C0B66226335A59D26CB4EDC6 ] AppMgmt C:\WINDOWS\System32\appmgmts.dll 00:31:14.0765 0772 AppMgmt - ok 00:31:14.0796 0772 [ 08E03E8AB837DC9DD2737930ECD19FBC ] AR5211 C:\WINDOWS\system32\DRIVERS\WPN311.sys 00:31:14.0796 0772 AR5211 - ok 00:31:14.0843 0772 [ 00E031FE2D849BE503FC4A47271F1EA5 ] AR5416 C:\WINDOWS\system32\DRIVERS\athw.sys 00:31:14.0859 0772 AR5416 - ok 00:31:14.0859 0772 asc - ok 00:31:14.0875 0772 asc3350p - ok 00:31:14.0875 0772 asc3550 - ok 00:31:14.0937 0772 [ 0E5E4957549056E2BF2C49F4F6B601AD ] aspnet_state C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\aspnet_state.exe 00:31:14.0968 0772 aspnet_state - ok 00:31:14.0984 0772 [ B153AFFAC761E7F5FCFA822B9C4E97BC ] AsyncMac C:\WINDOWS\system32\DRIVERS\asyncmac.sys 00:31:14.0984 0772 AsyncMac - ok 00:31:15.0015 0772 [ 9F3A2F5AA6875C72BF062C712CFA2674 ] atapi C:\WINDOWS\system32\DRIVERS\atapi.sys 00:31:15.0015 0772 atapi - ok 00:31:15.0015 0772 Atdisk - ok 00:31:15.0031 0772 [ 9916C1225104BA14794209CFA8012159 ] Atmarpc C:\WINDOWS\system32\DRIVERS\atmarpc.sys 00:31:15.0046 0772 Atmarpc - ok 00:31:15.0062 0772 [ 3C391503E59C88DA73B8C74097147BC9 ] audiobridge C:\WINDOWS\system32\DRIVERS\aubridge.sys 00:31:15.0062 0772 audiobridge - ok 00:31:15.0078 0772 [ DEF7A7882BEC100FE0B2CE2549188F9D ] AudioSrv C:\WINDOWS\System32\audiosrv.dll 00:31:15.0078 0772 AudioSrv - ok 00:31:15.0109 0772 [ D9F724AA26C010A217C97606B160ED68 ] audstub C:\WINDOWS\system32\DRIVERS\audstub.sys 00:31:15.0109 0772 audstub - ok 00:31:15.0140 0772 [ DA1F27D85E0D1525F6621372E7B685E9 ] Beep C:\WINDOWS\system32\drivers\Beep.sys 00:31:15.0140 0772 Beep - ok 00:31:15.0296 0772 [ A9E111A358AC5F7EBA7AC61E43FC6725 ] BHDrvx86 C:\Documents and Settings\All Users\Application Data\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Data\Definitions\BASHDefs\20120823.013\BHDrvx86.sys 00:31:15.0312 0772 BHDrvx86 - ok 00:31:15.0343 0772 [ 574738F61FCA2935F5265DC4E5691314 ] BITS C:\WINDOWS\system32\qmgr.dll 00:31:15.0359 0772 BITS - ok 00:31:15.0406 0772 [ DB5BEA73EDAF19AC68B2C0FAD0F92B1A ] Bonjour Service C:\Program Files\Bonjour\mDNSResponder.exe 00:31:15.0421 0772 Bonjour Service - ok 00:31:15.0437 0772 [ CFD4E51402DA9838B5A04AE680AF54A0 ] Browser C:\WINDOWS\System32\browser.dll 00:31:15.0453 0772 Browser - ok 00:31:15.0500 0772 catchme - ok 00:31:15.0515 0772 [ 90A673FC8E12A79AFBED2576F6A7AAF9 ] cbidf2k C:\WINDOWS\system32\drivers\cbidf2k.sys 00:31:15.0515 0772 cbidf2k - ok 00:31:15.0531 0772 [ 0BE5AEF125BE881C4F854C554F2B025C ] CCDECODE C:\WINDOWS\system32\DRIVERS\CCDECODE.sys 00:31:15.0531 0772 CCDECODE - ok 00:31:15.0546 0772 cd20xrnt - ok 00:31:15.0562 0772 [ C1B486A7658353D33A10CC15211A873B ] Cdaudio C:\WINDOWS\system32\drivers\Cdaudio.sys 00:31:15.0562 0772 Cdaudio - ok 00:31:15.0593 0772 [ C885B02847F5D2FD45A24E219ED93B32 ] Cdfs C:\WINDOWS\system32\drivers\Cdfs.sys 00:31:15.0593 0772 Cdfs - ok 00:31:15.0609 0772 [ 1F4260CC5B42272D71F79E570A27A4FE ] Cdrom C:\WINDOWS\system32\DRIVERS\cdrom.sys 00:31:15.0609 0772 Cdrom - ok 00:31:15.0609 0772 Changer - ok 00:31:15.0718 0772 [ 557D890E38FA68F5137F8F22516E5D25 ] CiscoVpnInstallService C:\DOCUME~1\Basilio\LOCALS~1\temp\vpninst\INSTAL~1.EXE 00:31:15.0718 0772 CiscoVpnInstallService - ok 00:31:15.0734 0772 [ 1CFE720EB8D93A7158A4EBC3AB178BDE ] cisvc C:\WINDOWS\system32\cisvc.exe 00:31:15.0734 0772 cisvc - ok 00:31:15.0750 0772 [ 34CBE729F38138217F9C80212A2A0C82 ] ClipSrv C:\WINDOWS\system32\clipsrv.exe 00:31:15.0750 0772 ClipSrv - ok 00:31:15.0781 0772 [ D87ACAED61E417BBA546CED5E7E36D9C ] clr_optimization_v2.0.50727_32 C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe 00:31:15.0781 0772 clr_optimization_v2.0.50727_32 - ok 00:31:15.0812 0772 [ C5A75EB48E2344ABDC162BDA79E16841 ] clr_optimization_v4.0.30319_32 C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe 00:31:15.0812 0772 clr_optimization_v4.0.30319_32 - ok 00:31:15.0828 0772 CmdIde - ok 00:31:15.0828 0772 COMSysApp - ok 00:31:15.0843 0772 Cpqarray - ok 00:31:15.0875 0772 [ C2EB4539A4F6AB6EDD01BDC191619975 ] cpuz135 C:\WINDOWS\system32\drivers\cpuz135_x32.sys 00:31:15.0875 0772 cpuz135 - ok 00:31:15.0906 0772 [ 3D4E199942E29207970E04315D02AD3B ] CryptSvc C:\WINDOWS\System32\cryptsvc.dll 00:31:15.0906 0772 CryptSvc - ok 00:31:15.0921 0772 [ 71007BD2E1E26927FE3E4EB00C0BEEDF ] ctljystk C:\WINDOWS\system32\DRIVERS\ctljystk.sys 00:31:15.0937 0772 ctljystk - ok 00:31:15.0968 0772 [ B5ECADF7708960F1818C7FA015F4C239 ] CVirtA C:\WINDOWS\system32\DRIVERS\CVirtA.sys 00:31:15.0968 0772 CVirtA - ok 00:31:15.0968 0772 dac2w2k - ok 00:31:15.0968 0772 dac960nt - ok 00:31:16.0015 0772 [ 6B27A5C03DFB94B4245739065431322C ] DcomLaunch C:\WINDOWS\system32\rpcss.dll 00:31:16.0015 0772 DcomLaunch - ok 00:31:16.0046 0772 [ 5E38D7684A49CACFB752B046357E0589 ] Dhcp C:\WINDOWS\System32\dhcpcsvc.dll 00:31:16.0046 0772 Dhcp - ok 00:31:16.0062 0772 [ 044452051F3E02E7963599FC8F4F3E25 ] Disk C:\WINDOWS\system32\DRIVERS\disk.sys 00:31:16.0062 0772 Disk - ok 00:31:16.0062 0772 dmadmin - ok 00:31:16.0093 0772 [ D992FE1274BDE0F84AD826ACAE022A41 ] dmboot C:\WINDOWS\system32\drivers\dmboot.sys 00:31:16.0109 0772 dmboot - ok 00:31:16.0125 0772 dmio - ok 00:31:16.0140 0772 [ E9317282A63CA4D188C0DF5E09C6AC5F ] dmload C:\WINDOWS\system32\drivers\dmload.sys 00:31:16.0140 0772 dmload - ok 00:31:16.0156 0772 [ 57EDEC2E5F59F0335E92F35184BC8631 ] dmserver C:\WINDOWS\System32\dmserver.dll 00:31:16.0156 0772 dmserver - ok 00:31:16.0187 0772 [ 8A208DFCF89792A484E76C40E5F50B45 ] DMusic C:\WINDOWS\system32\drivers\DMusic.sys 00:31:16.0187 0772 DMusic - ok 00:31:16.0203 0772 [ 5F7E24FA9EAB896051FFB87F840730D2 ] Dnscache C:\WINDOWS\System32\dnsrslvr.dll 00:31:16.0218 0772 Dnscache - ok 00:31:16.0234 0772 [ 0F0F6E687E5E15579EF4DA8DD6945814 ] Dot3svc C:\WINDOWS\System32\dot3svc.dll 00:31:16.0234 0772 Dot3svc - ok 00:31:16.0250 0772 dpti2o - ok 00:31:16.0265 0772 [ 8F5FCFF8E8848AFAC920905FBD9D33C8 ] drmkaud C:\WINDOWS\system32\drivers\drmkaud.sys 00:31:16.0265 0772 drmkaud - ok 00:31:16.0281 0772 [ 651554E483712B708EDE864D0CA1AA73 ] DrvAgent32 C:\WINDOWS\system32\Drivers\DrvAgent32.sys 00:31:16.0281 0772 DrvAgent32 - ok 00:31:16.0296 0772 [ 2187855A7703ADEF0CEF9EE4285182CC ] EapHost C:\WINDOWS\System32\eapsvc.dll 00:31:16.0312 0772 EapHost - ok 00:31:16.0375 0772 [ 85B8B4032A895A746D46A288A9B30DED ] eeCtrl C:\Program Files\Common Files\Symantec Shared\EENGINE\eeCtrl.sys 00:31:16.0390 0772 eeCtrl - ok 00:31:16.0421 0772 [ 01F83E1B5DCE05F5CB7D99113CA9E890 ] emu10k C:\WINDOWS\system32\drivers\emu10k1m.sys 00:31:16.0437 0772 emu10k - ok 00:31:16.0437 0772 [ 7FFA171CCE6A8BFC774862A578BA39A2 ] emu10k1 C:\WINDOWS\system32\drivers\ctlfacem.sys 00:31:16.0437 0772 emu10k1 - ok 00:31:16.0437 0772 EraserUtilDrv11220 - ok 00:31:16.0453 0772 EraserUtilRebootDrv - ok 00:31:16.0468 0772 [ BC93B4A066477954555966D77FEC9ECB ] ERSvc C:\WINDOWS\System32\ersvc.dll 00:31:16.0468 0772 ERSvc - ok 00:31:16.0515 0772 [ 65DF52F5B8B6E9BBD183505225C37315 ] Eventlog C:\WINDOWS\system32\services.exe 00:31:16.0515 0772 Eventlog - ok 00:31:16.0546 0772 [ D4991D98F2DB73C60D042F1AEF79EFAE ] EventSystem C:\WINDOWS\System32\es.dll 00:31:16.0546 0772 EventSystem - ok 00:31:16.0578 0772 [ 38D332A6D56AF32635675F132548343E ] Fastfat C:\WINDOWS\system32\drivers\Fastfat.sys 00:31:16.0578 0772 Fastfat - ok 00:31:16.0609 0772 [ 99BC0B50F511924348BE19C7C7313BBF ] FastUserSwitchingCompatibility C:\WINDOWS\System32\shsvcs.dll 00:31:16.0609 0772 FastUserSwitchingCompatibility - ok 00:31:16.0625 0772 [ 92CDD60B6730B9F50F6A1A0C1F8CDC81 ] Fdc C:\WINDOWS\system32\DRIVERS\fdc.sys 00:31:16.0625 0772 Fdc - ok 00:31:16.0625 0772 [ D45926117EB9FA946A6AF572FBE1CAA3 ] Fips C:\WINDOWS\system32\drivers\Fips.sys 00:31:16.0640 0772 Fips - ok 00:31:16.0640 0772 [ 9D27E7B80BFCDF1CDD9B555862D5E7F0 ] Flpydisk C:\WINDOWS\system32\DRIVERS\flpydisk.sys 00:31:16.0656 0772 Flpydisk - ok 00:31:16.0671 0772 [ B2CF4B0786F8212CB92ED2B50C6DB6B0 ] FltMgr C:\WINDOWS\system32\drivers\fltmgr.sys 00:31:16.0671 0772 FltMgr - ok 00:31:16.0718 0772 [ 8BA7C024070F2B7FDD98ED8A4BA41789 ] FontCache3.0.0.0 C:\WINDOWS\Microsoft.NET\Framework\v3.0\WPF\PresentationFontCache.exe 00:31:16.0718 0772 FontCache3.0.0.0 - ok 00:31:16.0734 0772 [ 3E1E2BD4F39B0E2B7DC4F4D2BCC2779A ] Fs_Rec C:\WINDOWS\system32\drivers\Fs_Rec.sys 00:31:16.0734 0772 Fs_Rec - ok 00:31:16.0734 0772 [ 6AC26732762483366C3969C9E4D2259D ] Ftdisk C:\WINDOWS\system32\DRIVERS\ftdisk.sys 00:31:16.0734 0772 Ftdisk - ok 00:31:16.0765 0772 [ 065639773D8B03F33577F6CDAEA21063 ] gameenum C:\WINDOWS\system32\DRIVERS\gameenum.sys 00:31:16.0765 0772 gameenum - ok 00:31:16.0781 0772 [ 8182FF89C65E4D38B2DE4BB0FB18564E ] GEARAspiWDM C:\WINDOWS\system32\DRIVERS\GEARAspiWDM.sys 00:31:16.0781 0772 GEARAspiWDM - ok 00:31:16.0812 0772 [ 0A02C63C8B144BD8C86B103DEE7C86A2 ] Gpc C:\WINDOWS\system32\DRIVERS\msgpc.sys 00:31:16.0812 0772 Gpc - ok 00:31:16.0843 0772 [ 626A24ED1228580B9518C01930936DF9 ] gupdate1c9e6304563b6d2 C:\Program Files\Google\Update\GoogleUpdate.exe 00:31:16.0859 0772 gupdate1c9e6304563b6d2 - ok 00:31:16.0859 0772 [ 626A24ED1228580B9518C01930936DF9 ] gupdatem C:\Program Files\Google\Update\GoogleUpdate.exe 00:31:16.0859 0772 gupdatem - ok 00:31:16.0906 0772 [ 408DDD80EEDE47175F6844817B90213E ] gusvc C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe 00:31:16.0921 0772 gusvc - ok 00:31:17.0000 0772 [ 4FCCA060DFE0C51A09DD5C3843888BCD ] helpsvc C:\WINDOWS\PCHealth\HelpCtr\Binaries\pchsvc.dll 00:31:17.0000 0772 helpsvc - ok 00:31:17.0031 0772 [ DEB04DA35CC871B6D309B77E1443C796 ] HidServ C:\WINDOWS\System32\hidserv.dll 00:31:17.0031 0772 HidServ - ok 00:31:17.0062 0772 [ CCF82C5EC8A7326C3066DE870C06DAF1 ] hidusb C:\WINDOWS\system32\DRIVERS\hidusb.sys 00:31:17.0062 0772 hidusb - ok 00:31:17.0078 0772 [ 8878BD685E490239777BFE51320B88E9 ] hkmsvc C:\WINDOWS\System32\kmsvc.dll 00:31:17.0078 0772 hkmsvc - ok 00:31:17.0078 0772 hpn - ok 00:31:17.0093 0772 hpt3xx - ok 00:31:17.0125 0772 [ F80A415EF82CD06FFAF0D971528EAD38 ] HTTP C:\WINDOWS\system32\Drivers\HTTP.sys 00:31:17.0125 0772 HTTP - ok 00:31:17.0156 0772 [ 6100A808600F44D999CEBDEF8841C7A3 ] HTTPFilter C:\WINDOWS\System32\w3ssl.dll 00:31:17.0156 0772 HTTPFilter - ok 00:31:17.0156 0772 i2omgmt - ok 00:31:17.0171 0772 i2omp - ok 00:31:17.0187 0772 [ 4A0B06AA8943C1E332520F7440C0AA30 ] i8042prt C:\WINDOWS\system32\DRIVERS\i8042prt.sys 00:31:17.0187 0772 i8042prt - ok 00:31:17.0234 0772 [ 6F95324909B502E2651442C1548AB12F ] IDriverT C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe 00:31:17.0234 0772 IDriverT - ok 00:31:17.0281 0772 [ C01AC32DC5C03076CFB852CB5DA5229C ] idsvc C:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\infocard.exe 00:31:17.0312 0772 idsvc - ok 00:31:17.0359 0772 [ C19BF2A07BE972A110220DF6B1E89D14 ] IDSxpx86 C:\Documents and Settings\All Users\Application Data\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Data\Definitions\IPSDefs\20120908.001\IDSxpx86.sys 00:31:17.0375 0772 IDSxpx86 - ok 00:31:17.0406 0772 [ 6F86988EEB7A58FBD16A77ED51A84DE1 ] imagedrv C:\WINDOWS\system32\Drivers\imagedrv.sys 00:31:17.0406 0772 imagedrv - ok 00:31:17.0406 0772 [ 6CD5F93AA6691DBBC7F409A3DBFC0D8E ] imagesrv C:\WINDOWS\system32\DRIVERS\imagesrv.sys 00:31:17.0406 0772 imagesrv - ok 00:31:17.0437 0772 [ 083A052659F5310DD8B6A6CB05EDCF8E ] Imapi C:\WINDOWS\system32\DRIVERS\imapi.sys 00:31:17.0437 0772 Imapi - ok 00:31:17.0468 0772 [ 30DEAF54A9755BB8546168CFE8A6B5E1 ] ImapiService C:\WINDOWS\system32\imapi.exe 00:31:17.0468 0772 ImapiService - ok 00:31:17.0500 0772 [ 9BDDD676793EA025C58F3201532AD61D ] InCDfs C:\WINDOWS\system32\drivers\InCDFs.sys 00:31:17.0515 0772 InCDfs - ok 00:31:17.0515 0772 [ 612A367AE6A642F9107B9DE93D920E63 ] InCDPass C:\WINDOWS\system32\drivers\InCDPass.sys 00:31:17.0515 0772 InCDPass - ok 00:31:17.0531 0772 [ 0C5AA351F96B91FB7CA4890AA8DD56F7 ] InCDrec C:\WINDOWS\system32\drivers\InCDrec.sys 00:31:17.0531 0772 InCDrec - ok 00:31:17.0546 0772 [ C3C3217907C63A543D61C0F130D2524D ] incdrm C:\WINDOWS\system32\drivers\InCDRm.sys 00:31:17.0546 0772 incdrm - ok 00:31:17.0609 0772 [ 0462720476EFFE992BECD63E03F7DAB1 ] InCDsrv C:\Program Files\Nero\Nero 7\InCD\InCDsrv.exe 00:31:17.0625 0772 InCDsrv - ok 00:31:17.0625 0772 ini910u - ok 00:31:17.0640 0772 IntelIde - ok 00:31:17.0656 0772 [ 3BB22519A194418D5FEC05D800A19AD0 ] ip6fw C:\WINDOWS\system32\drivers\ip6fw.sys 00:31:17.0656 0772 ip6fw - ok 00:31:17.0671 0772 [ 731F22BA402EE4B62748ADAF6363C182 ] IpFilterDriver C:\WINDOWS\system32\DRIVERS\ipfltdrv.sys 00:31:17.0671 0772 IpFilterDriver - ok 00:31:17.0687 0772 [ B87AB476DCF76E72010632B5550955F5 ] IpInIp C:\WINDOWS\system32\DRIVERS\ipinip.sys 00:31:17.0687 0772 IpInIp - ok 00:31:17.0718 0772 [ CC748EA12C6EFFDE940EE98098BF96BB ] IpNat C:\WINDOWS\system32\DRIVERS\ipnat.sys 00:31:17.0718 0772 IpNat - ok 00:31:17.0765 0772 [ CE004777B92DEA56FE14EC900D20BAA4 ] iPod Service C:\Program Files\iPod\bin\iPodService.exe 00:31:17.0781 0772 iPod Service - ok 00:31:17.0781 0772 [ 23C74D75E36E7158768DD63D92789A91 ] IPSec C:\WINDOWS\system32\DRIVERS\ipsec.sys 00:31:17.0781 0772 IPSec - ok 00:31:17.0812 0772 [ C93C9FF7B04D772627A3646D89F7BF89 ] IRENUM C:\WINDOWS\system32\DRIVERS\irenum.sys 00:31:17.0812 0772 IRENUM - ok 00:31:17.0828 0772 [ 05A299EC56E52649B1CF2FC52D20F2D7 ] isapnp C:\WINDOWS\system32\DRIVERS\isapnp.sys 00:31:17.0828 0772 isapnp - ok 00:31:17.0828 0772 iscFlash - ok 00:31:17.0890 0772 [ 0A5709543986843D37A92290B7838340 ] JavaQuickStarterService C:\Program Files\Java\jre6\bin\jqs.exe 00:31:17.0906 0772 JavaQuickStarterService - ok 00:31:17.0937 0772 [ 463C1EC80CD17420A542B7F36A36F128 ] Kbdclass C:\WINDOWS\system32\DRIVERS\kbdclass.sys 00:31:17.0937 0772 Kbdclass - ok 00:31:17.0953 0772 [ 692BCF44383D056AED41B045A323D378 ] kmixer C:\WINDOWS\system32\drivers\kmixer.sys 00:31:17.0953 0772 kmixer - ok 00:31:17.0984 0772 [ B467646C54CC746128904E1654C750C1 ] KSecDD C:\WINDOWS\system32\drivers\KSecDD.sys 00:31:18.0000 0772 KSecDD - ok 00:31:18.0015 0772 [ 3A7C3CBE5D96B8AE96CE81F0B22FB527 ] lanmanserver C:\WINDOWS\System32\srvsvc.dll 00:31:18.0031 0772 lanmanserver - ok 00:31:18.0062 0772 [ A8888A5327621856C0CEC4E385F69309 ] lanmanworkstation C:\WINDOWS\System32\wkssvc.dll 00:31:18.0062 0772 lanmanworkstation - ok 00:31:18.0078 0772 lbrtfdc - ok 00:31:18.0109 0772 [ A7DB739AE99A796D91580147E919CC59 ] LmHosts C:\WINDOWS\System32\lmhsvc.dll 00:31:18.0109 0772 LmHosts - ok 00:31:18.0140 0772 [ 986B1FF5814366D71E0AC5755C88F2D3 ] Messenger C:\WINDOWS\System32\msgsvc.dll 00:31:18.0140 0772 Messenger - ok 00:31:18.0156 0772 [ 4AE068242760A1FB6E1A44BF4E16AFA6 ] mnmdd C:\WINDOWS\system32\drivers\mnmdd.sys 00:31:18.0156 0772 mnmdd - ok 00:31:18.0187 0772 [ D18F1F0C101D06A1C1ADF26EED16FCDD ] mnmsrvc C:\WINDOWS\System32\mnmsrvc.exe 00:31:18.0187 0772 mnmsrvc - ok 00:31:18.0203 0772 [ DFCBAD3CEC1C5F964962AE10E0BCC8E1 ] Modem C:\WINDOWS\system32\drivers\Modem.sys 00:31:18.0203 0772 Modem - ok 00:31:18.0234 0772 [ E190ED75BCC7928143F8F2AF4C34D91D ] MotDev C:\WINDOWS\system32\DRIVERS\motodrv.sys 00:31:18.0234 0772 MotDev - ok 00:31:18.0265 0772 [ 54FEE02961C70FD9D4D7E2F87AFA23FA ] motmodem C:\WINDOWS\system32\DRIVERS\motmodem.sys 00:31:18.0265 0772 motmodem - ok 00:31:18.0281 0772 [ 35C9E97194C8CFB8430125F8DBC34D04 ] Mouclass C:\WINDOWS\system32\DRIVERS\mouclass.sys 00:31:18.0281 0772 Mouclass - ok 00:31:18.0312 0772 [ B1C303E17FB9D46E87A98E4BA6769685 ] mouhid C:\WINDOWS\system32\DRIVERS\mouhid.sys 00:31:18.0312 0772 mouhid - ok 00:31:18.0328 0772 [ A80B9A0BAD1B73637DBCBBA7DF72D3FD ] MountMgr C:\WINDOWS\system32\drivers\MountMgr.sys 00:31:18.0328 0772 MountMgr - ok 00:31:18.0375 0772 [ 46297FA8E30A6007F14118FC2B942FBC ] MozillaMaintenance C:\Program Files\Mozilla Maintenance Service\maintenanceservice.exe 00:31:18.0375 0772 MozillaMaintenance - ok 00:31:18.0375 0772 mraid35x - ok 00:31:18.0406 0772 [ 11D42BB6206F33FBB3BA0288D3EF81BD ] MRxDAV C:\WINDOWS\system32\DRIVERS\mrxdav.sys 00:31:18.0406 0772 MRxDAV - ok 00:31:18.0437 0772 [ 7D304A5EB4344EBEEAB53A2FE3FFB9F0 ] MRxSmb C:\WINDOWS\system32\DRIVERS\mrxsmb.sys 00:31:18.0453 0772 MRxSmb - ok 00:31:18.0468 0772 [ A137F1470499A205ABBB9AAFB3B6F2B1 ] MSDTC C:\WINDOWS\System32\msdtc.exe 00:31:18.0468 0772 MSDTC - ok 00:31:18.0500 0772 [ C941EA2454BA8350021D774DAF0F1027 ] Msfs C:\WINDOWS\system32\drivers\Msfs.sys 00:31:18.0500 0772 Msfs - ok 00:31:18.0515 0772 MSIServer - ok 00:31:18.0531 0772 [ D1575E71568F4D9E14CA56B7B0453BF1 ] MSKSSRV C:\WINDOWS\system32\drivers\MSKSSRV.sys 00:31:18.0531 0772 MSKSSRV - ok 00:31:18.0546 0772 [ 325BB26842FC7CCC1FCCE2C457317F3E ] MSPCLOCK C:\WINDOWS\system32\drivers\MSPCLOCK.sys 00:31:18.0546 0772 MSPCLOCK - ok 00:31:18.0562 0772 [ BAD59648BA099DA4A17680B39730CB3D ] MSPQM C:\WINDOWS\system32\drivers\MSPQM.sys 00:31:18.0562 0772 MSPQM - ok 00:31:18.0578 0772 [ AF5F4F3F14A8EA2C26DE30F7A1E17136 ] mssmbios C:\WINDOWS\system32\DRIVERS\mssmbios.sys 00:31:18.0578 0772 mssmbios - ok 00:31:18.0593 0772 [ E53736A9E30C45FA9E7B5EAC55056D1D ] MSTEE C:\WINDOWS\system32\drivers\MSTEE.sys 00:31:18.0609 0772 MSTEE - ok 00:31:18.0625 0772 [ DE6A75F5C270E756C5508D94B6CF68F5 ] Mup C:\WINDOWS\system32\drivers\Mup.sys 00:31:18.0640 0772 Mup - ok 00:31:18.0656 0772 [ 5B50F1B2A2ED47D560577B221DA734DB ] NABTSFEC C:\WINDOWS\system32\DRIVERS\NABTSFEC.sys 00:31:18.0656 0772 NABTSFEC - ok 00:31:18.0671 0772 [ 0102140028FAD045756796E1C685D695 ] napagent C:\WINDOWS\System32\qagentrt.dll 00:31:18.0687 0772 napagent - ok 00:31:18.0750 0772 [ FA0B7D801E71CE79B915BAE5A90DE224 ] NAVENG C:\Documents and Settings\All Users\Application Data\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Data\Definitions\VirusDefs\20120903.017\NAVENG.SYS 00:31:18.0750 0772 NAVENG - ok 00:31:18.0796 0772 [ 80BB71A7D14CF14B54514A201BF5B985 ] NAVEX15 C:\Documents and Settings\All Users\Application Data\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Data\Definitions\VirusDefs\20120903.017\NAVEX15.SYS 00:31:18.0812 0772 NAVEX15 - ok 00:31:18.0859 0772 [ F46070DDADA5C396B1F2EBF1C46DBB08 ] NBService C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe 00:31:18.0875 0772 NBService - ok 00:31:18.0906 0772 [ 1DF7F42665C94B825322FAE71721130D ] NDIS C:\WINDOWS\system32\drivers\NDIS.sys 00:31:18.0906 0772 NDIS - ok 00:31:18.0937 0772 [ 7FF1F1FD8609C149AA432F95A8163D97 ] NdisIP C:\WINDOWS\system32\DRIVERS\NdisIP.sys 00:31:18.0937 0772 NdisIP - ok 00:31:18.0968 0772 [ 0109C4F3850DFBAB279542515386AE22 ] NdisTapi C:\WINDOWS\system32\DRIVERS\ndistapi.sys 00:31:18.0968 0772 NdisTapi - ok 00:31:18.0984 0772 [ F927A4434C5028758A842943EF1A3849 ] Ndisuio C:\WINDOWS\system32\DRIVERS\ndisuio.sys 00:31:18.0984 0772 Ndisuio - ok 00:31:18.0984 0772 [ EDC1531A49C80614B2CFDA43CA8659AB ] NdisWan C:\WINDOWS\system32\DRIVERS\ndiswan.sys 00:31:19.0000 0772 NdisWan - ok 00:31:19.0015 0772 [ 9282BD12DFB069D3889EB3FCC1000A9B ] NDProxy C:\WINDOWS\system32\drivers\NDProxy.sys 00:31:19.0015 0772 NDProxy - ok 00:31:19.0031 0772 [ 5D81CF9A2F1A3A756B66CF684911CDF0 ] NetBIOS C:\WINDOWS\system32\DRIVERS\netbios.sys 00:31:19.0031 0772 NetBIOS - ok 00:31:19.0062 0772 [ 74B2B2F5BEA5E9A3DC021D685551BD3D ] NetBT C:\WINDOWS\system32\DRIVERS\netbt.sys 00:31:19.0062 0772 NetBT - ok 00:31:19.0093 0772 [ B857BA82860D7FF85AE29B095645563B ] NetDDE C:\WINDOWS\system32\netdde.exe 00:31:19.0109 0772 NetDDE - ok 00:31:19.0109 0772 [ B857BA82860D7FF85AE29B095645563B ] NetDDEdsdm C:\WINDOWS\system32\netdde.exe 00:31:19.0109 0772 NetDDEdsdm - ok 00:31:19.0125 0772 [ BF2466B3E18E970D8A976FB95FC1CA85 ] Netlogon C:\WINDOWS\system32\lsass.exe 00:31:19.0140 0772 Netlogon - ok 00:31:19.0140 0772 [ 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE ] Netman C:\WINDOWS\System32\netman.dll 00:31:19.0156 0772 Netman - ok 00:31:19.0203 0772 [ D34612C5D02D026535B3095D620626AE ] NetTcpPortSharing C:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\SMSvcHost.exe 00:31:19.0218 0772 NetTcpPortSharing - ok 00:31:19.0234 0772 [ 943337D786A56729263071623BBB9DE5 ] Nla C:\WINDOWS\System32\mswsock.dll 00:31:19.0234 0772 Nla - ok 00:31:19.0312 0772 [ 433049770B810D7C83C5C94CDB3E09D2 ] NMIndexingService C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe 00:31:19.0312 0772 NMIndexingService - ok 00:31:19.0328 0772 [ F6C40E0A565EE3CE5AEEB325E10054F2 ] nmwcd C:\WINDOWS\system32\drivers\ccdcmb.sys 00:31:19.0343 0772 nmwcd - ok 00:31:19.0375 0772 [ 2A394E9E1FA3565E4B2FEA470FFE4D6B ] nmwcdc C:\WINDOWS\system32\drivers\ccdcmbo.sys 00:31:19.0375 0772 nmwcdc - ok 00:31:19.0390 0772 [ 3182D64AE053D6FB034F44B6DEF8034A ] Npfs C:\WINDOWS\system32\drivers\Npfs.sys 00:31:19.0390 0772 Npfs - ok 00:31:19.0406 0772 [ 78A08DD6A8D65E697C18E1DB01C5CDCA ] Ntfs C:\WINDOWS\system32\drivers\Ntfs.sys 00:31:19.0421 0772 Ntfs - ok 00:31:19.0437 0772 [ BF2466B3E18E970D8A976FB95FC1CA85 ] NtLmSsp C:\WINDOWS\System32\lsass.exe 00:31:19.0437 0772 NtLmSsp - ok 00:31:19.0468 0772 [ 156F64A3345BD23C600655FB4D10BC08 ] NtmsSvc C:\WINDOWS\system32\ntmssvc.dll 00:31:19.0484 0772 NtmsSvc - ok 00:31:19.0515 0772 [ CF7E041663119E09D2E118521ADA9300 ] NuidFltr C:\WINDOWS\system32\DRIVERS\NuidFltr.sys 00:31:19.0515 0772 NuidFltr - ok 00:31:19.0515 0772 [ 73C1E1F395918BC2C6DD67AF7591A3AD ] Null C:\WINDOWS\system32\drivers\Null.sys 00:31:19.0515 0772 Null - ok 00:31:19.0750 0772 [ 4B54DCD6ADEE535DF80F07C59DDD8F14 ] nv C:\WINDOWS\system32\DRIVERS\nv4_mini.sys 00:31:19.0937 0772 nv - ok 00:31:19.0968 0772 [ 0344AA9113DC16EEC379F4652020849D ] nvata C:\WINDOWS\system32\DRIVERS\nvata.sys 00:31:19.0968 0772 nvata - ok 00:31:19.0984 0772 [ 720CC533EECB65553BD86B139CA04433 ] NVENETFD C:\WINDOWS\system32\DRIVERS\NVENETFD.sys 00:31:19.0984 0772 NVENETFD - ok 00:31:20.0000 0772 [ 5F9F545CC5904DD8765F84EE1D056406 ] nvnetbus C:\WINDOWS\system32\DRIVERS\nvnetbus.sys 00:31:20.0000 0772 nvnetbus - ok 00:31:20.0046 0772 [ 0573C75A2895D973EA6EF2495620BA49 ] NVSvc C:\WINDOWS\system32\nvsvc32.exe 00:31:20.0046 0772 NVSvc - ok 00:31:20.0125 0772 [ 9C84945FEEE40EA42D3BCA5C22250D47 ] nvUpdatusService C:\Program Files\NVIDIA Corporation\NVIDIA Updatus\daemonu.exe 00:31:20.0156 0772 nvUpdatusService - ok 00:31:20.0187 0772 [ B305F3FAD35083837EF46A0BBCE2FC57 ] NwlnkFlt C:\WINDOWS\system32\DRIVERS\nwlnkflt.sys 00:31:20.0187 0772 NwlnkFlt - ok 00:31:20.0187 0772 [ C99B3415198D1AAB7227F2C88FD664B9 ] NwlnkFwd C:\WINDOWS\system32\DRIVERS\nwlnkfwd.sys 00:31:20.0187 0772 NwlnkFwd - ok 00:31:20.0265 0772 [ 785F487A64950F3CB8E9F16253BA3B7B ] odserv C:\Program Files\Common Files\Microsoft Shared\OFFICE12\ODSERV.EXE 00:31:20.0281 0772 odserv - ok 00:31:20.0312 0772 [ 5A432A042DAE460ABE7199B758E8606C ] ose C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE 00:31:20.0328 0772 ose - ok 00:31:20.0343 0772 [ 5575FAF8F97CE5E713D108C2A58D7C7C ] Parport C:\WINDOWS\system32\DRIVERS\parport.sys 00:31:20.0343 0772 Parport - ok 00:31:20.0359 0772 [ BEB3BA25197665D82EC7065B724171C6 ] PartMgr C:\WINDOWS\system32\drivers\PartMgr.sys 00:31:20.0359 0772 PartMgr - ok 00:31:20.0390 0772 [ 70E98B3FD8E963A6A46A2E6247E0BEA1 ] ParVdm C:\WINDOWS\system32\drivers\ParVdm.sys 00:31:20.0390 0772 ParVdm - ok 00:31:20.0421 0772 [ 65FB0C4AA30D84849E0E4C97CB5501CE ] pbfilter C:\Program Files\PeerBlock\pbfilter.sys 00:31:20.0421 0772 pbfilter - ok 00:31:20.0437 0772 [ F451DCACBAA67F3307305EBD4A39EA07 ] pccsmcfd C:\WINDOWS\system32\DRIVERS\pccsmcfd.sys 00:31:20.0437 0772 pccsmcfd - ok 00:31:20.0468 0772 [ A219903CCF74233761D92BEF471A07B1 ] PCI C:\WINDOWS\system32\DRIVERS\pci.sys 00:31:20.0468 0772 PCI - ok 00:31:20.0468 0772 PCIDump - ok 00:31:20.0500 0772 [ CCF5F451BB1A5A2A522A76E670000FF0 ] PCIIde C:\WINDOWS\system32\DRIVERS\pciide.sys 00:31:20.0500 0772 PCIIde - ok 00:31:20.0515 0772 [ 9E89EF60E9EE05E3F2EEF2DA7397F1C1 ] Pcmcia C:\WINDOWS\system32\drivers\Pcmcia.sys 00:31:20.0515 0772 Pcmcia - ok 00:31:20.0515 0772 PDCOMP - ok 00:31:20.0531 0772 PDFRAME - ok 00:31:20.0531 0772 PDRELI - ok 00:31:20.0531 0772 PDRFRAME - ok 00:31:20.0546 0772 perc2 - ok 00:31:20.0546 0772 perc2hib - ok 00:31:20.0578 0772 [ 65DF52F5B8B6E9BBD183505225C37315 ] PlugPlay C:\WINDOWS\system32\services.exe 00:31:20.0578 0772 PlugPlay - ok 00:31:20.0593 0772 [ 3A2BDD76E7D2A5F40A7174793D1BA794 ] PnkBstrA C:\WINDOWS\system32\PnkBstrA.exe 00:31:20.0609 0772 PnkBstrA - ok 00:31:20.0609 0772 [ BF2466B3E18E970D8A976FB95FC1CA85 ] PolicyAgent C:\WINDOWS\system32\lsass.exe 00:31:20.0609 0772 PolicyAgent - ok 00:31:20.0656 0772 [ EFEEC01B1D3CF84F16DDD24D9D9D8F99 ] PptpMiniport C:\WINDOWS\system32\DRIVERS\raspptp.sys 00:31:20.0656 0772 PptpMiniport - ok 00:31:20.0656 0772 [ A32BEBAF723557681BFC6BD93E98BD26 ] Processor C:\WINDOWS\system32\DRIVERS\processr.sys 00:31:20.0656 0772 Processor - ok 00:31:20.0671 0772 [ BF2466B3E18E970D8A976FB95FC1CA85 ] ProtectedStorage C:\WINDOWS\system32\lsass.exe 00:31:20.0671 0772 ProtectedStorage - ok 00:31:20.0671 0772 [ 09298EC810B07E5D582CB3A3F9255424 ] PSched C:\WINDOWS\system32\DRIVERS\psched.sys 00:31:20.0671 0772 PSched - ok 00:31:20.0703 0772 [ 80D317BD1C3DBC5D4FE7B1678C60CADD ] Ptilink C:\WINDOWS\system32\DRIVERS\ptilink.sys 00:31:20.0703 0772 Ptilink - ok 00:31:20.0718 0772 [ E42E3433DBB4CFFE8FDD91EAB29AEA8E ] PxHelp20 C:\WINDOWS\system32\Drivers\PxHelp20.sys 00:31:20.0718 0772 PxHelp20 - ok 00:31:20.0750 0772 [ FDDD1AEB9F81EF1E6E48AE1EDC2A97D6 ] QCDonner C:\WINDOWS\system32\DRIVERS\OVCD.sys 00:31:20.0750 0772 QCDonner - ok 00:31:20.0750 0772 ql1080 - ok 00:31:20.0765 0772 Ql10wnt - ok 00:31:20.0765 0772 ql12160 - ok 00:31:20.0765 0772 ql1240 - ok 00:31:20.0781 0772 ql1280 - ok 00:31:20.0781 0772 [ FE0D99D6F31E4FAD8159F690D68DED9C ] RasAcd C:\WINDOWS\system32\DRIVERS\rasacd.sys 00:31:20.0781 0772 RasAcd - ok 00:31:20.0812 0772 [ AD188BE7BDF94E8DF4CA0A55C00A5073 ] RasAuto C:\WINDOWS\System32\rasauto.dll 00:31:20.0828 0772 RasAuto - ok 00:31:20.0828 0772 [ 11B4A627BC9614B885C4969BFA5FF8A6 ] Rasl2tp C:\WINDOWS\system32\DRIVERS\rasl2tp.sys 00:31:20.0843 0772 Rasl2tp - ok 00:31:20.0843 0772 [ 76A9A3CBEADD68CC57CDA5E1D7448235 ] RasMan C:\WINDOWS\System32\rasmans.dll 00:31:20.0843 0772 RasMan - ok 00:31:20.0859 0772 [ 5BC962F2654137C9909C3D4603587DEE ] RasPppoe C:\WINDOWS\system32\DRIVERS\raspppoe.sys 00:31:20.0859 0772 RasPppoe - ok 00:31:20.0875 0772 [ FDBB1D60066FCFBB7452FD8F9829B242 ] Raspti C:\WINDOWS\system32\DRIVERS\raspti.sys 00:31:20.0875 0772 Raspti - ok 00:31:20.0890 0772 [ 7AD224AD1A1437FE28D89CF22B17780A ] Rdbss C:\WINDOWS\system32\DRIVERS\rdbss.sys 00:31:20.0890 0772 Rdbss - ok 00:31:20.0921 0772 [ 4912D5B403614CE99C28420F75353332 ] RDPCDD C:\WINDOWS\system32\DRIVERS\RDPCDD.sys 00:31:20.0921 0772 RDPCDD - ok 00:31:20.0953 0772 [ 15CABD0F7C00C47C70124907916AF3F1 ] rdpdr C:\WINDOWS\system32\DRIVERS\rdpdr.sys 00:31:20.0953 0772 rdpdr - ok 00:31:20.0984 0772 [ 43AF5212BD8FB5BA6EED9754358BD8F7 ] RDPWD C:\WINDOWS\system32\drivers\RDPWD.sys 00:31:20.0984 0772 RDPWD - ok 00:31:21.0015 0772 [ 3C37BF86641BDA977C3BF8A840F3B7FA ] RDSessMgr C:\WINDOWS\system32\sessmgr.exe 00:31:21.0015 0772 RDSessMgr - ok 00:31:21.0046 0772 [ F828DD7E1419B6653894A8F97A0094C5 ] redbook C:\WINDOWS\system32\DRIVERS\redbook.sys 00:31:21.0046 0772 redbook - ok 00:31:21.0078 0772 [ 7E699FF5F59B5D9DE5390E3C34C67CF5 ] RemoteAccess C:\WINDOWS\System32\mprdim.dll 00:31:21.0078 0772 RemoteAccess - ok 00:31:21.0093 0772 [ 5B19B557B0C188210A56A6B699D90B8F ] RemoteRegistry C:\WINDOWS\system32\regsvc.dll 00:31:21.0093 0772 RemoteRegistry - ok 00:31:21.0093 0772 rglfgg - ok 00:31:21.0140 0772 [ F17713D108ACA124A139FDE877EEF68A ] RimUsb C:\WINDOWS\system32\Drivers\RimUsb.sys 00:31:21.0140 0772 RimUsb - ok 00:31:21.0156 0772 [ D9B34325EE5DF78B8F28A3DE9F577C7D ] RimVSerPort C:\WINDOWS\system32\DRIVERS\RimSerial.sys 00:31:21.0156 0772 RimVSerPort - ok 00:31:21.0171 0772 [ D8B0B4ADE32574B2D9C5CC34DC0DBBE7 ] ROOTMODEM C:\WINDOWS\system32\Drivers\RootMdm.sys 00:31:21.0187 0772 ROOTMODEM - ok 00:31:21.0203 0772 RoxLiveShare9 - ok 00:31:21.0218 0772 [ AAED593F84AFA419BBAE8572AF87CF6A ] RpcLocator C:\WINDOWS\System32\locator.exe 00:31:21.0218 0772 RpcLocator - ok 00:31:21.0265 0772 [ 6B27A5C03DFB94B4245739065431322C ] RpcSs C:\WINDOWS\System32\rpcss.dll 00:31:21.0265 0772 RpcSs - ok 00:31:21.0296 0772 [ 471B3F9741D762ABE75E9DEEA4787E47 ] RSVP C:\WINDOWS\System32\rsvp.exe 00:31:21.0296 0772 RSVP - ok 00:31:21.0312 0772 [ BF2466B3E18E970D8A976FB95FC1CA85 ] SamSs C:\WINDOWS\system32\lsass.exe 00:31:21.0312 0772 SamSs - ok 00:31:21.0343 0772 [ 86D007E7A654B9A71D1D7D856B104353 ] SCardSvr C:\WINDOWS\System32\SCardSvr.exe 00:31:21.0343 0772 SCardSvr - ok 00:31:21.0375 0772 [ 0A9A7365A1CA4319AA7C1D6CD8E4EAFA ] Schedule C:\WINDOWS\system32\schedsvc.dll 00:31:21.0375 0772 Schedule - ok 00:31:21.0406 0772 [ 90A3935D05B494A5A39D37E71F09A677 ] Secdrv C:\WINDOWS\system32\DRIVERS\secdrv.sys 00:31:21.0421 0772 Secdrv - ok 00:31:21.0437 0772 [ CBE612E2BB6A10E3563336191EDA1250 ] seclogon C:\WINDOWS\System32\seclogon.dll 00:31:21.0437 0772 seclogon - ok 00:31:21.0453 0772 [ 7FDD5D0684ECA8C1F68B4D99D124DCD0 ] SENS C:\WINDOWS\system32\sens.dll 00:31:21.0468 0772 SENS - ok 00:31:21.0468 0772 sensorsview - ok 00:31:21.0546 0772 [ 74885BDFF62E537F268EBF8E8CEC24BB ] SepMasterService C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\ccSvcHst.exe 00:31:21.0546 0772 SepMasterService - ok 00:31:21.0578 0772 [ 0F29512CCD6BEAD730039FB4BD2C85CE ] serenum C:\WINDOWS\system32\DRIVERS\serenum.sys 00:31:21.0578 0772 serenum - ok 00:31:21.0578 0772 [ CCA207A8896D4C6A0C9CE29A4AE411A7 ] Serial C:\WINDOWS\system32\DRIVERS\serial.sys 00:31:21.0593 0772 Serial - ok 00:31:21.0640 0772 [ E90CE237E99C5D26CB3872318A7799D0 ] ServiceLayer C:\Program Files\PC Connectivity Solution\ServiceLayer.exe 00:31:21.0656 0772 ServiceLayer - ok 00:31:21.0671 0772 [ 8E6B8C671615D126FDC553D1E2DE5562 ] Sfloppy C:\WINDOWS\system32\drivers\Sfloppy.sys 00:31:21.0671 0772 Sfloppy - ok 00:31:21.0703 0772 [ 0B1A5E9CACB5CDD54A2815107BD7C772 ] sfman C:\WINDOWS\system32\drivers\sfmanm.sys 00:31:21.0703 0772 sfman - ok 00:31:21.0734 0772 [ 83F41D0D89645D7235C051AB1D9523AC ] SharedAccess C:\WINDOWS\System32\ipnathlp.dll 00:31:21.0750 0772 SharedAccess - ok 00:31:21.0750 0772 [ 99BC0B50F511924348BE19C7C7313BBF ] ShellHWDetection C:\WINDOWS\System32\shsvcs.dll 00:31:21.0765 0772 ShellHWDetection - ok 00:31:21.0765 0772 Simbad - ok 00:31:21.0875 0772 [ 0F97E7A47A52F4A36969F0FC319654C2 ] Skype C2C Service C:\Documents and Settings\All Users\Application Data\Skype\Toolbars\Skype C2C Service\c2c_service.exe 00:31:21.0921 0772 Skype C2C Service - ok 00:31:21.0968 0772 [ E62ABB10E4E6C2563C8311B7B75E3431 ] SkypeUpdate C:\Program Files\Skype\Updater\Updater.exe 00:31:21.0968 0772 SkypeUpdate - ok 00:31:21.0984 0772 [ 866D538EBE33709A5C9F5C62B73B7D14 ] SLIP C:\WINDOWS\system32\DRIVERS\SLIP.sys 00:31:21.0984 0772 SLIP - ok 00:31:22.0046 0772 [ 244687A7F63848235B8B5CC493B6CAFF ] SmcService C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\Smc.exe 00:31:22.0078 0772 SmcService - ok 00:31:22.0093 0772 [ 6CD803703835CC3EA4E8D47B2517F1C1 ] SNAC C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\snac.exe 00:31:22.0093 0772 SNAC - ok 00:31:22.0125 0772 [ DFADFC2C86662F40759BF02ADD27D569 ] sonypvs1 C:\WINDOWS\system32\DRIVERS\sonypvs1.sys 00:31:22.0140 0772 sonypvs1 - ok 00:31:22.0140 0772 Sparrow - ok 00:31:22.0187 0772 [ AB8B92451ECB048A4D1DE7C3FFCB4A9F ] splitter C:\WINDOWS\system32\drivers\splitter.sys 00:31:22.0187 0772 splitter - ok 00:31:22.0218 0772 [ 60784F891563FB1B767F70117FC2428F ] Spooler C:\WINDOWS\system32\spoolsv.exe 00:31:22.0218 0772 Spooler - ok 00:31:22.0265 0772 [ CDDDEC541BC3C96F91ECB48759673505 ] sptd C:\WINDOWS\system32\Drivers\sptd.sys 00:31:22.0265 0772 Suspicious file (NoAccess): C:\WINDOWS\system32\Drivers\sptd.sys. md5: CDDDEC541BC3C96F91ECB48759673505 00:31:22.0265 0772 sptd ( LockedFile.Multi.Generic ) - warning 00:31:22.0265 0772 sptd - detected LockedFile.Multi.Generic (1) 00:31:22.0265 0772 [ 76BB022C2FB6902FD5BDD4F78FC13A5D ] sr C:\WINDOWS\system32\DRIVERS\sr.sys 00:31:22.0281 0772 sr - ok 00:31:22.0296 0772 [ 3805DF0AC4296A34BA4BF93B346CC378 ] srservice C:\WINDOWS\system32\srsvc.dll 00:31:22.0312 0772 srservice - ok 00:31:22.0359 0772 [ 818FF33E09C5EF86E721E1FC00154564 ] SRTSP C:\WINDOWS\system32\Drivers\SEP\0C0103E8\009D.105\x86\SRTSP.SYS 00:31:22.0359 0772 SRTSP - ok 00:31:22.0375 0772 [ 3C01529E8B986D9DC7489F7CE8BCAD91 ] SRTSPX C:\WINDOWS\system32\Drivers\SEP\0C0103E8\009D.105\x86\SRTSPX.SYS 00:31:22.0390 0772 SRTSPX - ok 00:31:22.0406 0772 [ 47DDFC2F003F7F9F0592C6874962A2E7 ] Srv C:\WINDOWS\system32\DRIVERS\srv.sys 00:31:22.0421 0772 Srv - ok 00:31:22.0437 0772 [ 0A5679B3714EDAB99E357057EE88FCA6 ] SSDPSRV C:\WINDOWS\System32\ssdpsrv.dll 00:31:22.0437 0772 SSDPSRV - ok 00:31:22.0453 0772 Steam Client Service - ok 00:31:22.0484 0772 [ 8BAD69CBAC032D4BBACFCE0306174C30 ] stisvc C:\WINDOWS\system32\wiaservc.dll 00:31:22.0484 0772 stisvc - ok 00:31:22.0500 0772 [ 77813007BA6265C4B6098187E6ED79D2 ] streamip C:\WINDOWS\system32\DRIVERS\StreamIP.sys 00:31:22.0500 0772 streamip - ok 00:31:22.0515 0772 [ 3941D127AEF12E93ADDF6FE6EE027E0F ] swenum C:\WINDOWS\system32\DRIVERS\swenum.sys 00:31:22.0515 0772 swenum - ok 00:31:22.0531 0772 [ 8CE882BCC6CF8A62F2B2323D95CB3D01 ] swmidi C:\WINDOWS\system32\drivers\swmidi.sys 00:31:22.0531 0772 swmidi - ok 00:31:22.0531 0772 SwPrv - ok 00:31:22.0562 0772 [ A0B824E49347B279ACB3903C04C78F75 ] SyDvCtrl C:\Program Files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\SyDvCtrl32.sys 00:31:22.0562 0772 SyDvCtrl - ok 00:31:22.0562 0772 symc810 - ok 00:31:22.0562 0772 symc8xx - ok 00:31:22.0593 0772 [ 4F52D56310FEF75249914F352DDE7D13 ] SymDS C:\WINDOWS\system32\Drivers\SEP\0C0103E8\009D.105\x86\SYMDS.SYS 00:31:22.0593 0772 SymDS - ok 00:31:22.0640 0772 [ 71B5577BADCF9C9420393395601BB995 ] SymEFA C:\WINDOWS\system32\Drivers\SEP\0C0103E8\009D.105\x86\SYMEFA.SYS 00:31:22.0640 0772 SymEFA - ok 00:31:22.0671 0772 [ 98D28D08E68145FB550EE7670B43BAF2 ] SymEvent C:\WINDOWS\system32\Drivers\SYMEVENT.SYS 00:31:22.0687 0772 SymEvent - ok 00:31:22.0718 0772 [ 7450A24AFBC9B0804D0A987204FFC0F8 ] SymIRON C:\WINDOWS\system32\Drivers\SEP\0C0103E8\009D.105\x86\Ironx86.SYS 00:31:22.0718 0772 SymIRON - ok 00:31:22.0750 0772 [ 2B574C93D074222D2BC8FF9A27567BFD ] SYMTDI C:\WINDOWS\system32\Drivers\SEP\0C0103E8\009D.105\x86\SYMTDI.SYS 00:31:22.0750 0772 SYMTDI - ok 00:31:22.0765 0772 sym_hi - ok 00:31:22.0765 0772 sym_u3 - ok 00:31:22.0796 0772 [ 8B83F3ED0F1688B4958F77CD6D2BF290 ] sysaudio C:\WINDOWS\system32\drivers\sysaudio.sys 00:31:22.0796 0772 sysaudio - ok 00:31:22.0812 0772 [ C7ABBC59B43274B1109DF6B24D617051 ] SysmonLog C:\WINDOWS\system32\smlogsvc.exe 00:31:22.0828 0772 SysmonLog - ok 00:31:22.0843 0772 [ 65C165C4324D153429BF3BA9350F3084 ] SysPlant C:\WINDOWS\system32\Drivers\SysPlant.sys 00:31:22.0859 0772 SysPlant - ok 00:31:22.0875 0772 [ 3CB78C17BB664637787C9A1C98F79C38 ] TapiSrv C:\WINDOWS\System32\tapisrv.dll 00:31:22.0890 0772 TapiSrv - ok 00:31:22.0921 0772 [ 9AEFA14BD6B182D61E3119FA5F436D3D ] Tcpip C:\WINDOWS\system32\DRIVERS\tcpip.sys 00:31:22.0921 0772 Tcpip - ok 00:31:22.0953 0772 [ 6471A66807F5E104E4885F5B67349397 ] TDPIPE C:\WINDOWS\system32\drivers\TDPIPE.sys 00:31:22.0953 0772 TDPIPE - ok 00:31:22.0968 0772 [ C56B6D0402371CF3700EB322EF3AAF61 ] TDTCP C:\WINDOWS\system32\drivers\TDTCP.sys 00:31:22.0968 0772 TDTCP - ok 00:31:22.0984 0772 [ 88155247177638048422893737429D9E ] TermDD C:\WINDOWS\system32\DRIVERS\termdd.sys 00:31:22.0984 0772 TermDD - ok 00:31:23.0015 0772 [ FF3477C03BE7201C294C35F684B3479F ] TermService C:\WINDOWS\System32\termsrv.dll 00:31:23.0031 0772 TermService - ok 00:31:23.0046 0772 [ 99BC0B50F511924348BE19C7C7313BBF ] Themes C:\WINDOWS\System32\shsvcs.dll 00:31:23.0046 0772 Themes - ok 00:31:23.0062 0772 [ DB7205804759FF62C34E3EFD8A4CC76A ] TlntSvr C:\WINDOWS\System32\tlntsvr.exe 00:31:23.0062 0772 TlntSvr - ok 00:31:23.0078 0772 TosIde - ok 00:31:23.0093 0772 [ 55BCA12F7F523D35CA3CB833C725F54E ] TrkWks C:\WINDOWS\system32\trkwks.dll 00:31:23.0093 0772 TrkWks - ok 00:31:23.0109 0772 [ 5787B80C2E3C5E2F56C2A233D91FA2C9 ] Udfs C:\WINDOWS\system32\drivers\Udfs.sys 00:31:23.0109 0772 Udfs - ok 00:31:23.0125 0772 ultra - ok 00:31:23.0156 0772 [ 402DDC88356B1BAC0EE3DD1580C76A31 ] Update C:\WINDOWS\system32\DRIVERS\update.sys 00:31:23.0156 0772 Update - ok 00:31:23.0171 0772 [ 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 ] upnphost C:\WINDOWS\System32\upnphost.dll 00:31:23.0187 0772 upnphost - ok 00:31:23.0218 0772 [ 47F5F9D837D80FFD5882A14DB9DA0A67 ] upperdev C:\WINDOWS\system32\DRIVERS\usbser_lowerflt.sys 00:31:23.0218 0772 upperdev - ok 00:31:23.0234 0772 [ 05365FB38FCA1E98F7A566AAAF5D1815 ] UPS C:\WINDOWS\System32\ups.exe 00:31:23.0234 0772 UPS - ok 00:31:23.0250 0772 [ EAFE1E00739AFE6C51487A050E772E17 ] USBAAPL C:\WINDOWS\system32\Drivers\usbaapl.sys 00:31:23.0250 0772 USBAAPL - ok 00:31:23.0296 0772 [ E919708DB44ED8543A7C017953148330 ] usbaudio C:\WINDOWS\system32\drivers\usbaudio.sys 00:31:23.0296 0772 usbaudio - ok 00:31:23.0328 0772 [ 173F317CE0DB8E21322E71B7E60A27E8 ] usbccgp C:\WINDOWS\system32\DRIVERS\usbccgp.sys 00:31:23.0328 0772 usbccgp - ok 00:31:23.0359 0772 [ 65DCF09D0E37D4C6B11B5B0B76D470A7 ] usbehci C:\WINDOWS\system32\DRIVERS\usbehci.sys 00:31:23.0359 0772 usbehci - ok 00:31:23.0375 0772 [ 1AB3CDDE553B6E064D2E754EFE20285C ] usbhub C:\WINDOWS\system32\DRIVERS\usbhub.sys 00:31:23.0390 0772 usbhub - ok 00:31:23.0390 0772 [ 0DAECCE65366EA32B162F85F07C6753B ] usbohci C:\WINDOWS\system32\DRIVERS\usbohci.sys 00:31:23.0390 0772 usbohci - ok 00:31:23.0421 0772 [ A0B8CF9DEB1184FBDD20784A58FA75D4 ] usbscan C:\WINDOWS\system32\DRIVERS\usbscan.sys 00:31:23.0421 0772 usbscan - ok 00:31:23.0437 0772 [ 1C888B000C2F9492F4B15B5B6B84873E ] usbser C:\WINDOWS\system32\drivers\usbser.sys 00:31:23.0468 0772 usbser - ok 00:31:23.0500 0772 [ E44F0D17BE0908B58DCC99CCB99C6C32 ] UsbserFilt C:\WINDOWS\system32\DRIVERS\usbser_lowerfltj.sys 00:31:23.0500 0772 UsbserFilt - ok 00:31:23.0515 0772 [ A32426D9B14A089EAA1D922E0C5801A9 ] USBSTOR C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS 00:31:23.0515 0772 USBSTOR - ok 00:31:23.0531 0772 [ 0D3A8FAFCEACD8B7625CD549757A7DF1 ] VgaSave C:\WINDOWS\System32\drivers\vga.sys 00:31:23.0546 0772 VgaSave - ok 00:31:23.0546 0772 ViaIde - ok 00:31:23.0578 0772 [ 4C8FCB5CC53AAB716D810740FE59D025 ] VolSnap C:\WINDOWS\system32\drivers\VolSnap.sys 00:31:23.0578 0772 VolSnap - ok 00:31:23.0593 0772 vsdatant - ok 00:31:23.0625 0772 [ 7A9DB3A67C333BF0BD42E42B8596854B ] VSS C:\WINDOWS\System32\vssvc.exe 00:31:23.0640 0772 VSS - ok 00:31:23.0656 0772 [ 54AF4B1D5459500EF0937F6D33B1914F ] W32Time C:\WINDOWS\system32\w32time.dll 00:31:23.0656 0772 W32Time - ok 00:31:23.0671 0772 [ E20B95BAEDB550F32DD489265C1DA1F6 ] Wanarp C:\WINDOWS\system32\DRIVERS\wanarp.sys 00:31:23.0671 0772 Wanarp - ok 00:31:23.0703 0772 [ D918617B46457B9AC28027722E30F647 ] Wdf01000 C:\WINDOWS\system32\DRIVERS\Wdf01000.sys 00:31:23.0703 0772 Wdf01000 - ok 00:31:23.0718 0772 WDICA - ok 00:31:23.0734 0772 [ 6768ACF64B18196494413695F0C3A00F ] wdmaud C:\WINDOWS\system32\drivers\wdmaud.sys 00:31:23.0734 0772 wdmaud - ok 00:31:23.0765 0772 [ 77A354E28153AD2D5E120A5A8687BC06 ] WebClient C:\WINDOWS\System32\webclnt.dll 00:31:23.0765 0772 WebClient - ok 00:31:23.0812 0772 [ F45DD1E1365D857DD08BC23563370D0E ] WinDefend C:\Program Files\Windows Defender\MsMpEng.exe 00:31:23.0812 0772 WinDefend - ok 00:31:23.0859 0772 [ 2D0E4ED081963804CCC196A0929275B5 ] winmgmt C:\WINDOWS\system32\wbem\WMIsvc.dll 00:31:23.0859 0772 winmgmt - ok 00:31:23.0890 0772 [ C51B4A5C05A5475708E3C81C7765B71D ] WmdmPmSN C:\WINDOWS\system32\MsPMSNSv.dll 00:31:23.0906 0772 WmdmPmSN - ok 00:31:23.0937 0772 [ E76F8807070ED04E7408A86D6D3A6137 ] Wmi C:\WINDOWS\System32\advapi32.dll 00:31:23.0937 0772 Wmi - ok 00:31:23.0968 0772 [ E0673F1106E62A68D2257E376079F821 ] WmiApSrv C:\WINDOWS\System32\wbem\wmiapsrv.exe 00:31:23.0968 0772 WmiApSrv - ok 00:31:24.0031 0772 [ F74E3D9A7FA9556C3BBB14D4E5E63D3B ] WMPNetworkSvc C:\Program Files\Windows Media Player\WMPNetwk.exe 00:31:24.0046 0772 WMPNetworkSvc - ok 00:31:24.0062 0772 [ CF4DEF1BF66F06964DC0D91844239104 ] WpdUsb C:\WINDOWS\system32\DRIVERS\wpdusb.sys 00:31:24.0062 0772 WpdUsb - ok 00:31:24.0140 0772 [ DCF3E3EDF5109EE8BC02FE6E1F045795 ] WPFFontCache_v0400 C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe 00:31:24.0156 0772 WPFFontCache_v0400 - ok 00:31:24.0203 0772 [ 6ABE6E225ADB5A751622A9CC3BC19CE8 ] WS2IFSL C:\WINDOWS\System32\drivers\ws2ifsl.sys 00:31:24.0203 0772 WS2IFSL - ok 00:31:24.0234 0772 [ 7C278E6408D1DCE642230C0585A854D5 ] wscsvc C:\WINDOWS\system32\wscsvc.dll 00:31:24.0234 0772 wscsvc - ok 00:31:24.0234 0772 WSearch - ok 00:31:24.0250 0772 [ C98B39829C2BBD34E454150633C62C78 ] WSTCODEC C:\WINDOWS\system32\DRIVERS\WSTCODEC.SYS 00:31:24.0250 0772 WSTCODEC - ok 00:31:24.0265 0772 [ 35321FB577CDC98CE3EB3A3EB9E4610A ] wuauserv C:\WINDOWS\system32\wuauserv.dll 00:31:24.0281 0772 wuauserv - ok 00:31:24.0296 0772 [ F15FEAFFFBB3644CCC80C5DA584E6311 ] WudfPf C:\WINDOWS\system32\DRIVERS\WudfPf.sys 00:31:24.0312 0772 WudfPf - ok 00:31:24.0328 0772 [ 28B524262BCE6DE1F7EF9F510BA3985B ] WudfRd C:\WINDOWS\system32\DRIVERS\wudfrd.sys 00:31:24.0328 0772 WudfRd - ok 00:31:24.0343 0772 [ 05231C04253C5BC30B26CBAAE680ED89 ] WudfSvc C:\WINDOWS\System32\WUDFSvc.dll 00:31:24.0343 0772 WudfSvc - ok 00:31:24.0390 0772 [ 81DC3F549F44B1C1FFF022DEC9ECF30B ] WZCSVC C:\WINDOWS\System32\wzcsvc.dll 00:31:24.0390 0772 WZCSVC - ok 00:31:24.0406 0772 xdgjddwbvrch - ok 00:31:24.0437 0772 [ 295D21F14C335B53CB8154E5B1F892B9 ] xmlprov C:\WINDOWS\System32\xmlprov.dll 00:31:24.0437 0772 xmlprov - ok 00:31:24.0515 0772 [ DD0042F0C3B606A6A8B92D49AFB18AD6 ] YahooAUService C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe 00:31:24.0531 0772 YahooAUService - ok 00:31:24.0546 0772 ================ Scan global =============================== 00:31:24.0578 0772 [ 42F1F4C0AFB08410E5F02D4B13EBB623 ] C:\WINDOWS\system32\basesrv.dll 00:31:24.0609 0772 [ 8C7DCA4B158BF16894120786A7A5F366 ] C:\WINDOWS\system32\winsrv.dll 00:31:24.0609 0772 [ 8C7DCA4B158BF16894120786A7A5F366 ] C:\WINDOWS\system32\winsrv.dll 00:31:24.0640 0772 [ 65DF52F5B8B6E9BBD183505225C37315 ] C:\WINDOWS\system32\services.exe 00:31:24.0640 0772 [Global] - ok 00:31:24.0640 0772 ================ Scan MBR ================================== 00:31:24.0640 0772 [ 8F558EB6672622401DA993E1E865C861 ] \Device\Harddisk1\DR1 00:31:24.0734 0772 \Device\Harddisk1\DR1 - ok 00:31:24.0750 0772 [ 8F558EB6672622401DA993E1E865C861 ] \Device\Harddisk2\DR2 00:31:24.0828 0772 \Device\Harddisk2\DR2 - ok 00:31:24.0828 0772 ================ Scan VBR ================================== 00:31:24.0828 0772 [ B8CFA1C130AB7B9E5195245BAF964148 ] \Device\Harddisk1\DR1\Partition1 00:31:24.0828 0772 \Device\Harddisk1\DR1\Partition1 - ok 00:31:24.0843 0772 [ E12A7E5C69236BEFEC6466E96B613FB0 ] \Device\Harddisk2\DR2\Partition1 00:31:24.0843 0772 \Device\Harddisk2\DR2\Partition1 - ok 00:31:24.0843 0772 ============================================================ 00:31:24.0843 0772 Scan finished 00:31:24.0843 0772 ============================================================ 00:31:24.0859 1408 Detected object count: 1 00:31:24.0859 1408 Actual detected object count: 1 00:31:34.0500 1408 sptd ( LockedFile.Multi.Generic ) - skipped by user 00:31:34.0500 1408 sptd ( LockedFile.Multi.Generic ) - User select action: Skip
Download and Install Combofix
Download ComboFix from one of the following locations:
Link 2
VERY IMPORTANT !!! Save ComboFix.exe to your Desktop
* IMPORTANT - Disable your AntiVirus and AntiSpyware applications, usually via a right click on the System Tray icon. They may otherwise interfere with our tools. If you have difficulty properly disabling your protective programs, refer to this link here
  • Double click on ComboFix.exe & follow the prompts.
As part of it's process, ComboFix will check to see if the Microsoft Windows Recovery Console is installed. With malware infections being as they are today, it's strongly recommended to have this pre-installed on your machine before doing any malware removal. It will allow you to boot up into a special recovery/repair mode that will allow us to more easily help you should your computer have a problem after an attempted removal of malware.
  • Follow the prompts to allow ComboFix to download and install the Microsoft Windows Recovery Console, and when prompted, agree to the End-User License Agreement to install the Microsoft Windows Recovery Console.
**Please note: If the Microsoft Windows Recovery Console is already installed, ComboFix will continue it's malware removal procedures.
  • Once the Microsoft Windows Recovery Console is installed using ComboFix, you should see the following message:
  • Click on Yes, to continue scanning for malware.
When finished, it shall produce a log for you. Please include the C:\ComboFix.txt in your next reply.
Notes:
1. 1. Do not mouse-click anywhere on the screen while it is running. That may cause it to stall. In fact, I suggest you do not do anything else on the computer while Combofix is running as it can cause it to stall. It may appear at times that it isn't doing anything but it is. Just let it run. It may also reboot the machine as a part of what it is doing and that is not unusual. (If your computer requires a login then you WILL need to fill in the login/password for it to continue. If your computer does not have a login then it will continue on it's own..) Then, just sit tight until it finishes. Sometimes it takes 10 minutes, sometimes it takes an hour. Just be patient until the log pops up. If it takes more than an hour and doesn't appear to be doing antying, you can stop it and come back and let me know.
2. Do not "re-run" Combofix. If you have a problem, reply back for further instructions.
Please make sure you include the combo fix log in your next reply as well as describe how your computer is running now
Hi Patndoris, I went through your Combofix instructions, and pulled it off - everything went without a hitch, and happened exactly as you described (I had to install the Windows Recovery Console). Right now my computer is actually behaving a lot better than when I made my first post - logging in to Windows and getting to the desktop is faster (not back to normal 100%, but not abnormally slow, like taking 10+ minutes to get to desktop). I do suspect that the system is also just old and that a reimaged and reinstalled Windows would make it right as rain. But there is no longer any truly abnormal 10 minutes or more wait, for the PC to start up. That behavior was mainly why I came here. Below is the Combofix log. Do let me know if you'd like me try anything further. Again, thanks for your help! EDIT: The Combofix log was too long, and the forum said I had to shorten my reply. I will post the log in a total of 3 parts, starting with the below. ————————— ComboFix 12-09-13.03 - Basilio 09/13/2012 23:48:54.6.2 - x86 Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.2047.1298 [GMT -4:00] Running from: c:\documents and settings\[removed]\Desktop\ComboFix.exe AV: Symantec Endpoint Protection *Disabled/Updated* {FB06448E-52B8-493A-90F3-E43226D3305C} . . ((((((((((((((((((((((((((((((((((((((( Other Deletions ))))))))))))))))))))))))))))))))))))))))))))))))) . . c:\documents and settings\All Users\Application Data\TEMP c:\documents and settings\Basilio\Application Data\Basilio3SQLite3.dll c:\documents and settings\Basilio\Application Data\Basiliolog.dat c:\documents and settings\Basilio\Application Data\Microsoft\~DFK575acb.tmp c:\documents and settings\Basilio\Application Data\Microsoft\1eaadjc.dll c:\documents and settings\Basilio\Application Data\Microsoft\bass.dll c:\documents and settings\Basilio\Application Data\Microsoft\cxaadji.dll c:\documents and settings\Basilio\Application Data\Microsoft\engine_vx.dll c:\documents and settings\Basilio\Application Data\Microsoft\kfgresk.dll c:\documents and settings\Basilio\Application Data\Microsoft\khaadjf.dll c:\documents and settings\Basilio\Application Data\Microsoft\mjcriu.dll c:\documents and settings\Basilio\Application Data\Microsoft\mnhjrel.dll c:\documents and settings\Basilio\Application Data\Microsoft\ncaadjg.dll c:\documents and settings\Basilio\Application Data\Microsoft\peaadje.dll c:\documents and settings\Basilio\Application Data\Microsoft\qwadjb.dll c:\documents and settings\Basilio\Application Data\Microsoft\rsaadjd.dll c:\documents and settings\Basilio\Application Data\Microsoft\vqaadjh.dll c:\documents and settings\Basilio\Application Data\Microsoft\wqaadjj.dll c:\documents and settings\Basilio\Application Data\PriceGong c:\documents and settings\Basilio\Application Data\PriceGong\Data\1.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\17781.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\413.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\a.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\b.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\c.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\d.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\e.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\f.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\g.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\h.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\i.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\j.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\k.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\l.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\m.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\mru.xml c:\documents and settings\Basilio\Application Data\PriceGong\Data\n.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\o.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\p.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\q.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\r.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\s.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\t.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\u.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\v.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\w.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\wlu.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\x.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\y.txt c:\documents and settings\Basilio\Application Data\PriceGong\Data\z.txt c:\documents and settings\Basilio\WINDOWS c:\windows\system32\syoepk_lib0.dll c:\windows\system32\URTTemp c:\windows\system32\URTTemp\regtlib.exe c:\windows\system32\windir F:\install.exe . . ((((((((((((((((((((((((( Files Created from 2012-08-14 to 2012-09-14 ))))))))))))))))))))))))))))))) . . 2012-09-13 06:49 . 2012-09-13 06:49 73696 —-a-w- c:\program files\Mozilla Firefox\breakpadinjector.dll 2012-09-03 19:39 . 2012-09-03 19:39 ——– d—–w- c:\documents and settings\LocalService\Local Settings\Application Data\Adobe 2012-08-19 07:25 . 2012-08-19 07:26 ——– d—–w- c:\program files\Common Files\Nokia 2012-08-19 07:23 . 2012-06-27 19:18 19072 —-a-w- c:\windows\system32\drivers\pccsmcfd.sys 2012-08-19 07:23 . 2012-08-19 07:23 ——– d—–w- c:\program files\PC Connectivity Solution 2012-08-17 03:11 . 2012-08-17 03:11 60872 —-a-w- c:\windows\system32\S32EVNT1.DLL 2012-08-17 03:11 . 2012-08-17 03:11 127096 —-a-w- c:\windows\system32\drivers\SYMEVENT.SYS 2012-08-17 03:10 . 2012-08-17 03:10 90032 —-a-w- c:\windows\system32\drivers\SysPlant.sys 2012-08-17 03:10 . 2012-08-17 03:10 76208 —-a-w- c:\windows\system32\FwsVpn.dll 2012-08-17 03:10 . 2012-08-17 03:10 374704 —-a-w- c:\windows\system32\sysfer.dll 2012-08-17 03:10 . 2012-08-17 03:10 32208 —-a-w- c:\windows\system32\drivers\WGX.SYS 2012-08-17 03:10 . 2012-08-17 03:10 241584 —-a-w- c:\windows\system32\SymVPN.dll 2012-08-17 03:10 . 2012-08-17 03:10 10672 —-a-w- c:\windows\system32\sysferThunk.dll 2012-08-17 03:10 . 2012-08-17 03:10 ——– d—–w- c:\documents and settings\All Users\Application Data\regid.1992_12.com.symantec 2012-08-17 03:10 . 2012-08-17 03:11 ——– d—–w- c:\program files\Symantec 2012-08-17 03:10 . 2012-08-17 03:10 ——– d—–w- c:\windows\system32\drivers\SEP 2012-08-15 16:52 . 2012-08-15 16:52 4472832 —-a-w- c:\windows\system32\GPhotos.scr . . . (((((((((((((((((((((((((((((((((((((((( Find3M Report )))))))))))))))))))))))))))))))))))))))))))))))))))) . 2012-08-31 06:18 . 2012-04-13 18:57 696520 —-a-w- c:\windows\system32\FlashPlayerApp.exe 2012-08-31 06:18 . 2011-05-22 15:25 73416 —-a-w- c:\windows\system32\FlashPlayerCPLApp.cpl 2012-07-06 13:58 . 2001-08-23 12:00 78336 —-a-w- c:\windows\system32\browser.dll 2012-07-04 14:05 . 2009-04-18 21:30 139784 —-a-w- c:\windows\system32\drivers\rdpwd.sys 2012-07-03 17:46 . 2009-04-20 11:47 22344 —-a-w- c:\windows\system32\drivers\mbam.sys 2012-07-03 13:40 . 2001-08-23 12:00 1866112 —-a-w- c:\windows\system32\win32k.sys 2012-07-02 17:49 . 2010-04-18 06:10 916992 —-a-w- c:\windows\system32\wininet.dll 2012-07-02 17:49 . 2001-08-23 12:00 43520 —-a-w- c:\windows\system32\licmgr10.dll 2012-07-02 17:49 . 2001-08-23 12:00 1469440 ——w- c:\windows\system32\inetcpl.cpl 2012-07-02 12:05 . 2004-08-04 05:59 385024 —-a-w- c:\windows\system32\html.iec 2012-09-13 06:49 . 2011-12-17 18:07 266720 —-a-w- c:\program files\mozilla firefox\components\browsercomps.dll (continued on another post - this is part 1 of 3)
(continued from previous post - part 2 of 3) ((((((((((((((((((((((((((((( SnapShot_2010-06-22_12.24.06 ))))))))))))))))))))))))))))))))))))))))) . + 2011-04-19 02:51 . 2011-04-19 02:51 51024 c:\windows\WinSxS\x86_Microsoft.VC90.OpenMP_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_4ddc769f\vcomp90.dll + 2011-01-11 14:59 . 2011-01-11 14:59 51024 c:\windows\WinSxS\x86_Microsoft.VC90.OpenMP_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_214ee422\vcomp90.dll + 2009-07-12 04:02 . 2009-07-12 04:02 51008 c:\windows\WinSxS\x86_Microsoft.VC90.OpenMP_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_f0ccd4aa\vcomp90.dll + 2011-04-19 02:51 . 2011-04-19 02:51 59728 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90rus.dll + 2011-04-19 02:51 . 2011-04-19 02:51 42832 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90kor.dll + 2011-04-19 02:51 . 2011-04-19 02:51 43344 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90jpn.dll + 2011-04-19 02:51 . 2011-04-19 02:51 61264 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90ita.dll + 2011-04-19 02:51 . 2011-04-19 02:51 62800 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90fra.dll + 2011-04-19 02:51 . 2011-04-19 02:51 61776 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90esp.dll + 2011-04-19 02:51 . 2011-04-19 02:51 61776 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90esn.dll + 2011-04-19 02:51 . 2011-04-19 02:51 53584 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90enu.dll + 2011-04-19 02:51 . 2011-04-19 02:51 63312 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90deu.dll + 2011-04-19 02:51 . 2011-04-19 02:51 36688 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90cht.dll + 2011-04-19 02:51 . 2011-04-19 02:51 35664 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_730c3508\mfc90chs.dll + 2011-01-11 14:59 . 2011-01-11 14:59 59728 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90rus.dll + 2011-01-11 14:59 . 2011-01-11 14:59 42832 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90kor.dll + 2011-01-11 14:59 . 2011-01-11 14:59 43344 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90jpn.dll + 2011-01-11 14:59 . 2011-01-11 14:59 61264 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90ita.dll + 2011-01-11 14:59 . 2011-01-11 14:59 62800 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90fra.dll + 2011-01-11 14:59 . 2011-01-11 14:59 61776 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90esp.dll + 2011-01-11 14:59 . 2011-01-11 14:59 61776 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90esn.dll + 2011-01-11 14:59 . 2011-01-11 14:59 53584 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90enu.dll + 2011-01-11 14:59 . 2011-01-11 14:59 63312 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90deu.dll + 2011-01-11 14:59 . 2011-01-11 14:59 36688 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90cht.dll + 2011-01-11 14:59 . 2011-01-11 14:59 35664 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_467ea28b\mfc90chs.dll + 2009-07-12 04:02 . 2009-07-12 04:02 59728 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90rus.dll + 2009-07-12 04:02 . 2009-07-12 04:02 42832 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90kor.dll + 2009-07-12 04:02 . 2009-07-12 04:02 43344 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90jpn.dll + 2009-07-12 04:02 . 2009-07-12 04:02 61264 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90ita.dll + 2009-07-12 04:02 . 2009-07-12 04:02 62800 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90fra.dll + 2009-07-12 04:02 . 2009-07-12 04:02 61760 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90esp.dll + 2009-07-12 04:02 . 2009-07-12 04:02 61776 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90esn.dll + 2009-07-12 04:02 . 2009-07-12 04:02 53568 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90enu.dll + 2009-07-12 04:02 . 2009-07-12 04:02 63296 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90deu.dll + 2009-07-12 04:02 . 2009-07-12 04:02 36688 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90cht.dll + 2009-07-12 04:02 . 2009-07-12 04:02 35648 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_15fc9313\mfc90chs.dll + 2007-11-07 05:19 . 2007-11-07 05:19 46592 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90kor.dll + 2007-11-07 05:19 . 2007-11-07 05:19 47104 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90jpn.dll + 2007-11-07 05:19 . 2007-11-07 05:19 59392 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90ita.dll + 2007-11-07 05:19 . 2007-11-07 05:19 60416 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90fra.dll + 2007-11-07 05:19 . 2007-11-07 05:19 59392 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90esp.dll + 2007-11-07 05:19 . 2007-11-07 05:19 59392 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90esn.dll + 2007-11-07 05:19 . 2007-11-07 05:19 54272 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90enu.dll + 2007-11-07 05:19 . 2007-11-07 05:19 60928 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90deu.dll + 2007-11-07 05:19 . 2007-11-07 05:19 41984 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90cht.dll + 2007-11-07 05:19 . 2007-11-07 05:19 41472 c:\windows\WinSxS\x86_Microsoft.VC90.MFCLOC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_11f3ea3a\mfc90chs.dll + 2011-04-19 02:51 . 2011-04-19 02:51 59904 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_028bc148\mfcm90u.dll + 2011-04-19 02:51 . 2011-04-19 02:51 59904 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_028bc148\mfcm90.dll + 2011-01-11 14:59 . 2011-01-11 14:59 59904 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_d5fe2ecb\mfcm90u.dll + 2011-01-11 14:59 . 2011-01-11 14:59 59904 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_d5fe2ecb\mfcm90.dll + 2009-07-12 04:05 . 2009-07-12 04:05 59904 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_a57c1f53\mfcm90u.dll + 2009-07-12 04:05 . 2009-07-12 04:05 59904 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_a57c1f53\mfcm90.dll + 2007-11-07 02:51 . 2007-11-07 02:51 59904 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_a173767a\mfcm90u.dll + 2007-11-07 02:51 . 2007-11-07 02:51 59904 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_a173767a\mfcm90.dll + 2006-12-02 04:46 . 2006-12-02 04:46 65536 c:\windows\WinSxS\x86_Microsoft.VC80.OpenMP_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6c18549a\vcomp.dll + 2011-05-14 00:17 . 2011-05-14 00:17 65536 c:\windows\WinSxS\x86_Microsoft.VC80.OpenMP_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_452bf920\vcomp.dll + 2005-09-23 05:35 . 2005-09-23 05:35 65536 c:\windows\WinSxS\x86_Microsoft.VC80.OpenMP_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0ee63867\vcomp.dll - 2006-12-02 04:08 . 2006-12-02 04:08 49152 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80KOR.dll + 2008-10-25 01:15 . 2008-10-25 01:15 49152 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80KOR.dll - 2006-12-02 04:08 . 2006-12-02 04:08 49152 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80JPN.dll + 2008-10-25 01:15 . 2008-10-25 01:15 49152 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80JPN.dll - 2006-12-02 04:08 . 2006-12-02 04:08 61440 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80ITA.dll + 2008-10-25 01:15 . 2008-10-25 01:15 61440 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80ITA.dll + 2008-10-25 01:15 . 2008-10-25 01:15 61440 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80FRA.dll - 2006-12-02 04:08 . 2006-12-02 04:08 61440 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80FRA.dll + 2008-10-25 01:15 . 2008-10-25 01:15 61440 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80ESP.dll - 2006-12-02 04:08 . 2006-12-02 04:08 61440 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80ESP.dll + 2008-10-25 01:15 . 2008-10-25 01:15 57344 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80ENU.dll - 2006-12-02 04:08 . 2006-12-02 04:08 57344 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80ENU.dll + 2008-10-25 01:15 . 2008-10-25 01:15 65536 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80DEU.dll - 2006-12-02 04:08 . 2006-12-02 04:08 65536 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80DEU.dll + 2008-10-25 01:15 . 2008-10-25 01:15 45056 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80CHT.dll - 2006-12-02 04:08 . 2006-12-02 04:08 45056 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80CHT.dll - 2006-12-02 04:08 . 2006-12-02 04:08 40960 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80CHS.dll + 2008-10-25 01:15 . 2008-10-25 01:15 40960 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303\mfc80CHS.dll + 2011-05-13 23:45 . 2011-05-13 23:45 49152 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_6a5bb789\mfc80KOR.dll + 2011-05-13 23:45 . 2011-05-13 23:45 49152 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_6a5bb789\mfc80JPN.dll + 2011-05-13 23:45 . 2011-05-13 23:45 61440 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_6a5bb789\mfc80ITA.dll + 2011-05-13 23:45 . 2011-05-13 23:45 61440 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_6a5bb789\mfc80FRA.dll + 2011-05-13 23:45 . 2011-05-13 23:45 61440 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_6a5bb789\mfc80ESP.dll + 2011-05-13 23:45 . 2011-05-13 23:45 57344 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_6a5bb789\mfc80ENU.dll + 2011-05-13 23:45 . 2011-05-13 23:45 65536 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_6a5bb789\mfc80DEU.dll + 2011-05-13 23:45 . 2011-05-13 23:45 45056 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_6a5bb789\mfc80CHT.dll + 2011-05-13 23:45 . 2011-05-13 23:45 40960 c:\windows\WinSxS\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_6a5bb789\mfc80CHS.dll - 2006-12-02 04:26 . 2006-12-02 04:26 57856 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\mfcm80u.dll + 2008-10-25 01:15 . 2008-10-25 01:15 57856 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\mfcm80u.dll - 2006-12-02 04:25 . 2006-12-02 04:25 69632 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\mfcm80.dll + 2008-10-25 01:15 . 2008-10-25 01:15 69632 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\mfcm80.dll + 2011-05-14 05:06 . 2011-05-14 05:06 57856 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_150c9e8b\mfcm80u.dll + 2011-05-14 05:23 . 2011-05-14 05:23 69632 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_150c9e8b\mfcm80.dll + 2008-10-25 01:15 . 2008-10-25 01:15 96256 c:\windows\WinSxS\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_cbb27474\ATL80.dll - 2006-12-02 02:56 . 2006-12-02 02:56 96256 c:\windows\WinSxS\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_cbb27474\ATL80.dll + 2011-05-13 22:37 . 2011-05-13 22:37 97280 c:\windows\WinSxS\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_a4c618fa\ATL80.dll + 2012-08-19 07:26 . 2012-08-19 07:26 82432 c:\windows\WinSxS\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\msxml4r.dll + 2012-09-14 01:34 . 2012-09-14 01:34 16384 c:\windows\temp\Perflib_Perfdata_724.dat - 2009-04-26 19:04 . 2004-01-25 04:00 70656 c:\windows\system32\yv12vfw.dll + 2010-12-20 07:02 . 2004-01-25 05:00 70656 c:\windows\system32\yv12vfw.dll + 2009-09-21 01:59 . 2005-12-05 23:07 61136 c:\windows\system32\xinput9_1_0.dll - 2009-09-21 01:59 . 2005-12-05 22:07 61136 c:\windows\system32\xinput9_1_0.dll + 2009-09-21 01:59 . 2007-04-04 23:53 81768 c:\windows\system32\xinput1_3.dll - 2009-09-21 01:59 . 2007-04-04 22:53 81768 c:\windows\system32\xinput1_3.dll + 2009-09-21 01:59 . 2006-07-28 14:30 62744 c:\windows\system32\xinput1_2.dll - 2009-09-21 01:59 . 2006-07-28 13:30 62744 c:\windows\system32\xinput1_2.dll - 2009-09-21 01:59 . 2006-03-31 16:39 62672 c:\windows\system32\xinput1_1.dll + 2009-09-21 01:59 . 2006-03-31 17:39 62672 c:\windows\system32\xinput1_1.dll + 2011-10-25 00:21 . 2010-02-04 14:01 74072 c:\windows\system32\XAPOFX1_4.dll + 2011-10-25 00:21 . 2009-09-04 21:44 69464 c:\windows\system32\XAPOFX1_3.dll + 2011-10-25 00:21 . 2008-10-27 15:04 70992 c:\windows\system32\XAPOFX1_2.dll + 2011-10-25 00:21 . 2008-07-31 14:41 68616 c:\windows\system32\XAPOFX1_1.dll + 2011-10-25 00:21 . 2008-05-30 19:17 65032 c:\windows\system32\XAPOFX1_0.dll + 2011-10-25 00:21 . 2010-02-04 14:01 22360 c:\windows\system32\X3DAudio1_7.dll + 2011-10-25 00:21 . 2009-03-16 18:18 22360 c:\windows\system32\X3DAudio1_6.dll + 2011-10-25 00:21 . 2008-10-27 15:04 23376 c:\windows\system32\X3DAudio1_5.dll + 2011-10-25 00:21 . 2008-05-30 19:17 25608 c:\windows\system32\X3DAudio1_4.dll + 2011-10-25 00:21 . 2008-03-05 21:00 25608 c:\windows\system32\X3DAudio1_3.dll + 2009-09-21 01:59 . 2007-10-22 08:37 17928 c:\windows\system32\X3DAudio1_2.dll + 2009-09-21 01:59 . 2007-03-05 17:42 15128 c:\windows\system32\x3daudio1_1.dll - 2009-09-21 01:59 . 2007-03-05 16:42 15128 c:\windows\system32\x3daudio1_1.dll + 2009-09-21 01:59 . 2006-02-03 13:41 14032 c:\windows\system32\x3daudio1_0.dll - 2009-09-21 01:59 . 2006-02-03 12:41 14032 c:\windows\system32\x3daudio1_0.dll + 2009-04-19 18:29 . 2012-06-02 19:19 45080 c:\windows\system32\wups2.dll + 2009-04-19 18:29 . 2012-06-02 19:19 35864 c:\windows\system32\wups.dll + 2009-04-18 21:30 . 2012-06-02 19:19 53784 c:\windows\system32\wuauclt.exe + 2012-03-07 05:25 . 2007-11-01 04:48 20992 c:\windows\system32\windowspowershell\v1.0\pwrshsip.dll - 2009-04-19 19:07 . 2010-04-21 13:28 46080 c:\windows\system32\tzchange.exe + 2009-04-19 19:07 . 2011-11-08 13:46 46080 c:\windows\system32\tzchange.exe + 2001-08-23 12:00 . 2010-08-27 05:57 99840 c:\windows\system32\srvsvc.dll - 2009-04-19 18:43 . 2009-01-07 23:21 26144 c:\windows\system32\spupdsvc.exe + 2009-04-19 18:43 . 2008-11-07 22:55 26144 c:\windows\system32\spupdsvc.exe + 2001-08-23 12:00 . 2010-08-17 13:17 58880 c:\windows\system32\spoolsv.exe + 2011-03-11 04:38 . 2005-09-24 05:28 14848 c:\windows\system32\spool\drivers\w32x86\ad2kregp.dll + 2004-12-14 07:08 . 2005-09-24 05:28 14848 c:\windows\system32\spool\drivers\w32x86\3\AD2KREGP.DLL + 2010-04-20 05:10 . 2008-11-07 22:55 16928 c:\windows\system32\spmsgXP_2k3.dll + 2012-06-08 23:30 . 2012-06-02 19:19 45080 c:\windows\system32\SoftwareDistribution\Setup\ServiceStartup\wups2.dll\7.6.7600.256\wups2.dll + 2012-06-08 23:30 . 2012-06-02 19:19 35864 c:\windows\system32\SoftwareDistribution\Setup\ServiceStartup\wups.dll\7.6.7600.256\wups.dll + 2011-12-16 02:25 . 2011-08-02 21:38 42496 c:\windows\system32\ReinstallBackups\0013\DriverFiles\usbaapl.sys + 2011-11-26 17:44 . 2008-04-14 00:12 23552 c:\windows\system32\ReinstallBackups\0007\DriverFiles\i386\wdmaud.drv + 2011-11-26 17:44 . 2008-04-13 18:45 49408 c:\windows\system32\ReinstallBackups\0007\DriverFiles\i386\stream.sys + 2011-11-26 17:44 . 2008-04-13 18:45 60160 c:\windows\system32\ReinstallBackups\0007\DriverFiles\i386\drmk.sys + 2008-02-13 21:16 . 2010-07-12 18:36 68592 c:\windows\system32\pxinsa64.exe + 2009-06-05 22:52 . 2010-07-12 18:36 72176 c:\windows\system32\pxhpinst.exe + 2010-03-31 04:16 . 2010-03-31 04:16 99176 c:\windows\system32\PresentationHostProxy.dll + 2009-09-21 01:55 . 2011-01-27 03:06 75136 c:\windows\system32\PnkBstrA.exe + 2001-08-23 12:00 . 2012-06-14 06:19 87684 c:\windows\system32\perfc009.dat + 2001-08-23 12:00 . 2011-11-18 12:35 60416 c:\windows\system32\packager.exe + 2011-11-05 18:50 . 2011-10-08 04:50 65536 c:\windows\system32\OpenCL.dll + 2001-08-23 12:00 . 2011-09-26 15:41 20480 c:\windows\system32\oleaccrc.dll + 2006-08-12 04:43 . 2011-10-08 04:50 54272 c:\windows\system32\nvwddi.dll + 2008-05-02 14:58 . 2012-01-09 21:28 75264 c:\windows\system32\nmwcdcls.dll + 2009-11-07 05:07 . 2009-11-07 05:07 49488 c:\windows\system32\netfxperf.dll + 2009-11-07 05:07 . 2009-11-07 05:07 11600 c:\windows\system32\mui\0409\mscorees.dll + 2001-08-23 12:00 . 2012-07-02 17:49 67072 c:\windows\system32\mshtmled.dll + 2007-08-13 22:54 . 2012-07-02 17:49 55296 c:\windows\system32\msfeedsbs.dll - 2007-08-13 22:54 . 2010-05-06 10:41 55296 c:\windows\system32\msfeedsbs.dll - 2001-08-23 12:00 . 2008-04-14 00:11 23040 c:\windows\system32\mciseq.dll + 2001-08-23 12:00 . 2011-10-14 14:47 23040 c:\windows\system32\mciseq.dll + 2003-05-02 00:06 . 2003-05-02 00:06 59392 c:\windows\system32\lfwmf11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 27648 c:\windows\system32\lftga11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 56320 c:\windows\system32\lfpsd11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 33280 c:\windows\system32\lfpcx11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 26112 c:\windows\system32\lfpcd11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 41472 c:\windows\system32\lfgif11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 81408 c:\windows\system32\lffax11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 31232 c:\windows\system32\lfeps11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 36864 c:\windows\system32\lfbmp11n.dll - 2001-08-23 12:00 . 2010-05-06 10:41 25600 c:\windows\system32\jsproxy.dll + 2001-08-23 12:00 . 2012-07-02 17:49 25600 c:\windows\system32\jsproxy.dll + 2009-04-18 21:31 . 2010-11-18 18:12 81920 c:\windows\system32\isign32.dll - 2009-04-18 21:31 . 2008-04-14 00:11 81920 c:\windows\system32\isign32.dll - 2001-08-23 12:00 . 2008-04-14 00:11 80384 c:\windows\system32\iccvid.dll + 2001-08-23 12:00 . 2010-06-17 14:03 80384 c:\windows\system32\iccvid.dll + 2010-03-18 17:16 . 2010-03-18 17:16 70472 c:\windows\system32\dxva2.dll + 2012-03-21 05:45 . 2012-02-15 15:01 43520 c:\windows\system32\DRVSTORE\usbaapl_87F84F5DA3368BC69CA5BE7F6A79CAA709E36E13\usbaapl.sys + 2012-08-19 07:23 . 2012-06-27 19:18 19072 c:\windows\system32\DRVSTORE\pccsmcfd_52F0DFAA648E25523CF0EE10FEDF6AC712ED34DB\pccsmcfd.sys + 2012-06-29 05:06 . 2012-01-09 21:28 75264 c:\windows\system32\DRVSTORE\nmwcdnsuc_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\nmwcdcls.dll + 2012-06-29 05:06 . 2012-01-09 21:28 75264 c:\windows\system32\DRVSTORE\nmwcdnsu_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\nmwcdcls.dll + 2011-10-24 16:32 . 2011-08-02 21:38 18432 c:\windows\system32\DRVSTORE\netaapl_63AA05C4700EB9CAF2D048DAC1D06D764A0D4C41\netaapl.sys + 2012-06-29 05:06 . 2012-01-09 21:28 75264 c:\windows\system32\DRVSTORE\ccdcmbo_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\nmwcdcls.dll + 2012-06-29 05:06 . 2012-01-09 21:28 23168 c:\windows\system32\DRVSTORE\ccdcmbo_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\ccdcmbo.sys + 2012-06-29 05:06 . 2012-01-09 21:28 75264 c:\windows\system32\DRVSTORE\ccdcmb_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\nmwcdcls.dll + 2012-06-29 05:06 . 2012-01-09 21:28 18176 c:\windows\system32\DRVSTORE\ccdcmb_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\ccdcmb.sys + 2006-11-02 11:22 . 2009-07-14 14:35 37608 c:\windows\system32\drivers\wdfldr.sys + 2010-06-26 17:51 . 2008-04-13 18:45 26112 c:\windows\system32\drivers\usbser.sys + 2009-09-15 01:00 . 2012-02-15 15:01 43520 c:\windows\system32\drivers\usbaapl.sys - 2009-04-19 17:48 . 2008-04-13 18:45 49408 c:\windows\system32\drivers\stream.sys + 2009-04-19 17:48 . 2008-04-13 19:45 49408 c:\windows\system32\drivers\stream.sys + 2011-10-30 23:23 . 2011-10-30 23:23 31864 c:\windows\system32\drivers\SEP\0C0103E8\009D.105\x86\srtspx.sys + 2008-04-16 18:51 . 2008-04-16 18:51 22784 c:\windows\system32\drivers\RimUsb.sys + 2008-02-13 07:00 . 2010-07-12 18:36 45648 c:\windows\system32\drivers\pxhelp20.sys + 2001-08-23 12:00 . 2010-11-02 15:17 40960 c:\windows\system32\drivers\ndproxy.sys + 2001-08-23 12:00 . 2011-07-08 14:02 10496 c:\windows\system32\drivers\ndistapi.sys + 2011-11-05 18:08 . 2011-11-05 18:08 23456 c:\windows\system32\drivers\DrvAgent32.sys + 2009-04-19 17:48 . 2008-04-13 19:45 60160 c:\windows\system32\drivers\drmk.sys - 2009-04-19 17:48 . 2008-04-13 18:45 60160 c:\windows\system32\drivers\drmk.sys + 2011-11-05 16:46 . 2010-11-09 19:35 21992 c:\windows\system32\drivers\cpuz135_x32.sys + 2012-06-29 05:06 . 2012-01-09 21:28 23168 c:\windows\system32\drivers\ccdcmbo.sys + 2012-06-29 05:06 . 2012-01-09 21:28 18176 c:\windows\system32\drivers\ccdcmb.sys + 2011-10-20 23:26 . 2011-10-20 23:26 94208 c:\windows\system32\dpl100.dll + 2011-08-31 03:05 . 2011-08-31 03:05 73064 c:\windows\system32\dnssd.dll + 2001-08-23 12:00 . 2009-04-20 17:17 45568 c:\windows\system32\dnsrslvr.dll - 2001-08-23 12:00 . 2008-04-14 00:11 45568 c:\windows\system32\dnsrslvr.dll + 2011-08-31 03:05 . 2011-08-31 03:05 83816 c:\windows\system32\dns-sd.exe - 2010-02-24 05:17 . 2010-05-06 10:41 12800 c:\windows\system32\dllcache\xpshims.dll + 2010-02-24 05:17 . 2012-07-02 17:49 12800 c:\windows\system32\dllcache\xpshims.dll + 2009-04-19 18:29 . 2012-06-02 19:19 35864 c:\windows\system32\dllcache\wups.dll + 2009-04-18 21:30 . 2012-06-02 19:19 53784 c:\windows\system32\dllcache\wuauclt.exe + 2010-12-15 21:24 . 2010-10-11 14:59 45568 c:\windows\system32\dllcache\wab.exe + 2010-06-26 17:51 . 2008-04-13 18:45 26112 c:\windows\system32\dllcache\usbser.sys + 2009-04-19 17:48 . 2008-04-13 19:45 49408 c:\windows\system32\dllcache\stream.sys - 2009-04-19 17:48 . 2008-04-13 18:45 49408 c:\windows\system32\dllcache\stream.sys + 2010-08-27 05:57 . 2010-08-27 05:57 99840 c:\windows\system32\dllcache\srvsvc.dll + 2010-08-17 13:17 . 2010-08-17 13:17 58880 c:\windows\system32\dllcache\spoolsv.exe + 2011-11-18 12:35 . 2011-11-18 12:35 60416 c:\windows\system32\dllcache\packager.exe + 2001-08-23 12:00 . 2011-09-26 15:41 20480 c:\windows\system32\dllcache\oleaccrc.dll + 2010-12-16 05:25 . 2010-11-02 15:17 40960 c:\windows\system32\dllcache\ndproxy.sys + 2011-08-10 13:56 . 2011-07-08 14:02 10496 c:\windows\system32\dllcache\ndistapi.sys + 2007-08-13 22:54 . 2012-07-02 17:49 67072 c:\windows\system32\dllcache\mshtmled.dll + 2009-04-19 19:31 . 2012-07-02 17:49 55296 c:\windows\system32\dllcache\msfeedsbs.dll - 2009-04-19 19:31 . 2010-05-06 10:41 55296 c:\windows\system32\dllcache\msfeedsbs.dll + 2011-10-14 14:47 . 2011-10-14 14:47 23040 c:\windows\system32\dllcache\mciseq.dll + 2007-08-13 22:44 . 2012-07-02 17:49 43520 c:\windows\system32\dllcache\licmgr10.dll + 2007-08-13 22:54 . 2012-07-02 17:49 25600 c:\windows\system32\dllcache\jsproxy.dll - 2007-08-13 22:54 . 2010-05-06 10:41 25600 c:\windows\system32\dllcache\jsproxy.dll + 2010-11-18 18:12 . 2010-11-18 18:12 81920 c:\windows\system32\dllcache\isign32.dll + 2009-04-19 17:48 . 2008-04-13 19:45 60160 c:\windows\system32\dllcache\drmk.sys - 2009-04-19 17:48 . 2008-04-13 18:45 60160 c:\windows\system32\dllcache\drmk.sys + 2009-04-20 17:17 . 2009-04-20 17:17 45568 c:\windows\system32\dllcache\dnsrslvr.dll + 2009-12-14 07:08 . 2011-10-28 05:31 33280 c:\windows\system32\dllcache\csrsrv.dll - 2009-12-14 07:08 . 2009-12-14 07:08 33280 c:\windows\system32\dllcache\csrsrv.dll + 2011-05-09 22:48 . 2011-05-09 22:48 62592 c:\windows\system32\dllcache\cdrom.sys + 2001-08-23 12:00 . 2012-06-02 19:19 97304 c:\windows\system32\dllcache\cdm.dll + 2012-07-06 13:58 . 2012-07-06 13:58 78336 c:\windows\system32\dllcache\browser.dll + 2001-08-23 12:00 . 2011-10-28 05:31 33280 c:\windows\system32\csrsrv.dll - 2001-08-23 12:00 . 2009-12-14 07:08 33280 c:\windows\system32\csrsrv.dll - 2009-10-01 19:43 . 2009-11-08 05:46 32768 c:\windows\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\index.dat + 2009-10-01 19:43 . 2012-09-13 05:54 32768 c:\windows\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\index.dat - 2009-04-18 21:34 . 2009-11-08 05:46 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat + 2009-04-18 21:34 . 2012-09-13 05:54 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat - 2009-10-01 19:43 . 2009-11-08 05:46 16384 c:\windows\system32\config\systemprofile\Cookies\index.dat + 2010-06-22 23:40 . 2012-09-13 05:54 16384 c:\windows\system32\config\systemprofile\Cookies\index.dat + 2009-04-19 17:48 . 2006-08-01 20:02 49152 c:\windows\system32\ChCfg.exe - 2009-04-19 17:48 . 2006-08-01 19:02 49152 c:\windows\system32\ChCfg.exe + 2001-08-23 12:00 . 2012-06-02 19:19 97304 c:\windows\system32\cdm.dll + 2010-06-25 03:40 . 2005-07-14 16:31 27648 c:\windows\system32\AVSredirect.dll + 2010-01-14 22:23 . 2010-01-14 22:23 89600 c:\windows\system32\atl71.dll - 2004-12-14 06:12 . 2004-12-14 06:12 22016 c:\windows\system32\AdobePDF.dll + 2004-12-14 07:12 . 2004-12-14 07:12 22016 c:\windows\system32\AdobePDF.dll + 2010-03-18 17:16 . 2010-03-18 17:16 87408 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WindowsFormsIntegration.dll + 2010-03-18 17:16 . 2010-03-18 17:16 93024 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\UIAutomationTypes.dll + 2010-03-18 17:16 . 2010-03-18 17:16 35688 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\UIAutomationProvider.dll + 2010-03-18 17:16 . 2010-03-18 17:16 17784 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\System.Windows.Presentation.dll + 2010-03-18 17:16 . 2010-03-18 17:16 58240 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\System.Windows.Input.Manipulations.dll + 2010-03-18 17:16 . 2010-03-18 17:16 67912 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PenIMC.dll + 2010-03-18 17:16 . 2010-03-18 17:16 31576 c:\windows\Microsoft.NET\Framework\v4.0.30319\WMINet_Utils.dll + 2010-03-18 17:16 . 2010-03-18 17:16 44920 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Web.ApplicationServices.dll + 2010-03-18 17:16 . 2010-03-18 17:16 37240 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.ServiceModel.Channels.dll + 2010-03-18 17:16 . 2010-03-18 17:16 64352 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Numerics.dll + 2010-03-18 17:16 . 2010-03-18 17:16 45952 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.EnterpriseServices.Thunk.dll + 2010-03-18 17:16 . 2010-03-18 17:16 51032 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Device.dll + 2010-03-18 17:16 . 2010-03-18 17:16 50552 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Data.DataSetExtensions.dll + 2010-03-18 17:16 . 2010-03-18 17:16 81784 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Configuration.Install.dll + 2010-03-18 17:16 . 2010-03-18 17:16 81800 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.ComponentModel.DataAnnotations.dll + 2010-03-18 17:16 . 2010-03-18 17:16 39784 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.AddIn.Contract.dll + 2010-03-18 17:16 . 2010-03-18 17:16 68952 c:\windows\Microsoft.NET\Framework\v4.0.30319\SMDiagnostics.dll + 2010-03-18 19:58 . 2010-03-18 19:58 96088 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\SetupUtility.exe + 2010-03-18 20:16 . 2010-03-18 20:16 78152 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\Setup.exe + 2010-03-18 20:16 . 2010-03-18 20:16 18776 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\3082\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 14168 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\3076\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18776 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\2070\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 14168 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\2052\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 17752 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1055\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 17752 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1053\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18264 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1049\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18264 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1046\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18264 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1045\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 17752 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1044\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 19288 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1043\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 15192 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1042\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 15704 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1041\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18264 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1040\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18776 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1038\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 16728 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1037\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18776 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1036\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18264 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1035\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 17240 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1033\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 19288 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1032\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18776 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1031\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18264 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1030\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 18264 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1029\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 14168 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1028\SetupResources.dll + 2010-03-18 20:16 . 2010-03-18 20:16 17240 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\1025\SetupResources.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\v4.0.30319\SbsNclPerf.dll + 2010-03-18 17:16 . 2010-03-18 17:16 58192 c:\windows\Microsoft.NET\Framework\v4.0.30319\regtlibv12.exe + 2010-03-18 17:16 . 2010-03-18 17:16 32592 c:\windows\Microsoft.NET\Framework\v4.0.30319\RegSvcs.exe + 2010-03-18 17:16 . 2010-03-18 17:16 52040 c:\windows\Microsoft.NET\Framework\v4.0.30319\RegAsm.exe + 2010-03-18 17:16 . 2010-03-18 17:16 21336 c:\windows\Microsoft.NET\Framework\v4.0.30319\normalization.dll + 2011-12-15 17:08 . 2011-12-15 17:08 57616 c:\windows\Microsoft.NET\Framework\v4.0.30319\nlssorting.dll + 2010-03-18 17:16 . 2010-03-18 17:16 27984 c:\windows\Microsoft.NET\Framework\v4.0.30319\MUI\0409\mscorsecr.dll + 2010-03-18 17:16 . 2010-03-18 17:16 40784 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorpe.dll + 2010-03-18 17:16 . 2010-03-18 17:16 20816 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscoreeis.dll + 2010-03-18 17:16 . 2010-03-18 17:16 12128 c:\windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.VisualC.Dll + 2010-03-18 17:16 . 2010-03-18 17:16 97680 c:\windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.VisualBasic.Compatibility.Data.dll + 2010-03-18 17:16 . 2010-03-18 17:16 36168 c:\windows\Microsoft.NET\Framework\v4.0.30319\jsc.exe + 2010-03-18 17:16 . 2010-03-18 17:16 78168 c:\windows\Microsoft.NET\Framework\v4.0.30319\ISymWrapper.dll + 2010-03-18 17:16 . 2010-03-18 17:16 58200 c:\windows\Microsoft.NET\Framework\v4.0.30319\InstallUtilLib.dll + 2010-03-18 17:16 . 2010-03-18 17:16 27992 c:\windows\Microsoft.NET\Framework\v4.0.30319\InstallUtil.exe + 2010-03-18 17:16 . 2010-03-18 17:16 42312 c:\windows\Microsoft.NET\Framework\v4.0.30319\fusion.dll + 2010-03-18 17:16 . 2010-03-18 17:16 11592 c:\windows\Microsoft.NET\Framework\v4.0.30319\dfsvc.exe + 2010-03-18 17:16 . 2010-03-18 17:16 88904 c:\windows\Microsoft.NET\Framework\v4.0.30319\dfdll.dll + 2010-03-18 17:16 . 2010-03-18 17:16 31048 c:\windows\Microsoft.NET\Framework\v4.0.30319\cvtres.exe + 2010-03-18 17:16 . 2010-03-18 17:16 81248 c:\windows\Microsoft.NET\Framework\v4.0.30319\CustomMarshalers.dll + 2010-03-18 17:16 . 2010-03-18 17:16 44368 c:\windows\Microsoft.NET\Framework\v4.0.30319\Culture.dll + 2010-03-18 17:16 . 2010-03-18 17:16 95048 c:\windows\Microsoft.NET\Framework\v4.0.30319\CasPol.exe + 2010-03-18 17:16 . 2010-03-18 17:16 29008 c:\windows\Microsoft.NET\Framework\v4.0.30319\AddInUtil.exe + 2010-03-18 17:16 . 2010-03-18 17:16 29528 c:\windows\Microsoft.NET\Framework\v4.0.30319\AddInProcess32.exe + 2010-03-18 17:16 . 2010-03-18 17:16 29016 c:\windows\Microsoft.NET\Framework\v4.0.30319\AddInProcess.exe + 2010-03-18 17:16 . 2010-03-18 17:16 17240 c:\windows\Microsoft.NET\Framework\v4.0.30319\Accessibility.dll + 2010-03-18 17:16 . 2010-03-18 17:16 10064 c:\windows\Microsoft.NET\Framework\v4.0.30319\1033\CvtResUI.dll + 2010-03-18 17:16 . 2010-03-18 17:16 24400 c:\windows\Microsoft.NET\Framework\v4.0.30319\1033\alinkui.dll + 2009-11-07 05:07 . 2009-11-07 05:07 13648 c:\windows\Microsoft.NET\Framework\v2.0.50727\sbscmp20_mscorlib.dll + 2011-12-25 08:49 . 2011-12-25 08:49 31504 c:\windows\Microsoft.NET\Framework\v2.0.50727\aspnet_wp.exe + 2004-07-15 06:11 . 2004-07-15 06:11 31744 c:\windows\Microsoft.NET\Framework\v1.1.4322\WMINet_Utils.dll + 2009-06-24 23:56 . 2009-06-24 23:56 73728 c:\windows\Microsoft.NET\Framework\v1.1.4322\Updates\hotfix.exe + 2004-07-15 18:28 . 2004-07-15 18:28 57344 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Web.RegularExpressions.dll + 2011-12-25 15:07 . 2011-12-25 15:07 81920 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Security.dll + 2004-07-15 04:35 . 2004-07-15 04:35 66560 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.EnterpriseServices.Thunk.dll + 2003-02-21 11:26 . 2003-02-21 11:26 65536 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Drawing.Design.dll + 2004-07-15 18:28 . 2004-07-15 18:28 90112 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.DirectoryServices.dll + 2003-02-21 11:26 . 2003-02-21 11:26 77824 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Configuration.Install.dll + 2003-02-21 11:25 . 2003-02-21 11:25 12288 c:\windows\Microsoft.NET\Framework\v1.1.4322\RegSvcs.exe + 2004-07-15 18:28 . 2004-07-15 18:28 32768 c:\windows\Microsoft.NET\Framework\v1.1.4322\RegCode.dll + 2003-02-21 11:25 . 2003-02-21 11:25 28672 c:\windows\Microsoft.NET\Framework\v1.1.4322\RegAsm.exe + 2004-07-15 04:34 . 2004-07-15 04:34 94208 c:\windows\Microsoft.NET\Framework\v1.1.4322\PerfCounter.dll + 2003-02-20 23:09 . 2003-02-20 23:09 73728 c:\windows\Microsoft.NET\Framework\v1.1.4322\ngen.exe + 2003-02-20 22:43 . 2003-02-20 22:43 22528 c:\windows\Microsoft.NET\Framework\v1.1.4322\MUI\0409\mscorsecr.dll + 2003-02-20 23:18 . 2003-02-20 23:18 20480 c:\windows\Microsoft.NET\Framework\v1.1.4322\mtxoci8.dll + 2011-12-25 02:55 . 2011-12-25 02:55 77824 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorsn.dll + 2004-07-15 04:33 . 2004-07-15 04:33 81920 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorsec.dll + 2003-02-20 23:06 . 2003-02-20 23:06 65536 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorpe.dll + 2011-12-25 02:55 . 2011-12-25 02:55 86016 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorie.dll + 2004-07-15 04:32 . 2004-07-15 04:32 86016 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscordbc.dll + 2004-07-15 18:28 . 2004-07-15 18:28 49152 c:\windows\Microsoft.NET\Framework\v1.1.4322\MigPolWin.exe + 2004-07-15 18:28 . 2004-07-15 18:28 49152 c:\windows\Microsoft.NET\Framework\v1.1.4322\MigPol.exe + 2003-02-21 11:25 . 2003-02-21 11:25 11264 c:\windows\Microsoft.NET\Framework\v1.1.4322\Microsoft.Vsa.Vb.CodeDOMProcessor.dll + 2003-02-21 11:24 . 2003-02-21 11:24 32768 c:\windows\Microsoft.NET\Framework\v1.1.4322\Microsoft.Vsa.dll + 2003-02-21 11:24 . 2003-02-21 11:24 28672 c:\windows\Microsoft.NET\Framework\v1.1.4322\Microsoft.VisualBasic.Vsa.dll + 2003-02-21 11:24 . 2003-02-21 11:24 40960 c:\windows\Microsoft.NET\Framework\v1.1.4322\jsc.exe + 2003-02-21 11:24 . 2003-02-21 11:24 26112 c:\windows\Microsoft.NET\Framework\v1.1.4322\ISymWrapper.dll + 2003-02-20 23:22 . 2003-02-20 23:22 40960 c:\windows\Microsoft.NET\Framework\v1.1.4322\InstallUtilLib.dll + 2003-02-21 11:24 . 2003-02-21 11:24 15872 c:\windows\Microsoft.NET\Framework\v1.1.4322\InstallUtil.exe + 2004-07-15 18:31 . 2004-07-15 18:31 32768 c:\windows\Microsoft.NET\Framework\v1.1.4322\IEHost.dll + 2003-10-08 18:30 . 2003-10-08 18:30 81920 c:\windows\Microsoft.NET\Framework\v1.1.4322\gacutil.exe + 2003-02-21 08:12 . 2003-02-21 08:12 28672 c:\windows\Microsoft.NET\Framework\v1.1.4322\cvtres.exe + 2003-02-21 11:24 . 2003-02-21 11:24 33792 c:\windows\Microsoft.NET\Framework\v1.1.4322\CustomMarshalers.dll + 2003-02-21 11:24 . 2003-02-21 11:24 12288 c:\windows\Microsoft.NET\Framework\v1.1.4322\cscompmgd.dll + 2004-07-15 15:23 . 2004-07-15 15:23 49152 c:\windows\Microsoft.NET\Framework\v1.1.4322\csc.exe + 2011-12-25 02:55 . 2011-12-25 02:55 81920 c:\windows\Microsoft.NET\Framework\v1.1.4322\CORPerfMonExt.dll + 2003-02-21 11:24 . 2003-02-21 11:24 49152 c:\windows\Microsoft.NET\Framework\v1.1.4322\ConfigWizards.exe + 2003-02-21 11:24 . 2003-02-21 11:24 94208 c:\windows\Microsoft.NET\Framework\v1.1.4322\CasPol.exe + 2011-12-25 03:49 . 2011-12-25 03:49 32768 c:\windows\Microsoft.NET\Framework\v1.1.4322\aspnet_wp.exe + 2004-07-15 05:49 . 2004-07-15 05:49 32768 c:\windows\Microsoft.NET\Framework\v1.1.4322\aspnet_state.exe + 2004-07-15 05:49 . 2004-07-15 05:49 20480 c:\windows\Microsoft.NET\Framework\v1.1.4322\aspnet_regiis.exe + 2003-02-20 23:19 . 2003-02-20 23:19 40960 c:\windows\Microsoft.NET\Framework\v1.1.4322\aspnet_rc.dll + 2011-12-25 03:49 . 2011-12-25 03:49 24576 c:\windows\Microsoft.NET\Framework\v1.1.4322\aspnet_filter.dll + 2003-02-21 09:00 . 2003-02-21 09:00 98304 c:\windows\Microsoft.NET\Framework\v1.1.4322\alink.dll + 2003-02-21 07:55 . 2003-02-21 07:55 94208 c:\windows\Microsoft.NET\Framework\v1.1.4322\1033\cscompui.dll + 2003-02-21 06:59 . 2003-02-21 06:59 16896 c:\windows\Microsoft.NET\Framework\v1.1.4322\1033\alinkui.dll + 2009-11-07 05:07 . 2009-11-07 05:07 13648 c:\windows\Microsoft.NET\Framework\SharedReg12.dll + 2009-11-07 05:07 . 2009-11-07 05:07 13648 c:\windows\Microsoft.NET\Framework\sbscmp20_perfcounter.dll + 2009-11-07 05:07 . 2009-11-07 05:07 13648 c:\windows\Microsoft.NET\Framework\sbscmp20_mscorwks.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbscmp20_mscorlib.dll + 2009-11-07 05:07 . 2009-11-07 05:07 13648 c:\windows\Microsoft.NET\Framework\sbscmp10.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbs_wminet_utils.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbs_system.enterpriseservices.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbs_system.data.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbs_system.configuration.install.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbs_mscorsec.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbs_mscorrc.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbs_mscordbi.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbs_microsoft.jscript.dll + 2010-03-18 17:16 . 2010-03-18 17:16 13648 c:\windows\Microsoft.NET\Framework\sbs_diasymreader.dll + 2009-11-07 05:07 . 2009-11-07 05:07 86864 c:\windows\Microsoft.NET\Framework\NETFXSBS10.exe - 2009-09-21 01:59 . 2005-03-18 20:23 12800 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.Diagnostics.dll + 2009-09-21 01:59 . 2005-03-18 22:23 12800 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.Diagnostics.dll - 2009-09-21 01:59 . 2005-03-18 20:23 53248 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.AudioVideoPlayback.dll + 2009-09-21 01:59 . 2005-03-18 22:23 53248 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.AudioVideoPlayback.dll + 2012-06-14 06:17 . 2012-06-14 06:17 87408 c:\windows\Microsoft.NET\assembly\GAC_MSIL\WindowsFormsIntegration\v4.0_4.0.0.0__31bf3856ad364e35\WindowsFormsIntegration.dll + 2012-06-14 06:17 . 2012-06-14 06:17 93024 c:\windows\Microsoft.NET\assembly\GAC_MSIL\UIAutomationTypes\v4.0_4.0.0.0__31bf3856ad364e35\UIAutomationTypes.dll + 2012-06-14 06:17 . 2012-06-14 06:17 35688 c:\windows\Microsoft.NET\assembly\GAC_MSIL\UIAutomationProvider\v4.0_4.0.0.0__31bf3856ad364e35\UIAutomationProvider.dll + 2012-06-14 06:17 . 2012-06-14 06:17 17784 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Windows.Presentation\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Presentation.dll + 2012-06-14 06:17 . 2012-06-14 06:17 58240 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Windows.Input.Manipulations\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Input.Manipulations.dll + 2012-06-14 06:17 . 2012-06-14 06:17 44920 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Web.ApplicationServices\v4.0_4.0.0.0__31bf3856ad364e35\System.Web.ApplicationServices.dll + 2012-06-14 06:17 . 2012-06-14 06:17 37240 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.ServiceModel.Channels\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Channels.dll + 2012-06-14 06:17 . 2012-06-14 06:17 64352 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Numerics\v4.0_4.0.0.0__b77a5c561934e089\System.Numerics.dll + 2012-06-14 06:17 . 2012-06-14 06:17 51032 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Device\v4.0_4.0.0.0__b77a5c561934e089\System.Device.dll + 2012-06-14 06:17 . 2012-06-14 06:17 50552 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Data.DataSetExtensions\v4.0_4.0.0.0__b77a5c561934e089\System.Data.DataSetExtensions.dll + 2012-06-14 06:17 . 2012-06-14 06:17 81784 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Configuration.Install\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.Install.dll + 2012-06-14 06:17 . 2012-06-14 06:17 81800 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.ComponentModel.DataAnnotations\v4.0_4.0.0.0__31bf3856ad364e35\System.ComponentModel.DataAnnotations.dll + 2012-06-14 06:17 . 2012-06-14 06:17 39784 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.AddIn.Contract\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.AddIn.Contract.dll + 2012-06-14 06:17 . 2012-06-14 06:17 68952 c:\windows\Microsoft.NET\assembly\GAC_MSIL\SMDiagnostics\v4.0_4.0.0.0__b77a5c561934e089\SMDiagnostics.dll + 2012-06-14 06:17 . 2012-06-14 06:17 12128 c:\windows\Microsoft.NET\assembly\GAC_MSIL\Microsoft.VisualC\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualC.Dll + 2012-06-14 06:17 . 2012-06-14 06:17 97680 c:\windows\Microsoft.NET\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility.Data\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.Data.dll + 2012-06-14 06:17 . 2012-06-14 06:17 17240 c:\windows\Microsoft.NET\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0__b03f5f7f11d50a3a\Accessibility.dll + 2012-06-14 06:17 . 2012-06-14 06:17 78168 c:\windows\Microsoft.NET\assembly\GAC_32\ISymWrapper\v4.0_4.0.0.0__b03f5f7f11d50a3a\ISymWrapper.dll + 2012-06-14 06:17 . 2012-06-14 06:17 81248 c:\windows\Microsoft.NET\assembly\GAC_32\CustomMarshalers\v4.0_4.0.0.0__b03f5f7f11d50a3a\CustomMarshalers.dll + 2011-12-14 04:45 . 2011-12-14 04:45 38400 c:\windows\Installer\d1a605b.msi + 2012-07-20 04:37 . 2012-07-20 04:37 22016 c:\windows\Installer\b73b423.msi + 2011-07-26 01:24 . 2011-07-26 01:24 48128 c:\windows\Installer\b2dda7a.msi + 2012-04-21 16:32 . 2012-04-21 16:32 29184 c:\windows\Installer\3b1086.msi + 2012-04-21 16:32 . 2012-04-21 16:32 78336 c:\windows\Installer\3b107f.msi + 2011-07-11 04:29 . 2011-07-11 04:29 19968 c:\windows\Installer\1b1026f5.msi + 2011-12-06 06:22 . 2011-12-06 06:22 24576 c:\windows\Installer\108ac241.msi + 2011-12-06 06:22 . 2011-12-06 06:22 28160 c:\windows\Installer\108ac23a.msi + 2011-03-03 03:04 . 2011-03-03 03:04 15086 c:\windows\Installer\{D27928E5-C1A2-47B1-9834-6191D3AC34CE}\Cabos.exe + 2011-05-31 00:58 . 2011-05-31 00:58 65536 c:\windows\Installer\{B3FED300-806C-11E0-A0D0-B8AC6F97B88E}\UNINST_Uninstall_G_F6A848FB884248E6A4CDCBDCF41F6A74_1.exe - 2009-04-22 23:06 . 2009-04-22 23:06 25214 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\SC_Distiller.exe + 2011-02-16 04:04 . 2011-03-11 04:39 25214 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\SC_Distiller.exe + 2011-02-16 04:04 . 2011-03-11 04:39 25214 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\SC_Acrobat_Standard.exe - 2009-04-22 23:06 . 2009-04-22 23:06 25214 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\SC_Acrobat_Standard.exe + 2011-02-16 04:04 . 2011-03-11 04:39 25214 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\SC_Acrobat.exe - 2009-04-22 23:06 . 2009-04-22 23:06 25214 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\SC_Acrobat.exe + 2011-02-16 04:04 . 2011-03-11 04:39 65536 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\PM_Designer.exe - 2009-04-22 23:06 . 2009-04-22 23:06 65536 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\PM_Designer.exe - 2009-12-30 20:55 . 2010-06-09 07:01 90112 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\xlicons.exe + 2009-12-30 20:55 . 2011-06-17 07:08 90112 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\xlicons.exe + 2009-12-30 20:55 . 2011-06-17 07:08 45056 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\wordicon.exe - 2009-12-30 20:55 . 2010-06-09 07:01 45056 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\wordicon.exe - 2009-12-30 20:55 . 2010-06-09 07:01 22528 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\unbndico.exe + 2009-12-30 20:55 . 2011-06-17 07:08 22528 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\unbndico.exe - 2009-12-30 20:55 . 2010-06-09 07:01 12800 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\pubs.exe + 2009-12-30 20:55 . 2011-06-17 07:08 12800 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\pubs.exe + 2009-12-30 20:55 . 2011-06-17 07:08 16384 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\PEicons.exe - 2009-12-30 20:55 . 2010-06-09 07:01 16384 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\PEicons.exe + 2009-12-30 20:55 . 2011-06-17 07:08 34304 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\misc.exe - 2009-12-30 20:55 . 2010-06-09 07:01 34304 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\misc.exe - 2009-10-01 01:42 . 2010-06-13 01:11 35088 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\oisicon.exe + 2011-07-26 01:28 . 2012-09-12 12:24 35088 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\oisicon.exe + 2011-07-26 01:28 . 2012-09-12 12:24 18704 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\mspicons.exe - 2009-10-01 01:42 . 2010-06-13 01:11 18704 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\mspicons.exe + 2011-07-26 01:28 . 2012-09-12 12:24 20240 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\cagicon.exe - 2009-10-01 01:42 . 2010-06-13 01:11 20240 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\cagicon.exe + 2012-08-15 05:53 . 2012-08-15 05:53 38240 c:\windows\Installer\{90120000-0020-0409-0000-0000000FF1CE}\O12ConvIcon.exe - 2010-06-09 07:10 . 2010-06-09 07:10 38240 c:\windows\Installer\{90120000-0020-0409-0000-0000000FF1CE}\O12ConvIcon.exe + 2009-04-19 20:18 . 2012-08-15 05:47 23040 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\unbndico.exe - 2009-04-19 20:18 . 2010-06-09 07:11 23040 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\unbndico.exe + 2009-04-19 20:18 . 2012-08-15 05:47 61440 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\pubs.exe - 2009-04-19 20:18 . 2010-06-09 07:11 61440 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\pubs.exe + 2009-04-19 20:18 . 2012-08-15 05:47 27136 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\oisicon.exe - 2009-04-19 20:18 . 2010-06-09 07:11 27136 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\oisicon.exe - 2009-04-19 20:18 . 2010-06-09 07:11 11264 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\mspicons.exe + 2009-04-19 20:18 . 2012-08-15 05:47 11264 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\mspicons.exe + 2009-04-19 20:18 . 2012-08-15 05:47 86016 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\inficon.exe - 2009-04-19 20:18 . 2010-06-09 07:11 86016 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\inficon.exe - 2009-04-19 20:18 . 2010-06-09 07:11 12288 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\cagicon.exe + 2009-04-19 20:18 . 2012-08-15 05:47 12288 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\cagicon.exe + 2011-12-14 04:45 . 2012-05-12 07:59 49152 c:\windows\Installer\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}\ConfigIcon.dll + 2011-08-02 22:43 . 2011-08-02 22:43 27136 c:\windows\Installer\{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}\AppleSoftwareUpdateIco.exe + 2012-08-19 07:23 . 2012-08-19 07:23 10134 c:\windows\Installer\{7390478C-8581-415E-92E9-2997D9306B81}\ARPPRODUCTICON.exe + 2011-11-18 05:23 . 2011-11-18 05:24 65536 c:\windows\Installer\{5A3C1721-F8ED-11E0-8AFB-B8AC6F97B88E}\UNINST_Uninstall_G_F6A848FB884248E6A4CDCBDCF41F6A74_1.exe + 2011-11-18 05:24 . 2011-11-18 05:24 65536 c:\windows\Installer\{5A3C1721-F8ED-11E0-8AFB-B8AC6F97B88E}\UNINST_Uninstall_G_F6A848FB884248E6A4CDCBDCF41F6A74.exe + 2011-11-18 05:23 . 2011-11-18 05:23 65536 c:\windows\Installer\{5A3C1721-F8ED-11E0-8AFB-B8AC6F97B88E}\ShortcutOGL_EB071909B9884F8CBF3D6115D4ADEE5E.exe + 2011-11-18 05:23 . 2011-11-18 05:23 65536 c:\windows\Installer\{5A3C1721-F8ED-11E0-8AFB-B8AC6F97B88E}\ShortcutDX_EB071909B9884F8CBF3D6115D4ADEE5E.exe + 2011-11-18 05:24 . 2011-11-18 05:24 65536 c:\windows\Installer\{5A3C1721-F8ED-11E0-8AFB-B8AC6F97B88E}\googleearth.exe1_F6A848FB884248E6A4CDCBDCF41F6A74.exe + 2011-11-18 05:23 . 2011-11-18 05:23 65536 c:\windows\Installer\{5A3C1721-F8ED-11E0-8AFB-B8AC6F97B88E}\googleearth.exe_F6A848FB884248E6A4CDCBDCF41F6A74.exe + 2011-11-18 05:23 . 2011-11-18 05:23 65536 c:\windows\Installer\{5A3C1721-F8ED-11E0-8AFB-B8AC6F97B88E}\ARPPRODUCTICON.exe + 2010-09-30 01:47 . 2010-09-30 01:47 25214 c:\windows\Installer\{4286E640-B5FB-11DF-AC4B-005056C00008}\UNINST_Uninstall_G_F6A848FB884248E6A4CDCBDCF41F6A74_1.exe + 2012-08-19 07:27 . 2012-08-19 07:27 54489 c:\windows\Installer\{3B69A712-4CBC-40B1-AE55-0203075FD093}\ARPPRODUCTICON.exe + 2011-06-06 16:55 . 2011-06-06 16:55 17304 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\ViewerPS.dll + 2011-06-06 16:55 . 2011-06-06 16:55 35736 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\reader_sl.exe + 2011-06-06 16:55 . 2011-06-06 16:55 88992 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\PDFPrevHndlr.dll + 2011-06-06 16:55 . 2011-06-06 16:55 94608 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\eula.exe + 2011-06-06 16:55 . 2011-06-06 16:55 49064 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\acrotextextractor.exe + 2011-06-06 16:55 . 2011-06-06 16:55 17824 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\AcroRd32Info.exe + 2011-06-06 16:55 . 2011-06-06 16:55 63912 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\acroiehelpershim.dll + 2011-06-06 16:55 . 2011-06-06 16:55 64928 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\AcroIEHelper.dll + 2011-06-06 16:55 . 2011-06-06 16:55 63384 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\Acrofx32.dll + 2009-02-26 22:43 . 2009-02-26 22:43 71520 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\XL12CNVP.DLL + 2009-02-26 21:45 . 2009-02-26 21:45 20808 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\WRD12EXE.EXE + 1999-11-24 22:40 . 1999-11-24 22:40 40960 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\VBAME.DLL + 2008-08-26 02:50 . 2008-08-26 02:50 86016 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\MSADDNDR.DLL + 2006-10-27 01:17 . 2006-10-27 01:17 11072 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\XLCALL32.DLL - 2009-10-01 01:41 . 2009-10-01 01:41 12096 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\WORDPOL.DLL + 2011-07-26 01:27 . 2011-07-26 01:27 12096 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\WORDPOL.DLL - 2009-10-01 01:41 . 2009-10-01 01:41 12080 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\VBIDEPOL.DLL + 2011-07-26 01:27 . 2011-07-26 01:27 12080 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\VBIDEPOL.DLL + 2011-07-26 01:27 . 2011-07-26 01:27 64288 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\VBIDEPIA.DLL - 2009-10-01 01:41 . 2009-10-01 01:41 64288 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\VBIDEPIA.DLL + 2006-10-26 23:49 . 2006-10-26 23:49 34104 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\SETLANG.EXE + 2006-10-27 00:12 . 2006-10-27 00:12 40424 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\REFIEBAR.DLL + 2011-07-26 01:27 . 2011-07-26 01:27 12112 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\PPTPOL.DLL + 2006-10-27 00:00 . 2006-10-27 00:00 23392 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\OISCTRL.DLL - 2009-10-01 01:41 . 2009-10-01 01:41 11544 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\OFFICEPL.DLL + 2011-07-26 01:27 . 2011-07-26 01:27 11544 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\OFFICEPL.DLL + 2006-10-27 00:12 . 2006-10-27 00:12 65824 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\NAME.DLL + 2011-07-26 01:27 . 2011-07-26 01:27 12104 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MSTAGPOL.DLL + 2011-07-26 01:27 . 2011-07-26 01:27 20280 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MSTAGPIA.DLL + 2006-10-26 23:52 . 2006-10-26 23:52 66368 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MSOMSE.DLL + 2006-10-26 23:52 . 2006-10-26 23:52 48424 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MSE7.EXE + 2006-10-27 00:12 . 2006-10-27 00:12 89400 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\METCONV.DLL + 2011-07-26 01:27 . 2011-07-26 01:27 12096 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\GRAPHPOL.DLL + 2011-07-26 01:27 . 2011-07-26 01:27 12096 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\EXCELPOL.DLL + 2006-10-27 00:13 . 2006-10-27 00:13 56120 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\ACERCLR.DLL + 2006-10-27 00:13 . 2006-10-27 00:13 56192 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\ACECNFLT.EXE + 2009-02-26 22:43 . 2009-02-26 22:43 71520 c:\windows\Installer\$PatchCache$\Managed\00002109020090400000000000F01FEC\12.0.6612\XL12CNVP.DLL + 2009-02-26 21:45 . 2009-02-26 21:45 20808 c:\windows\Installer\$PatchCache$\Managed\00002109020090400000000000F01FEC\12.0.6612\WRD12EXE.EXE + 2009-02-26 17:06 . 2009-02-26 17:06 16712 c:\windows\Installer\$PatchCache$\Managed\00002109020090400000000000F01FEC\12.0.6612\PXBPROXY.DLL + 2009-02-26 17:06 . 2009-02-26 17:06 68488 c:\windows\Installer\$PatchCache$\Managed\00002109020090400000000000F01FEC\12.0.6612\PXBCOM.EXE + 2012-08-15 05:44 . 2012-05-11 14:42 12800 c:\windows\ie8updates\KB2722913-IE8\xpshims.dll + 2012-08-15 05:44 . 2012-05-11 14:42 67072 c:\windows\ie8updates\KB2722913-IE8\mshtmled.dll + 2012-08-15 05:44 . 2012-05-11 14:42 55296 c:\windows\ie8updates\KB2722913-IE8\msfeedsbs.dll + 2012-08-15 05:44 . 2012-05-11 14:42 43520 c:\windows\ie8updates\KB2722913-IE8\licmgr10.dll + 2012-08-15 05:44 . 2012-05-11 14:42 25600 c:\windows\ie8updates\KB2722913-IE8\jsproxy.dll + 2012-06-14 06:08 . 2012-03-01 11:01 12800 c:\windows\ie8updates\KB2699988-IE8\xpshims.dll + 2012-06-14 06:08 . 2012-03-01 11:01 66560 c:\windows\ie8updates\KB2699988-IE8\mshtmled.dll + 2012-06-14 06:08 . 2012-03-01 11:01 55296 c:\windows\ie8updates\KB2699988-IE8\msfeedsbs.dll + 2012-06-14 06:08 . 2012-03-01 11:01 43520 c:\windows\ie8updates\KB2699988-IE8\licmgr10.dll + 2012-06-14 06:08 . 2012-03-01 11:01 25600 c:\windows\ie8updates\KB2699988-IE8\jsproxy.dll + 2012-04-11 12:54 . 2011-12-17 19:46 12800 c:\windows\ie8updates\KB2675157-IE8\xpshims.dll + 2012-04-11 12:54 . 2011-12-17 19:46 66560 c:\windows\ie8updates\KB2675157-IE8\mshtmled.dll + 2012-04-11 12:54 . 2011-12-17 19:46 55296 c:\windows\ie8updates\KB2675157-IE8\msfeedsbs.dll + 2012-04-11 12:54 . 2011-12-17 19:46 43520 c:\windows\ie8updates\KB2675157-IE8\licmgr10.dll + 2012-04-11 12:54 . 2011-12-17 19:46 25600 c:\windows\ie8updates\KB2675157-IE8\jsproxy.dll + 2012-02-16 08:05 . 2011-11-04 19:20 12800 c:\windows\ie8updates\KB2647516-IE8\xpshims.dll + 2012-02-16 08:05 . 2011-11-04 19:20 66560 c:\windows\ie8updates\KB2647516-IE8\mshtmled.dll + 2012-02-16 08:05 . 2011-11-04 19:20 55296 c:\windows\ie8updates\KB2647516-IE8\msfeedsbs.dll + 2012-02-16 08:05 . 2011-11-04 19:20 43520 c:\windows\ie8updates\KB2647516-IE8\licmgr10.dll + 2012-02-16 08:05 . 2011-11-04 19:20 25600 c:\windows\ie8updates\KB2647516-IE8\jsproxy.dll + 2011-12-15 05:50 . 2011-08-22 23:48 12800 c:\windows\ie8updates\KB2618444-IE8\xpshims.dll + 2011-12-15 05:50 . 2011-08-22 23:48 66560 c:\windows\ie8updates\KB2618444-IE8\mshtmled.dll + 2011-12-15 05:50 . 2011-08-22 23:48 55296 c:\windows\ie8updates\KB2618444-IE8\msfeedsbs.dll + 2011-12-15 05:50 . 2011-08-22 23:48 43520 c:\windows\ie8updates\KB2618444-IE8\licmgr10.dll + 2011-12-15 05:50 . 2011-08-22 23:48 25600 c:\windows\ie8updates\KB2618444-IE8\jsproxy.dll + 2011-10-12 11:48 . 2011-06-23 18:36 12800 c:\windows\ie8updates\KB2586448-IE8\xpshims.dll + 2011-10-12 11:48 . 2011-06-23 18:36 66560 c:\windows\ie8updates\KB2586448-IE8\mshtmled.dll + 2011-10-12 11:48 . 2011-06-23 18:36 55296 c:\windows\ie8updates\KB2586448-IE8\msfeedsbs.dll + 2011-10-12 11:48 . 2011-06-23 18:36 43520 c:\windows\ie8updates\KB2586448-IE8\licmgr10.dll + 2011-10-12 11:48 . 2011-06-23 18:36 25600 c:\windows\ie8updates\KB2586448-IE8\jsproxy.dll + 2011-08-11 12:00 . 2011-04-25 16:11 12800 c:\windows\ie8updates\KB2559049-IE8\xpshims.dll + 2011-08-11 12:00 . 2011-04-25 16:11 66560 c:\windows\ie8updates\KB2559049-IE8\mshtmled.dll + 2011-08-11 12:00 . 2011-04-25 16:11 55296 c:\windows\ie8updates\KB2559049-IE8\msfeedsbs.dll + 2011-08-11 12:00 . 2011-04-25 16:11 43520 c:\windows\ie8updates\KB2559049-IE8\licmgr10.dll + 2011-08-11 12:00 . 2011-04-25 16:11 25600 c:\windows\ie8updates\KB2559049-IE8\jsproxy.dll + 2011-06-17 07:03 . 2011-02-22 23:06 12800 c:\windows\ie8updates\KB2530548-IE8\xpshims.dll + 2011-06-17 07:03 . 2011-02-22 23:06 66560 c:\windows\ie8updates\KB2530548-IE8\mshtmled.dll + 2011-06-17 07:03 . 2011-02-22 23:06 55296 c:\windows\ie8updates\KB2530548-IE8\msfeedsbs.dll + 2011-06-17 07:03 . 2011-02-22 23:06 43520 c:\windows\ie8updates\KB2530548-IE8\licmgr10.dll + 2011-06-17 07:03 . 2011-02-22 23:06 25600 c:\windows\ie8updates\KB2530548-IE8\jsproxy.dll + 2011-04-15 07:09 . 2010-12-20 23:59 12800 c:\windows\ie8updates\KB2497640-IE8\xpshims.dll + 2011-04-15 07:09 . 2010-12-20 23:59 66560 c:\windows\ie8updates\KB2497640-IE8\mshtmled.dll + 2011-04-15 07:09 . 2010-12-20 23:59 55296 c:\windows\ie8updates\KB2497640-IE8\msfeedsbs.dll + 2011-04-15 07:09 . 2010-12-20 23:59 43520 c:\windows\ie8updates\KB2497640-IE8\licmgr10.dll + 2011-04-15 07:09 . 2010-12-20 23:59 25600 c:\windows\ie8updates\KB2497640-IE8\jsproxy.dll + 2011-02-11 08:01 . 2010-11-06 00:26 12800 c:\windows\ie8updates\KB2482017-IE8\xpshims.dll + 2011-02-11 08:01 . 2010-11-06 00:26 66560 c:\windows\ie8updates\KB2482017-IE8\mshtmled.dll + 2011-02-11 08:01 . 2010-11-06 00:26 55296 c:\windows\ie8updates\KB2482017-IE8\msfeedsbs.dll + 2011-02-11 08:01 . 2010-11-06 00:26 43520 c:\windows\ie8updates\KB2482017-IE8\licmgr10.dll + 2011-02-11 08:01 . 2010-11-06 00:26 25600 c:\windows\ie8updates\KB2482017-IE8\jsproxy.dll + 2010-12-16 08:03 . 2010-09-10 05:58 12800 c:\windows\ie8updates\KB2416400-IE8\xpshims.dll + 2010-12-16 08:03 . 2010-09-10 05:58 66560 c:\windows\ie8updates\KB2416400-IE8\mshtmled.dll + 2010-12-16 08:03 . 2010-09-10 05:58 55296 c:\windows\ie8updates\KB2416400-IE8\msfeedsbs.dll + 2010-12-16 08:03 . 2010-09-10 05:58 43520 c:\windows\ie8updates\KB2416400-IE8\licmgr10.dll + 2010-12-16 08:03 . 2010-09-10 05:58 25600 c:\windows\ie8updates\KB2416400-IE8\jsproxy.dll + 2010-10-14 07:05 . 2010-06-24 12:22 12800 c:\windows\ie8updates\KB2360131-IE8\xpshims.dll + 2010-10-14 07:05 . 2009-03-08 09:31 66560 c:\windows\ie8updates\KB2360131-IE8\mshtmled.dll + 2010-10-14 07:05 . 2010-06-24 12:21 55296 c:\windows\ie8updates\KB2360131-IE8\msfeedsbs.dll + 2010-10-14 07:05 . 2009-03-08 09:34 43008 c:\windows\ie8updates\KB2360131-IE8\licmgr10.dll + 2010-10-14 07:05 . 2010-06-24 12:21 25600 c:\windows\ie8updates\KB2360131-IE8\jsproxy.dll + 2010-08-12 03:39 . 2010-05-06 10:41 12800 c:\windows\ie8updates\KB2183461-IE8\xpshims.dll + 2010-08-12 03:39 . 2010-05-06 10:41 55296 c:\windows\ie8updates\KB2183461-IE8\msfeedsbs.dll + 2010-08-12 03:39 . 2010-05-06 10:41 25600 c:\windows\ie8updates\KB2183461-IE8\jsproxy.dll + 2012-03-29 03:32 . 2012-03-29 03:32 90112 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing.Design\1.0.5000.0__b03f5f7f11d50a3a_fe5e3026\System.Drawing.Design.dll + 2012-04-11 12:54 . 2012-04-11 12:54 90112 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing.Design\1.0.5000.0__b03f5f7f11d50a3a_2b6cadbc\System.Drawing.Design.dll + 2012-06-14 06:08 . 2012-06-14 06:08 90112 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing.Design\1.0.5000.0__b03f5f7f11d50a3a_1bf8c99a\System.Drawing.Design.dll + 2012-03-29 03:32 . 2012-03-29 03:32 61440 c:\windows\assembly\NativeImages1_v1.1.4322\CustomMarshalers\1.0.5000.0__b03f5f7f11d50a3a_41dc7668\CustomMarshalers.dll + 2012-05-09 23:32 . 2012-05-09 23:32 96768 c:\windows\assembly\NativeImages_v4.0.30319_32\UIAutomationProvider\05787d96761cf20b76b927ace10ef1d3\UIAutomationProvider.ni.dll + 2012-05-09 23:34 . 2012-05-09 23:34 35328 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Pres#\b9b7098a0488ac87026a0cadd2d7d972\System.Windows.Presentation.ni.dll + 2012-05-09 23:34 . 2012-05-09 23:34 71680 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Web.Applicat#\e5cf7be6b9deee73d674f2bc43752fed\System.Web.ApplicationServices.ni.dll + 2012-05-09 23:34 . 2012-05-09 23:34 82432 c:\windows\assembly\NativeImages_v4.0.30319_32\System.ServiceModel#\39c6c5375d1763165dd8c1623bd10668\System.ServiceModel.Channels.ni.dll + 2012-05-09 23:33 . 2012-05-09 23:33 78848 c:\windows\assembly\NativeImages_v4.0.30319_32\System.AddIn.Contra#\59be5fb54e018032511415f0b0523ee3\System.AddIn.Contract.ni.dll + 2012-05-09 23:32 . 2012-05-09 23:32 11776 c:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.VisualC\46f273930666397a8cb538ffe9190eef\Microsoft.VisualC.ni.dll + 2012-05-09 23:32 . 2012-05-09 23:32 44544 c:\windows\assembly\NativeImages_v4.0.30319_32\Accessibility\62c1a496dff99a6e5f5e4278d31ca4c1\Accessibility.ni.dll + 2012-05-09 22:38 . 2012-05-09 22:38 60928 c:\windows\assembly\NativeImages_v2.0.50727_32\UIAutomationProvider\f121ccced1aa14badb316d8d9be5154d\UIAutomationProvider.ni.dll + 2012-05-09 23:31 . 2012-05-09 23:31 37888 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Windows.Pres#\316e223f2ab8c69cd6a5a06de21650ec\System.Windows.Presentation.ni.dll + 2012-06-14 12:09 . 2012-06-14 12:09 36864 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.DynamicD#\3b34fc2c8c94ffe21f75168980b69dfe\System.Web.DynamicData.Design.ni.dll + 2012-05-09 23:29 . 2012-05-09 23:29 94208 c:\windows\assembly\NativeImages_v2.0.50727_32\System.ComponentMod#\34c988dea48c291b4e648941207e83fb\System.ComponentModel.DataAnnotations.ni.dll + 2012-05-09 23:29 . 2012-05-09 23:29 82944 c:\windows\assembly\NativeImages_v2.0.50727_32\System.AddIn.Contra#\7bb7e51275fa19f8b4894c772bdb1e10\System.AddIn.Contract.ni.dll + 2012-05-09 22:37 . 2012-05-09 22:37 47104 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationFontCac#\f0c4a4528f130ef2ff1ae63dd7b39075\PresentationFontCache.ni.exe + 2012-05-09 22:36 . 2012-05-09 22:36 39424 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationCFFRast#\53931181e5a5e194da82605613cda6af\PresentationCFFRasterizer.ni.dll + 2012-05-09 23:30 . 2012-05-09 23:30 55296 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Vsa\f2be3ad4cda6853d7959a84cec0414c5\Microsoft.Vsa.ni.dll + 2012-05-09 23:28 . 2012-05-09 23:28 30208 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.PowerShel#\c8fc74b6f19de1a403f0e557a11aa9ca\Microsoft.PowerShell.Commands.Utility.resources.ni.dll + 2012-05-09 23:28 . 2012-05-09 23:28 35328 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.PowerShel#\a2bb2449699f12ceb3eaff60a5a0632d\Microsoft.PowerShell.ConsoleHost.resources.ni.dll + 2012-05-09 23:28 . 2012-05-09 23:28 17408 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.PowerShel#\3056b7bb6c5f44fd998e89d397f6fc79\Microsoft.PowerShell.Security.resources.ni.dll + 2012-05-09 23:28 . 2012-05-09 23:28 19456 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.PowerShel#\0a5d8c3e21d8683958868496373bb435\Microsoft.PowerShell.Commands.Management.resources.ni.dll + 2012-05-09 23:28 . 2012-05-09 23:28 65024 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Fra#\8fab9cd28bbc860a34feec119512664d\Microsoft.Build.Framework.ni.dll + 2012-05-09 23:28 . 2012-05-09 23:28 74752 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Fra#\0eac132c7c36f1c100ae23c956b379e7\Microsoft.Build.Framework.ni.dll + 2012-05-09 23:28 . 2012-05-09 23:28 14336 c:\windows\assembly\NativeImages_v2.0.50727_32\dfsvc\d66bc03eb7eae89b4dde2d09eda1414f\dfsvc.ni.exe + 2012-05-09 23:28 . 2012-05-09 23:28 25600 c:\windows\assembly\NativeImages_v2.0.50727_32\Accessibility\016444dfc5f7e3d11c776f2fbc7a4594\Accessibility.ni.dll + 2012-06-14 06:19 . 2012-06-14 06:19 77824 c:\windows\assembly\GAC_MSIL\System.Web.RegularExpressions\2.0.0.0__b03f5f7f11d50a3a\System.Web.RegularExpressions.dll - 2010-06-09 07:05 . 2010-06-09 07:05 77824 c:\windows\assembly\GAC_MSIL\System.Web.RegularExpressions\2.0.0.0__b03f5f7f11d50a3a\System.Web.RegularExpressions.dll + 2012-06-14 06:19 . 2012-06-14 06:19 81920 c:\windows\assembly\GAC_MSIL\System.Drawing.Design\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.Design.dll - 2010-06-09 07:05 . 2010-06-09 07:05 81920 c:\windows\assembly\GAC_MSIL\System.Drawing.Design\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.Design.dll + 2012-06-14 06:19 . 2012-06-14 06:19 81920 c:\windows\assembly\GAC_MSIL\System.Configuration.Install\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.Install.dll - 2010-06-09 07:05 . 2010-06-09 07:05 81920 c:\windows\assembly\GAC_MSIL\System.Configuration.Install\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.Install.dll + 2012-06-14 06:19 . 2012-06-14 06:19 32768 c:\windows\assembly\GAC_MSIL\Microsoft.Vsa\8.0.0.0__b03f5f7f11d50a3a\Microsoft.Vsa.dll - 2010-06-09 07:05 . 2010-06-09 07:05 32768 c:\windows\assembly\GAC_MSIL\Microsoft.Vsa\8.0.0.0__b03f5f7f11d50a3a\Microsoft.Vsa.dll + 2012-06-14 06:19 . 2012-06-14 06:19 12800 c:\windows\assembly\GAC_MSIL\Microsoft.Vsa.Vb.CodeDOMProcessor\8.0.0.0__b03f5f7f11d50a3a\Microsoft.Vsa.Vb.CodeDOMProcessor.dll - 2010-06-09 07:05 . 2010-06-09 07:05 12800 c:\windows\assembly\GAC_MSIL\Microsoft.Vsa.Vb.CodeDOMProcessor\8.0.0.0__b03f5f7f11d50a3a\Microsoft.Vsa.Vb.CodeDOMProcessor.dll - 2010-06-09 07:05 . 2010-06-09 07:05 28672 c:\windows\assembly\GAC_MSIL\Microsoft.VisualBasic.Vsa\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Vsa.dll + 2012-06-14 06:19 . 2012-06-14 06:19 28672 c:\windows\assembly\GAC_MSIL\Microsoft.VisualBasic.Vsa\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Vsa.dll + 2012-03-07 05:25 . 2012-03-07 05:25 65536 c:\windows\assembly\GAC_MSIL\Microsoft.PowerShell.Security\1.0.0.0__31bf3856ad364e35\Microsoft.PowerShell.Security.dll + 2012-03-07 05:25 . 2012-03-07 05:25 36864 c:\windows\assembly\GAC_MSIL\Microsoft.PowerShell.ConsoleHost.resources\1.0.0.0_en_31bf3856ad364e35\Microsoft.PowerShell.ConsoleHost.resources.dll + 2012-03-07 05:25 . 2012-03-07 05:25 32768 c:\windows\assembly\GAC_MSIL\Microsoft.PowerShell.Commands.Utility.resources\1.0.0.0_en_31bf3856ad364e35\Microsoft.PowerShell.Commands.Utility.resources.dll + 2012-03-07 05:25 . 2012-03-07 05:25 11264 c:\windows\assembly\GAC_MSIL\Microsoft.PowerShell.Commands.Management.resources\1.0.0.0_en_31bf3856ad364e35\Microsoft.PowerShell.Commands.Management.resources.dll - 2010-06-09 07:05 . 2010-06-09 07:05 77824 c:\windows\assembly\GAC_MSIL\Microsoft.Build.Utilities\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Utilities.dll + 2012-06-14 06:19 . 2012-06-14 06:19 77824 c:\windows\assembly\GAC_MSIL\Microsoft.Build.Utilities\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Utilities.dll + 2012-06-14 06:19 . 2012-06-14 06:19 36864 c:\windows\assembly\GAC_MSIL\Microsoft.Build.Framework\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Framework.dll - 2010-06-09 07:05 . 2010-06-09 07:05 36864 c:\windows\assembly\GAC_MSIL\Microsoft.Build.Framework\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Framework.dll + 2012-06-14 06:19 . 2012-06-14 06:19 77824 c:\windows\assembly\GAC_MSIL\IEHost\2.0.0.0__b03f5f7f11d50a3a\IEHost.dll - 2010-06-09 07:05 . 2010-06-09 07:05 77824 c:\windows\assembly\GAC_MSIL\IEHost\2.0.0.0__b03f5f7f11d50a3a\IEHost.dll - 2010-06-09 07:05 . 2010-06-09 07:05 13312 c:\windows\assembly\GAC_MSIL\cscompmgd\8.0.0.0__b03f5f7f11d50a3a\cscompmgd.dll + 2012-06-14 06:19 . 2012-06-14 06:19 13312 c:\windows\assembly\GAC_MSIL\cscompmgd\8.0.0.0__b03f5f7f11d50a3a\cscompmgd.dll - 2010-06-09 07:05 . 2010-06-09 07:05 10752 c:\windows\assembly\GAC_MSIL\Accessibility\2.0.0.0__b03f5f7f11d50a3a\Accessibility.dll + 2012-06-14 06:19 . 2012-06-14 06:19 10752 c:\windows\assembly\GAC_MSIL\Accessibility\2.0.0.0__b03f5f7f11d50a3a\Accessibility.dll - 2010-06-09 07:05 . 2010-06-09 07:05 72192 c:\windows\assembly\GAC_32\ISymWrapper\2.0.0.0__b03f5f7f11d50a3a\ISymWrapper.dll + 2012-06-14 06:19 . 2012-06-14 06:19 72192 c:\windows\assembly\GAC_32\ISymWrapper\2.0.0.0__b03f5f7f11d50a3a\ISymWrapper.dll + 2012-06-14 06:19 . 2012-06-14 06:19 69120 c:\windows\assembly\GAC_32\CustomMarshalers\2.0.0.0__b03f5f7f11d50a3a\CustomMarshalers.dll - 2010-06-09 07:05 . 2010-06-09 07:05 69120 c:\windows\assembly\GAC_32\CustomMarshalers\2.0.0.0__b03f5f7f11d50a3a\CustomMarshalers.dll + 2012-03-27 05:39 . 2012-03-27 05:39 57344 c:\windows\assembly\GAC\System.Web.RegularExpressions\1.0.5000.0__b03f5f7f11d50a3a\System.Web.RegularExpressions.dll + 2012-03-29 03:31 . 2012-03-29 03:31 81920 c:\windows\assembly\GAC\System.Security\1.0.5000.0__b03f5f7f11d50a3a\System.Security.dll + 2012-03-27 05:39 . 2012-03-27 05:39 66560 c:\windows\assembly\GAC\System.EnterpriseServices\1.0.5000.0__b03f5f7f11d50a3a\System.EnterpriseServices.Thunk.dll + 2012-03-27 05:38 . 2012-03-27 05:38 65536 c:\windows\assembly\GAC\System.Drawing.Design\1.0.5000.0__b03f5f7f11d50a3a\System.Drawing.Design.dll + 2012-03-27 05:39 . 2012-03-27 05:39 90112 c:\windows\assembly\GAC\System.DirectoryServices\1.0.5000.0__b03f5f7f11d50a3a\System.DirectoryServices.dll + 2012-03-27 05:38 . 2012-03-27 05:38 77824 c:\windows\assembly\GAC\System.Configuration.Install\1.0.5000.0__b03f5f7f11d50a3a\System.Configuration.Install.dll - 2009-10-01 01:41 . 2009-10-01 01:41 16384 c:\windows\assembly\GAC\stdole\7.0.3300.0__b03f5f7f11d50a3a\stdole.dll + 2011-07-26 01:27 . 2011-07-26 01:27 16384 c:\windows\assembly\GAC\stdole\7.0.3300.0__b03f5f7f11d50a3a\stdole.dll + 2012-03-27 05:39 . 2012-03-27 05:39 32768 c:\windows\assembly\GAC\Regcode\1.0.5000.0__b03f5f7f11d50a3a\RegCode.dll + 2011-07-26 11:57 . 2011-07-26 11:57 10576 c:\windows\assembly\GAC\Policy.11.0.office\12.0.0.0__71e9bce111e9429c\Policy.11.0.Office.dll - 2009-10-08 12:28 . 2009-10-08 12:28 10576 c:\windows\assembly\GAC\Policy.11.0.office\12.0.0.0__71e9bce111e9429c\Policy.11.0.Office.dll - 2009-10-08 12:28 . 2009-10-08 12:28 11112 c:\windows\assembly\GAC\Policy.11.0.Microsoft.Vbe.Interop\12.0.0.0__71e9bce111e9429c\Policy.11.0.Microsoft.Vbe.Interop.dll + 2011-07-26 11:57 . 2011-07-26 11:57 11112 c:\windows\assembly\GAC\Policy.11.0.Microsoft.Vbe.Interop\12.0.0.0__71e9bce111e9429c\Policy.11.0.Microsoft.Vbe.Interop.dll + 2012-03-29 04:52 . 2012-03-29 04:52 11144 c:\windows\assembly\GAC\Policy.11.0.Microsoft.Office.Interop.Word\12.0.0.0__71e9bce111e9429c\Policy.11.0.Microsoft.Office.Interop.Word.dll + 2011-07-26 11:57 . 2011-07-26 11:57 11136 c:\windows\assembly\GAC\Policy.11.0.Microsoft.Office.Interop.SmartTag\12.0.0.0__71e9bce111e9429c\Policy.11.0.Microsoft.Office.Interop.SmartTag.dll + 2011-07-26 11:58 . 2011-07-26 11:58 11152 c:\windows\assembly\GAC\Policy.11.0.Microsoft.Office.Interop.PowerPoint\12.0.0.0__71e9bce111e9429c\Policy.11.0.Microsoft.Office.Interop.PowerPoint.dll + 2011-07-26 11:57 . 2011-07-26 11:57 11128 c:\windows\assembly\GAC\Policy.11.0.Microsoft.Office.Interop.Graph\12.0.0.0__71e9bce111e9429c\Policy.11.0.Microsoft.Office.Interop.Graph.dll + 2011-07-26 11:58 . 2011-07-26 11:58 11144 c:\windows\assembly\GAC\Policy.11.0.Microsoft.Office.Interop.Excel\12.0.0.0__71e9bce111e9429c\Policy.11.0.Microsoft.Office.Interop.Excel.dll + 2012-03-27 05:37 . 2012-03-27 05:37 32768 c:\windows\assembly\GAC\Microsoft.Vsa\7.0.5000.0__b03f5f7f11d50a3a\Microsoft.Vsa.dll + 2012-03-27 05:37 . 2012-03-27 05:37 11264 c:\windows\assembly\GAC\Microsoft.Vsa.Vb.CodeDOMProcessor\7.0.5000.0__b03f5f7f11d50a3a\Microsoft.Vsa.Vb.CodeDOMProcessor.dll + 2012-03-27 05:37 . 2012-03-27 05:37 28672 c:\windows\assembly\GAC\Microsoft.VisualBasic.Vsa\7.0.5000.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Vsa.dll - 2009-10-08 12:28 . 2009-10-08 12:28 63336 c:\windows\assembly\GAC\Microsoft.Vbe.Interop\12.0.0.0__71e9bce111e9429c\Microsoft.Vbe.Interop.dll + 2012-03-29 04:52 . 2012-03-29 04:52 63336 c:\windows\assembly\GAC\Microsoft.Vbe.Interop\12.0.0.0__71e9bce111e9429c\Microsoft.Vbe.Interop.dll + 2011-07-26 01:27 . 2011-07-26 01:27 13312 c:\windows\assembly\GAC\Microsoft.StdFormat\7.0.3300.0__b03f5f7f11d50a3a\Microsoft.stdformat.dll - 2009-10-01 01:41 . 2009-10-01 01:41 13312 c:\windows\assembly\GAC\Microsoft.StdFormat\7.0.3300.0__b03f5f7f11d50a3a\Microsoft.stdformat.dll + 2011-07-26 11:57 . 2011-07-26 11:57 19320 c:\windows\assembly\GAC\Microsoft.Office.Interop.SmartTag\12.0.0.0__71e9bce111e9429c\Microsoft.Office.Interop.SmartTag.dll - 2009-10-01 01:41 . 2009-10-01 01:41 80696 c:\windows\assembly\GAC\Microsoft.Office.Interop.Access.Dao\12.0.0.0__71e9bce111e9429c\Microsoft.Office.interop.access.dao.dll + 2011-07-26 01:27 . 2011-07-26 01:27 80696 c:\windows\assembly\GAC\Microsoft.Office.Interop.Access.Dao\12.0.0.0__71e9bce111e9429c\Microsoft.Office.interop.access.dao.dll + 2011-12-09 03:39 . 2011-12-09 03:39 12800 c:\windows\assembly\GAC\Microsoft.DirectX.Diagnostics\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Diagnostics.dll - 2009-09-21 01:59 . 2009-09-21 01:59 12800 c:\windows\assembly\GAC\Microsoft.DirectX.Diagnostics\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Diagnostics.dll - 2009-09-21 01:59 . 2009-09-21 01:59 53248 c:\windows\assembly\GAC\Microsoft.DirectX.AudioVideoPlayback\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.AudioVideoPlayback.dll + 2011-12-09 03:39 . 2011-12-09 03:39 53248 c:\windows\assembly\GAC\Microsoft.DirectX.AudioVideoPlayback\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.AudioVideoPlayback.dll + 2012-03-27 05:38 . 2012-03-27 05:38 26112 c:\windows\assembly\GAC\ISymWrapper\1.0.5000.0__b03f5f7f11d50a3a\ISymWrapper.dll + 2012-03-27 05:39 . 2012-03-27 05:39 32768 c:\windows\assembly\GAC\IEHost\1.0.5000.0__b03f5f7f11d50a3a\IEHost.dll + 2012-03-27 05:37 . 2012-03-27 05:37 33792 c:\windows\assembly\GAC\CustomMarshalers\1.0.5000.0__b03f5f7f11d50a3a\CustomMarshalers.dll + 2012-03-27 05:37 . 2012-03-27 05:37 12288 c:\windows\assembly\GAC\cscompmgd\7.0.5000.0__b03f5f7f11d50a3a\cscompmgd.dll + 2012-07-28 20:17 . 2012-07-28 20:17 45056 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla51.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla39.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla38.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla37.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla36.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla35.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla33.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla27.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla26.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla25.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla24.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla23.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla22.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla21.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla18.dll + 2012-07-28 20:17 . 2012-07-28 20:17 29480 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla.dll + 2012-07-28 20:17 . 2012-07-28 20:17 26421 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCall.dll + 2012-06-29 05:12 . 2008-03-27 20:27 35040 c:\windows\$NtUninstallWdf01009$\wdfldr.sys + 2012-06-29 05:12 . 2009-07-13 20:49 47104 c:\windows\$NtUninstallWdf01009$\spuninst\KmdfCustom.dll + 2010-09-15 06:32 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB982802\update\spcustom.dll + 2010-09-15 06:32 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB982802\spmsg.dll + 2010-08-11 12:07 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB982665\update\spcustom.dll + 2010-08-11 12:07 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB982665\spmsg.dll + 2010-06-17 14:02 . 2010-06-17 14:02 80384 c:\windows\$hf_mig$\KB982665\SP3QFE\iccvid.dll + 2010-08-12 03:44 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB982214\update\spcustom.dll + 2010-08-12 03:44 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB982214\spmsg.dll + 2010-10-14 07:07 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB982132\update\spcustom.dll + 2010-10-14 07:07 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB982132\spmsg.dll + 2010-08-11 12:08 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB981997\update\spcustom.dll + 2010-08-11 12:08 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB981997\spmsg.dll + 2010-10-14 07:02 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB981957\update\spcustom.dll + 2010-10-14 07:02 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB981957\spmsg.dll + 2010-08-12 03:42 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB981852\update\spcustom.dll + 2010-08-10 23:36 . 2010-06-18 06:28 16896 c:\windows\$hf_mig$\KB981852\update\mpsyschk.dll + 2010-08-12 03:42 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB981852\spmsg.dll + 2010-09-15 06:31 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB981322\update\spcustom.dll + 2010-09-15 06:31 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB981322\spmsg.dll + 2010-08-12 03:38 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB980436\update\spcustom.dll + 2010-08-12 03:38 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB980436\spmsg.dll + 2010-10-14 07:06 . 2009-05-26 09:01 26488 c:\windows\$hf_mig$\KB979687\update\spcustom.dll + 2010-10-14 07:06 . 2009-05-26 09:01 17272 c:\windows\$hf_mig$\KB979687\spmsg.dll + 2011-02-24 08:00 . 2008-07-08 13:02 26488 c:\windows\$hf_mig$\KB971029\update\spcustom.dll + 2011-02-24 08:00 . 2008-07-08 13:02 17272 c:\windows\$hf_mig$\KB971029\spmsg.dll + 2012-07-11 12:26 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2719985\update\spcustom.dll + 2012-07-11 12:26 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2719985\spmsg.dll + 2012-06-05 22:55 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2718704\update\spcustom.dll + 2012-06-05 22:55 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2718704\spmsg.dll + 2012-07-11 12:28 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2718523\update\spcustom.dll + 2012-07-11 12:28 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2718523\spmsg.dll + 2012-08-15 05:53 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2712808\update\spcustom.dll + 2012-08-15 05:53 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2712808\spmsg.dll + 2012-06-14 06:05 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2709162\update\spcustom.dll + 2012-06-14 06:05 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2709162\spmsg.dll + 2012-06-14 06:20 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2707511\update\spcustom.dll + 2012-06-13 22:26 . 2012-05-05 03:16 16896 c:\windows\$hf_mig$\KB2707511\update\mpsyschk.dll + 2012-06-14 06:20 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2707511\spmsg.dll + 2012-08-15 05:47 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2705219\update\spcustom.dll + 2012-08-15 05:47 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2705219\spmsg.dll + 2012-07-06 13:58 . 2012-07-06 13:58 78336 c:\windows\$hf_mig$\KB2705219\SP3QFE\browser.dll + 2012-06-14 06:08 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2699988-IE8\update\spcustom.dll + 2012-06-14 06:08 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2699988-IE8\spmsg.dll + 2012-06-13 22:26 . 2012-05-11 14:41 12800 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\xpshims.dll + 2012-06-13 22:26 . 2012-05-11 14:41 67072 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\mshtmled.dll + 2012-06-13 22:26 . 2012-05-11 14:41 55296 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\msfeedsbs.dll + 2012-06-13 22:26 . 2012-05-11 14:41 43520 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\licmgr10.dll + 2012-06-13 22:26 . 2012-05-11 14:41 25600 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\jsproxy.dll + 2012-07-11 12:20 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2698365\update\spcustom.dll + 2012-07-11 12:20 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2698365\spmsg.dll + 2012-07-11 04:37 . 2012-05-28 18:15 57344 c:\windows\$hf_mig$\KB2698365\SP3QFE\msador15.dll + 2012-05-09 22:30 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2695962\update\spcustom.dll + 2012-05-09 22:30 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2695962\spmsg.dll + 2012-07-11 12:28 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2691442\update\spcustom.dll + 2012-07-11 12:28 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2691442\spmsg.dll + 2012-05-09 22:31 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2686509\update\spcustom.dll + 2012-05-09 22:31 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2686509\spmsg.dll + 2012-06-14 06:08 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2685939\update\spcustom.dll + 2012-06-14 06:08 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2685939\spmsg.dll + 2012-05-09 22:23 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2676562\update\spcustom.dll + 2012-05-09 05:31 . 2012-04-11 13:53 16896 c:\windows\$hf_mig$\KB2676562\update\mpsyschk.dll + 2012-05-09 22:23 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2676562\spmsg.dll + 2012-04-11 12:54 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2675157-IE8\update\spcustom.dll + 2012-04-11 12:54 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2675157-IE8\spmsg.dll + 2012-04-11 07:33 . 2012-03-01 10:58 12800 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\xpshims.dll + 2012-04-11 07:33 . 2012-03-01 10:58 66560 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\mshtmled.dll + 2012-04-11 07:33 . 2012-03-01 10:58 55296 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\msfeedsbs.dll + 2012-04-11 07:33 . 2012-03-01 10:58 43520 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\licmgr10.dll + 2012-04-11 07:33 . 2012-03-01 10:58 25600 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\jsproxy.dll + 2012-02-16 08:00 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2661637\update\spcustom.dll + 2012-02-16 08:00 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2661637\spmsg.dll + 2012-02-16 08:06 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2660465\update\spcustom.dll + 2012-02-16 08:06 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2660465\spmsg.dll + 2012-07-11 12:27 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2655992\update\spcustom.dll + 2012-07-11 12:27 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2655992\spmsg.dll + 2012-04-11 12:46 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2653956\update\spcustom.dll + 2012-04-11 12:46 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2653956\spmsg.dll + 2012-03-14 07:01 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2647518\update\spcustom.dll + 2012-03-14 07:01 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2647518\spmsg.dll + 2012-02-16 08:05 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2647516-IE8\update\spcustom.dll + 2012-02-16 08:05 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2647516-IE8\spmsg.dll + 2012-02-16 07:52 . 2011-12-17 19:45 12800 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\xpshims.dll + 2012-02-16 07:52 . 2011-12-17 19:45 66560 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\mshtmled.dll + 2012-02-16 07:52 . 2011-12-17 19:45 55296 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\msfeedsbs.dll + 2012-02-16 07:52 . 2011-12-17 19:45 43520 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\licmgr10.dll + 2012-02-16 07:52 . 2011-12-17 19:45 25600 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\jsproxy.dll + 2012-01-12 08:04 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2646524\update\spcustom.dll + 2012-01-12 08:04 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2646524\spmsg.dll + 2011-11-11 07:21 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2641690\update\spcustom.dll + 2011-11-11 07:21 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2641690\spmsg.dll + 2012-03-14 07:04 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2641653\update\spcustom.dll + 2012-03-14 07:04 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2641653\spmsg.dll + 2011-12-15 05:51 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2639417\update\spcustom.dll + 2011-12-15 05:51 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2639417\spmsg.dll + 2011-12-15 05:44 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2633171\update\spcustom.dll + 2011-12-15 03:59 . 2011-10-26 10:50 16896 c:\windows\$hf_mig$\KB2633171\update\mpsyschk.dll + 2011-12-15 05:44 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2633171\spmsg.dll + 2012-01-12 08:04 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2631813\update\spcustom.dll + 2012-01-12 08:04 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2631813\spmsg.dll + 2011-12-15 05:51 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2624667\update\spcustom.dll + 2011-12-15 05:51 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2624667\spmsg.dll + 2012-03-14 07:01 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2621440\update\spcustom.dll + 2012-03-14 07:01 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2621440\spmsg.dll + 2011-12-15 05:44 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2620712\update\spcustom.dll + 2011-12-15 05:44 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2620712\spmsg.dll + 2011-10-28 05:31 . 2011-10-28 05:31 33280 c:\windows\$hf_mig$\KB2620712\SP3QFE\csrsrv.dll + 2011-12-15 05:45 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2619339\update\spcustom.dll + 2011-12-15 05:45 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2619339\spmsg.dll + 2011-12-15 05:44 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2618451\update\spcustom.dll + 2011-12-15 05:44 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2618451\spmsg.dll + 2011-12-15 05:50 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2618444-IE8\update\spcustom.dll + 2011-12-15 05:50 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2618444-IE8\spmsg.dll + 2011-12-15 03:59 . 2011-11-04 19:19 12800 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\xpshims.dll + 2011-12-15 03:59 . 2011-11-04 19:19 66560 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\mshtmled.dll + 2011-12-15 03:59 . 2011-11-04 19:19 55296 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\msfeedsbs.dll + 2011-12-15 03:59 . 2011-11-04 19:19 43520 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\licmgr10.dll + 2011-12-15 03:59 . 2011-11-04 19:19 25600 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\jsproxy.dll + 2011-09-15 12:48 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2616676\update\spcustom.dll + 2011-09-15 12:48 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2616676\spmsg.dll + 2011-09-07 12:27 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2607712\update\spcustom.dll + 2011-09-07 12:27 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2607712\spmsg.dll + 2012-01-12 08:01 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2603381\update\spcustom.dll + 2012-01-12 08:01 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2603381\spmsg.dll + 2012-01-12 08:01 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2598479\update\spcustom.dll + 2012-01-12 08:01 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2598479\spmsg.dll + 2011-10-14 14:45 . 2011-10-14 14:45 23040 c:\windows\$hf_mig$\KB2598479\SP3QFE\mciseq.dll + 2011-10-12 11:49 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2592799\update\spcustom.dll + 2011-10-12 11:49 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2592799\spmsg.dll + 2011-10-12 11:48 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2586448-IE8\update\spcustom.dll + 2011-10-12 11:48 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2586448-IE8\spmsg.dll + 2011-10-11 23:17 . 2011-08-22 23:47 12800 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\xpshims.dll + 2011-10-11 23:17 . 2011-08-22 23:47 66560 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\mshtmled.dll + 2011-10-11 23:17 . 2011-08-22 23:47 55296 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\msfeedsbs.dll + 2011-10-11 23:17 . 2011-08-22 23:47 43520 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\licmgr10.dll + 2011-10-11 23:17 . 2011-08-22 23:47 25600 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\jsproxy.dll + 2012-01-14 15:48 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2585542\update\spcustom.dll + 2012-01-14 15:48 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2585542\spmsg.dll + 2012-01-12 08:00 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2584146\update\spcustom.dll + 2012-01-12 08:00 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2584146\spmsg.dll + 2011-11-18 12:41 . 2011-11-18 12:41 60416 c:\windows\$hf_mig$\KB2584146\SP3QFE\packager.exe + 2011-09-15 12:43 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2570947\update\spcustom.dll + 2011-09-15 12:43 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2570947\spmsg.dll + 2011-08-11 12:10 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2570222\update\spcustom.dll + 2011-08-11 12:10 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2570222\spmsg.dll + 2011-08-11 12:11 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2567680\update\spcustom.dll + 2011-08-11 12:11 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2567680\spmsg.dll + 2011-10-12 11:49 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2567053\update\spcustom.dll + 2011-10-12 11:49 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2567053\spmsg.dll + 2011-08-11 11:59 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2566454\update\spcustom.dll + 2011-08-11 11:59 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2566454\spmsg.dll + 2011-08-10 13:56 . 2011-07-08 13:51 10496 c:\windows\$hf_mig$\KB2566454\SP3QFE\ndistapi.sys + 2011-08-11 11:59 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2562937\update\spcustom.dll + 2011-08-11 11:59 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2562937\spmsg.dll + 2011-08-11 12:00 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2559049-IE8\update\spcustom.dll + 2011-08-11 12:00 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2559049-IE8\spmsg.dll + 2011-08-10 13:56 . 2011-06-23 18:33 12800 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\xpshims.dll + 2011-08-10 13:56 . 2011-06-23 18:33 66560 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\mshtmled.dll + 2011-08-10 13:56 . 2011-06-23 18:33 55296 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\msfeedsbs.dll + 2011-08-10 13:56 . 2011-06-23 18:33 43520 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\licmgr10.dll + 2011-08-10 13:56 . 2011-06-23 18:33 25600 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\jsproxy.dll + 2011-07-14 11:54 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2555917\update\spcustom.dll + 2011-07-14 11:54 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2555917\spmsg.dll + 2011-06-17 07:03 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2544893\update\spcustom.dll + 2011-06-17 07:03 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2544893\spmsg.dll + 2011-11-10 12:58 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2544893-v2\update\spcustom.dll + 2011-11-10 12:58 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2544893-v2\spmsg.dll + 2011-06-17 07:00 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2544521-IE8\update\spcustom.dll + 2011-06-17 07:00 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2544521-IE8\spmsg.dll + 2011-06-29 07:00 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2541763\update\spcustom.dll + 2011-06-29 07:00 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2541763\spmsg.dll + 2011-06-17 07:04 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2536276\update\spcustom.dll + 2011-06-17 07:04 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2536276\spmsg.dll + 2011-08-11 12:10 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2536276-v2\update\spcustom.dll + 2011-08-11 12:10 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2536276-v2\spmsg.dll + 2011-06-17 07:04 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2535512\update\spcustom.dll + 2011-06-17 07:04 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2535512\spmsg.dll + 2011-06-17 07:03 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2530548-IE8\update\spcustom.dll + 2011-06-17 07:03 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2530548-IE8\spmsg.dll + 2011-06-16 22:25 . 2011-04-25 16:09 12800 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\xpshims.dll + 2011-06-16 22:25 . 2011-04-25 16:09 66560 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\mshtmled.dll + 2011-06-16 22:25 . 2011-04-25 16:09 55296 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\msfeedsbs.dll + 2011-06-16 22:25 . 2011-04-25 16:09 43520 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\licmgr10.dll + 2011-06-16 22:25 . 2011-04-25 16:09 25600 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\jsproxy.dll + 2011-03-25 03:18 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2524375\update\spcustom.dll + 2011-03-25 03:18 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2524375\spmsg.dll + 2011-04-15 07:05 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2511455\update\spcustom.dll + 2011-04-15 07:05 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2511455\spmsg.dll + 2011-04-15 07:01 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2510531-IE8\update\spcustom.dll + 2011-04-15 07:01 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2510531-IE8\spmsg.dll + 2011-04-15 07:01 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2509553\update\spcustom.dll + 2011-04-15 07:01 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2509553\spmsg.dll + 2009-04-20 17:06 . 2009-04-20 17:06 45568 c:\windows\$hf_mig$\KB2509553\SP3QFE\dnsrslvr.dll + 2011-04-15 07:05 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2508429\update\spcustom.dll + 2011-04-15 07:05 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2508429\spmsg.dll + 2011-04-15 07:06 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2508272\update\spcustom.dll + 2011-04-15 07:06 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2508272\spmsg.dll + 2011-07-14 11:57 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2507938\update\spcustom.dll + 2011-07-14 11:57 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2507938\spmsg.dll + 2011-04-26 11:02 . 2011-04-26 11:02 33280 c:\windows\$hf_mig$\KB2507938\SP3QFE\csrsrv.dll + 2011-04-15 07:05 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2507618\update\spcustom.dll + 2011-04-15 07:05 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2507618\spmsg.dll + 2011-04-15 07:09 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2506223\update\spcustom.dll + 2011-04-15 07:09 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2506223\spmsg.dll + 2011-04-15 07:04 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2506212\update\spcustom.dll + 2011-04-15 07:04 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2506212\spmsg.dll + 2011-06-17 07:05 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2503665\update\spcustom.dll + 2011-06-17 07:05 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2503665\spmsg.dll + 2011-04-15 07:06 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2503658\update\spcustom.dll + 2011-04-15 07:06 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2503658\spmsg.dll + 2011-04-15 07:09 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2497640-IE8\update\spcustom.dll + 2011-04-15 07:09 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2497640-IE8\spmsg.dll + 2011-04-14 11:29 . 2011-02-22 23:27 12800 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\xpshims.dll + 2011-04-14 11:29 . 2011-02-22 23:27 66560 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\mshtmled.dll + 2011-04-14 11:29 . 2011-02-22 23:27 55296 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\msfeedsbs.dll + 2011-04-14 11:29 . 2011-02-22 23:27 43520 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\licmgr10.dll + 2011-04-14 11:29 . 2011-02-22 23:27 25600 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\jsproxy.dll + 2011-04-15 07:10 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2485663\update\spcustom.dll + 2011-04-15 07:10 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2485663\spmsg.dll + 2011-02-10 23:46 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2485376\update\spcustom.dll + 2011-02-10 23:46 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2485376\spmsg.dll + 2011-02-10 23:44 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2483185\update\spcustom.dll + 2011-02-10 23:44 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2483185\spmsg.dll + 2011-02-11 08:01 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2482017-IE8\update\spcustom.dll + 2011-02-11 08:01 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2482017-IE8\spmsg.dll + 2011-02-10 23:49 . 2010-12-20 23:58 12800 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\xpshims.dll + 2011-02-10 23:49 . 2010-12-20 23:58 66560 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\mshtmled.dll + 2011-02-10 23:49 . 2010-12-20 23:58 55296 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\msfeedsbs.dll + 2011-02-10 23:49 . 2010-12-20 23:58 43520 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\licmgr10.dll + 2011-02-10 23:49 . 2010-12-20 23:58 25600 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\jsproxy.dll + 2011-03-09 08:01 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2481109\update\spcustom.dll + 2011-03-09 08:01 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2481109\spmsg.dll + 2011-02-02 07:57 . 2011-02-02 07:57 53248 c:\windows\$hf_mig$\KB2481109\SP3QFE\tsgqec.dll + 2011-03-09 08:04 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2479943\update\spcustom.dll + 2011-03-09 08:04 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2479943\spmsg.dll + 2011-02-10 23:45 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2479628\update\spcustom.dll + 2011-02-10 23:45 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2479628\spmsg.dll + 2011-02-10 23:46 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2478971\update\spcustom.dll + 2011-02-10 23:46 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2478971\spmsg.dll + 2011-02-10 23:38 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2478960\update\spcustom.dll + 2011-02-10 23:38 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2478960\spmsg.dll + 2011-02-10 23:39 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2476687\update\spcustom.dll + 2011-02-10 23:39 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2476687\spmsg.dll + 2010-12-09 14:29 . 2010-12-09 14:29 33280 c:\windows\$hf_mig$\KB2476687\SP3QFE\csrsrv.dll + 2011-06-17 07:06 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2476490\update\spcustom.dll + 2011-06-17 07:06 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2476490\spmsg.dll + 2010-12-16 08:02 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2467659\update\spcustom.dll + 2010-12-16 08:02 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2467659\spmsg.dll + 2010-12-16 08:03 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2443105\update\spcustom.dll + 2010-12-16 08:03 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2443105\spmsg.dll + 2010-11-18 18:12 . 2010-11-18 18:12 81920 c:\windows\$hf_mig$\KB2443105\SP3QFE\isign32.dll + 2010-12-16 08:03 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB2440591\update\spcustom.dll + 2010-12-16 08:03 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB2440591\spmsg.dll + 2010-12-16 05:25 . 2010-11-03 05:55 40960 c:\windows\$hf_mig$\KB2440591\SP3QFE\ndproxy.sys + 2010-12-16 08:02 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB2436673\update\spcustom.dll + 2010-12-16 08:02 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB2436673\spmsg.dll + 2010-12-16 08:00 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2423089\update\spcustom.dll + 2010-12-16 08:00 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2423089\spmsg.dll + 2010-12-15 21:24 . 2010-10-11 14:55 45568 c:\windows\$hf_mig$\KB2423089\SP3QFE\wab.exe + 2011-01-12 08:01 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2419632\update\spcustom.dll + 2011-01-12 08:01 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2419632\spmsg.dll + 2010-12-16 08:03 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2416400-IE8\update\spcustom.dll + 2010-12-16 08:03 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2416400-IE8\spmsg.dll + 2010-12-16 05:25 . 2010-11-06 00:27 12800 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\xpshims.dll + 2010-12-16 05:25 . 2010-11-06 00:27 66560 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\mshtmled.dll + 2010-12-16 05:25 . 2010-11-06 00:27 55296 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\msfeedsbs.dll + 2010-12-16 05:25 . 2010-11-06 00:27 43520 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\licmgr10.dll + 2010-12-16 05:25 . 2010-11-06 00:27 25600 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\jsproxy.dll + 2011-02-10 23:38 . 2010-07-05 13:15 26488 c:\windows\$hf_mig$\KB2393802\update\spcustom.dll + 2011-02-09 23:28 . 2010-12-09 15:15 16896 c:\windows\$hf_mig$\KB2393802\update\mpsyschk.dll + 2011-02-10 23:38 . 2010-07-05 13:15 17272 c:\windows\$hf_mig$\KB2393802\spmsg.dll + 2010-10-14 07:08 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2387149\update\spcustom.dll + 2010-10-14 07:08 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2387149\spmsg.dll + 2010-10-14 07:00 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2360937\update\spcustom.dll + 2010-10-14 07:00 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2360937\spmsg.dll + 2010-10-14 07:05 . 2009-05-26 09:01 26488 c:\windows\$hf_mig$\KB2360131-IE8\update\spcustom.dll + 2010-10-14 07:05 . 2009-05-26 09:01 17272 c:\windows\$hf_mig$\KB2360131-IE8\spmsg.dll + 2010-10-13 22:28 . 2010-09-10 05:57 12800 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\xpshims.dll + 2010-10-13 22:28 . 2010-09-10 05:57 66560 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\mshtmled.dll + 2010-10-13 22:28 . 2010-09-10 05:57 55296 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\msfeedsbs.dll + 2010-10-13 22:28 . 2010-09-10 05:57 43520 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\licmgr10.dll + 2010-10-13 22:28 . 2010-09-10 05:57 25600 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\jsproxy.dll + 2010-09-15 06:33 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB2347290\update\spcustom.dll + 2010-09-15 06:33 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB2347290\spmsg.dll + 2010-08-17 13:19 . 2010-08-17 13:19 58880 c:\windows\$hf_mig$\KB2347290\SP3QFE\spoolsv.exe + 2010-10-14 07:08 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2345886\update\spcustom.dll + 2010-10-14 07:08 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2345886\spmsg.dll + 2010-08-27 06:05 . 2010-08-27 06:05 99840 c:\windows\$hf_mig$\KB2345886\SP3QFE\srvsvc.dll + 2010-12-16 08:03 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB2296199\update\spcustom.dll + 2010-12-16 08:03 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB2296199\spmsg.dll + 2010-08-03 12:24 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2286198\update\spcustom.dll + 2010-08-03 12:24 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2286198\spmsg.dll + 2010-10-14 07:08 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2279986\update\spcustom.dll + 2010-10-14 07:08 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2279986\spmsg.dll + 2010-09-15 06:34 . 2009-05-26 09:01 26488 c:\windows\$hf_mig$\KB2259922\update\spcustom.dll + 2010-09-15 06:34 . 2009-05-26 09:01 17272 c:\windows\$hf_mig$\KB2259922\spmsg.dll + 2010-07-14 07:06 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB2229593\update\spcustom.dll + 2010-07-14 07:06 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB2229593\spmsg.dll + 2010-08-12 03:39 . 2009-05-26 09:01 26488 c:\windows\$hf_mig$\KB2183461-IE8\update\spcustom.dll + 2010-08-12 03:39 . 2009-05-26 09:01 17272 c:\windows\$hf_mig$\KB2183461-IE8\spmsg.dll + 2010-08-10 23:34 . 2010-06-24 12:24 12800 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\xpshims.dll + 2010-08-10 23:34 . 2010-06-24 12:24 55296 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\msfeedsbs.dll + 2010-08-10 23:34 . 2010-06-24 12:24 25600 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\jsproxy.dll + 2010-08-12 03:38 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2160329\update\spcustom.dll + 2010-08-12 03:38 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2160329\spmsg.dll + 2010-09-15 06:29 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2141007\update\spcustom.dll + 2010-09-15 06:29 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2141007\spmsg.dll + 2010-09-15 06:33 . 2010-02-22 14:23 26488 c:\windows\$hf_mig$\KB2121546\update\spcustom.dll + 2010-09-15 06:33 . 2010-02-22 14:23 17272 c:\windows\$hf_mig$\KB2121546\spmsg.dll + 2010-08-12 03:44 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB2115168\update\spcustom.dll + 2010-08-12 03:44 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB2115168\spmsg.dll + 2010-08-12 03:42 . 2009-05-26 11:40 26488 c:\windows\$hf_mig$\KB2079403\update\spcustom.dll + 2010-08-12 03:42 . 2009-05-26 11:40 17272 c:\windows\$hf_mig$\KB2079403\spmsg.dll - 2010-06-09 07:05 . 2010-06-09 07:05 8192 c:\windows\WinSxS\MSIL_IEExecRemote_b03f5f7f11d50a3a_2.0.0.0_x-ww_6e57c34e\IEExecRemote.dll + 2012-06-14 06:19 . 2012-06-14 06:19 8192 c:\windows\WinSxS\MSIL_IEExecRemote_b03f5f7f11d50a3a_2.0.0.0_x-ww_6e57c34e\IEExecRemote.dll + 2009-04-19 19:26 . 2011-02-17 12:32 5120 c:\windows\system32\xpsp4res.dll + 2012-03-07 05:25 . 2007-06-30 18:49 4608 c:\windows\system32\windowspowershell\v1.0\pwrshmsg.dll + 2011-11-26 17:44 . 2008-04-14 00:11 4096 c:\windows\system32\ReinstallBackups\0007\DriverFiles\i386\ksuser.dll + 2003-02-20 22:43 . 2003-02-20 22:43 4096 c:\windows\system32\mui\0409\mscoreer.dll + 2012-02-16 07:51 . 2012-01-11 19:06 3072 c:\windows\system32\iacenc.dll + 2012-06-29 05:06 . 2012-01-09 21:28 8576 c:\windows\system32\DRVSTORE\nmwcdnsuc_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\nmwcdnsuc.sys + 2012-06-29 05:06 . 2012-01-09 21:28 8192 c:\windows\system32\DRVSTORE\ccdcmbm_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\usbser_lowerflt.sys + 2012-06-29 05:06 . 2012-01-09 21:28 8192 c:\windows\system32\DRVSTORE\ccdcmbj_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\usbser_lowerfltj.sys + 2012-06-29 05:06 . 2012-01-09 21:28 8192 c:\windows\system32\drivers\usbser_lowerfltj.sys + 2012-06-29 05:06 . 2012-01-09 21:28 8192 c:\windows\system32\drivers\usbser_lowerflt.sys + 2007-01-18 20:28 . 2007-01-18 20:28 5275 c:\windows\system32\drivers\CVirtA.sys + 2012-02-16 07:51 . 2012-01-11 19:06 3072 c:\windows\system32\dllcache\iacenc.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.3082.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.3076.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.2070.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8024 c:\windows\Microsoft.NET\NETFXRepair.2052.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1055.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1053.dll + 2010-03-18 17:16 . 2010-03-18 17:16 9048 c:\windows\Microsoft.NET\NETFXRepair.1049.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1046.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1045.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1044.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1043.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1042.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1041.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1040.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1038.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1037.dll + 2010-03-18 17:16 . 2010-03-18 17:16 9048 c:\windows\Microsoft.NET\NETFXRepair.1036.dll + 2010-03-18 17:16 . 2010-03-18 17:16 9048 c:\windows\Microsoft.NET\NETFXRepair.1035.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1033.dll + 2010-03-18 17:16 . 2010-03-18 17:16 9048 c:\windows\Microsoft.NET\NETFXRepair.1032.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1031.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1030.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1029.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8024 c:\windows\Microsoft.NET\NETFXRepair.1028.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8536 c:\windows\Microsoft.NET\NETFXRepair.1025.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8032 c:\windows\Microsoft.NET\Framework\v4.0.30319\ServiceModelRegUI.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8040 c:\windows\Microsoft.NET\Framework\v4.0.30319\ServiceModelInstallRC.dll + 2010-03-18 17:16 . 2010-03-18 17:16 8032 c:\windows\Microsoft.NET\Framework\v4.0.30319\ServiceModelEvents.dll + 2003-02-20 23:09 . 2003-02-20 23:09 9216 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscortim.dll + 2003-02-21 11:25 . 2003-02-21 11:25 6656 c:\windows\Microsoft.NET\Framework\v1.1.4322\Microsoft_VsaVb.dll + 2003-02-21 11:25 . 2003-02-21 11:25 6144 c:\windows\Microsoft.NET\Framework\v1.1.4322\Microsoft.VisualC.Dll + 2003-02-21 11:24 . 2003-02-21 11:24 4608 c:\windows\Microsoft.NET\Framework\v1.1.4322\IIEHost.dll + 2004-07-15 18:31 . 2004-07-15 18:31 8192 c:\windows\Microsoft.NET\Framework\v1.1.4322\IEExecRemote.dll + 2003-02-21 11:24 . 2003-02-21 11:24 7680 c:\windows\Microsoft.NET\Framework\v1.1.4322\IEExec.exe + 2003-02-21 11:24 . 2003-02-21 11:24 7680 c:\windows\Microsoft.NET\Framework\v1.1.4322\Accessibility.dll + 2009-04-22 23:06 . 2011-03-11 04:39 7278 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\SC_ELEMENTS_DT.exe - 2009-04-22 23:06 . 2009-04-22 23:06 7278 c:\windows\Installer\{AC76BA86-1033-0000-7760-100000000002}\SC_ELEMENTS_DT.exe + 2012-06-29 05:06 . 2012-06-29 05:06 3262 c:\windows\Installer\{A57025CC-5F2E-4D01-B387-06DB10500D43}\ARPPRODUCTICON.exe - 2009-12-30 20:55 . 2010-06-09 07:01 3584 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\opwicon.exe + 2009-12-30 20:55 . 2011-06-17 07:08 3584 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\opwicon.exe + 2009-12-30 20:55 . 2011-06-17 07:08 8192 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\mspicons.exe - 2009-12-30 20:55 . 2010-06-09 07:01 8192 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\mspicons.exe + 2009-12-30 20:55 . 2011-06-17 07:08 2560 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\cagicon.exe - 2009-12-30 20:55 . 2010-06-09 07:01 2560 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\cagicon.exe + 2009-04-19 20:18 . 2012-08-15 05:47 4096 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\opwicon.exe - 2009-04-19 20:18 . 2010-06-09 07:11 4096 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\opwicon.exe + 2012-05-09 23:32 . 2012-05-09 23:32 9728 c:\windows\assembly\NativeImages_v4.0.30319_32\dfsvc\fd866b4158c3bd2a26c875f2896c5573\dfsvc.ni.exe + 2012-06-14 06:19 . 2012-06-14 06:19 7168 c:\windows\assembly\GAC_MSIL\Microsoft_VsaVb\8.0.0.0__b03f5f7f11d50a3a\Microsoft_VsaVb.dll - 2010-06-09 07:05 . 2010-06-09 07:05 7168 c:\windows\assembly\GAC_MSIL\Microsoft_VsaVb\8.0.0.0__b03f5f7f11d50a3a\Microsoft_VsaVb.dll + 2012-06-14 06:19 . 2012-06-14 06:19 5632 c:\windows\assembly\GAC_MSIL\Microsoft.VisualC\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualC.Dll - 2010-06-09 07:05 . 2010-06-09 07:05 5632 c:\windows\assembly\GAC_MSIL\Microsoft.VisualC\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualC.Dll + 2012-03-07 05:25 . 2012-03-07 05:25 8704 c:\windows\assembly\GAC_MSIL\Microsoft.PowerShell.Security.resources\1.0.0.0_en_31bf3856ad364e35\Microsoft.PowerShell.Security.resources.dll - 2010-06-09 07:05 . 2010-06-09 07:05 6656 c:\windows\assembly\GAC_MSIL\IIEHost\2.0.0.0__b03f5f7f11d50a3a\IIEHost.dll + 2012-06-14 06:19 . 2012-06-14 06:19 6656 c:\windows\assembly\GAC_MSIL\IIEHost\2.0.0.0__b03f5f7f11d50a3a\IIEHost.dll + 2012-06-14 06:19 . 2012-06-14 06:19 8192 c:\windows\assembly\GAC_MSIL\IEExecRemote\2.0.0.0__b03f5f7f11d50a3a\IEExecRemote.dll - 2010-06-09 07:05 . 2010-06-09 07:05 8192 c:\windows\assembly\GAC_MSIL\IEExecRemote\2.0.0.0__b03f5f7f11d50a3a\IEExecRemote.dll + 2011-07-26 01:27 . 2011-07-26 01:27 4096 c:\windows\assembly\GAC\MSDATASRC\7.0.3300.0__b03f5f7f11d50a3a\msdatasrc.dll - 2009-10-01 01:41 . 2009-10-01 01:41 4096 c:\windows\assembly\GAC\MSDATASRC\7.0.3300.0__b03f5f7f11d50a3a\msdatasrc.dll + 2012-03-27 05:37 . 2012-03-27 05:37 6656 c:\windows\assembly\GAC\Microsoft_VsaVb\7.0.5000.0__b03f5f7f11d50a3a\Microsoft_VsaVb.dll + 2012-03-27 05:37 . 2012-03-27 05:37 6144 c:\windows\assembly\GAC\Microsoft.VisualC\7.0.5000.0__b03f5f7f11d50a3a\Microsoft.VisualC.dll + 2012-03-27 05:38 . 2012-03-27 05:38 4608 c:\windows\assembly\GAC\IIEHost\1.0.5000.0__b03f5f7f11d50a3a\IIEHost.dll + 2012-03-27 05:39 . 2012-03-27 05:39 8192 c:\windows\assembly\GAC\IEExecRemote\1.0.5000.0__b03f5f7f11d50a3a\IEExecRemote.dll + 2011-07-26 01:27 . 2011-07-26 01:27 4608 c:\windows\assembly\GAC\Extensibility\7.0.3300.0__b03f5f7f11d50a3a\extensibility.dll - 2009-10-01 01:41 . 2009-10-01 01:41 4608 c:\windows\assembly\GAC\Extensibility\7.0.3300.0__b03f5f7f11d50a3a\extensibility.dll + 2012-03-27 05:37 . 2012-03-27 05:37 7680 c:\windows\assembly\GAC\Accessibility\1.0.5000.0__b03f5f7f11d50a3a\Accessibility.dll + 2010-07-22 05:57 . 2010-07-22 05:57 5120 c:\windows\$hf_mig$\KB982802\SP3QFE\xpsp4res.dll + 2010-07-12 12:53 . 2010-07-12 12:53 5120 c:\windows\$hf_mig$\KB979687\SP3QFE\xpsp4res.dll + 2012-05-09 05:30 . 2012-04-19 11:26 8192 c:\windows\$hf_mig$\KB2686509\update\kblChecker.dll + 2012-02-16 07:51 . 2012-01-11 19:05 3072 c:\windows\$hf_mig$\KB2661637\SP3QFE\iacenc.dll + 2012-01-12 00:06 . 2011-11-03 18:17 4608 c:\windows\$hf_mig$\KB2603381\update\customaddreg.dll + 2011-02-17 12:32 . 2011-02-17 12:32 5120 c:\windows\$hf_mig$\KB2508429\SP3QFE\xpsp4res.dll + 2010-10-13 22:22 . 2010-08-13 12:53 5120 c:\windows\$hf_mig$\KB2360937\SP3QFE\xpsp4res.dll + 2010-08-26 12:52 . 2010-08-26 12:52 5120 c:\windows\$hf_mig$\KB2345886\SP3QFE\xpsp4res.dll + 2012-06-14 06:17 . 2012-06-14 06:17 109568 c:\windows\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_4.0.0.0_x-ww_29b51492\System.EnterpriseServices.Wrapper.dll + 2012-06-14 06:17 . 2012-06-14 06:17 246128 c:\windows\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_4.0.0.0_x-ww_29b51492\System.EnterpriseServices.dll + 2012-06-14 06:19 . 2012-06-14 06:19 113664 c:\windows\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790\System.EnterpriseServices.Wrapper.dll - 2010-06-09 07:05 . 2010-06-09 07:05 113664 c:\windows\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790\System.EnterpriseServices.Wrapper.dll + 2012-06-14 06:19 . 2012-06-14 06:19 258048 c:\windows\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790\System.EnterpriseServices.dll - 2010-06-09 07:05 . 2010-06-09 07:05 258048 c:\windows\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790\System.EnterpriseServices.dll + 2011-04-19 02:51 . 2011-04-19 02:51 653136 c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\msvcr90.dll + 2011-04-19 02:51 . 2011-04-19 02:51 569680 c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\msvcp90.dll + 2011-04-19 02:51 . 2011-04-19 02:51 225280 c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_31a54e43\msvcm90.dll + 2011-01-11 14:59 . 2011-01-11 14:59 653136 c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_0517bbc6\msvcr90.dll + 2011-01-11 14:59 . 2011-01-11 14:59 569680 c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_0517bbc6\msvcp90.dll + 2011-01-11 14:59 . 2011-01-11 14:59 225280 c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_0517bbc6\msvcm90.dll + 2009-07-12 04:02 . 2009-07-12 04:02 653120 c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\msvcr90.dll + 2009-07-12 04:02 . 2009-07-12 04:02 569664 c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\msvcp90.dll + 2009-07-12 04:05 . 2009-07-12 04:05 225280 c:\windows\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e\msvcm90.dll + 2011-04-19 02:51 . 2011-04-19 02:51 159048 c:\windows\WinSxS\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_92453bb7\atl90.dll + 2011-01-11 14:59 . 2011-01-11 14:59 159048 c:\windows\WinSxS\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_65b7a93a\atl90.dll + 2007-11-07 05:19 . 2007-11-07 05:19 161784 c:\windows\WinSxS\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_312cf0e9\atl90.dll + 2008-10-25 01:15 . 2008-10-25 01:15 626688 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\msvcr80.dll - 2006-12-02 02:54 . 2006-12-02 02:54 626688 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\msvcr80.dll - 2006-12-02 02:54 . 2006-12-02 02:54 548864 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\msvcp80.dll + 2008-10-25 01:15 . 2008-10-25 01:15 548864 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\msvcp80.dll - 2006-12-02 02:54 . 2006-12-02 02:54 479232 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\msvcm80.dll + 2008-10-25 01:15 . 2008-10-25 01:15 479232 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700\msvcm80.dll + 2011-05-14 05:17 . 2011-05-14 05:17 632656 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\msvcr80.dll + 2011-05-14 05:12 . 2011-05-14 05:12 554832 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\msvcp80.dll + 2011-05-14 05:11 . 2011-05-14 05:11 479232 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\msvcm80.dll + 2006-06-05 19:14 . 2006-06-05 19:14 626688 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_681e29fb\msvcr80.dll + 2006-06-05 19:14 . 2006-06-05 19:14 548864 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_681e29fb\msvcp80.dll + 2006-06-05 19:14 . 2006-06-05 19:14 479232 c:\windows\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_681e29fb\msvcm80.dll + 2010-12-20 07:02 . 2010-12-07 18:40 183808 c:\windows\system32\xvidvfw.dll + 2010-12-20 07:02 . 2010-12-07 18:22 810496 c:\windows\system32\xvidcore.dll + 2012-04-06 03:13 . 2012-04-06 03:13 299080 c:\windows\system32\XPSViewer\XPSViewer.exe + 2011-10-25 00:21 . 2010-02-04 14:01 528216 c:\windows\system32\XAudio2_6.dll + 2011-10-25 00:21 . 2009-09-04 21:44 515416 c:\windows\system32\XAudio2_5.dll + 2011-10-25 00:21 . 2009-03-16 18:18 517448 c:\windows\system32\XAudio2_4.dll + 2011-10-25 00:21 . 2008-10-27 15:04 514384 c:\windows\system32\XAudio2_3.dll + 2011-10-25 00:21 . 2008-07-31 14:40 509448 c:\windows\system32\XAudio2_2.dll + 2011-10-25 00:21 . 2008-05-30 19:19 507400 c:\windows\system32\XAudio2_1.dll + 2011-10-25 00:21 . 2008-03-05 21:03 479752 c:\windows\system32\XAudio2_0.dll + 2011-10-25 00:21 . 2010-02-04 14:01 238936 c:\windows\system32\xactengine3_6.dll + 2011-10-25 00:21 . 2009-09-04 21:44 238936 c:\windows\system32\xactengine3_5.dll + 2011-10-25 00:21 . 2009-03-16 18:18 235352 c:\windows\system32\xactengine3_4.dll + 2011-10-25 00:21 . 2008-10-27 15:04 235856 c:\windows\system32\xactengine3_3.dll + 2011-10-25 00:21 . 2008-07-31 14:41 238088 c:\windows\system32\xactengine3_2.dll + 2011-10-25 00:21 . 2008-05-30 19:18 238088 c:\windows\system32\xactengine3_1.dll + 2011-10-25 00:21 . 2008-03-05 21:03 238088 c:\windows\system32\xactengine3_0.dll + 2011-10-25 00:21 . 2007-07-20 05:57 267112 c:\windows\system32\xactengine2_9.dll - 2009-09-21 01:59 . 2007-05-31 23:30 266088 c:\windows\system32\xactengine2_8.dll + 2009-09-21 01:59 . 2007-06-21 01:46 266088 c:\windows\system32\xactengine2_8.dll + 2009-09-21 01:59 . 2007-04-04 23:55 261480 c:\windows\system32\xactengine2_7.dll - 2009-09-21 01:59 . 2007-04-04 22:55 261480 c:\windows\system32\xactengine2_7.dll - 2009-09-21 01:59 . 2007-01-24 19:27 255848 c:\windows\system32\xactengine2_6.dll + 2009-09-21 01:59 . 2007-01-24 20:27 255848 c:\windows\system32\xactengine2_6.dll + 2009-09-21 01:59 . 2006-12-08 17:02 251672 c:\windows\system32\xactengine2_5.dll - 2009-09-21 01:59 . 2006-12-08 16:02 251672 c:\windows\system32\xactengine2_5.dll - 2009-09-21 01:59 . 2006-09-28 20:05 237848 c:\windows\system32\xactengine2_4.dll + 2009-09-21 01:59 . 2006-09-28 21:05 237848 c:\windows\system32\xactengine2_4.dll + 2009-09-21 01:59 . 2006-07-28 14:30 236824 c:\windows\system32\xactengine2_3.dll - 2009-09-21 01:59 . 2006-07-28 13:30 236824 c:\windows\system32\xactengine2_3.dll - 2009-09-21 01:59 . 2006-05-31 11:24 230168 c:\windows\system32\xactengine2_2.dll + 2009-09-21 01:59 . 2006-05-31 12:24 230168 c:\windows\system32\xactengine2_2.dll + 2011-10-25 00:21 . 2007-10-22 08:39 267272 c:\windows\system32\xactengine2_10.dll - 2009-09-21 01:59 . 2006-03-31 16:39 229584 c:\windows\system32\xactengine2_1.dll + 2009-09-21 01:59 . 2006-03-31 17:39 229584 c:\windows\system32\xactengine2_1.dll + 2009-09-21 01:59 . 2006-02-03 13:42 230096 c:\windows\system32\xactengine2_0.dll - 2009-09-21 01:59 . 2006-02-03 12:42 230096 c:\windows\system32\xactengine2_0.dll + 2008-10-16 18:12 . 2012-06-02 19:19 210968 c:\windows\system32\wuweb.dll + 2009-04-19 18:29 . 2012-06-02 19:19 329240 c:\windows\system32\wucltui.dll + 2009-04-19 18:29 . 2012-06-02 19:19 577048 c:\windows\system32\wuapi.dll + 2001-08-23 12:00 . 2012-02-29 14:10 177664 c:\windows\system32\wintrust.dll - 2001-08-23 12:00 . 2009-12-24 06:59 177664 c:\windows\system32\wintrust.dll - 2001-08-23 12:00 . 2008-04-14 00:12 293376 c:\windows\system32\winsrv.dll + 2001-08-23 12:00 . 2011-11-25 21:57 293376 c:\windows\system32\winsrv.dll + 2001-08-23 12:00 . 2011-10-14 14:47 176128 c:\windows\system32\winmm.dll - 2001-08-23 12:00 . 2008-04-14 00:12 176128 c:\windows\system32\winmm.dll + 2009-04-19 18:31 . 2011-11-16 14:21 354816 c:\windows\system32\winhttp.dll - 2009-04-19 18:31 . 2009-08-25 09:17 354816 c:\windows\system32\winhttp.dll + 2012-03-07 05:25 . 2007-10-30 09:15 330240 c:\windows\system32\windowspowershell\v1.0\powershell.exe + 2007-03-26 05:00 . 2010-07-12 18:36 100848 c:\windows\system32\vxblock.dll + 2010-11-12 02:22 . 2004-06-26 22:39 438272 c:\windows\system32\vp6vfw.dll + 2001-08-23 12:00 . 2011-03-04 06:37 420864 c:\windows\system32\vbscript.dll - 2001-08-23 12:00 . 2008-04-14 00:12 406016 c:\windows\system32\usp10.dll + 2001-08-23 12:00 . 2010-04-16 15:36 406016 c:\windows\system32\usp10.dll - 2001-08-23 12:00 . 2009-03-08 09:34 105984 c:\windows\system32\url.dll + 2001-08-23 12:00 . 2012-07-02 17:49 105984 c:\windows\system32\url.dll + 2010-12-20 07:02 . 2010-03-15 10:31 165376 c:\windows\system32\unrar.dll + 2008-07-29 23:59 . 2011-09-26 15:41 611328 c:\windows\system32\uiautomationcore.dll + 2001-08-23 12:00 . 2010-08-27 08:02 119808 c:\windows\system32\t2embed.dll - 2001-08-23 12:00 . 2009-10-15 16:28 119808 c:\windows\system32\t2embed.dll + 2002-10-06 22:11 . 2002-10-06 22:11 455168 c:\windows\system32\spool\drivers\w32x86\PSCRIPT5.DLL - 2002-10-06 21:11 . 2002-10-06 21:11 455168 c:\windows\system32\spool\drivers\w32x86\PSCRIPT5.DLL - 2002-10-06 21:11 . 2002-10-06 21:11 129024 c:\windows\system32\spool\drivers\w32x86\PS5UI.DLL + 2002-10-06 22:11 . 2002-10-06 22:11 129024 c:\windows\system32\spool\drivers\w32x86\PS5UI.DLL - 2004-12-14 06:07 . 2004-12-14 06:07 143360 c:\windows\system32\spool\drivers\w32x86\ad2kuigp.dll + 2011-03-11 04:38 . 2005-09-24 05:27 143360 c:\windows\system32\spool\drivers\w32x86\ad2kuigp.dll + 2002-10-06 22:11 . 2002-10-06 22:11 455168 c:\windows\system32\spool\drivers\w32x86\3\PSCRIPT5.DLL - 2002-10-06 21:11 . 2002-10-06 21:11 455168 c:\windows\system32\spool\drivers\w32x86\3\PSCRIPT5.DLL - 2002-10-06 21:11 . 2002-10-06 21:11 129024 c:\windows\system32\spool\drivers\w32x86\3\Ps5ui.dll + 2002-10-06 22:11 . 2002-10-06 22:11 129024 c:\windows\system32\spool\drivers\w32x86\3\Ps5ui.dll + 2004-12-14 07:07 . 2005-09-24 05:27 143360 c:\windows\system32\spool\drivers\w32x86\3\AD2KUIGP.DLL - 2004-12-14 06:07 . 2004-12-14 06:07 143360 c:\windows\system32\spool\drivers\w32x86\3\AD2KUIGP.DLL - 2001-08-23 12:00 . 2008-04-14 00:12 135168 c:\windows\system32\shsvcs.dll + 2001-08-23 12:00 . 2009-07-27 23:17 135168 c:\windows\system32\shsvcs.dll + 2001-08-23 12:00 . 2011-01-21 14:44 439296 c:\windows\system32\shimgvw.dll + 2010-04-18 06:10 . 2012-06-04 04:32 152576 c:\windows\system32\schannel.dll - 2004-08-04 07:56 . 2008-04-14 00:12 270848 c:\windows\system32\sbe.dll + 2004-08-04 07:56 . 2011-02-09 13:53 270848 c:\windows\system32\sbe.dll + 2009-04-19 17:48 . 2006-10-18 07:53 147456 c:\windows\system32\RtlCPAPI.dll - 2009-04-19 17:48 . 2006-10-18 06:53 147456 c:\windows\system32\RtlCPAPI.dll + 2001-08-23 12:00 . 2010-08-16 08:45 590848 c:\windows\system32\rpcrt4.dll + 2011-11-26 17:44 . 2007-04-16 19:28 577536 c:\windows\system32\ReinstallBackups\0007\DriverFiles\SOUNDMAN.EXE + 2011-11-26 17:44 . 2006-10-18 06:53 147456 c:\windows\system32\ReinstallBackups\0007\DriverFiles\RTLCPAPI.dll + 2011-11-26 17:44 . 2008-04-13 19:19 146048 c:\windows\system32\ReinstallBackups\0007\DriverFiles\i386\portcls.sys + 2011-11-26 17:44 . 2008-04-13 19:16 141056 c:\windows\system32\ReinstallBackups\0007\DriverFiles\i386\ks.sys + 2011-11-26 17:44 . 2006-07-31 16:27 217088 c:\windows\system32\ReinstallBackups\0007\DriverFiles\Alcrmv.exe - 2001-08-23 12:00 . 2008-04-14 00:12 386048 c:\windows\system32\qdvd.dll + 2001-08-23 12:00 . 2011-11-03 15:28 386048 c:\windows\system32\qdvd.dll + 2007-07-05 21:55 . 2010-07-12 18:36 440816 c:\windows\system32\PxWave.dll + 2007-07-05 21:55 . 2010-07-12 18:36 219632 c:\windows\system32\PxMas.dll + 2008-02-13 21:16 . 2010-07-12 18:36 126448 c:\windows\system32\pxinsi64.exe + 2007-06-07 05:02 . 2010-07-12 18:36 567792 c:\windows\system32\pxdrv.dll + 2007-04-04 21:08 . 2010-07-12 18:36 133616 c:\windows\system32\PxAFS.DLL + 2007-07-05 21:55 . 2010-07-12 18:36 698864 c:\windows\system32\Px.dll + 2010-03-31 04:10 . 2010-03-31 04:10 295264 c:\windows\system32\PresentationHost.exe + 2009-09-21 01:55 . 2011-12-31 20:24 271200 c:\windows\system32\PnkBstrB.exe - 2009-04-26 19:04 . 2001-06-22 23:31 278528 c:\windows\system32\pncrt.dll + 2010-12-23 05:10 . 2004-10-09 22:00 278528 c:\windows\system32\pncrt.dll + 2001-08-23 12:00 . 2012-06-14 06:19 505278 c:\windows\system32\perfh009.dat + 2003-05-02 00:06 . 2003-05-02 00:06 212480 c:\windows\system32\PCDLIB32.DLL - 2001-08-23 12:00 . 2008-04-14 00:12 551936 c:\windows\system32\oleaut32.dll + 2001-08-23 12:00 . 2010-12-20 17:32 551936 c:\windows\system32\oleaut32.dll + 2001-08-23 12:00 . 2011-09-26 15:41 220160 c:\windows\system32\oleacc.dll - 2001-08-23 12:00 . 2008-04-14 00:12 249856 c:\windows\system32\odbc32.dll + 2001-08-23 12:00 . 2010-11-09 14:52 249856 c:\windows\system32\odbc32.dll + 2001-08-23 12:00 . 2012-07-02 17:49 206848 c:\windows\system32\occache.dll - 2001-08-23 12:00 . 2010-05-06 10:41 206848 c:\windows\system32\occache.dll + 2006-08-12 04:42 . 2011-10-08 04:50 298304 c:\windows\system32\nvsvc32.exe + 2006-08-12 04:43 . 2011-10-08 04:50 203072 c:\windows\system32\nvmctray.dll + 2011-11-05 18:50 . 2011-10-08 04:50 877376 c:\windows\system32\nvgenco32.dll + 2011-11-05 18:51 . 2011-11-05 18:51 285176 c:\windows\system32\nvdrsdb1.bin + 2011-11-05 18:51 . 2011-11-05 18:51 285176 c:\windows\system32\nvdrsdb0.bin + 2011-11-05 18:50 . 2011-10-08 04:50 919872 c:\windows\system32\nvdispco32.dll + 2006-08-12 04:44 . 2011-10-08 04:50 220992 c:\windows\system32\nvcolor.exe + 2001-08-23 12:00 . 2010-12-09 15:15 718336 c:\windows\system32\ntdll.dll + 2008-05-02 14:58 . 2008-05-02 14:58 148992 c:\windows\system32\nsesetup.dll + 2012-06-29 05:06 . 2012-01-09 21:28 605696 c:\windows\system32\nmwcdcocls.dll + 2001-08-23 12:00 . 2012-07-06 13:58 337920 c:\windows\system32\netapi32.dll + 2009-04-22 05:44 . 2012-06-02 19:18 214256 c:\windows\system32\muweb.dll + 2009-04-22 05:44 . 2012-06-02 19:18 275696 c:\windows\system32\mucltui.dll + 2001-08-23 12:00 . 2008-06-20 16:02 245248 c:\windows\system32\mswsock.dll - 2001-08-23 12:00 . 2008-06-20 17:46 245248 c:\windows\system32\mswsock.dll + 2003-02-21 08:42 . 2007-03-22 00:33 348160 c:\windows\system32\MSVCR71.DLL - 2003-02-21 08:42 . 2003-02-21 08:42 348160 c:\windows\system32\msvcr71.dll + 2010-03-18 17:16 . 2010-03-18 17:16 771424 c:\windows\system32\msvcr100_clr0400.dll + 2011-02-19 04:40 . 2011-02-19 04:40 773968 c:\windows\system32\msvcr100.dll + 2003-03-19 02:14 . 2007-03-22 00:33 503808 c:\windows\system32\MSVCP71.DLL + 2011-02-20 03:03 . 2011-02-20 03:03 421200 c:\windows\system32\msvcp100.dll + 2009-04-18 21:30 . 2011-01-27 11:57 677888 c:\windows\system32\mstsc.exe - 2009-04-18 21:30 . 2008-04-14 00:12 677888 c:\windows\system32\mstsc.exe + 2001-08-23 12:00 . 2012-07-02 17:49 611840 c:\windows\system32\mstime.dll - 2001-08-23 12:00 . 2010-05-06 10:41 611840 c:\windows\system32\mstime.dll + 2007-11-08 07:19 . 2007-11-08 07:19 129024 c:\windows\system32\MSSTDFMT.DLL + 2007-08-13 22:54 . 2012-07-02 17:49 629760 c:\windows\system32\msfeeds.dll + 2009-09-24 04:30 . 2009-09-24 04:30 156488 c:\windows\system32\mscorier.dll + 2009-11-07 05:07 . 2009-11-07 05:07 297808 c:\windows\system32\mscoree.dll + 2006-10-19 01:47 . 2010-03-30 16:24 317440 c:\windows\system32\mp4sdecd.dll - 2006-10-19 01:47 . 2006-10-19 01:47 317440 c:\windows\system32\MP4SDECD.dll + 2001-08-23 12:00 . 2011-02-08 13:33 974848 c:\windows\system32\mfc42u.dll + 2001-08-23 12:00 . 2011-02-08 13:33 978944 c:\windows\system32\mfc42.dll + 2001-08-23 12:00 . 2010-09-18 06:53 953856 c:\windows\system32\mfc40u.dll + 2001-08-23 12:00 . 2010-09-18 06:53 954368 c:\windows\system32\mfc40.dll + 2012-08-31 06:18 . 2012-08-31 06:18 690888 c:\windows\system32\Macromed\Flash\FlashUtil32_11_4_402_265_Plugin.exe + 2012-08-15 04:48 . 2012-08-15 04:48 686792 c:\windows\system32\Macromed\Flash\FlashUtil32_11_3_300_271_ActiveX.exe + 2012-08-15 04:48 . 2012-08-15 04:48 466632 c:\windows\system32\Macromed\Flash\FlashUtil32_11_3_300_271_ActiveX.dll + 2012-04-13 18:57 . 2012-08-31 06:18 250568 c:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe + 2003-05-02 00:06 . 2003-05-02 00:06 716288 c:\windows\system32\Ltwvc11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 392192 c:\windows\system32\ltkrn11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 127488 c:\windows\system32\ltimg11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 118784 c:\windows\system32\ltfil11n.DLL + 2003-05-02 00:06 . 2003-05-02 00:06 262656 c:\windows\system32\LTDIS11n.dll + 2001-08-23 12:00 . 2010-12-20 17:26 730112 c:\windows\system32\lsasrv.dll - 2001-08-23 12:00 . 2009-06-25 08:25 730112 c:\windows\system32\lsasrv.dll + 2001-08-23 12:00 . 2012-05-14 09:22 345600 c:\windows\system32\localspl.dll - 2001-08-23 12:00 . 2009-05-07 15:32 345600 c:\windows\system32\localspl.dll + 2003-05-02 00:06 . 2003-05-02 00:06 152064 c:\windows\system32\lftif11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 172032 c:\windows\system32\Lfpng11n.dll + 2003-05-02 00:06 . 2003-05-02 00:06 285184 c:\windows\system32\LFCMP11n.DLL - 2001-08-23 12:00 . 2009-06-25 08:25 301568 c:\windows\system32\kerberos.dll + 2001-08-23 12:00 . 2010-12-22 12:34 301568 c:\windows\system32\kerberos.dll + 2001-08-23 12:00 . 2011-03-04 06:37 726528 c:\windows\system32\jscript.dll - 2001-08-23 12:00 . 2009-12-09 05:53 726528 c:\windows\system32\jscript.dll + 2012-02-21 01:50 . 2012-02-21 01:50 157472 c:\windows\system32\javaws.exe + 2012-02-21 01:50 . 2012-02-21 01:50 149280 c:\windows\system32\javaw.exe + 2012-02-21 01:50 . 2012-02-21 01:50 149280 c:\windows\system32\java.exe + 2009-04-18 21:31 . 2011-10-10 14:22 692736 c:\windows\system32\inetcomm.dll + 2011-05-09 22:48 . 2011-05-09 22:48 922112 c:\windows\system32\imapi2fs.dll + 2011-05-09 22:48 . 2011-05-09 22:48 426496 c:\windows\system32\imapi2.dll + 2001-08-23 12:00 . 2012-02-29 14:10 148480 c:\windows\system32\imagehlp.dll + 2001-08-23 12:00 . 2012-07-02 17:49 184320 c:\windows\system32\iepeers.dll - 2001-08-23 12:00 . 2010-05-06 10:41 184320 c:\windows\system32\iepeers.dll + 2001-08-23 12:00 . 2012-07-02 17:49 387584 c:\windows\system32\iedkcs32.dll - 2001-08-23 12:00 . 2010-05-06 10:41 387584 c:\windows\system32\iedkcs32.dll + 2001-08-23 12:00 . 2012-07-02 12:05 174080 c:\windows\system32\ie4uinit.exe + 2012-09-12 02:21 . 2012-09-12 02:21 198552 c:\windows\system32\FNTCACHE.DAT + 2010-12-20 07:02 . 2010-09-08 14:09 108032 c:\windows\system32\ff_vfw.dll + 2010-03-18 17:16 . 2010-03-18 17:16 486216 c:\windows\system32\evr.dll - 2004-08-04 07:56 . 2008-04-14 00:11 186880 c:\windows\system32\encdec.dll + 2004-08-04 07:56 . 2011-10-18 11:13 186880 c:\windows\system32\encdec.dll + 2011-11-05 18:51 . 2011-10-08 04:50 602432 c:\windows\system32\easyupdatusapiu.dll + 2012-08-19 07:23 . 2012-06-27 19:18 592896 c:\windows\system32\DRVSTORE\pccswpddri_58E92219CA3FF6890A1AA097BB664B7DC817D147\PCCSWpdDriver.dll + 2012-06-29 05:06 . 2012-01-09 21:28 137600 c:\windows\system32\DRVSTORE\nmwcdnsu_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\nmwcdnsu.sys + 2012-06-29 05:06 . 2012-01-09 21:28 605696 c:\windows\system32\DRVSTORE\ccdcmb_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\nmwcdcocls.dll + 2012-06-29 05:06 . 2012-01-09 21:28 123904 c:\windows\system32\DRVSTORE\ccdcmb_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\ccdcmbwu.dll + 2006-11-02 11:22 . 2009-07-14 14:35 444136 c:\windows\system32\drivers\wdf01000.sys + 2009-07-08 04:32 . 2009-05-07 07:04 157712 c:\windows\system32\drivers\tmcomm.sys + 2001-08-23 12:00 . 2011-02-17 13:18 357888 c:\windows\system32\drivers\srv.sys + 2011-10-30 23:23 . 2011-10-30 23:23 370552 c:\windows\system32\drivers\SEP\0C0103E8\009D.105\x86\symtdi.sys + 2011-10-30 23:23 . 2011-10-30 23:23 758904 c:\windows\system32\drivers\SEP\0C0103E8\009D.105\x86\SymEFA.sys + 2011-10-30 23:23 . 2011-10-30 23:23 340088 c:\windows\system32\drivers\SEP\0C0103E8\009D.105\x86\SymDS.sys + 2011-10-30 23:23 . 2011-10-30 23:23 522872 c:\windows\system32\drivers\SEP\0C0103E8\009D.105\x86\srtsp.sys + 2011-10-30 23:23 . 2011-10-30 23:23 137336 c:\windows\system32\drivers\SEP\0C0103E8\009D.105\x86\Ironx86.sys - 2009-04-19 17:48 . 2008-04-13 19:19 146048 c:\windows\system32\drivers\portcls.sys + 2009-04-19 17:48 . 2008-04-13 20:19 146048 c:\windows\system32\drivers\portcls.sys + 2009-09-21 01:56 . 2011-12-31 20:24 138160 c:\windows\system32\drivers\PnkBstrK.sys + 2001-08-23 12:00 . 2011-04-21 13:37 105472 c:\windows\system32\drivers\mup.sys + 2001-08-23 12:00 . 2011-07-15 13:29 456320 c:\windows\system32\drivers\mrxsmb.sys - 2010-04-18 05:29 . 2008-04-13 19:16 141056 c:\windows\system32\drivers\ks.sys + 2010-04-18 05:29 . 2008-04-13 20:16 141056 c:\windows\system32\drivers\ks.sys + 2011-03-24 00:07 . 2007-01-31 17:45 127376 c:\windows\system32\drivers\dne2000.sys - 2001-08-23 12:00 . 2008-08-14 10:04 138496 c:\windows\system32\drivers\afd.sys + 2001-08-23 12:00 . 2011-08-17 13:49 138496 c:\windows\system32\drivers\afd.sys + 2001-08-23 12:00 . 2011-03-03 06:55 149504 c:\windows\system32\dnsapi.dll + 2011-03-24 00:07 . 2007-01-31 17:45 101904 c:\windows\system32\dneinobj.dll + 2008-10-16 18:12 . 2012-06-02 19:19 210968 c:\windows\system32\dllcache\wuweb.dll + 2009-04-19 18:29 . 2012-06-02 19:19 329240 c:\windows\system32\dllcache\wucltui.dll + 2009-04-19 18:29 . 2012-06-02 19:19 577048 c:\windows\system32\dllcache\wuapi.dll + 2009-04-19 19:26 . 2010-07-12 12:55 218112 c:\windows\system32\dllcache\wordpad.exe - 2009-12-24 06:59 . 2009-12-24 06:59 177664 c:\windows\system32\dllcache\wintrust.dll + 2009-12-24 06:59 . 2012-02-29 14:10 177664 c:\windows\system32\dllcache\wintrust.dll + 2010-06-18 17:45 . 2011-11-25 21:57 293376 c:\windows\system32\dllcache\winsrv.dll + 2011-10-14 14:47 . 2011-10-14 14:47 176128 c:\windows\system32\dllcache\winmm.dll + 2007-08-13 22:54 . 2012-07-02 17:49 916992 c:\windows\system32\dllcache\wininet.dll + 2008-12-16 12:30 . 2011-11-16 14:21 354816 c:\windows\system32\dllcache\winhttp.dll - 2008-12-16 12:30 . 2009-08-25 09:17 354816 c:\windows\system32\dllcache\winhttp.dll + 2007-08-13 22:54 . 2011-04-30 03:01 758784 c:\windows\system32\dllcache\vgx.dll + 2007-08-13 22:54 . 2011-03-04 06:37 420864 c:\windows\system32\dllcache\vbscript.dll + 2010-04-16 15:36 . 2010-04-16 15:36 406016 c:\windows\system32\dllcache\usp10.dll - 2007-08-13 22:44 . 2009-03-08 09:34 105984 c:\windows\system32\dllcache\url.dll + 2007-08-13 22:44 . 2012-07-02 17:49 105984 c:\windows\system32\dllcache\url.dll + 2009-06-16 14:36 . 2010-08-27 08:02 119808 c:\windows\system32\dllcache\t2embed.dll - 2009-06-16 14:36 . 2009-10-15 16:28 119808 c:\windows\system32\dllcache\t2embed.dll + 2009-04-19 19:27 . 2011-02-17 13:18 357888 c:\windows\system32\dllcache\srv.sys + 2009-07-27 23:17 . 2009-07-27 23:17 135168 c:\windows\system32\dllcache\shsvcs.dll + 2011-01-21 14:44 . 2011-01-21 14:44 439296 c:\windows\system32\dllcache\shimgvw.dll + 2008-12-05 06:54 . 2012-06-04 04:32 152576 c:\windows\system32\dllcache\schannel.dll + 2011-02-09 13:53 . 2011-02-09 13:53 270848 c:\windows\system32\dllcache\sbe.dll + 2009-04-15 14:51 . 2010-08-16 08:45 590848 c:\windows\system32\dllcache\rpcrt4.dll + 2011-08-10 13:56 . 2012-07-04 14:05 139784 c:\windows\system32\dllcache\rdpwd.sys + 2011-11-03 15:28 . 2011-11-03 15:28 386048 c:\windows\system32\dllcache\qdvd.dll - 2009-04-19 17:48 . 2008-04-13 19:19 146048 c:\windows\system32\dllcache\portcls.sys + 2009-04-19 17:48 . 2008-04-13 20:19 146048 c:\windows\system32\dllcache\portcls.sys + 2010-12-20 17:32 . 2010-12-20 17:32 551936 c:\windows\system32\dllcache\oleaut32.dll + 2001-08-23 12:00 . 2011-09-26 15:41 220160 c:\windows\system32\dllcache\oleacc.dll + 2010-11-09 14:52 . 2010-11-09 14:52 249856 c:\windows\system32\dllcache\odbc32.dll + 2007-08-13 22:44 . 2012-07-02 17:49 206848 c:\windows\system32\dllcache\occache.dll - 2007-08-13 22:44 . 2010-05-06 10:41 206848 c:\windows\system32\dllcache\occache.dll + 2009-04-19 19:27 . 2010-12-09 15:15 718336 c:\windows\system32\dllcache\ntdll.dll + 2009-04-19 19:26 . 2012-07-06 13:58 337920 c:\windows\system32\dllcache\netapi32.dll + 2011-06-16 22:26 . 2011-04-21 13:37 105472 c:\windows\system32\dllcache\mup.sys - 2008-06-20 17:46 . 2008-06-20 17:46 245248 c:\windows\system32\dllcache\mswsock.dll + 2008-06-20 17:46 . 2008-06-20 16:02 245248 c:\windows\system32\dllcache\mswsock.dll + 2007-08-13 22:54 . 2012-07-02 17:49 611840 c:\windows\system32\dllcache\mstime.dll - 2007-08-13 22:54 . 2010-05-06 10:41 611840 c:\windows\system32\dllcache\mstime.dll + 2010-11-09 14:52 . 2010-11-09 14:52 102400 c:\windows\system32\dllcache\msjro.dll + 2009-04-19 19:31 . 2012-07-02 17:49 629760 c:\windows\system32\dllcache\msfeeds.dll + 2010-11-09 14:52 . 2010-11-09 14:52 200704 c:\windows\system32\dllcache\msadox.dll + 2010-11-09 14:52 . 2010-11-09 14:52 180224 c:\windows\system32\dllcache\msadomd.dll + 2010-11-09 14:52 . 2012-05-28 18:16 536576 c:\windows\system32\dllcache\msado15.dll + 2010-11-09 14:52 . 2010-11-09 14:52 143360 c:\windows\system32\dllcache\msadco.dll + 2009-04-19 19:27 . 2011-07-15 13:29 456320 c:\windows\system32\dllcache\mrxsmb.sys + 2010-03-30 16:24 . 2010-03-30 16:24 317440 c:\windows\system32\dllcache\mp4sdecd.dll + 2010-09-18 16:23 . 2011-02-08 13:33 974848 c:\windows\system32\dllcache\mfc42u.dll + 2010-10-13 22:34 . 2011-02-08 13:33 978944 c:\windows\system32\dllcache\mfc42.dll + 2010-10-13 22:34 . 2010-09-18 06:53 953856 c:\windows\system32\dllcache\mfc40u.dll + 2001-08-23 12:00 . 2010-09-18 06:53 954368 c:\windows\system32\dllcache\mfc40.dll + 2009-04-19 19:27 . 2010-12-20 17:26 730112 c:\windows\system32\dllcache\lsasrv.dll - 2009-04-19 19:27 . 2009-06-25 08:25 730112 c:\windows\system32\dllcache\lsasrv.dll + 2009-05-07 15:32 . 2012-05-14 09:22 345600 c:\windows\system32\dllcache\localspl.dll - 2009-05-07 15:32 . 2009-05-07 15:32 345600 c:\windows\system32\dllcache\localspl.dll + 2011-01-27 11:57 . 2011-01-27 11:57 677888 c:\windows\system32\dllcache\lhmstsc.exe - 2009-04-19 17:48 . 2008-04-13 19:16 141056 c:\windows\system32\dllcache\ks.sys + 2010-04-18 05:29 . 2008-04-13 20:16 141056 c:\windows\system32\dllcache\ks.sys + 2009-06-25 08:25 . 2010-12-22 12:34 301568 c:\windows\system32\dllcache\kerberos.dll - 2009-06-25 08:25 . 2009-06-25 08:25 301568 c:\windows\system32\dllcache\kerberos.dll + 2012-06-13 22:26 . 2012-07-02 17:49 521728 c:\windows\system32\dllcache\jsdbgui.dll + 2007-08-13 22:38 . 2011-03-04 06:37 726528 c:\windows\system32\dllcache\jscript.dll - 2007-08-13 22:38 . 2009-12-09 05:53 726528 c:\windows\system32\dllcache\jscript.dll + 2009-04-19 19:26 . 2011-10-10 14:22 692736 c:\windows\system32\dllcache\inetcomm.dll + 2011-05-09 22:48 . 2011-05-09 22:48 922112 c:\windows\system32\dllcache\imapi2fs.dll + 2011-05-09 22:48 . 2011-05-09 22:48 426496 c:\windows\system32\dllcache\imapi2.dll + 2012-02-29 14:10 . 2012-02-29 14:10 148480 c:\windows\system32\dllcache\imagehlp.dll + 2010-02-24 05:17 . 2012-07-02 17:49 247808 c:\windows\system32\dllcache\ieproxy.dll - 2010-02-24 05:17 . 2010-05-06 10:41 247808 c:\windows\system32\dllcache\ieproxy.dll - 2007-08-13 22:54 . 2010-05-06 10:41 184320 c:\windows\system32\dllcache\iepeers.dll + 2007-08-13 22:54 . 2012-07-02 17:49 184320 c:\windows\system32\dllcache\iepeers.dll - 2010-06-09 00:32 . 2010-05-06 10:41 743424 c:\windows\system32\dllcache\iedvtool.dll + 2010-06-09 00:32 . 2012-07-02 17:49 743424 c:\windows\system32\dllcache\iedvtool.dll + 2007-08-13 22:39 . 2012-07-02 17:49 387584 c:\windows\system32\dllcache\iedkcs32.dll - 2007-08-13 22:39 . 2010-05-06 10:41 387584 c:\windows\system32\dllcache\iedkcs32.dll + 2007-08-13 22:39 . 2012-07-02 12:05 174080 c:\windows\system32\dllcache\ie4uinit.exe + 2010-07-13 22:50 . 2010-06-14 14:31 744448 c:\windows\system32\dllcache\helpsvc.exe + 2011-02-09 13:53 . 2011-10-18 11:13 186880 c:\windows\system32\dllcache\encdec.dll + 2008-06-20 17:46 . 2011-03-03 06:55 149504 c:\windows\system32\dllcache\dnsapi.dll + 2011-09-03 10:17 . 2012-05-31 13:22 599040 c:\windows\system32\dllcache\crypt32.dll + 2010-10-13 22:34 . 2010-08-23 16:12 617472 c:\windows\system32\dllcache\comctl32.dll + 2010-04-20 05:30 . 2011-02-15 12:56 290432 c:\windows\system32\dllcache\atmfd.dll + 2008-06-20 11:40 . 2011-08-17 13:49 138496 c:\windows\system32\dllcache\afd.sys - 2008-06-20 11:40 . 2008-08-14 10:04 138496 c:\windows\system32\dllcache\afd.sys - 2009-09-25 16:41 . 2009-09-25 16:41 843776 c:\windows\system32\divx_xx16.dll + 2010-02-19 19:27 . 2010-02-19 19:27 843776 c:\windows\system32\divx_xx16.dll + 2010-02-19 19:27 . 2010-02-19 19:27 839680 c:\windows\system32\divx_xx11.dll - 2009-09-25 16:41 . 2009-09-25 16:41 839680 c:\windows\system32\divx_xx11.dll + 2010-02-19 19:27 . 2010-02-19 19:27 856064 c:\windows\system32\divx_xx0c.dll - 2009-09-25 16:41 . 2009-09-25 16:41 856064 c:\windows\system32\divx_xx0c.dll + 2010-02-19 19:27 . 2010-02-19 19:27 847872 c:\windows\system32\divx_xx0a.dll - 2009-09-25 16:41 . 2009-09-25 16:41 847872 c:\windows\system32\divx_xx0a.dll + 2010-02-19 19:27 . 2010-02-19 19:27 856064 c:\windows\system32\divx_xx07.dll - 2009-09-25 16:41 . 2009-09-25 16:41 856064 c:\windows\system32\divx_xx07.dll + 2010-02-19 19:27 . 2010-02-19 19:27 720384 c:\windows\system32\DivX.dll + 2010-10-25 22:44 . 2012-02-21 01:50 472808 c:\windows\system32\deployJava1.dll + 2011-10-25 00:21 . 2009-09-04 21:29 235344 c:\windows\system32\d3dx11_42.dll + 2011-10-25 00:21 . 2009-09-04 21:29 453456 c:\windows\system32\d3dx10_42.dll + 2011-10-25 00:21 . 2009-03-09 19:27 453456 c:\windows\system32\d3dx10_41.dll + 2011-10-25 00:21 . 2008-10-15 10:22 452440 c:\windows\system32\d3dx10_40.dll + 2011-10-25 00:21 . 2008-07-10 16:01 467984 c:\windows\system32\d3dx10_39.dll + 2011-10-25 00:21 . 2008-05-30 19:11 467984 c:\windows\system32\d3dx10_38.dll + 2011-10-25 00:21 . 2008-02-06 04:07 462864 c:\windows\system32\d3dx10_37.dll + 2011-10-25 00:21 . 2007-10-02 14:56 444776 c:\windows\system32\d3dx10_36.dll + 2011-10-25 00:21 . 2007-07-19 23:14 444776 c:\windows\system32\d3dx10_35.dll - 2009-09-21 01:59 . 2007-05-16 20:45 443752 c:\windows\system32\d3dx10_34.dll + 2009-09-21 01:59 . 2007-05-16 21:45 443752 c:\windows\system32\d3dx10_34.dll + 2009-09-21 01:59 . 2007-03-15 21:57 443752 c:\windows\system32\d3dx10_33.dll - 2009-09-21 01:59 . 2007-03-15 20:57 443752 c:\windows\system32\d3dx10_33.dll + 2001-08-23 12:00 . 2012-05-31 13:22 599040 c:\windows\system32\crypt32.dll - 2001-08-23 12:00 . 2008-04-14 00:11 599040 c:\windows\system32\crypt32.dll + 2010-06-22 23:40 . 2010-06-23 02:21 262144 c:\windows\system32\config\systemprofile\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat - 2001-08-23 12:00 . 2008-04-14 00:11 617472 c:\windows\system32\comctl32.dll + 2001-08-23 12:00 . 2010-08-23 16:12 617472 c:\windows\system32\comctl32.dll + 2012-06-29 05:06 . 2012-01-09 21:28 123904 c:\windows\system32\ccdcmbwu.dll + 2010-06-22 23:34 . 2009-07-13 16:06 511328 c:\windows\system32\capicom.dll + 2001-08-23 12:00 . 2011-02-15 12:56 290432 c:\windows\system32\atmfd.dll + 2011-02-20 03:03 . 2011-02-20 03:03 138056 c:\windows\system32\atl100.dll + 2009-04-19 17:48 . 2007-04-16 20:28 577536 c:\windows\soundman.exe - 2009-04-19 17:48 . 2007-04-16 19:28 577536 c:\windows\soundman.exe - 2009-04-18 21:31 . 2008-04-14 00:12 744448 c:\windows\PCHEALTH\HELPCTR\Binaries\helpsvc.exe + 2009-04-18 21:31 . 2010-06-14 14:31 744448 c:\windows\PCHEALTH\HELPCTR\Binaries\helpsvc.exe + 2010-03-18 17:16 . 2010-03-18 17:16 114520 c:\windows\Microsoft.NET\NETFXRepair.exe + 2012-01-19 17:08 . 2012-01-19 17:08 917272 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\wpftxt_v0400.dll + 2010-03-18 17:16 . 2010-03-18 17:16 753504 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe + 2010-03-18 17:16 . 2010-03-18 17:16 350592 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\UIAutomationClientsideProviders.dll + 2010-03-18 17:16 . 2010-03-18 17:16 163168 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\UIAutomationClient.dll + 2010-03-18 17:16 . 2010-03-18 17:16 675672 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\System.Speech.dll + 2010-03-18 17:16 . 2010-03-18 17:16 334688 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\System.Printing.dll + 2010-03-18 17:16 . 2010-03-18 17:16 581464 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\ReachFramework.dll + 2010-03-18 17:16 . 2010-03-18 17:16 832856 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationUI.dll + 2010-03-18 17:16 . 2010-03-18 17:16 801136 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationNative_v0400.dll + 2011-12-15 17:08 . 2011-12-15 17:08 182056 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationHost_v0400.dll + 2010-03-18 17:16 . 2010-03-18 17:16 194424 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationFramework.Royale.dll + 2010-03-18 17:16 . 2010-03-18 17:16 478576 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationFramework.Luna.dll + 2010-03-18 17:16 . 2010-03-18 17:16 167288 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationFramework.Classic.dll + 2010-03-18 17:16 . 2010-03-18 17:16 232304 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationFramework.Aero.dll + 2010-03-18 17:16 . 2010-03-18 17:16 807264 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\NaturalLanguage6.dll + 2010-03-18 17:16 . 2010-03-18 17:16 138592 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Xml.Linq.dll + 2010-03-18 17:16 . 2010-03-18 17:16 699224 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Xaml.dll + 2010-03-18 17:16 . 2010-03-18 17:16 857960 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Web.Services.dll + 2010-03-18 17:16 . 2010-03-18 17:16 269672 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Transactions.dll + 2010-03-18 17:16 . 2010-03-18 17:16 113512 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.ServiceProcess.dll + 2010-03-18 17:16 . 2010-03-18 17:16 129912 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.ServiceModel.Routing.dll + 2010-03-18 17:16 . 2010-03-18 17:16 390008 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.ServiceModel.Discovery.dll + 2010-03-18 17:16 . 2010-03-18 17:16 505208 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.ServiceModel.Activities.dll + 2010-03-18 17:16 . 2010-03-18 17:16 261472 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Security.dll + 2010-03-18 17:16 . 2010-03-18 17:16 122264 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Runtime.Serialization.Formatters.Soap.dll + 2010-03-18 17:16 . 2010-03-18 17:16 291184 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Runtime.Remoting.dll + 2010-03-18 17:16 . 2010-03-18 17:16 349568 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Runtime.DurableInstancing.dll + 2010-03-18 17:16 . 2010-03-18 17:16 231760 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Net.dll + 2010-03-18 17:16 . 2010-03-18 17:16 253280 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Messaging.dll + 2010-03-18 17:16 . 2010-03-18 17:16 134528 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Management.Instrumentation.dll + 2010-03-18 17:16 . 2010-03-18 17:16 378720 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Management.dll + 2010-03-18 17:16 . 2010-03-18 17:16 123736 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.IO.Log.dll + 2010-03-18 17:16 . 2010-03-18 17:16 125816 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.IdentityModel.Selectors.dll + 2010-03-18 17:16 . 2010-03-18 17:16 392552 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.IdentityModel.dll + 2010-03-18 04:51 . 2010-03-18 04:51 109568 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.EnterpriseServices.Wrapper.dll + 2010-03-18 17:16 . 2010-03-18 17:16 246128 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.EnterpriseServices.dll + 2010-03-18 17:16 . 2010-03-18 17:16 120152 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Dynamic.dll + 2012-04-21 15:03 . 2012-04-21 15:03 616024 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Drawing.dll + 2010-03-18 17:16 . 2010-03-18 17:16 182144 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.DirectoryServices.Protocols.dll + 2010-03-18 17:16 . 2010-03-18 17:16 395120 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.DirectoryServices.dll + 2010-03-18 17:16 . 2010-03-18 17:16 285072 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.DirectoryServices.AccountManagement.dll + 2010-03-18 17:16 . 2010-03-18 17:16 829280 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Deployment.dll + 2010-03-18 17:16 . 2010-03-18 17:16 747360 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Data.SqlXml.dll + 2010-03-18 17:16 . 2010-03-18 17:16 436600 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Data.Services.Client.dll + 2010-03-18 17:16 . 2010-03-18 17:16 683872 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Data.Linq.dll + 2010-03-18 17:16 . 2010-03-18 17:16 409448 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.configuration.dll + 2010-03-18 17:16 . 2010-03-18 17:16 210816 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.ComponentModel.Composition.dll + 2011-12-15 17:08 . 2011-12-15 17:08 156440 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.AddIn.dll + 2010-03-18 17:16 . 2010-03-18 17:16 122248 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Activities.DurableInstancing.dll + 2010-03-18 17:16 . 2010-03-18 17:16 525704 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Activities.Core.Presentation.dll + 2010-03-18 17:16 . 2010-03-18 17:16 112976 c:\windows\Microsoft.NET\Framework\v4.0.30319\sysglobl.dll + 2011-12-15 17:08 . 2011-12-15 17:08 518400 c:\windows\Microsoft.NET\Framework\v4.0.30319\SOS.dll + 2010-03-18 17:16 . 2010-03-18 17:16 124240 c:\windows\Microsoft.NET\Framework\v4.0.30319\SMSvcHost.exe + 2009-08-31 10:44 . 2009-08-31 10:44 144416 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\sqmapi.dll + 2010-03-18 20:16 . 2010-03-18 20:16 295248 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\SetupUi.dll + 2010-03-18 20:16 . 2010-03-18 20:16 807256 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\SetupEngine.dll + 2011-12-26 09:39 . 2011-12-26 09:39 192792 c:\windows\Microsoft.NET\Framework\v4.0.30319\ServiceModelReg.exe + 2010-03-18 17:16 . 2010-03-18 17:16 121688 c:\windows\Microsoft.NET\Framework\v4.0.30319\PerfCounter.dll + 2010-03-18 17:16 . 2010-03-18 17:16 150856 c:\windows\Microsoft.NET\Framework\v4.0.30319\ngen.exe + 2010-03-18 17:16 . 2010-03-18 17:16 130384 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe + 2010-03-18 17:16 . 2010-03-18 17:16 335184 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvc.dll + 2010-03-18 17:16 . 2010-03-18 17:16 110936 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsecimpl.dll + 2010-03-18 17:16 . 2010-03-18 17:16 372048 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorrc.dll + 2010-03-18 17:16 . 2010-03-18 17:16 145752 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorpehost.dll + 2010-03-18 17:16 . 2010-03-18 17:16 413008 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll + 2011-12-15 17:08 . 2011-12-15 17:08 957200 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscordbi.dll + 2010-03-18 17:16 . 2010-03-18 17:16 661352 c:\windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.VisualBasic.dll + 2010-03-18 17:16 . 2010-03-18 17:16 349576 c:\windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.VisualBasic.Compatibility.dll + 2010-03-18 17:16 . 2010-03-18 17:16 170368 c:\windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Transactions.Bridge.Dtc.dll + 2010-03-18 17:16 . 2010-03-18 17:16 387960 c:\windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Transactions.Bridge.dll + 2010-03-18 17:16 . 2010-03-18 17:16 746336 c:\windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.JScript.dll + 2010-03-18 17:16 . 2010-03-18 17:16 505184 c:\windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.CSharp.dll + 2010-03-18 17:16 . 2010-03-18 17:16 794464 c:\windows\Microsoft.NET\Framework\v4.0.30319\EventLogMessages.dll + 2010-03-18 17:16 . 2010-03-18 17:16 688472 c:\windows\Microsoft.NET\Framework\v4.0.30319\diasymreader.dll + 2010-03-18 17:16 . 2010-03-18 17:16 129880 c:\windows\Microsoft.NET\Framework\v4.0.30319\CORPerfMonExt.dll + 2011-12-15 17:08 . 2011-12-15 17:08 386824 c:\windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll + 2010-03-18 17:16 . 2010-03-18 17:16 105808 c:\windows\Microsoft.NET\Framework\v4.0.30319\AppLaunch.exe + 2010-03-18 17:16 . 2010-03-18 17:16 105288 c:\windows\Microsoft.NET\Framework\v4.0.30319\alink.dll + 2010-03-18 17:16 . 2010-03-18 17:16 139088 c:\windows\Microsoft.NET\Framework\v4.0.30319\AdoNetDiag.dll + 2010-03-18 17:16 . 2010-03-18 17:16 255304 c:\windows\Microsoft.NET\Framework\v4.0.30319\1033\vbc7ui.dll + 2010-03-18 17:16 . 2010-03-18 17:16 255896 c:\windows\Microsoft.NET\Framework\v4.0.30319\1033\Microsoft.VisualBasic.Activities.CompilerUI.dll + 2010-03-18 17:16 . 2010-03-18 17:16 182088 c:\windows\Microsoft.NET\Framework\v4.0.30319\1033\cscui.dll + 2012-04-06 03:52 . 2012-04-06 03:52 131168 c:\windows\Microsoft.NET\Framework\v3.0\WPF\PresentationHostDLL.dll + 2011-12-25 08:49 . 2011-12-25 08:49 436496 c:\windows\Microsoft.NET\Framework\v2.0.50727\webengine.dll + 2012-04-21 11:15 . 2012-04-21 11:15 630784 c:\windows\Microsoft.NET\Framework\v2.0.50727\System.Drawing.dll + 2011-12-25 07:50 . 2011-12-25 07:50 389888 c:\windows\Microsoft.NET\Framework\v2.0.50727\SOS.dll + 2011-12-25 07:50 . 2011-12-25 07:50 364816 c:\windows\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll + 2011-12-25 07:50 . 2011-12-25 07:50 989968 c:\windows\Microsoft.NET\Framework\v2.0.50727\mscordacwks.dll + 2004-07-15 15:23 . 2004-07-15 15:23 737280 c:\windows\Microsoft.NET\Framework\v1.1.4322\vbc.exe + 2004-07-15 18:31 . 2004-07-15 18:31 573440 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Web.Services.dll + 2004-07-15 18:28 . 2004-07-15 18:28 819200 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Web.Mobile.dll + 2004-07-15 18:28 . 2004-07-15 18:28 126976 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.ServiceProcess.dll + 2004-07-15 18:31 . 2004-07-15 18:31 131072 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Runtime.Serialization.Formatters.Soap.dll + 2004-07-15 18:28 . 2004-07-15 18:28 323584 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Runtime.Remoting.dll + 2004-07-15 18:31 . 2004-07-15 18:31 241664 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Messaging.dll + 2004-07-15 18:31 . 2004-07-15 18:31 372736 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Management.dll + 2004-07-15 18:28 . 2004-07-15 18:28 241664 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.EnterpriseServices.dll + 2012-04-25 21:45 . 2012-04-25 21:45 471040 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Drawing.dll + 2004-07-15 18:31 . 2004-07-15 18:31 303104 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Data.OracleClient.dll + 2004-07-15 04:35 . 2004-07-15 04:35 319488 c:\windows\Microsoft.NET\Framework\v1.1.4322\SOS.dll + 2003-02-20 23:09 . 2003-02-20 23:09 122880 c:\windows\Microsoft.NET\Framework\v1.1.4322\shfusres.dll + 2003-02-20 23:09 . 2003-02-20 23:09 253952 c:\windows\Microsoft.NET\Framework\v1.1.4322\shfusion.dll + 2004-08-10 20:20 . 2004-08-10 20:20 106496 c:\windows\Microsoft.NET\Framework\v1.1.4322\netfxupdate.exe + 2003-02-21 08:42 . 2003-02-21 08:42 348160 c:\windows\Microsoft.NET\Framework\v1.1.4322\msvcr71.dll + 2004-07-15 04:33 . 2004-07-15 04:33 143360 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorrc.dll + 2003-02-20 22:43 . 2003-02-20 22:43 131072 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscormmc.dll + 2011-12-25 02:55 . 2011-12-25 02:55 102400 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorld.dll + 2011-12-25 02:53 . 2011-12-25 02:53 315392 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorjit.dll + 2004-07-15 04:32 . 2004-07-15 04:32 233472 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscordbi.dll + 2004-07-15 18:28 . 2004-07-15 18:28 299008 c:\windows\Microsoft.NET\Framework\v1.1.4322\Microsoft.VisualBasic.dll + 2004-07-15 18:28 . 2004-07-15 18:28 720896 c:\windows\Microsoft.NET\Framework\v1.1.4322\Microsoft.JScript.dll + 2004-07-15 04:35 . 2004-07-15 04:35 196608 c:\windows\Microsoft.NET\Framework\v1.1.4322\ilasm.exe + 2004-07-15 04:24 . 2004-07-15 04:24 282624 c:\windows\Microsoft.NET\Framework\v1.1.4322\fusion.dll + 2003-02-20 23:16 . 2003-02-20 23:16 798720 c:\windows\Microsoft.NET\Framework\v1.1.4322\EventLogMessages.dll + 2003-02-21 14:21 . 2003-02-21 14:21 524288 c:\windows\Microsoft.NET\Framework\v1.1.4322\diasymreader.dll + 2004-07-15 15:23 . 2004-07-15 15:23 626688 c:\windows\Microsoft.NET\Framework\v1.1.4322\cscomp.dll + 2002-07-29 15:11 . 2002-07-29 15:11 219136 c:\windows\Microsoft.NET\Framework\v1.1.4322\c_g18030.dll + 2011-12-25 03:49 . 2011-12-25 03:49 258048 c:\windows\Microsoft.NET\Framework\v1.1.4322\aspnet_isapi.dll + 2003-02-21 09:04 . 2003-02-21 09:04 155648 c:\windows\Microsoft.NET\Framework\v1.1.4322\1033\Vsavb7rtUI.dll + 2003-02-21 07:02 . 2003-02-21 07:02 131072 c:\windows\Microsoft.NET\Framework\v1.1.4322\1033\vbc7ui.dll - 2009-09-21 01:59 . 2006-03-31 15:27 578560 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2911.0\Microsoft.DirectX.Direct3DX.dll + 2009-09-21 01:59 . 2006-03-31 16:27 578560 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2911.0\Microsoft.DirectX.Direct3DX.dll + 2009-09-21 01:59 . 2006-02-03 12:40 578560 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2910.0\Microsoft.DirectX.Direct3DX.dll - 2009-09-21 01:59 . 2006-02-03 11:40 578560 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2910.0\Microsoft.DirectX.Direct3DX.dll - 2009-09-21 01:59 . 2005-12-05 21:20 577536 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2909.0\Microsoft.DirectX.Direct3DX.dll + 2009-09-21 01:59 . 2005-12-05 22:20 577536 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2909.0\Microsoft.DirectX.Direct3DX.dll + 2009-09-21 01:59 . 2005-09-28 19:11 577536 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2908.0\Microsoft.DirectX.Direct3DX.dll - 2009-09-21 01:59 . 2005-09-28 18:11 577536 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2908.0\Microsoft.DirectX.Direct3DX.dll + 2009-09-21 01:59 . 2005-07-22 22:21 577024 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2907.0\Microsoft.DirectX.Direct3DX.dll - 2009-09-21 01:59 . 2005-07-22 21:21 577024 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2907.0\Microsoft.DirectX.Direct3DX.dll + 2009-09-21 01:59 . 2005-05-26 20:15 576000 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2906.0\Microsoft.DirectX.Direct3DX.dll - 2009-09-21 01:59 . 2005-05-26 19:15 576000 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2906.0\Microsoft.DirectX.Direct3DX.dll - 2009-09-21 01:59 . 2005-03-18 21:23 567296 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2905.0\Microsoft.DirectX.Direct3DX.dll + 2009-09-21 01:59 . 2005-03-18 22:23 567296 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2905.0\Microsoft.DirectX.Direct3DX.dll - 2009-09-21 01:59 . 2005-02-05 23:32 563712 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2904.0\Microsoft.DirectX.Direct3DX.dll + 2009-09-21 01:59 . 2005-02-06 00:32 563712 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2904.0\Microsoft.DirectX.Direct3DX.dll + 2009-09-21 01:59 . 2005-03-18 22:23 223232 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.dll - 2009-09-21 01:59 . 2005-03-18 20:23 223232 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.dll + 2009-09-21 01:59 . 2005-03-18 22:23 178176 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectSound.dll - 2009-09-21 01:59 . 2005-03-18 20:23 178176 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectSound.dll - 2009-09-21 01:59 . 2005-03-18 20:23 364544 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectPlay.dll + 2009-09-21 01:59 . 2005-03-18 22:23 364544 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectPlay.dll - 2009-09-21 01:59 . 2005-03-18 20:23 159232 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectInput.dll + 2009-09-21 01:59 . 2005-03-18 22:23 159232 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectInput.dll + 2009-09-21 01:59 . 2005-03-18 22:23 145920 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectDraw.dll - 2009-09-21 01:59 . 2005-03-18 20:23 145920 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.DirectDraw.dll - 2009-09-21 01:59 . 2005-03-18 20:23 473600 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.Direct3D.dll + 2009-09-21 01:59 . 2005-03-18 22:23 473600 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.Direct3D.dll + 2012-06-14 06:17 . 2012-06-14 06:17 350592 c:\windows\Microsoft.NET\assembly\GAC_MSIL\UIAutomationClientsideProviders\v4.0_4.0.0.0__31bf3856ad364e35\UIAutomationClientsideProviders.dll + 2012-06-14 06:17 . 2012-06-14 06:17 163168 c:\windows\Microsoft.NET\assembly\GAC_MSIL\UIAutomationClient\v4.0_4.0.0.0__31bf3856ad364e35\UIAutomationClient.dll + 2012-06-14 06:17 . 2012-06-14 06:17 138592 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll + 2012-06-14 06:17 . 2012-06-14 06:17 699224 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Xaml\v4.0_4.0.0.0__b77a5c561934e089\System.Xaml.dll + 2012-06-14 06:17 . 2012-06-14 06:17 857960 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Web.Services\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll + 2012-06-14 06:17 . 2012-06-14 06:17 675672 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Speech\v4.0_4.0.0.0__31bf3856ad364e35\System.Speech.dll + 2012-06-14 06:17 . 2012-06-14 06:17 113512 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.ServiceProcess\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.ServiceProcess.dll + 2012-06-14 06:17 . 2012-06-14 06:17 129912 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.ServiceModel.Routing\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Routing.dll + 2012-06-14 06:17 . 2012-06-14 06:17 390008 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.ServiceModel.Discovery\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Discovery.dll + 2012-06-14 06:17 . 2012-06-14 06:17 505208 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.ServiceModel.Activities\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Activities.dll + 2012-06-14 06:17 . 2012-06-14 06:17 261472 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Security\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Security.dll + 2012-06-14 06:17 . 2012-06-14 06:17 122264 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Runtime.Serialization.Formatters.Soap\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Runtime.Serialization.Formatters.Soap.dll + 2012-06-14 06:17 . 2012-06-14 06:17 291184 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Runtime.Remoting\v4.0_4.0.0.0__b77a5c561934e089\System.Runtime.Remoting.dll + 2012-06-14 06:17 . 2012-06-14 06:17 349568 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Runtime.DurableInstancing\v4.0_4.0.0.0__31bf3856ad364e35\System.Runtime.DurableInstancing.dll + 2012-06-14 06:17 . 2012-06-14 06:17 231760 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Net\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Net.dll + 2012-06-14 06:17 . 2012-06-14 06:17 253280 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Messaging\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Messaging.dll + 2012-06-14 06:17 . 2012-06-14 06:17 378720 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Management\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Management.dll + 2012-06-14 06:17 . 2012-06-14 06:17 134528 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Management.Instrumentation\v4.0_4.0.0.0__b77a5c561934e089\System.Management.Instrumentation.dll + 2012-06-14 06:17 . 2012-06-14 06:17 123736 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.IO.Log\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.IO.Log.dll + 2012-06-14 06:17 . 2012-06-14 06:17 392552 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.IdentityModel\v4.0_4.0.0.0__b77a5c561934e089\System.IdentityModel.dll + 2012-06-14 06:17 . 2012-06-14 06:17 125816 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.IdentityModel.Selectors\v4.0_4.0.0.0__b77a5c561934e089\System.IdentityModel.Selectors.dll + 2012-06-14 06:17 . 2012-06-14 06:17 120152 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Dynamic\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Dynamic.dll + 2012-06-14 06:17 . 2012-06-14 06:17 616024 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll + 2012-06-14 06:17 . 2012-06-14 06:17 395120 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.DirectoryServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.dll + 2012-06-14 06:17 . 2012-06-14 06:17 182144 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.DirectoryServices.Protocols\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.Protocols.dll + 2012-06-14 06:17 . 2012-06-14 06:17 285072 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.DirectoryServices.AccountManagement\v4.0_4.0.0.0__b77a5c561934e089\System.DirectoryServices.AccountManagement.dll + 2012-06-14 06:17 . 2012-06-14 06:17 829280 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Deployment\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Deployment.dll + 2012-06-14 06:17 . 2012-06-14 06:17 747360 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Data.SqlXml\v4.0_4.0.0.0__b77a5c561934e089\System.Data.SqlXml.dll + 2012-06-14 06:17 . 2012-06-14 06:17 436600 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Data.Services.Client\v4.0_4.0.0.0__b77a5c561934e089\System.Data.Services.Client.dll + 2012-06-14 06:17 . 2012-06-14 06:17 683872 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Data.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Data.Linq.dll + 2012-06-14 06:17 . 2012-06-14 06:17 409448 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.configuration.dll + 2012-06-14 06:17 . 2012-06-14 06:17 210816 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.ComponentModel.Composition\v4.0_4.0.0.0__b77a5c561934e089\System.ComponentModel.Composition.dll + 2012-06-14 06:17 . 2012-06-14 06:17 156440 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.AddIn\v4.0_4.0.0.0__b77a5c561934e089\System.AddIn.dll + 2012-06-14 06:17 . 2012-06-14 06:17 122248 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Activities.DurableInstancing\v4.0_4.0.0.0__31bf3856ad364e35\System.Activities.DurableInstancing.dll + 2012-06-14 06:17 . 2012-06-14 06:17 525704 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Activities.Core.Presentation\v4.0_4.0.0.0__31bf3856ad364e35\System.Activities.Core.Presentation.dll + 2012-06-14 06:17 . 2012-06-14 06:17 112976 c:\windows\Microsoft.NET\assembly\GAC_MSIL\sysglobl\v4.0_4.0.0.0__b03f5f7f11d50a3a\sysglobl.dll + 2012-06-14 06:17 . 2012-06-14 06:17 581464 c:\windows\Microsoft.NET\assembly\GAC_MSIL\ReachFramework\v4.0_4.0.0.0__31bf3856ad364e35\ReachFramework.dll + 2012-06-14 06:17 . 2012-06-14 06:17 832856 c:\windows\Microsoft.NET\assembly\GAC_MSIL\PresentationUI\v4.0_4.0.0.0__31bf3856ad364e35\PresentationUI.dll + 2012-06-14 06:17 . 2012-06-14 06:17 194424 c:\windows\Microsoft.NET\assembly\GAC_MSIL\PresentationFramework.Royale\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.Royale.dll + 2012-06-14 06:17 . 2012-06-14 06:17 478576 c:\windows\Microsoft.NET\assembly\GAC_MSIL\PresentationFramework.Luna\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.Luna.dll + 2012-06-14 06:17 . 2012-06-14 06:17 167288 c:\windows\Microsoft.NET\assembly\GAC_MSIL\PresentationFramework.Classic\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.Classic.dll + 2012-06-14 06:17 . 2012-06-14 06:17 232304 c:\windows\Microsoft.NET\assembly\GAC_MSIL\PresentationFramework.Aero\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.Aero.dll + 2012-06-14 06:17 . 2012-06-14 06:17 661352 c:\windows\Microsoft.NET\assembly\GAC_MSIL\Microsoft.VisualBasic\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll + 2012-06-14 06:17 . 2012-06-14 06:17 349576 c:\windows\Microsoft.NET\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.dll + 2012-06-14 06:17 . 2012-06-14 06:17 387960 c:\windows\Microsoft.NET\assembly\GAC_MSIL\Microsoft.Transactions.Bridge\v4.0_4.0.0.0__b03f5f7f11d50a3a\Microsoft.Transactions.Bridge.dll + 2012-06-14 06:17 . 2012-06-14 06:17 746336 c:\windows\Microsoft.NET\assembly\GAC_MSIL\Microsoft.JScript\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.JScript.dll + 2012-06-14 06:17 . 2012-06-14 06:17 505184 c:\windows\Microsoft.NET\assembly\GAC_MSIL\Microsoft.CSharp\v4.0_4.0.0.0__b03f5f7f11d50a3a\Microsoft.CSharp.dll + 2012-06-14 06:17 . 2012-06-14 06:17 269672 c:\windows\Microsoft.NET\assembly\GAC_32\System.Transactions\v4.0_4.0.0.0__b77a5c561934e089\System.Transactions.dll + 2012-06-14 06:17 . 2012-06-14 06:17 334688 c:\windows\Microsoft.NET\assembly\GAC_32\System.Printing\v4.0_4.0.0.0__31bf3856ad364e35\System.Printing.dll + 2012-06-14 06:17 . 2012-06-14 06:17 109568 c:\windows\Microsoft.NET\assembly\GAC_32\System.EnterpriseServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll + 2012-06-14 06:17 . 2012-06-14 06:17 246128 c:\windows\Microsoft.NET\assembly\GAC_32\System.EnterpriseServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll + 2012-06-14 06:17 . 2012-06-14 06:17 170368 c:\windows\Microsoft.NET\assembly\GAC_32\Microsoft.Transactions.Bridge.Dtc\v4.0_4.0.0.0__b03f5f7f11d50a3a\Microsoft.Transactions.Bridge.Dtc.dll + 2002-09-18 04:45 . 2002-09-18 04:45 119808 c:\windows\lsb_un20.exe + 2010-01-14 04:17 . 1998-10-02 23:00 327168 c:\windows\IsUninst.exe - 2010-01-14 04:17 . 1998-10-03 00:00 327168 c:\windows\IsUninst.exe + 2011-12-22 20:50 . 2011-12-22 20:50 256000 c:\windows\Installer\e51b7c6.msp + 2011-05-10 10:26 . 2011-05-10 10:26 223232 c:\windows\Installer\d464695.msi + 2010-11-12 16:08 . 2010-11-12 16:08 889344 c:\windows\Installer\d2ff58.msp + 2010-11-16 17:54 . 2010-11-16 17:54 906240 c:\windows\Installer\d2ff14.msp + 2012-03-23 05:41 . 2012-03-23 05:41 219648 c:\windows\Installer\ceaa36.msi + 2011-07-26 01:25 . 2011-07-26 01:25 501248 c:\windows\Installer\b2ddaca.msi + 2011-07-26 01:25 . 2011-07-26 01:25 501248 c:\windows\Installer\b2ddaae.msi + 2011-07-26 01:24 . 2011-07-26 01:24 506880 c:\windows\Installer\b2ddaa7.msi + 2011-07-26 01:24 . 2011-07-26 01:24 516608 c:\windows\Installer\b2dda9e.msi + 2011-07-26 01:24 . 2011-07-26 01:24 513024 c:\windows\Installer\b2dda96.msi + 2011-07-26 01:24 . 2011-07-26 01:24 501248 c:\windows\Installer\b2dda88.msi + 2011-07-26 01:23 . 2011-07-26 01:23 501248 c:\windows\Installer\b2dda5e.msi + 2011-08-08 05:02 . 2011-08-08 05:02 817664 c:\windows\Installer\a3176d6.msi + 2011-06-17 07:06 . 2011-06-17 07:06 223744 c:\windows\Installer\6dfae774.msi + 2011-06-17 07:03 . 2011-06-17 07:03 467456 c:\windows\Installer\6dfae708.msi + 2012-06-29 05:06 . 2012-06-29 05:06 337920 c:\windows\Installer\66954d7.msi + 2011-10-25 00:23 . 2011-10-25 00:23 228352 c:\windows\Installer\4042aa.msi + 2011-10-25 00:23 . 2011-10-25 00:23 331264 c:\windows\Installer\4042a1.msi + 2011-10-25 00:23 . 2011-10-25 00:23 424960 c:\windows\Installer\40429a.msi + 2011-11-11 13:34 . 2011-11-11 13:34 178688 c:\windows\Installer\3b63c.msi + 2012-04-21 16:32 . 2012-04-21 16:32 215552 c:\windows\Installer\3b1072.msi + 2012-02-03 03:56 . 2012-02-03 03:56 963584 c:\windows\Installer\308ad30.msp + 2012-08-19 07:23 . 2012-08-19 07:23 496128 c:\windows\Installer\1f9f9e.msi + 2011-03-03 03:04 . 2011-03-03 03:04 276992 c:\windows\Installer\1f2d6a0f.msi + 2010-09-24 01:02 . 2010-09-24 01:02 798208 c:\windows\Installer\1b7434e.msp + 2012-04-22 01:55 . 2012-04-22 01:55 980480 c:\windows\Installer\1a8274c.msp + 2012-03-27 05:39 . 2012-03-27 05:39 213504 c:\windows\Installer\18c99e8.msi + 2008-11-05 16:02 . 2008-11-05 16:02 119296 c:\windows\Installer\17115cb.msp + 2011-03-18 00:03 . 2011-03-18 00:03 308736 c:\windows\Installer\1299523b.msp + 2010-08-04 19:13 . 2010-08-04 19:13 686080 c:\windows\Installer\129951b4.msp + 2009-05-26 22:53 . 2009-05-26 22:53 579072 c:\windows\Installer\129950d6.msp + 2010-07-23 05:03 . 2010-07-23 05:03 338432 c:\windows\Installer\129950a8.msp + 2012-07-18 19:46 . 2012-07-18 19:46 593408 c:\windows\Installer\114e86b.msp + 2011-12-25 10:40 . 2011-12-25 10:40 819200 c:\windows\Installer\10b3d2a0.msp + 2012-02-21 01:50 . 2012-02-21 01:50 203776 c:\windows\Installer\1015d907.msi (continued on next post)
(continued from previous post - part 3 of 3)
+ 2012-02-21 01:50 . 2012-02-21 01:50 901120 c:\windows\Installer\1015d8f7.msi
+ 2012-09-13 07:00 . 2012-09-13 07:00 371272 c:\windows\Installer\{EE7257A2-39A2-4D2F-9DAC-F9F25B8AE1D8}\SkypeIcon.exe
+ 2009-12-30 20:55 . 2011-06-17 07:08 114688 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\outicon.exe
- 2009-12-30 20:55 . 2010-06-09 07:01 114688 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\outicon.exe
+ 2009-12-30 20:55 . 2011-06-17 07:08 155702 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\bcicon.exe
- 2009-12-30 20:55 . 2010-06-09 07:01 155702 c:\windows\Installer\{91130409-6000-11D3-8CFE-0050048383C9}\bcicon.exe
+ 2012-03-29 04:50 . 2012-03-29 04:50 217864 c:\windows\Installer\{90120000-006E-0409-0000-0000000FF1CE}\misc.exe
- 2010-06-13 01:10 . 2010-06-13 01:10 217864 c:\windows\Installer\{90120000-006E-0409-0000-0000000FF1CE}\misc.exe
+ 2011-07-26 01:28 . 2012-09-12 12:24 888080 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\wordicon.exe
- 2009-10-01 01:42 . 2010-06-13 01:11 888080 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\wordicon.exe
+ 2011-07-26 01:28 . 2012-09-12 12:24 272648 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\pubs.exe
- 2009-10-01 01:42 . 2010-06-13 01:11 272648 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\pubs.exe
+ 2011-07-26 01:28 . 2012-09-12 12:24 922384 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\pptico.exe
- 2009-10-01 01:42 . 2010-06-13 01:11 922384 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\pptico.exe
- 2009-10-01 01:42 . 2010-06-13 01:11 845584 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\outicon.exe
+ 2011-07-26 01:28 . 2012-09-12 12:24 845584 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\outicon.exe
- 2009-10-01 01:42 . 2010-06-13 01:11 217864 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\misc.exe
+ 2011-07-26 01:28 . 2012-09-12 12:24 217864 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\misc.exe
- 2009-10-01 01:42 . 2010-06-13 01:11 184080 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\joticon.exe
+ 2011-07-26 01:28 . 2012-09-12 12:24 184080 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\joticon.exe
- 2009-10-01 01:42 . 2010-06-13 01:11 159504 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\inficon.exe
+ 2011-07-26 01:28 . 2012-09-12 12:24 159504 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\inficon.exe
+ 2009-04-19 20:18 . 2012-08-15 05:47 409600 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\xlicons.exe
- 2009-04-19 20:18 . 2010-06-09 07:11 409600 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\xlicons.exe
- 2009-04-19 20:18 . 2010-06-09 07:11 286720 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\wordicon.exe
+ 2009-04-19 20:18 . 2012-08-15 05:47 286720 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\wordicon.exe
- 2009-04-19 20:18 . 2010-06-09 07:11 249856 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\pptico.exe
+ 2009-04-19 20:18 . 2012-08-15 05:47 249856 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\pptico.exe
+ 2009-04-19 20:18 . 2012-08-15 05:47 794624 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\outicon.exe
- 2009-04-19 20:18 . 2010-06-09 07:11 794624 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\outicon.exe
- 2009-04-19 20:18 . 2010-06-09 07:11 135168 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\misc.exe
+ 2009-04-19 20:18 . 2012-08-15 05:47 135168 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\misc.exe
- 2009-04-19 20:18 . 2010-06-09 07:11 593920 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\accicons.exe
+ 2009-04-19 20:18 . 2012-08-15 05:47 593920 c:\windows\Installer\{90110409-6000-11D3-8CFE-0150048383C9}\accicons.exe
+ 2012-03-21 05:47 . 2012-03-21 05:47 380928 c:\windows\Installer\{8B92D97D-DB3D-4926-A8F7-718FE7C5EE18}\iTunesIco.exe
+ 2007-04-19 18:01 . 2007-04-19 18:01 238424 c:\windows\Installer\$PatchCache$\Managed\9040110900063D11C8EF10054038389C\11.0.8173\MSCDM.DLL
+ 2011-06-06 16:55 . 2011-06-06 16:55 249232 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\sqlite.dll
+ 2011-06-06 16:55 . 2011-06-06 16:55 394136 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\pdfshell.dll
+ 2011-06-06 16:55 . 2011-06-06 16:55 103848 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\PDFPrevHndlrShim.exe
+ 2011-06-06 16:55 . 2011-06-06 16:55 183696 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\nppdf32.dll
+ 2011-06-06 16:55 . 2011-06-06 16:55 104344 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\AiodLite.dll
+ 2011-06-06 16:55 . 2011-06-06 16:55 937920 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\adobearm.exe
+ 2011-06-06 16:55 . 2011-06-06 16:55 102808 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\AcroRdIF.dll
+ 2011-06-06 16:55 . 2011-06-06 16:55 755088 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\AcroPDF.dll
+ 2011-06-06 16:55 . 2011-06-06 16:55 296344 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\acrobroker.exe
+ 2011-06-06 16:55 . 2011-06-06 16:55 205720 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\a3dutils.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 915800 c:\windows\Installer\$PatchCache$\Managed\5C1093C35543A0E32A41B090A305076A\4.0.30319\wpftxt_x86.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 181096 c:\windows\Installer\$PatchCache$\Managed\5C1093C35543A0E32A41B090A305076A\4.0.30319\PresentationHostDLL_X86.dll
+ 2011-01-14 11:10 . 2011-01-14 11:10 155520 c:\windows\Installer\$PatchCache$\Managed\00004109500200000000000000F01FEC\14.0.5130\GKWORD6.DLL
+ 2011-01-14 11:10 . 2011-01-14 11:10 140160 c:\windows\Installer\$PatchCache$\Managed\00004109500200000000000000F01FEC\14.0.5130\GKEXCEL2.DLL
+ 2011-09-16 00:41 . 2011-09-16 00:41 408936 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\WINWORD.EXE
+ 2007-06-07 23:51 . 2007-06-07 23:51 465800 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\OUTLFLTR.DLL
+ 2008-03-19 10:27 . 2008-03-19 10:27 661536 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\OGALEGIT.DLL
+ 2011-06-23 13:54 . 2011-06-23 13:54 119160 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\MSCONV97.DLL
+ 2008-10-25 10:18 . 2008-10-25 10:18 172880 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\IEAWSDC.DLL
- 2009-10-01 01:41 . 2009-10-01 01:41 781104 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\WORDPIA.DLL
+ 2011-07-26 01:27 . 2011-07-26 01:27 781104 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\WORDPIA.DLL
+ 2006-10-27 00:13 . 2006-10-27 00:13 503624 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\SELFCERT.EXE
+ 2011-07-26 01:27 . 2011-07-26 01:27 248632 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\PPTPIA.DLL
+ 2006-10-27 01:07 . 2006-10-27 01:07 368968 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\PPSLAX.DLL
+ 2006-10-27 19:04 . 2006-10-27 19:04 465200 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\POWERPNT.EXE
+ 2006-10-27 00:00 . 2006-10-27 00:00 285008 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\OISGRAPH.DLL
+ 2006-10-27 00:00 . 2006-10-27 00:00 998208 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\OISAPP.DLL
+ 2006-10-27 00:00 . 2006-10-27 00:00 274744 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\OIS.EXE
- 2009-10-01 01:41 . 2009-10-01 01:41 416544 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\OFFICE.DLL
+ 2011-07-26 01:27 . 2011-07-26 01:27 416544 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\OFFICE.DLL
+ 2006-10-26 23:55 . 2006-10-26 23:55 538904 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MSTORES.DLL
+ 2006-10-26 23:55 . 2006-10-26 23:55 145688 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MSTORE.EXE
+ 2006-10-26 23:55 . 2006-10-26 23:55 832800 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MSTORDB.EXE
+ 2006-10-26 23:50 . 2006-10-26 23:50 672024 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MSQRY32.EXE
+ 2006-10-26 23:52 . 2006-10-26 23:52 460616 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MODHELP.DLL
+ 2006-10-26 23:55 . 2006-10-26 23:55 828704 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\MEDCAT.DLL
+ 2011-07-26 01:27 . 2011-07-26 01:27 150320 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\GRAPHPIA.DLL
+ 2006-10-27 00:12 . 2006-10-27 00:12 106824 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\DSSM.EXE
+ 2006-10-27 00:13 . 2006-10-27 00:13 764800 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\ACECNF.DLL
+ 2009-02-26 21:45 . 2009-02-26 21:45 509256 c:\windows\Installer\$PatchCache$\Managed\00002109020090400000000000F01FEC\12.0.6612\WRD12CVR.DLL
+ 2012-08-15 05:44 . 2012-05-16 15:08 916992 c:\windows\ie8updates\KB2722913-IE8\wininet.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 105984 c:\windows\ie8updates\KB2722913-IE8\url.dll
+ 2012-08-15 05:44 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2722913-IE8\spuninst\updspapi.dll
+ 2012-08-15 05:44 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2722913-IE8\spuninst\spuninst.exe
+ 2012-08-15 05:44 . 2012-05-11 14:42 206848 c:\windows\ie8updates\KB2722913-IE8\occache.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 611840 c:\windows\ie8updates\KB2722913-IE8\mstime.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 629760 c:\windows\ie8updates\KB2722913-IE8\msfeeds.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 521728 c:\windows\ie8updates\KB2722913-IE8\jsdbgui.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 247808 c:\windows\ie8updates\KB2722913-IE8\ieproxy.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 184320 c:\windows\ie8updates\KB2722913-IE8\iepeers.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 743424 c:\windows\ie8updates\KB2722913-IE8\iedvtool.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 387584 c:\windows\ie8updates\KB2722913-IE8\iedkcs32.dll
+ 2012-08-15 05:44 . 2012-05-11 11:38 174080 c:\windows\ie8updates\KB2722913-IE8\ie4uinit.exe
+ 2012-06-14 06:08 . 2012-03-01 11:01 916992 c:\windows\ie8updates\KB2699988-IE8\wininet.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 105984 c:\windows\ie8updates\KB2699988-IE8\url.dll
+ 2012-06-14 06:08 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2699988-IE8\spuninst\updspapi.dll
+ 2012-06-14 06:08 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2699988-IE8\spuninst\spuninst.exe
+ 2012-06-14 06:08 . 2012-03-01 11:01 206848 c:\windows\ie8updates\KB2699988-IE8\occache.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 611840 c:\windows\ie8updates\KB2699988-IE8\mstime.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 602112 c:\windows\ie8updates\KB2699988-IE8\msfeeds.dll
+ 2012-06-14 06:08 . 2009-03-08 09:35 521216 c:\windows\ie8updates\KB2699988-IE8\jsdbgui.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 247808 c:\windows\ie8updates\KB2699988-IE8\ieproxy.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 184320 c:\windows\ie8updates\KB2699988-IE8\iepeers.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 743424 c:\windows\ie8updates\KB2699988-IE8\iedvtool.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 387584 c:\windows\ie8updates\KB2699988-IE8\iedkcs32.dll
+ 2012-06-14 06:08 . 2012-02-29 12:17 174080 c:\windows\ie8updates\KB2699988-IE8\ie4uinit.exe
+ 2012-04-11 12:54 . 2011-12-17 19:46 916992 c:\windows\ie8updates\KB2675157-IE8\wininet.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 105984 c:\windows\ie8updates\KB2675157-IE8\url.dll
+ 2012-04-11 12:54 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2675157-IE8\spuninst\updspapi.dll
+ 2012-04-11 12:54 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2675157-IE8\spuninst\spuninst.exe
+ 2012-04-11 12:54 . 2011-12-17 19:46 206848 c:\windows\ie8updates\KB2675157-IE8\occache.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 611840 c:\windows\ie8updates\KB2675157-IE8\mstime.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 602112 c:\windows\ie8updates\KB2675157-IE8\msfeeds.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 247808 c:\windows\ie8updates\KB2675157-IE8\ieproxy.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 184320 c:\windows\ie8updates\KB2675157-IE8\iepeers.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 743424 c:\windows\ie8updates\KB2675157-IE8\iedvtool.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 387584 c:\windows\ie8updates\KB2675157-IE8\iedkcs32.dll
+ 2012-04-11 12:54 . 2011-12-16 12:23 174080 c:\windows\ie8updates\KB2675157-IE8\ie4uinit.exe
+ 2012-02-16 08:05 . 2011-11-04 19:20 916992 c:\windows\ie8updates\KB2647516-IE8\wininet.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 105984 c:\windows\ie8updates\KB2647516-IE8\url.dll
+ 2012-02-16 08:05 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2647516-IE8\spuninst\updspapi.dll
+ 2012-02-16 08:05 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2647516-IE8\spuninst\spuninst.exe
+ 2012-02-16 08:05 . 2011-11-04 19:20 206848 c:\windows\ie8updates\KB2647516-IE8\occache.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 611840 c:\windows\ie8updates\KB2647516-IE8\mstime.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 602112 c:\windows\ie8updates\KB2647516-IE8\msfeeds.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 247808 c:\windows\ie8updates\KB2647516-IE8\ieproxy.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 184320 c:\windows\ie8updates\KB2647516-IE8\iepeers.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 743424 c:\windows\ie8updates\KB2647516-IE8\iedvtool.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 387584 c:\windows\ie8updates\KB2647516-IE8\iedkcs32.dll
+ 2012-02-16 08:05 . 2011-11-04 11:24 174080 c:\windows\ie8updates\KB2647516-IE8\ie4uinit.exe
+ 2011-12-15 05:50 . 2011-08-22 23:48 916480 c:\windows\ie8updates\KB2618444-IE8\wininet.dll
+ 2011-12-15 05:50 . 2011-08-22 23:48 105984 c:\windows\ie8updates\KB2618444-IE8\url.dll
+ 2011-12-15 05:50 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2618444-IE8\spuninst\updspapi.dll
+ 2011-12-15 05:50 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2618444-IE8\spuninst\spuninst.exe
+ 2011-12-15 05:50 . 2011-08-22 23:48 206848 c:\windows\ie8updates\KB2618444-IE8\occache.dll
+ 2011-12-15 05:50 . 2011-08-22 23:48 611840 c:\windows\ie8updates\KB2618444-IE8\mstime.dll
+ 2011-12-15 05:50 . 2011-08-22 23:48 602112 c:\windows\ie8updates\KB2618444-IE8\msfeeds.dll
+ 2011-12-15 05:50 . 2011-08-22 23:48 247808 c:\windows\ie8updates\KB2618444-IE8\ieproxy.dll
+ 2011-12-15 05:50 . 2011-08-22 23:48 184320 c:\windows\ie8updates\KB2618444-IE8\iepeers.dll
+ 2011-12-15 05:50 . 2011-08-22 23:48 743424 c:\windows\ie8updates\KB2618444-IE8\iedvtool.dll
+ 2011-12-15 05:50 . 2011-08-22 23:48 387584 c:\windows\ie8updates\KB2618444-IE8\iedkcs32.dll
+ 2011-12-15 05:50 . 2011-08-22 11:56 174080 c:\windows\ie8updates\KB2618444-IE8\ie4uinit.exe
+ 2011-10-12 11:48 . 2011-06-23 18:36 916480 c:\windows\ie8updates\KB2586448-IE8\wininet.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 105984 c:\windows\ie8updates\KB2586448-IE8\url.dll
+ 2011-10-12 11:48 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2586448-IE8\spuninst\updspapi.dll
+ 2011-10-12 11:48 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2586448-IE8\spuninst\spuninst.exe
+ 2011-10-12 11:48 . 2011-06-23 18:36 206848 c:\windows\ie8updates\KB2586448-IE8\occache.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 611840 c:\windows\ie8updates\KB2586448-IE8\mstime.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 602112 c:\windows\ie8updates\KB2586448-IE8\msfeeds.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 247808 c:\windows\ie8updates\KB2586448-IE8\ieproxy.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 184320 c:\windows\ie8updates\KB2586448-IE8\iepeers.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 743424 c:\windows\ie8updates\KB2586448-IE8\iedvtool.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 387584 c:\windows\ie8updates\KB2586448-IE8\iedkcs32.dll
+ 2011-10-12 11:48 . 2011-06-23 12:05 173568 c:\windows\ie8updates\KB2586448-IE8\ie4uinit.exe
+ 2011-08-11 12:00 . 2011-04-25 16:11 916480 c:\windows\ie8updates\KB2559049-IE8\wininet.dll
+ 2011-08-11 12:00 . 2009-03-08 09:34 105984 c:\windows\ie8updates\KB2559049-IE8\url.dll
+ 2011-08-11 12:00 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2559049-IE8\spuninst\updspapi.dll
+ 2011-08-11 12:00 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2559049-IE8\spuninst\spuninst.exe
+ 2011-08-11 12:00 . 2011-04-25 16:11 206848 c:\windows\ie8updates\KB2559049-IE8\occache.dll
+ 2011-08-11 12:00 . 2011-04-25 16:11 611840 c:\windows\ie8updates\KB2559049-IE8\mstime.dll
+ 2011-08-11 12:00 . 2011-04-25 16:11 602112 c:\windows\ie8updates\KB2559049-IE8\msfeeds.dll
+ 2011-08-11 12:00 . 2011-04-25 16:11 247808 c:\windows\ie8updates\KB2559049-IE8\ieproxy.dll
+ 2011-08-11 12:00 . 2011-04-25 16:11 184320 c:\windows\ie8updates\KB2559049-IE8\iepeers.dll
+ 2011-08-11 12:00 . 2011-04-25 16:11 743424 c:\windows\ie8updates\KB2559049-IE8\iedvtool.dll
+ 2011-08-11 12:00 . 2011-04-25 16:11 387584 c:\windows\ie8updates\KB2559049-IE8\iedkcs32.dll
+ 2011-08-11 12:00 . 2011-04-25 12:01 173568 c:\windows\ie8updates\KB2559049-IE8\ie4uinit.exe
+ 2011-06-17 07:00 . 2009-03-08 09:33 759296 c:\windows\ie8updates\KB2544521-IE8\vgx.dll
+ 2011-06-17 07:00 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2544521-IE8\spuninst\updspapi.dll
+ 2011-06-17 07:00 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2544521-IE8\spuninst\spuninst.exe
+ 2011-06-17 07:03 . 2011-02-22 23:06 916480 c:\windows\ie8updates\KB2530548-IE8\wininet.dll
+ 2011-06-17 07:03 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2530548-IE8\spuninst\updspapi.dll
+ 2011-06-17 07:03 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2530548-IE8\spuninst\spuninst.exe
+ 2011-06-17 07:03 . 2011-02-22 23:06 206848 c:\windows\ie8updates\KB2530548-IE8\occache.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 611840 c:\windows\ie8updates\KB2530548-IE8\mstime.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 602112 c:\windows\ie8updates\KB2530548-IE8\msfeeds.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 247808 c:\windows\ie8updates\KB2530548-IE8\ieproxy.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 184320 c:\windows\ie8updates\KB2530548-IE8\iepeers.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 743424 c:\windows\ie8updates\KB2530548-IE8\iedvtool.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 387584 c:\windows\ie8updates\KB2530548-IE8\iedkcs32.dll
+ 2011-06-17 07:03 . 2011-02-18 11:49 173568 c:\windows\ie8updates\KB2530548-IE8\ie4uinit.exe
+ 2011-04-15 07:01 . 2010-03-10 06:15 420352 c:\windows\ie8updates\KB2510531-IE8\vbscript.dll
+ 2011-04-15 07:01 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2510531-IE8\spuninst\updspapi.dll
+ 2011-04-15 07:01 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2510531-IE8\spuninst\spuninst.exe
+ 2011-04-15 07:01 . 2009-12-09 05:53 726528 c:\windows\ie8updates\KB2510531-IE8\jscript.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 916480 c:\windows\ie8updates\KB2497640-IE8\wininet.dll
+ 2011-04-15 07:09 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2497640-IE8\spuninst\updspapi.dll
+ 2011-04-15 07:09 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2497640-IE8\spuninst\spuninst.exe
+ 2011-04-15 07:09 . 2010-12-20 23:59 206848 c:\windows\ie8updates\KB2497640-IE8\occache.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 611840 c:\windows\ie8updates\KB2497640-IE8\mstime.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 602112 c:\windows\ie8updates\KB2497640-IE8\msfeeds.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 247808 c:\windows\ie8updates\KB2497640-IE8\ieproxy.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 184320 c:\windows\ie8updates\KB2497640-IE8\iepeers.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 743424 c:\windows\ie8updates\KB2497640-IE8\iedvtool.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 387584 c:\windows\ie8updates\KB2497640-IE8\iedkcs32.dll
+ 2011-04-15 07:09 . 2010-12-20 12:55 173568 c:\windows\ie8updates\KB2497640-IE8\ie4uinit.exe
+ 2011-02-11 08:01 . 2010-11-06 00:26 916480 c:\windows\ie8updates\KB2482017-IE8\wininet.dll
+ 2011-02-11 08:01 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2482017-IE8\spuninst\updspapi.dll
+ 2011-02-11 08:01 . 2010-07-05 13:15 231288 c:\windows\ie8updates\KB2482017-IE8\spuninst\spuninst.exe
+ 2011-02-11 08:01 . 2010-11-06 00:26 206848 c:\windows\ie8updates\KB2482017-IE8\occache.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 611840 c:\windows\ie8updates\KB2482017-IE8\mstime.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 602112 c:\windows\ie8updates\KB2482017-IE8\msfeeds.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 247808 c:\windows\ie8updates\KB2482017-IE8\ieproxy.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 184320 c:\windows\ie8updates\KB2482017-IE8\iepeers.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 743424 c:\windows\ie8updates\KB2482017-IE8\iedvtool.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 387584 c:\windows\ie8updates\KB2482017-IE8\iedkcs32.dll
+ 2011-02-11 08:01 . 2010-11-03 12:26 173568 c:\windows\ie8updates\KB2482017-IE8\ie4uinit.exe
+ 2010-12-16 08:03 . 2010-09-10 05:58 916480 c:\windows\ie8updates\KB2416400-IE8\wininet.dll
+ 2010-12-16 08:03 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2416400-IE8\spuninst\updspapi.dll
+ 2010-12-16 08:03 . 2010-02-22 14:23 231288 c:\windows\ie8updates\KB2416400-IE8\spuninst\spuninst.exe
+ 2010-12-16 08:03 . 2010-09-10 05:58 206848 c:\windows\ie8updates\KB2416400-IE8\occache.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 611840 c:\windows\ie8updates\KB2416400-IE8\mstime.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 602112 c:\windows\ie8updates\KB2416400-IE8\msfeeds.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 247808 c:\windows\ie8updates\KB2416400-IE8\ieproxy.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 184320 c:\windows\ie8updates\KB2416400-IE8\iepeers.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 743424 c:\windows\ie8updates\KB2416400-IE8\iedvtool.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 387584 c:\windows\ie8updates\KB2416400-IE8\iedkcs32.dll
+ 2010-12-16 08:03 . 2010-08-26 12:22 173056 c:\windows\ie8updates\KB2416400-IE8\ie4uinit.exe
+ 2010-10-14 07:05 . 2010-06-24 12:22 916480 c:\windows\ie8updates\KB2360131-IE8\wininet.dll
+ 2010-10-14 07:05 . 2010-07-05 13:16 382840 c:\windows\ie8updates\KB2360131-IE8\spuninst\updspapi.dll
+ 2010-10-14 07:05 . 2009-05-26 09:01 231288 c:\windows\ie8updates\KB2360131-IE8\spuninst\spuninst.exe
+ 2010-10-14 07:05 . 2010-06-24 12:22 206848 c:\windows\ie8updates\KB2360131-IE8\occache.dll
+ 2010-10-14 07:05 . 2010-06-24 12:22 611840 c:\windows\ie8updates\KB2360131-IE8\mstime.dll
+ 2010-10-14 07:05 . 2010-06-24 12:21 599040 c:\windows\ie8updates\KB2360131-IE8\msfeeds.dll
+ 2010-10-14 07:05 . 2010-06-24 12:21 247808 c:\windows\ie8updates\KB2360131-IE8\ieproxy.dll
+ 2010-10-14 07:05 . 2010-06-24 12:21 184320 c:\windows\ie8updates\KB2360131-IE8\iepeers.dll
+ 2010-10-14 07:05 . 2010-06-24 12:21 743424 c:\windows\ie8updates\KB2360131-IE8\iedvtool.dll
+ 2010-10-14 07:05 . 2010-06-24 12:21 387584 c:\windows\ie8updates\KB2360131-IE8\iedkcs32.dll
+ 2010-10-14 07:05 . 2010-06-23 12:08 173056 c:\windows\ie8updates\KB2360131-IE8\ie4uinit.exe
+ 2010-08-12 03:39 . 2010-05-06 10:41 916480 c:\windows\ie8updates\KB2183461-IE8\wininet.dll
+ 2010-08-12 03:39 . 2010-02-22 14:23 382840 c:\windows\ie8updates\KB2183461-IE8\spuninst\updspapi.dll
+ 2010-08-12 03:39 . 2009-05-26 09:01 231288 c:\windows\ie8updates\KB2183461-IE8\spuninst\spuninst.exe
+ 2010-08-12 03:39 . 2010-05-06 10:41 206848 c:\windows\ie8updates\KB2183461-IE8\occache.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 611840 c:\windows\ie8updates\KB2183461-IE8\mstime.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 599040 c:\windows\ie8updates\KB2183461-IE8\msfeeds.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 247808 c:\windows\ie8updates\KB2183461-IE8\ieproxy.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 184320 c:\windows\ie8updates\KB2183461-IE8\iepeers.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 743424 c:\windows\ie8updates\KB2183461-IE8\iedvtool.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 387584 c:\windows\ie8updates\KB2183461-IE8\iedkcs32.dll
+ 2010-08-12 03:39 . 2010-05-05 13:30 173056 c:\windows\ie8updates\KB2183461-IE8\ie4uinit.exe
+ 2009-04-19 19:27 . 2011-07-15 13:29 456320 c:\windows\Driver Cache\i386\mrxsmb.sys
+ 2009-04-03 14:26 . 2009-04-03 14:26 354608 c:\windows\Downloaded Program Files\sysreqlab_nvd.dll
+ 2010-08-20 04:46 . 2011-03-03 19:19 222584 c:\windows\Downloaded Program Files\BFHUpdater.dll
+ 2012-04-11 12:54 . 2012-04-11 12:54 843776 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing\1.0.5000.0__b03f5f7f11d50a3a_f65a6d97\System.Drawing.dll
+ 2012-06-14 06:08 . 2012-06-14 06:08 843776 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing\1.0.5000.0__b03f5f7f11d50a3a_da96c631\System.Drawing.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 835584 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing\1.0.5000.0__b03f5f7f11d50a3a_1d6e23c4\System.Drawing.dll
+ 2012-04-11 12:54 . 2012-04-11 12:54 192512 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing.Design\1.0.5000.0__b03f5f7f11d50a3a_a6e8dd68\System.Drawing.Design.dll
+ 2012-06-14 06:08 . 2012-06-14 06:08 192512 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing.Design\1.0.5000.0__b03f5f7f11d50a3a_63f6606c\System.Drawing.Design.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 192512 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing.Design\1.0.5000.0__b03f5f7f11d50a3a_36af94ed\System.Drawing.Design.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 118784 c:\windows\assembly\NativeImages1_v1.1.4322\CustomMarshalers\1.0.5000.0__b03f5f7f11d50a3a_ef5149bd\CustomMarshalers.dll
+ 2012-06-14 12:10 . 2012-06-14 12:10 253952 c:\windows\assembly\NativeImages_v4.0.30319_32\WindowsFormsIntegra#\9d59cf7eb15733ca09736eaaa2acaef6\WindowsFormsIntegration.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 196096 c:\windows\assembly\NativeImages_v4.0.30319_32\UIAutomationTypes\0a80fd3af7e48eb9cc9099fee5814dff\UIAutomationTypes.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 484352 c:\windows\assembly\NativeImages_v4.0.30319_32\UIAutomationClient\9b0ac8d84952a581adf18051bb60bea1\UIAutomationClient.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 391680 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Xml.Linq\f44e12702dadeae606b8eaca609b1336\System.Xml.Linq.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 188928 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Inpu#\59fb92c38f1035e7b11a23fc6e82c992\System.Windows.Input.Manipulations.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 646656 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Transactions\ce2aa3a5e89c326055ac8e2a309232f7\System.Transactions.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 221696 c:\windows\assembly\NativeImages_v4.0.30319_32\System.ServiceProce#\2516a49d10f4418f72e1c25f691815a8\System.ServiceProcess.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 365056 c:\windows\assembly\NativeImages_v4.0.30319_32\System.ServiceModel#\284141392cdba7fa4b2a4668125329a9\System.ServiceModel.Routing.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 729088 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Security\efe46aa882d9ac31f7fbbdc004fc99d5\System.Security.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 311296 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Runtime.Seri#\6a37764b2df9b3f9c7775701027ef779\System.Runtime.Serialization.Formatters.Soap.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 762368 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Runtime.Remo#\0f9d7198d2c0a3953fb59b1aca0d35f7\System.Runtime.Remoting.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 145408 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Numerics\7b7719d46a4da2e91e8c501347e48ab9\System.Numerics.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 652800 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Net\b0a7e53e8aaaca2d2ae065e85f959ff4\System.Net.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 626176 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Messaging\e7c4c4b181cff7c86388da8af37dc521\System.Messaging.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 395264 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Management.I#\d7cba8bd14e7352bc6b1f7cd35b7fd43\System.Management.Instrumentation.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 413696 c:\windows\assembly\NativeImages_v4.0.30319_32\System.IO.Log\100d056c9dc360ec5a25ff227a14840b\System.IO.Log.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 229376 c:\windows\assembly\NativeImages_v4.0.30319_32\System.IdentityMode#\5e38634854f36e1aff7500a351830427\System.IdentityModel.Selectors.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 236032 c:\windows\assembly\NativeImages_v4.0.30319_32\System.EnterpriseSe#\26ee061618887d629a9f7072970ffb85\System.EnterpriseServices.Wrapper.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 786944 c:\windows\assembly\NativeImages_v4.0.30319_32\System.EnterpriseSe#\26ee061618887d629a9f7072970ffb85\System.EnterpriseServices.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 377344 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Dynamic\1203e60a51fe0f726fbeaf0456f938a5\System.Dynamic.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 468992 c:\windows\assembly\NativeImages_v4.0.30319_32\System.DirectorySer#\c75c07a581ad459c8474cd83aa7dabf4\System.DirectoryServices.Protocols.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 913920 c:\windows\assembly\NativeImages_v4.0.30319_32\System.DirectorySer#\80373cd811bf63ae93af1733a6c7e1c5\System.DirectoryServices.AccountManagement.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 112640 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Device\6fbe438983c9ca94c80d64225ad2e5ce\System.Device.ni.dll
+ 2012-05-09 23:33 . 2012-05-09 23:33 134656 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Data.DataSet#\950c346ef6261ecc93ced8d995914a1d\System.Data.DataSetExtensions.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 980480 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Configuration\0c8e950df17a0abec10888e8ad966cbe\System.Configuration.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 148480 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Configuratio#\909306caa69b55ffdce3ae5a7f6baa20\System.Configuration.Install.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 690176 c:\windows\assembly\NativeImages_v4.0.30319_32\System.ComponentMod#\f7099031cfac8ec61b948bb09b07b1a1\System.ComponentModel.Composition.ni.dll
+ 2012-05-09 23:33 . 2012-05-09 23:33 194048 c:\windows\assembly\NativeImages_v4.0.30319_32\System.ComponentMod#\bcbd0e714127d69a895ef80afa5dfd78\System.ComponentModel.DataAnnotations.ni.dll
+ 2012-05-09 23:33 . 2012-05-09 23:33 624128 c:\windows\assembly\NativeImages_v4.0.30319_32\System.AddIn\41d68b79da934255ca82b466b93d7938\System.AddIn.ni.dll
+ 2012-05-09 23:33 . 2012-05-09 23:33 404992 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Activities.D#\2d00f7297e070e69c1cb44b25503b1c3\System.Activities.DurableInstancing.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 317952 c:\windows\assembly\NativeImages_v4.0.30319_32\SMSvcHost\0ae347a9076db27075e06a63f2123186\SMSvcHost.ni.exe
+ 2012-05-09 23:32 . 2012-05-09 23:32 142848 c:\windows\assembly\NativeImages_v4.0.30319_32\SMDiagnostics\9115e9f656b00fc4e46da91537ef1358\SMDiagnostics.ni.dll
+ 2012-05-09 22:33 . 2012-05-09 22:33 595968 c:\windows\assembly\NativeImages_v4.0.30319_32\PresentationFramewo#\ee6e30c355ec2ffab1525b42253f7aef\PresentationFramework.Aero.ni.dll
+ 2012-05-09 22:33 . 2012-05-09 22:33 387072 c:\windows\assembly\NativeImages_v4.0.30319_32\PresentationFramewo#\c0f724e8231a71eb4d062d4f5233ff7f\PresentationFramework.Royale.ni.dll
+ 2012-05-09 22:33 . 2012-05-09 22:33 309760 c:\windows\assembly\NativeImages_v4.0.30319_32\PresentationFramewo#\45d2307fb0898a18dec5a04ff9f8b85c\PresentationFramework.Classic.ni.dll
+ 2012-05-09 22:33 . 2012-05-09 22:33 755712 c:\windows\assembly\NativeImages_v4.0.30319_32\PresentationFramewo#\190e1740c9b998105a47ec31df0b6f11\PresentationFramework.Luna.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 303104 c:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.VisualBas#\93ed50e3d549aced91ec7d2730f7d982\Microsoft.VisualBasic.Compatibility.Data.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 418816 c:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.Transacti#\10d7bd563bd71306375c6887ddd9de46\Microsoft.Transactions.Bridge.Dtc.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 194048 c:\windows\assembly\NativeImages_v4.0.30319_32\CustomMarshalers\f11d5fea7ded12068e8cdb8b2f1bdbd9\CustomMarshalers.ni.dll
+ 2012-05-09 22:45 . 2012-05-09 22:45 321536 c:\windows\assembly\NativeImages_v2.0.50727_32\WsatConfig\ac4fc3032c19946f9b2729468888206d\WsatConfig.ni.exe
+ 2012-06-14 11:34 . 2012-06-14 11:34 240128 c:\windows\assembly\NativeImages_v2.0.50727_32\WindowsFormsIntegra#\86e11a59f02b2dda27ec2e7cba351744\WindowsFormsIntegration.ni.dll
+ 2012-05-09 22:38 . 2012-05-09 22:38 187904 c:\windows\assembly\NativeImages_v2.0.50727_32\UIAutomationTypes\be27ab5913cec2b292a019c2a13ec701\UIAutomationTypes.ni.dll
+ 2012-05-09 22:38 . 2012-05-09 22:38 447488 c:\windows\assembly\NativeImages_v2.0.50727_32\UIAutomationClient\04e5e2be34a70ee7f4c87550238095a0\UIAutomationClient.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 400896 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Xml.Linq\1c13b08593e99d6f5bef49ae7939c78b\System.Xml.Linq.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 129536 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.Routing\698c2093d7ac57af935b399d1c0b1790\System.Web.Routing.ni.dll
+ 2012-05-09 23:31 . 2012-05-09 23:31 202240 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.RegularE#\6c7765c10516d375e9ddedad2dbab848\System.Web.RegularExpressions.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 859648 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.Extensio#\75248baf640115daeb0e580f1c5ff98b\System.Web.Extensions.Design.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 328704 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.Entity\40c3b61ac38613e2b4b0f196e86185eb\System.Web.Entity.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 301056 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.Entity.D#\39cc9a830f7f08fd9f397be452fd78b0\System.Web.Entity.Design.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 547328 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.DynamicD#\88b1fd4792e7b698b788594d8e5e3c09\System.Web.DynamicData.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 141312 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.Abstract#\6333d22a2ea347432d46c40d93194c68\System.Web.Abstractions.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 627200 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Transactions\41f6f6dd0c8427d4a8e6fd3915505a6b\System.Transactions.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 212992 c:\windows\assembly\NativeImages_v2.0.50727_32\System.ServiceProce#\8b84bb74d7724e147a642a1d5358feb7\System.ServiceProcess.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 679936 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Security\129b15861e200613ff78ae15581f9093\System.Security.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 311296 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Runtime.Seri#\a644ec04e18202b60f9d828bc207972b\System.Runtime.Serialization.Formatters.Soap.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 621056 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Net\4a9eb43005a041959ddc5c7e586ab746\System.Net.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 998400 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Management\9080c8e8e7b6dfb502c1328673d636f8\System.Management.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 330752 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Management.I#\3182a049ba953010dec649cf290a9e90\System.Management.Instrumentation.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 160256 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Management.A#\565bc89beb2fb404b1612721a9d56d3a\System.Management.Automation.resources.ni.dll
+ 2012-05-09 22:45 . 2012-05-09 22:45 381440 c:\windows\assembly\NativeImages_v2.0.50727_32\System.IO.Log\8991f21d4b3676bf6f779110db8d4ac9\System.IO.Log.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 212992 c:\windows\assembly\NativeImages_v2.0.50727_32\System.IdentityMode#\cd9c60a35d4958e94d2e3dd2f778e2e9\System.IdentityModel.Selectors.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 280064 c:\windows\assembly\NativeImages_v2.0.50727_32\System.EnterpriseSe#\29bce0113d611084a9329349e33528ac\System.EnterpriseServices.Wrapper.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 627712 c:\windows\assembly\NativeImages_v2.0.50727_32\System.EnterpriseSe#\29bce0113d611084a9329349e33528ac\System.EnterpriseServices.ni.dll
+ 2012-06-14 11:34 . 2012-06-14 11:34 208384 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Drawing.Desi#\96a3fc1f74a00b618b70bd1701600408\System.Drawing.Design.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 455680 c:\windows\assembly\NativeImages_v2.0.50727_32\System.DirectorySer#\ca484772955bc4db03b5dcb611c09423\System.DirectoryServices.Protocols.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 881152 c:\windows\assembly\NativeImages_v2.0.50727_32\System.DirectorySer#\8ba5e68dddfd3279a8469d39eded48f3\System.DirectoryServices.AccountManagement.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 354816 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Data.Service#\a0109fce606a3110a5e7f9a4773f517e\System.Data.Services.Design.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 939008 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Data.Service#\3a68d0441f509ffa6f8f0fb9cfcc5780\System.Data.Services.Client.ni.dll
+ 2012-05-09 23:29 . 2012-05-09 23:29 756736 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Data.Entity.#\04440b3dd5d822da4973a525ee04b05d\System.Data.Entity.Design.ni.dll
+ 2012-05-09 23:29 . 2012-05-09 23:29 135680 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Data.DataSet#\7bbb5d9e3b161b4d4b968e590442d3ae\System.Data.DataSetExtensions.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 971264 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Configuration\3d5b7368bde0f65aa15d9f46b498cc89\System.Configuration.ni.dll
+ 2012-06-14 06:12 . 2012-06-14 06:12 141312 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Configuratio#\badd66e1d2b8416e9bb868ad059203c6\System.Configuration.Install.ni.dll
+ 2012-05-09 23:29 . 2012-05-09 23:29 634368 c:\windows\assembly\NativeImages_v2.0.50727_32\System.AddIn\931a2bece4668863db4f852401c828cf\System.AddIn.ni.dll
+ 2012-05-09 22:45 . 2012-05-09 22:45 366080 c:\windows\assembly\NativeImages_v2.0.50727_32\SMSvcHost\6762f1ee780fa9c0b4ef66b285c64844\SMSvcHost.ni.exe
+ 2012-05-09 22:45 . 2012-05-09 22:45 256000 c:\windows\assembly\NativeImages_v2.0.50727_32\SMDiagnostics\660c4d6dd69ef22bc05587e1998cd135\SMDiagnostics.ni.dll
+ 2012-05-09 22:45 . 2012-05-09 22:45 320512 c:\windows\assembly\NativeImages_v2.0.50727_32\ServiceModelReg\47ed5bc9f42ea0054ce9acfde5e640b8\ServiceModelReg.ni.exe
+ 2012-05-09 22:37 . 2012-05-09 22:37 258048 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationFramewo#\a4706b850df9a3483f2fc439b6abe616\PresentationFramework.Royale.ni.dll
+ 2012-05-09 22:37 . 2012-05-09 22:37 539648 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationFramewo#\8b873631a0855fb6aa0ad25f1d9de7fe\PresentationFramework.Luna.ni.dll
+ 2012-05-09 22:37 . 2012-05-09 22:37 224768 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationFramewo#\7416fe825e6e49a87fa8ff60c8971813\PresentationFramework.Classic.ni.dll
+ 2012-05-09 22:37 . 2012-05-09 22:37 368128 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationFramewo#\186c27fbd7b38b5551889274f6fa2ccd\PresentationFramework.Aero.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 133632 c:\windows\assembly\NativeImages_v2.0.50727_32\MSBuild\5a121969a115d11b6256eb960c145686\MSBuild.ni.exe
+ 2012-05-09 22:45 . 2012-05-09 22:45 386560 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Transacti#\97c613d3899b320a6765793bdf490272\Microsoft.Transactions.Bridge.Dtc.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 492032 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.PowerShel#\d4375675fc5879a48c22dc8d7c80e841\Microsoft.PowerShell.ConsoleHost.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 148480 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.PowerShel#\937d2550dddbd2e5995ec8f93083f357\Microsoft.PowerShell.Security.ni.dll
+ 2012-06-14 12:08 . 2012-06-14 12:08 968192 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.PowerShel#\6ae804fdcf9ea4c42f5cabe3b183dd5d\Microsoft.PowerShell.Commands.Utility.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 433664 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.PowerShel#\15b7846d6acc551a7afdf5cc3de7547b\Microsoft.PowerShell.Commands.Management.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 175104 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Uti#\dec22fb7d6b8929a41380e5359741a07\Microsoft.Build.Utilities.v3.5.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 144384 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Uti#\1009b31c86a1b798fffa9e0127cec29c\Microsoft.Build.Utilities.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 839680 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Eng#\21d88631ef629715d3eecdd08e62e0b8\Microsoft.Build.Engine.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 222720 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Con#\a0f38c6478cca8297fb160291346c1c9\Microsoft.Build.Conversion.v3.5.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 220672 c:\windows\assembly\NativeImages_v2.0.50727_32\CustomMarshalers\bb26dd100d656605c576881a1a823667\CustomMarshalers.ni.dll
+ 2012-05-09 22:45 . 2012-05-09 22:45 410112 c:\windows\assembly\NativeImages_v2.0.50727_32\ComSvcConfig\9869c02d18825fdd32e64135a3e7246b\ComSvcConfig.ni.exe
+ 2012-06-14 12:08 . 2012-06-14 12:08 842240 c:\windows\assembly\NativeImages_v2.0.50727_32\AspNetMMCExt\c0045c1c7c29c7e7cc7bd60001b729a7\AspNetMMCExt.ni.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 839680 c:\windows\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 839680 c:\windows\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 835584 c:\windows\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 835584 c:\windows\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 114688 c:\windows\assembly\GAC_MSIL\System.ServiceProcess\2.0.0.0__b03f5f7f11d50a3a\System.ServiceProcess.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 114688 c:\windows\assembly\GAC_MSIL\System.ServiceProcess\2.0.0.0__b03f5f7f11d50a3a\System.ServiceProcess.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 258048 c:\windows\assembly\GAC_MSIL\System.Security\2.0.0.0__b03f5f7f11d50a3a\System.Security.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 258048 c:\windows\assembly\GAC_MSIL\System.Security\2.0.0.0__b03f5f7f11d50a3a\System.Security.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 131072 c:\windows\assembly\GAC_MSIL\System.Runtime.Serialization.Formatters.Soap\2.0.0.0__b03f5f7f11d50a3a\System.Runtime.Serialization.Formatters.Soap.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 131072 c:\windows\assembly\GAC_MSIL\System.Runtime.Serialization.Formatters.Soap\2.0.0.0__b03f5f7f11d50a3a\System.Runtime.Serialization.Formatters.Soap.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 303104 c:\windows\assembly\GAC_MSIL\System.Runtime.Remoting\2.0.0.0__b77a5c561934e089\System.Runtime.Remoting.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 303104 c:\windows\assembly\GAC_MSIL\System.Runtime.Remoting\2.0.0.0__b77a5c561934e089\System.Runtime.Remoting.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 258048 c:\windows\assembly\GAC_MSIL\System.Messaging\2.0.0.0__b03f5f7f11d50a3a\System.Messaging.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 258048 c:\windows\assembly\GAC_MSIL\System.Messaging\2.0.0.0__b03f5f7f11d50a3a\System.Messaging.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 372736 c:\windows\assembly\GAC_MSIL\System.Management\2.0.0.0__b03f5f7f11d50a3a\System.Management.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 372736 c:\windows\assembly\GAC_MSIL\System.Management\2.0.0.0__b03f5f7f11d50a3a\System.Management.dll
+ 2012-03-07 05:25 . 2012-03-07 05:25 163840 c:\windows\assembly\GAC_MSIL\System.Management.Automation.resources\1.0.0.0_en_31bf3856ad364e35\System.Management.Automation.resources.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 630784 c:\windows\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 401408 c:\windows\assembly\GAC_MSIL\System.DirectoryServices\2.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 401408 c:\windows\assembly\GAC_MSIL\System.DirectoryServices\2.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 188416 c:\windows\assembly\GAC_MSIL\System.DirectoryServices.Protocols\2.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.Protocols.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 188416 c:\windows\assembly\GAC_MSIL\System.DirectoryServices.Protocols\2.0.0.0__b03f5f7f11d50a3a\System.DirectoryServices.Protocols.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 970752 c:\windows\assembly\GAC_MSIL\System.Deployment\2.0.0.0__b03f5f7f11d50a3a\System.Deployment.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 970752 c:\windows\assembly\GAC_MSIL\System.Deployment\2.0.0.0__b03f5f7f11d50a3a\System.Deployment.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 745472 c:\windows\assembly\GAC_MSIL\System.Data.SqlXml\2.0.0.0__b77a5c561934e089\System.Data.SqlXml.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 745472 c:\windows\assembly\GAC_MSIL\System.Data.SqlXml\2.0.0.0__b77a5c561934e089\System.Data.SqlXml.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 425984 c:\windows\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.configuration.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 425984 c:\windows\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.configuration.dll
- 2009-08-21 22:29 . 2009-08-21 22:29 163840 c:\windows\assembly\GAC_MSIL\System.AddIn\3.5.0.0__b77a5c561934e089\System.AddIn.dll
+ 2012-05-09 22:44 . 2012-05-09 22:44 163840 c:\windows\assembly\GAC_MSIL\System.AddIn\3.5.0.0__b77a5c561934e089\System.AddIn.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 110592 c:\windows\assembly\GAC_MSIL\sysglobl\2.0.0.0__b03f5f7f11d50a3a\sysglobl.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 110592 c:\windows\assembly\GAC_MSIL\sysglobl\2.0.0.0__b03f5f7f11d50a3a\sysglobl.dll
+ 2012-05-09 22:29 . 2012-05-09 22:29 532480 c:\windows\assembly\GAC_MSIL\ReachFramework\3.0.0.0__31bf3856ad364e35\ReachFramework.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 659456 c:\windows\assembly\GAC_MSIL\Microsoft.VisualBasic\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 659456 c:\windows\assembly\GAC_MSIL\Microsoft.VisualBasic\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 372736 c:\windows\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 372736 c:\windows\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 110592 c:\windows\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility.Data\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.Data.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 110592 c:\windows\assembly\GAC_MSIL\Microsoft.VisualBasic.Compatibility.Data\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Compatibility.Data.dll
+ 2012-03-07 05:25 . 2012-03-07 05:25 200704 c:\windows\assembly\GAC_MSIL\Microsoft.PowerShell.ConsoleHost\1.0.0.0__31bf3856ad364e35\Microsoft.PowerShell.ConsoleHost.dll
+ 2012-03-07 05:25 . 2012-03-07 05:25 294912 c:\windows\assembly\GAC_MSIL\Microsoft.PowerShell.Commands.Utility\1.0.0.0__31bf3856ad364e35\Microsoft.PowerShell.Commands.Utility.dll
+ 2012-03-07 05:25 . 2012-03-07 05:25 139264 c:\windows\assembly\GAC_MSIL\Microsoft.PowerShell.Commands.Management\1.0.0.0__31bf3856ad364e35\Microsoft.PowerShell.Commands.Management.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 749568 c:\windows\assembly\GAC_MSIL\Microsoft.JScript\8.0.0.0__b03f5f7f11d50a3a\Microsoft.JScript.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 749568 c:\windows\assembly\GAC_MSIL\Microsoft.JScript\8.0.0.0__b03f5f7f11d50a3a\Microsoft.JScript.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 655360 c:\windows\assembly\GAC_MSIL\Microsoft.Build.Tasks\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Tasks.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 655360 c:\windows\assembly\GAC_MSIL\Microsoft.Build.Tasks\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Tasks.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 348160 c:\windows\assembly\GAC_MSIL\Microsoft.Build.Engine\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Engine.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 348160 c:\windows\assembly\GAC_MSIL\Microsoft.Build.Engine\2.0.0.0__b03f5f7f11d50a3a\Microsoft.Build.Engine.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 507904 c:\windows\assembly\GAC_MSIL\AspNetMMCExt\2.0.0.0__b03f5f7f11d50a3a\AspNetMMCExt.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 507904 c:\windows\assembly\GAC_MSIL\AspNetMMCExt\2.0.0.0__b03f5f7f11d50a3a\AspNetMMCExt.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 261632 c:\windows\assembly\GAC_32\System.Transactions\2.0.0.0__b77a5c561934e089\System.Transactions.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 261632 c:\windows\assembly\GAC_32\System.Transactions\2.0.0.0__b77a5c561934e089\System.Transactions.dll
+ 2012-05-09 22:29 . 2012-05-09 22:29 368640 c:\windows\assembly\GAC_32\System.Printing\3.0.0.0__31bf3856ad364e35\System.Printing.dll
- 2009-08-21 22:29 . 2009-08-21 22:29 368640 c:\windows\assembly\GAC_32\System.Printing\3.0.0.0__31bf3856ad364e35\System.Printing.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 113664 c:\windows\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 113664 c:\windows\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 258048 c:\windows\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 258048 c:\windows\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 486400 c:\windows\assembly\GAC_32\System.Data.OracleClient\2.0.0.0__b77a5c561934e089\System.Data.OracleClient.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 486400 c:\windows\assembly\GAC_32\System.Data.OracleClient\2.0.0.0__b77a5c561934e089\System.Data.OracleClient.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 573440 c:\windows\assembly\GAC\System.Web.Services\1.0.5000.0__b03f5f7f11d50a3a\System.Web.Services.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 819200 c:\windows\assembly\GAC\System.Web.Mobile\1.0.5000.0__b03f5f7f11d50a3a\System.Web.Mobile.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 126976 c:\windows\assembly\GAC\System.ServiceProcess\1.0.5000.0__b03f5f7f11d50a3a\System.ServiceProcess.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 131072 c:\windows\assembly\GAC\System.Runtime.Serialization.Formatters.Soap\1.0.5000.0__b03f5f7f11d50a3a\System.Runtime.Serialization.Formatters.Soap.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 323584 c:\windows\assembly\GAC\System.Runtime.Remoting\1.0.5000.0__b77a5c561934e089\System.Runtime.Remoting.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 241664 c:\windows\assembly\GAC\System.Messaging\1.0.5000.0__b03f5f7f11d50a3a\System.Messaging.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 372736 c:\windows\assembly\GAC\System.Management\1.0.5000.0__b03f5f7f11d50a3a\System.Management.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 241664 c:\windows\assembly\GAC\System.EnterpriseServices\1.0.5000.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll
+ 2012-06-14 06:08 . 2012-06-14 06:08 471040 c:\windows\assembly\GAC\System.Drawing\1.0.5000.0__b03f5f7f11d50a3a\System.Drawing.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 303104 c:\windows\assembly\GAC\System.Data.OracleClient\1.0.5000.0__b77a5c561934e089\System.Data.OracleClient.dll
+ 2011-07-26 11:57 . 2011-07-26 11:57 423784 c:\windows\assembly\GAC\office\12.0.0.0__71e9bce111e9429c\OFFICE.DLL
- 2009-10-08 12:28 . 2009-10-08 12:28 423784 c:\windows\assembly\GAC\office\12.0.0.0__71e9bce111e9429c\OFFICE.DLL
+ 2011-07-26 01:27 . 2011-07-26 01:27 229376 c:\windows\assembly\GAC\mscomctl\10.0.4504.0__31bf3856ad364e35\MSCOMCTL.DLL
- 2009-10-01 01:41 . 2009-10-01 01:41 229376 c:\windows\assembly\GAC\mscomctl\10.0.4504.0__31bf3856ad364e35\MSCOMCTL.DLL
+ 2012-03-27 05:39 . 2012-03-27 05:39 299008 c:\windows\assembly\GAC\Microsoft.VisualBasic\7.0.5000.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll
+ 2011-07-26 01:27 . 2011-07-26 01:27 371496 c:\windows\assembly\GAC\Microsoft.Vbe.Interop.Forms\11.0.0.0__71e9bce111e9429c\Microsoft.Vbe.Interop.Forms.dll
- 2009-10-08 12:29 . 2009-10-08 12:29 870256 c:\windows\assembly\GAC\Microsoft.Office.Interop.Word\12.0.0.0__71e9bce111e9429c\Microsoft.Office.Interop.Word.dll
+ 2012-03-29 04:52 . 2012-03-29 04:52 870256 c:\windows\assembly\GAC\Microsoft.Office.Interop.Word\12.0.0.0__71e9bce111e9429c\Microsoft.Office.Interop.Word.dll
+ 2011-12-15 05:51 . 2011-12-15 05:51 350080 c:\windows\assembly\GAC\Microsoft.Office.Interop.PowerPoint\12.0.0.0__71e9bce111e9429c\Microsoft.Office.Interop.PowerPoint.dll
+ 2012-03-29 04:52 . 2012-03-29 04:52 149368 c:\windows\assembly\GAC\Microsoft.Office.Interop.Graph\12.0.0.0__71e9bce111e9429c\Microsoft.Office.Interop.Graph.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 720896 c:\windows\assembly\GAC\Microsoft.JScript\7.0.5000.0__b03f5f7f11d50a3a\Microsoft.JScript.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 223232 c:\windows\assembly\GAC\Microsoft.DirectX\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 223232 c:\windows\assembly\GAC\Microsoft.DirectX\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 178176 c:\windows\assembly\GAC\Microsoft.DirectX.DirectSound\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectSound.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 178176 c:\windows\assembly\GAC\Microsoft.DirectX.DirectSound\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectSound.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 364544 c:\windows\assembly\GAC\Microsoft.DirectX.DirectPlay\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectPlay.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 364544 c:\windows\assembly\GAC\Microsoft.DirectX.DirectPlay\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectPlay.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 159232 c:\windows\assembly\GAC\Microsoft.DirectX.DirectInput\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectInput.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 159232 c:\windows\assembly\GAC\Microsoft.DirectX.DirectInput\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectInput.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 145920 c:\windows\assembly\GAC\Microsoft.DirectX.DirectDraw\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectDraw.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 145920 c:\windows\assembly\GAC\Microsoft.DirectX.DirectDraw\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.DirectDraw.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 578560 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2911.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 578560 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2911.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 578560 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2910.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 578560 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2910.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 577536 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2909.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 577536 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2909.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 577536 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2908.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 577536 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2908.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 577024 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2907.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 577024 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2907.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 576000 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2906.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 576000 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2906.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 567296 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2905.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 567296 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2905.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 563712 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2904.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 563712 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2904.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 473600 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3D\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Direct3D.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 473600 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3D\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Direct3D.dll
+ 2011-07-26 01:27 . 2011-07-26 01:27 110592 c:\windows\assembly\GAC\ADODB\7.0.3300.0__b03f5f7f11d50a3a\adodb.dll
- 2009-10-01 01:41 . 2009-10-01 01:41 110592 c:\windows\assembly\GAC\ADODB\7.0.3300.0__b03f5f7f11d50a3a\adodb.dll
- 2009-04-19 17:48 . 2006-07-31 15:19 315392 c:\windows\alcupd.exe
+ 2009-04-19 17:48 . 2006-07-31 16:19 315392 c:\windows\alcupd.exe
- 2009-04-19 17:48 . 2006-07-31 15:27 217088 c:\windows\Alcrmv.exe
+ 2009-04-19 17:48 . 2006-07-31 16:27 217088 c:\windows\Alcrmv.exe
+ 2012-07-28 20:17 . 2012-07-28 20:17 125719 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla50.dll
+ 2012-07-28 20:17 . 2012-07-28 20:17 110799 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla49.dll
+ 2012-07-28 20:17 . 2012-07-28 20:17 116956 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla48.dll
+ 2012-07-28 20:17 . 2012-07-28 20:17 110936 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla47.dll
+ 2012-07-28 20:17 . 2012-07-28 20:17 110797 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla46.dll
+ 2012-07-28 20:17 . 2012-07-28 20:17 110500 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla44.dll
+ 2012-07-28 20:17 . 2012-07-28 20:17 111260 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla43.dll
+ 2012-07-28 20:17 . 2012-07-28 20:17 111269 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla42.dll
+ 2012-07-28 20:17 . 2012-07-28 20:17 111476 c:\windows\871DF2BE41D24334AC33839AF16FC8FE.TMP\WiseCustomCalla41.exe
+ 2012-06-29 05:12 . 2008-03-27 20:27 503008 c:\windows\$NtUninstallWdf01009$\wdf01000.sys
+ 2012-06-29 05:12 . 2008-11-07 22:55 382496 c:\windows\$NtUninstallWdf01009$\spuninst\updspapi.dll
+ 2012-06-29 05:12 . 2008-11-07 22:55 231456 c:\windows\$NtUninstallWdf01009$\spuninst\spuninst.exe
+ 2010-09-15 06:32 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB982802\update\updspapi.dll
+ 2010-09-15 06:32 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB982802\update\update.exe
+ 2010-09-15 06:32 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB982802\spuninst.exe
+ 2010-07-23 06:13 . 2010-07-23 06:13 590848 c:\windows\$hf_mig$\KB982802\SP3QFE\rpcrt4.dll
+ 2010-08-11 12:07 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB982665\update\updspapi.dll
+ 2010-08-11 12:07 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB982665\update\update.exe
+ 2010-08-11 12:07 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB982665\spuninst.exe
+ 2010-08-12 03:44 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB982214\update\updspapi.dll
+ 2010-08-12 03:44 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB982214\update\update.exe
+ 2010-08-12 03:44 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB982214\spuninst.exe
+ 2010-08-10 23:37 . 2010-06-21 14:18 354304 c:\windows\$hf_mig$\KB982214\SP3QFE\srv.sys
+ 2010-10-14 07:07 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB982132\update\updspapi.dll
+ 2010-10-14 07:07 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB982132\update\update.exe
+ 2010-10-14 07:07 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB982132\spuninst.exe
+ 2010-08-27 08:01 . 2010-08-27 08:01 119808 c:\windows\$hf_mig$\KB982132\SP3QFE\t2embed.dll
+ 2010-08-11 12:08 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB981997\update\updspapi.dll
+ 2010-08-11 12:08 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB981997\update\update.exe
+ 2010-08-11 12:08 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB981997\spuninst.exe
+ 2010-10-14 07:02 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB981957\update\updspapi.dll
+ 2010-10-14 07:02 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB981957\update\update.exe
+ 2010-10-14 07:02 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB981957\spuninst.exe
+ 2010-08-12 03:42 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB981852\update\updspapi.dll
+ 2010-08-12 03:42 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB981852\update\update.exe
+ 2010-08-12 03:42 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB981852\spuninst.exe
+ 2010-09-15 06:31 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB981322\update\updspapi.dll
+ 2010-09-15 06:31 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB981322\update\update.exe
+ 2010-09-15 06:31 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB981322\spuninst.exe
+ 2010-04-16 15:29 . 2010-04-16 15:29 406016 c:\windows\$hf_mig$\KB981322\SP3QFE\usp10.dll
+ 2010-08-12 03:38 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB980436\update\updspapi.dll
+ 2010-08-12 03:38 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB980436\update\update.exe
+ 2010-08-12 03:38 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB980436\spuninst.exe
+ 2010-06-30 12:23 . 2010-06-30 12:23 149504 c:\windows\$hf_mig$\KB980436\SP3QFE\schannel.dll
+ 2010-10-14 07:06 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB979687\update\updspapi.dll
+ 2010-10-14 07:06 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB979687\update\update.exe
+ 2010-10-14 07:06 . 2009-05-26 09:01 231288 c:\windows\$hf_mig$\KB979687\spuninst.exe
+ 2010-07-12 13:02 . 2010-07-12 13:02 218112 c:\windows\$hf_mig$\KB979687\SP3QFE\wordpad.exe
+ 2011-02-24 08:00 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB971029\update\updspapi.dll
+ 2011-02-24 08:00 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB971029\update\update.exe
+ 2011-02-24 08:00 . 2008-07-08 13:02 231288 c:\windows\$hf_mig$\KB971029\spuninst.exe
+ 2009-07-27 22:13 . 2009-07-27 22:13 135168 c:\windows\$hf_mig$\KB971029\SP3QFE\shsvcs.dll
+ 2012-07-11 12:26 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2719985\update\updspapi.dll
+ 2012-07-11 12:26 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2719985\update\update.exe
+ 2012-07-11 12:26 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2719985\spuninst.exe
+ 2012-06-05 22:55 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2718704\update\updspapi.dll
+ 2012-06-05 22:55 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2718704\update\update.exe
+ 2012-06-05 22:55 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2718704\spuninst.exe
+ 2012-05-31 13:19 . 2012-05-31 13:19 599552 c:\windows\$hf_mig$\KB2718704\SP3QFE\crypt32.dll
+ 2012-07-11 12:28 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2718523\update\updspapi.dll
+ 2012-07-11 12:28 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2718523\update\update.exe
+ 2012-07-11 12:28 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2718523\spuninst.exe
+ 2012-08-15 05:53 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2712808\update\updspapi.dll
+ 2012-08-15 05:53 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2712808\update\update.exe
+ 2012-08-15 05:53 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2712808\spuninst.exe
+ 2012-05-14 09:21 . 2012-05-14 09:21 346112 c:\windows\$hf_mig$\KB2712808\SP3QFE\localspl.dll
+ 2012-06-14 06:05 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2709162\update\updspapi.dll
+ 2012-06-14 06:05 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2709162\update\update.exe
+ 2012-06-14 06:05 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2709162\spuninst.exe
+ 2012-06-14 06:20 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2707511\update\updspapi.dll
+ 2012-06-14 06:20 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2707511\update\update.exe
+ 2012-06-14 06:20 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2707511\spuninst.exe
+ 2012-08-15 05:47 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2705219\update\updspapi.dll
+ 2012-08-15 05:47 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2705219\update\update.exe
+ 2012-08-15 05:47 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2705219\spuninst.exe
+ 2012-07-06 13:58 . 2012-07-06 13:58 339968 c:\windows\$hf_mig$\KB2705219\SP3QFE\netapi32.dll
+ 2012-06-14 06:08 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2699988-IE8\update\updspapi.dll
+ 2012-06-14 06:08 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2699988-IE8\update\update.exe
+ 2012-06-14 06:08 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2699988-IE8\spuninst.exe
+ 2012-06-13 22:26 . 2012-05-16 15:06 920064 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\wininet.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 105984 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\url.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 206848 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\occache.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 611840 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\mstime.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 630272 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\msfeeds.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 522240 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\jsdbgui.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 247808 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\ieproxy.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 184320 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\iepeers.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 743424 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\iedvtool.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 387584 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\iedkcs32.dll
+ 2012-06-13 22:26 . 2012-05-11 12:13 174080 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\ie4uinit.exe
+ 2012-07-11 12:20 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2698365\update\updspapi.dll
+ 2012-07-11 12:20 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2698365\update\update.exe
+ 2012-07-11 12:20 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2698365\spuninst.exe
+ 2012-07-11 04:37 . 2012-05-28 18:15 102400 c:\windows\$hf_mig$\KB2698365\SP3QFE\msjro.dll
+ 2012-07-11 04:37 . 2012-05-28 18:15 200704 c:\windows\$hf_mig$\KB2698365\SP3QFE\msadox.dll
+ 2012-07-11 04:37 . 2012-05-28 18:15 180224 c:\windows\$hf_mig$\KB2698365\SP3QFE\msadomd.dll
+ 2012-07-11 04:37 . 2012-05-28 18:15 565248 c:\windows\$hf_mig$\KB2698365\SP3QFE\msado15.dll
+ 2012-07-11 04:37 . 2012-05-28 18:15 143360 c:\windows\$hf_mig$\KB2698365\SP3QFE\msadco.dll
+ 2012-05-09 22:30 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2695962\update\updspapi.dll
+ 2012-05-09 22:30 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2695962\update\update.exe
+ 2012-05-09 22:30 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2695962\spuninst.exe
+ 2012-07-11 12:28 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2691442\update\updspapi.dll
+ 2012-07-11 12:28 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2691442\update\update.exe
+ 2012-07-11 12:28 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2691442\spuninst.exe
+ 2012-05-09 22:31 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2686509\update\updspapi.dll
+ 2012-05-09 22:31 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2686509\update\update.exe
+ 2012-05-09 22:31 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2686509\spuninst.exe
+ 2012-06-14 06:08 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2685939\update\updspapi.dll
+ 2012-06-14 06:08 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2685939\update\update.exe
+ 2012-06-14 06:08 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2685939\spuninst.exe
+ 2012-06-13 22:26 . 2012-05-02 13:45 139656 c:\windows\$hf_mig$\KB2685939\SP3QFE\rdpwd.sys
+ 2012-05-09 22:23 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2676562\update\updspapi.dll
+ 2012-05-09 22:23 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2676562\update\update.exe
+ 2012-05-09 22:23 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2676562\spuninst.exe
+ 2012-04-11 12:55 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2675157-IE8\update\updspapi.dll
+ 2012-04-11 12:54 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2675157-IE8\update\update.exe
+ 2012-04-11 12:54 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2675157-IE8\spuninst.exe
+ 2012-04-11 07:33 . 2012-03-01 10:58 919552 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\wininet.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 105984 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\url.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 206848 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\occache.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 611840 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\mstime.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 602112 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\msfeeds.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 247808 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\ieproxy.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 184320 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\iepeers.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 743424 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\iedvtool.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 387584 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\iedkcs32.dll
+ 2012-04-11 07:33 . 2012-02-29 12:30 174080 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\ie4uinit.exe
+ 2012-02-16 08:00 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2661637\update\updspapi.dll
+ 2012-02-16 08:00 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2661637\update\update.exe
+ 2012-02-16 08:00 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2661637\spuninst.exe
+ 2012-02-16 08:06 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2660465\update\updspapi.dll
+ 2012-02-16 08:06 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2660465\update\update.exe
+ 2012-02-16 08:06 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2660465\spuninst.exe
+ 2012-07-11 12:27 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2655992\update\updspapi.dll
+ 2012-07-11 12:27 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2655992\update\update.exe
+ 2012-07-11 12:27 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2655992\spuninst.exe
+ 2012-06-04 04:31 . 2012-06-04 04:31 153088 c:\windows\$hf_mig$\KB2655992\SP3QFE\schannel.dll
+ 2012-04-11 12:46 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2653956\update\updspapi.dll
+ 2012-04-11 12:46 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2653956\update\update.exe
+ 2012-04-11 12:46 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2653956\spuninst.exe
+ 2012-02-29 14:08 . 2012-02-29 14:08 178176 c:\windows\$hf_mig$\KB2653956\SP3QFE\wintrust.dll
+ 2012-02-29 14:08 . 2012-02-29 14:08 148480 c:\windows\$hf_mig$\KB2653956\SP3QFE\imagehlp.dll
+ 2012-03-14 07:01 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2647518\update\updspapi.dll
+ 2012-03-14 07:01 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2647518\update\update.exe
+ 2012-03-14 07:01 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2647518\spuninst.exe
+ 2012-02-16 08:05 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2647516-IE8\update\updspapi.dll
+ 2012-02-16 08:05 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2647516-IE8\update\update.exe
+ 2012-02-16 08:05 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2647516-IE8\spuninst.exe
+ 2012-02-16 07:52 . 2011-12-17 19:45 919552 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\wininet.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 105984 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\url.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 206848 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\occache.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 611840 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\mstime.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 602112 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\msfeeds.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 247808 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\ieproxy.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 184320 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\iepeers.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 743424 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\iedvtool.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 387584 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\iedkcs32.dll
+ 2012-02-16 07:52 . 2011-12-16 12:33 174080 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\ie4uinit.exe
+ 2012-01-12 08:04 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2646524\update\updspapi.dll
+ 2012-01-12 08:04 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2646524\update\update.exe
+ 2012-01-12 08:04 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2646524\spuninst.exe
+ 2011-11-25 21:56 . 2011-11-25 21:56 293376 c:\windows\$hf_mig$\KB2646524\SP3QFE\winsrv.dll
+ 2011-11-11 07:21 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2641690\update\updspapi.dll
+ 2011-11-11 07:21 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2641690\update\update.exe
+ 2011-11-11 07:21 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2641690\spuninst.exe
+ 2011-09-28 07:05 . 2011-09-28 07:05 599552 c:\windows\$hf_mig$\KB2641690\SP3QFE\crypt32.dll
+ 2012-03-14 07:04 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2641653\update\updspapi.dll
+ 2012-03-14 07:04 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2641653\update\update.exe
+ 2012-03-14 07:04 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2641653\spuninst.exe
+ 2011-12-15 05:51 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2639417\update\updspapi.dll
+ 2011-12-15 05:51 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2639417\update\update.exe
+ 2011-12-15 05:51 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2639417\spuninst.exe
+ 2011-12-15 05:44 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2633171\update\updspapi.dll
+ 2011-12-15 05:44 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2633171\update\update.exe
+ 2011-12-15 05:44 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2633171\spuninst.exe
+ 2012-01-12 08:04 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2631813\update\updspapi.dll
+ 2012-01-12 08:04 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2631813\update\update.exe
+ 2012-01-12 08:04 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2631813\spuninst.exe
+ 2011-11-03 15:27 . 2011-11-03 15:27 386048 c:\windows\$hf_mig$\KB2631813\SP3QFE\qdvd.dll
+ 2011-12-15 05:51 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2624667\update\updspapi.dll
+ 2011-12-15 05:51 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2624667\update\update.exe
+ 2011-12-15 05:51 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2624667\spuninst.exe
+ 2012-03-14 07:01 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2621440\update\updspapi.dll
+ 2012-03-14 07:01 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2621440\update\update.exe
+ 2012-03-14 07:01 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2621440\spuninst.exe
+ 2012-03-14 00:55 . 2012-01-09 16:19 139784 c:\windows\$hf_mig$\KB2621440\SP3QFE\rdpwd.sys
+ 2011-12-15 05:44 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2620712\update\updspapi.dll
+ 2011-12-15 05:44 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2620712\update\update.exe
+ 2011-12-15 05:44 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2620712\spuninst.exe
+ 2011-12-15 05:45 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2619339\update\updspapi.dll
+ 2011-12-15 05:45 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2619339\update\update.exe
+ 2011-12-15 05:45 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2619339\spuninst.exe
+ 2011-10-18 11:12 . 2011-10-18 11:12 186880 c:\windows\$hf_mig$\KB2619339\SP3QFE\encdec.dll
+ 2011-12-15 05:44 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2618451\update\updspapi.dll
+ 2011-12-15 05:44 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2618451\update\update.exe
+ 2011-12-15 05:44 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2618451\spuninst.exe
+ 2011-12-15 05:50 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2618444-IE8\update\updspapi.dll
+ 2011-12-15 05:50 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2618444-IE8\update\update.exe
+ 2011-12-15 05:50 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2618444-IE8\spuninst.exe
+ 2011-12-15 03:59 . 2011-11-04 19:19 919552 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\wininet.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 105984 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\url.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 206848 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\occache.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 611840 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\mstime.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 602112 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\msfeeds.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 247808 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\ieproxy.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 184320 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\iepeers.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 743424 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\iedvtool.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 387584 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\iedkcs32.dll
+ 2011-12-15 03:59 . 2011-10-25 12:01 174080 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\ie4uinit.exe
+ 2011-09-15 12:48 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2616676\update\updspapi.dll
+ 2011-09-15 12:48 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2616676\update\update.exe
+ 2011-09-15 12:48 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2616676\spuninst.exe
+ 2011-09-09 09:11 . 2011-09-09 09:11 599552 c:\windows\$hf_mig$\KB2616676\SP3QFE\crypt32.dll
+ 2011-09-07 12:27 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2607712\update\updspapi.dll
+ 2011-09-07 12:27 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2607712\update\update.exe
+ 2011-09-07 12:27 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2607712\spuninst.exe
+ 2011-09-03 10:16 . 2011-09-03 10:16 599552 c:\windows\$hf_mig$\KB2607712\SP3QFE\crypt32.dll
+ 2012-01-12 08:01 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2603381\update\updspapi.dll
+ 2012-01-12 08:01 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2603381\update\update.exe
+ 2012-01-12 08:01 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2603381\spuninst.exe
+ 2012-01-12 08:01 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2598479\update\updspapi.dll
+ 2012-01-12 08:01 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2598479\update\update.exe
+ 2012-01-12 08:01 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2598479\spuninst.exe
+ 2011-10-14 14:45 . 2011-10-14 14:45 176128 c:\windows\$hf_mig$\KB2598479\SP3QFE\winmm.dll
+ 2011-10-12 11:49 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2592799\update\updspapi.dll
+ 2011-10-12 11:49 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2592799\update\update.exe
+ 2011-10-12 11:49 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2592799\spuninst.exe
+ 2011-10-11 23:17 . 2011-08-17 13:41 138496 c:\windows\$hf_mig$\KB2592799\SP3QFE\afd.sys
+ 2011-10-12 11:48 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2586448-IE8\update\updspapi.dll
+ 2011-10-12 11:48 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2586448-IE8\update\update.exe
+ 2011-10-12 11:48 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2586448-IE8\spuninst.exe
+ 2011-10-11 23:17 . 2011-08-22 23:47 919552 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\wininet.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 105984 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\url.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 206848 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\occache.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 611840 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\mstime.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 602112 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\msfeeds.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 247808 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\ieproxy.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 184320 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\iepeers.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 743424 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\iedvtool.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 387584 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\iedkcs32.dll
+ 2011-10-11 23:17 . 2011-08-22 11:52 174080 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\ie4uinit.exe
+ 2012-01-14 15:48 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2585542\update\updspapi.dll
+ 2012-01-14 15:48 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2585542\update\update.exe
+ 2012-01-14 15:48 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2585542\spuninst.exe
+ 2011-11-16 14:20 . 2011-11-16 14:20 354816 c:\windows\$hf_mig$\KB2585542\SP3QFE\winhttp.dll
+ 2011-11-16 14:20 . 2011-11-16 14:20 152064 c:\windows\$hf_mig$\KB2585542\SP3QFE\schannel.dll
+ 2012-01-12 08:00 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2584146\update\updspapi.dll
+ 2012-01-12 08:00 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2584146\update\update.exe
+ 2012-01-12 08:00 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2584146\spuninst.exe
+ 2011-09-15 12:43 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2570947\update\updspapi.dll
+ 2011-09-15 12:43 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2570947\update\update.exe
+ 2011-09-15 12:43 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2570947\spuninst.exe
+ 2011-08-11 12:10 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2570222\update\updspapi.dll
+ 2011-08-11 12:10 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2570222\update\update.exe
+ 2011-08-11 12:10 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2570222\spuninst.exe
+ 2011-08-10 13:56 . 2011-06-24 14:09 139656 c:\windows\$hf_mig$\KB2570222\SP3QFE\rdpwd.sys
+ 2011-08-11 12:11 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2567680\update\updspapi.dll
+ 2011-08-11 12:11 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2567680\update\update.exe
+ 2011-08-11 12:11 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2567680\spuninst.exe
+ 2011-06-20 17:43 . 2011-06-20 17:43 293376 c:\windows\$hf_mig$\KB2567680\SP3QFE\winsrv.dll
+ 2011-10-12 11:49 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2567053\update\updspapi.dll
+ 2011-10-12 11:49 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2567053\update\update.exe
+ 2011-10-12 11:49 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2567053\spuninst.exe
+ 2011-08-11 11:59 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2566454\update\updspapi.dll
+ 2011-08-11 11:59 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2566454\update\update.exe
+ 2011-08-11 11:59 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2566454\spuninst.exe
+ 2011-08-11 11:59 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2562937\update\updspapi.dll
+ 2011-08-11 11:59 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2562937\update\update.exe
+ 2011-08-11 11:59 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2562937\spuninst.exe
+ 2011-08-11 12:00 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2559049-IE8\update\updspapi.dll
+ 2011-08-11 12:00 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2559049-IE8\update\update.exe
+ 2011-08-11 12:00 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2559049-IE8\spuninst.exe
+ 2011-08-10 13:56 . 2011-06-23 18:33 919552 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\wininet.dll
+ 2011-08-10 13:56 . 2011-06-23 18:33 105984 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\url.dll
+ 2011-08-10 13:56 . 2011-06-23 18:33 206848 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\occache.dll
+ 2011-08-10 13:56 . 2011-06-23 18:33 611840 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\mstime.dll
+ 2011-08-10 13:56 . 2011-06-23 18:33 602112 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\msfeeds.dll
+ 2011-08-10 13:56 . 2011-06-23 18:33 247808 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\ieproxy.dll
+ 2011-08-10 13:56 . 2011-06-23 18:33 184320 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\iepeers.dll
+ 2011-08-10 13:56 . 2011-06-23 18:33 743424 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\iedvtool.dll
+ 2011-08-10 13:56 . 2011-06-23 18:33 387584 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\iedkcs32.dll
+ 2011-08-10 13:56 . 2011-06-23 12:19 173568 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\ie4uinit.exe
+ 2011-07-14 11:54 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2555917\update\updspapi.dll
+ 2011-07-14 11:54 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2555917\update\update.exe
+ 2011-07-14 11:54 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2555917\spuninst.exe
+ 2011-06-17 07:03 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2544893\update\updspapi.dll
+ 2011-06-17 07:03 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2544893\update\update.exe
+ 2011-06-17 07:03 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2544893\spuninst.exe
+ 2011-06-16 22:24 . 2011-05-02 15:30 692736 c:\windows\$hf_mig$\KB2544893\SP3QFE\inetcomm.dll
+ 2011-11-10 12:58 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2544893-v2\update\updspapi.dll
+ 2011-11-10 12:58 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2544893-v2\update\update.exe
+ 2011-11-10 12:58 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2544893-v2\spuninst.exe
+ 2011-10-10 14:21 . 2011-10-10 14:21 692736 c:\windows\$hf_mig$\KB2544893-v2\SP3QFE\inetcomm.dll
+ 2011-06-17 07:00 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2544521-IE8\update\updspapi.dll
+ 2011-06-17 07:00 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2544521-IE8\update\update.exe
+ 2011-06-17 07:00 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2544521-IE8\spuninst.exe
+ 2011-06-16 22:24 . 2011-04-30 02:59 758784 c:\windows\$hf_mig$\KB2544521-IE8\SP3QFE\vgx.dll
+ 2011-06-29 07:00 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2541763\update\updspapi.dll
+ 2011-06-29 07:00 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2541763\update\update.exe
+ 2011-06-29 07:00 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2541763\spuninst.exe
+ 2011-04-29 17:23 . 2011-04-29 17:23 151552 c:\windows\$hf_mig$\KB2541763\SP3QFE\schannel.dll
+ 2011-06-17 07:04 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2536276\update\updspapi.dll
+ 2011-06-17 07:04 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2536276\update\update.exe
+ 2011-06-17 07:04 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2536276\spuninst.exe
+ 2011-06-16 22:25 . 2011-04-29 16:47 457856 c:\windows\$hf_mig$\KB2536276\SP3QFE\mrxsmb.sys
+ 2011-08-11 12:10 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2536276-v2\update\updspapi.dll
+ 2011-08-11 12:10 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2536276-v2\update\update.exe
+ 2011-08-11 12:10 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2536276-v2\spuninst.exe
+ 2011-08-10 13:56 . 2011-07-15 13:29 457856 c:\windows\$hf_mig$\KB2536276-v2\SP3QFE\mrxsmb.sys
+ 2011-06-17 07:04 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2535512\update\updspapi.dll
+ 2011-06-17 07:04 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2535512\update\update.exe
+ 2011-06-17 07:04 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2535512\spuninst.exe
+ 2011-06-16 22:26 . 2011-04-21 13:52 105472 c:\windows\$hf_mig$\KB2535512\SP3QFE\mup.sys
+ 2011-06-17 07:03 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2530548-IE8\update\updspapi.dll
+ 2011-06-17 07:03 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2530548-IE8\update\update.exe
+ 2011-06-17 07:03 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2530548-IE8\spuninst.exe
+ 2011-06-16 22:25 . 2011-04-25 16:09 919552 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\wininet.dll
+ 2011-06-16 22:25 . 2011-04-25 16:09 206848 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\occache.dll
+ 2011-06-16 22:25 . 2011-04-25 16:09 611840 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\mstime.dll
+ 2011-06-16 22:25 . 2011-04-25 16:09 602112 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\msfeeds.dll
+ 2011-06-16 22:25 . 2011-04-25 16:09 247808 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\ieproxy.dll
+ 2011-06-16 22:25 . 2011-04-25 16:09 184320 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\iepeers.dll
+ 2011-06-16 22:25 . 2011-04-25 16:09 743424 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\iedvtool.dll
+ 2011-06-16 22:25 . 2011-04-25 16:09 387584 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\iedkcs32.dll
+ 2011-06-16 22:25 . 2011-04-25 11:37 173568 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\ie4uinit.exe
+ 2011-03-25 03:18 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2524375\update\updspapi.dll
+ 2011-03-25 03:18 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2524375\update\update.exe
+ 2011-03-25 03:18 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2524375\spuninst.exe
+ 2011-04-15 07:05 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2511455\update\updspapi.dll
+ 2011-04-15 07:05 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2511455\update\update.exe
+ 2011-04-15 07:05 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2511455\spuninst.exe
+ 2011-04-14 11:28 . 2011-02-17 13:19 457472 c:\windows\$hf_mig$\KB2511455\SP3QFE\mrxsmb.sys
+ 2011-04-15 07:01 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2510531-IE8\update\updspapi.dll
+ 2011-04-15 07:01 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2510531-IE8\update\update.exe
+ 2011-04-15 07:01 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2510531-IE8\spuninst.exe
+ 2011-04-14 11:28 . 2011-03-04 06:35 420864 c:\windows\$hf_mig$\KB2510531-IE8\SP3QFE\vbscript.dll
+ 2011-04-14 11:28 . 2011-03-04 06:35 726528 c:\windows\$hf_mig$\KB2510531-IE8\SP3QFE\jscript.dll
+ 2011-04-15 07:01 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2509553\update\updspapi.dll
+ 2011-04-15 07:01 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2509553\update\update.exe
+ 2011-04-15 07:01 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2509553\spuninst.exe
+ 2008-06-20 11:16 . 2008-06-20 11:16 225856 c:\windows\$hf_mig$\KB2509553\SP3QFE\tcpip6.sys
+ 2008-06-20 11:59 . 2008-06-20 11:59 361600 c:\windows\$hf_mig$\KB2509553\SP3QFE\tcpip.sys
+ 2008-06-20 17:43 . 2008-06-20 17:43 245248 c:\windows\$hf_mig$\KB2509553\SP3QFE\mswsock.dll
+ 2011-03-03 06:53 . 2011-03-03 06:53 149504 c:\windows\$hf_mig$\KB2509553\SP3QFE\dnsapi.dll
+ 2008-10-16 15:07 . 2008-10-16 15:07 138496 c:\windows\$hf_mig$\KB2509553\SP3QFE\afd.sys
+ 2011-04-15 07:05 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2508429\update\updspapi.dll
+ 2011-04-15 07:05 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2508429\update\update.exe
+ 2011-04-15 07:05 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2508429\spuninst.exe
+ 2011-02-17 13:19 . 2011-02-17 13:19 357888 c:\windows\$hf_mig$\KB2508429\SP3QFE\srv.sys
+ 2011-04-15 07:06 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2508272\update\updspapi.dll
+ 2011-04-15 07:06 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2508272\update\update.exe
+ 2011-04-15 07:06 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2508272\spuninst.exe
+ 2011-07-14 11:57 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2507938\update\updspapi.dll
+ 2011-07-14 11:57 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2507938\update\update.exe
+ 2011-07-14 11:57 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2507938\spuninst.exe
+ 2011-04-26 11:02 . 2011-04-26 11:02 293376 c:\windows\$hf_mig$\KB2507938\SP3QFE\winsrv.dll
+ 2011-04-15 07:05 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2507618\update\updspapi.dll
+ 2011-04-15 07:05 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2507618\update\update.exe
+ 2011-04-15 07:05 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2507618\spuninst.exe
+ 2011-02-15 13:05 . 2011-02-15 13:05 290432 c:\windows\$hf_mig$\KB2507618\SP3QFE\atmfd.dll
+ 2011-04-15 07:09 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2506223\update\updspapi.dll
+ 2011-04-15 07:09 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2506223\update\update.exe
+ 2011-04-15 07:09 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2506223\spuninst.exe
+ 2011-04-15 07:04 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2506212\update\updspapi.dll
+ 2011-04-15 07:04 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2506212\update\update.exe
+ 2011-04-15 07:04 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2506212\spuninst.exe
+ 2011-02-08 13:32 . 2011-02-08 13:32 974848 c:\windows\$hf_mig$\KB2506212\SP3QFE\mfc42u.dll
+ 2011-02-08 13:32 . 2011-02-08 13:32 978944 c:\windows\$hf_mig$\KB2506212\SP3QFE\mfc42.dll
+ 2011-06-17 07:05 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2503665\update\updspapi.dll
+ 2011-06-17 07:05 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2503665\update\update.exe
+ 2011-06-17 07:05 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2503665\spuninst.exe
+ 2011-06-16 22:27 . 2011-02-16 13:25 138496 c:\windows\$hf_mig$\KB2503665\SP3QFE\afd.sys
+ 2011-04-15 07:06 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2503658\update\updspapi.dll
+ 2011-04-15 07:06 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2503658\update\update.exe
+ 2011-04-15 07:06 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2503658\spuninst.exe
+ 2011-03-07 05:31 . 2011-03-07 05:31 692736 c:\windows\$hf_mig$\KB2503658\SP3QFE\inetcomm.dll
+ 2011-04-15 07:09 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2497640-IE8\update\updspapi.dll
+ 2011-04-15 07:09 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2497640-IE8\update\update.exe
+ 2011-04-15 07:09 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2497640-IE8\spuninst.exe
+ 2011-04-14 11:29 . 2011-02-22 23:27 919552 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\wininet.dll
+ 2011-04-14 11:29 . 2011-02-22 23:27 206848 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\occache.dll
+ 2011-04-14 11:29 . 2011-02-22 23:27 611840 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\mstime.dll
+ 2011-04-14 11:29 . 2011-02-22 23:27 602112 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\msfeeds.dll
+ 2011-04-14 11:29 . 2011-02-22 23:27 247808 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\ieproxy.dll
+ 2011-04-14 11:29 . 2011-02-22 23:27 184320 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\iepeers.dll
+ 2011-04-14 11:29 . 2011-02-22 23:27 743424 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\iedvtool.dll
+ 2011-04-14 11:29 . 2011-02-22 23:27 387584 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\iedkcs32.dll
+ 2011-04-14 11:29 . 2011-02-22 12:08 173568 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\ie4uinit.exe
+ 2011-04-15 07:10 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2485663\update\updspapi.dll
+ 2011-04-15 07:10 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2485663\update\update.exe
+ 2011-04-15 07:10 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2485663\spuninst.exe
+ 2011-02-10 23:46 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2485376\update\updspapi.dll
+ 2011-02-10 23:46 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2485376\update\update.exe
+ 2011-02-10 23:46 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2485376\spuninst.exe
+ 2011-01-07 14:09 . 2011-01-07 14:09 290048 c:\windows\$hf_mig$\KB2485376\SP3QFE\atmfd.dll
+ 2011-02-10 23:44 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2483185\update\updspapi.dll
+ 2011-02-10 23:44 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2483185\update\update.exe
+ 2011-02-10 23:44 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2483185\spuninst.exe
+ 2011-01-21 14:42 . 2011-01-21 14:42 439808 c:\windows\$hf_mig$\KB2483185\SP3QFE\shimgvw.dll
+ 2011-02-11 08:01 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2482017-IE8\update\updspapi.dll
+ 2011-02-11 08:01 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2482017-IE8\update\update.exe
+ 2011-02-11 08:01 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2482017-IE8\spuninst.exe
+ 2011-02-10 23:49 . 2010-12-20 23:58 919552 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\wininet.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 206848 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\occache.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 611840 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\mstime.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 602112 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\msfeeds.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 247808 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\ieproxy.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 184320 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\iepeers.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 743424 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\iedvtool.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 387584 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\iedkcs32.dll
+ 2011-02-10 23:49 . 2010-12-20 12:48 173568 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\ie4uinit.exe
+ 2011-03-09 08:01 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2481109\update\updspapi.dll
+ 2011-03-09 08:01 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2481109\update\update.exe
+ 2011-03-09 08:01 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2481109\spuninst.exe
+ 2011-01-27 11:41 . 2011-01-27 11:41 677888 c:\windows\$hf_mig$\KB2481109\SP3QFE\lhmstsc.exe
+ 2011-02-02 07:57 . 2011-02-02 07:57 136192 c:\windows\$hf_mig$\KB2481109\SP3QFE\aaclient.dll
+ 2011-03-09 08:04 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2479943\update\updspapi.dll
+ 2011-03-09 08:04 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2479943\update\update.exe
+ 2011-03-09 08:04 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2479943\spuninst.exe
+ 2011-02-09 13:52 . 2011-02-09 13:52 270848 c:\windows\$hf_mig$\KB2479943\SP3QFE\sbe.dll
+ 2011-02-09 13:52 . 2011-02-09 13:52 186880 c:\windows\$hf_mig$\KB2479943\SP3QFE\encdec.dll
+ 2011-02-10 23:45 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2479628\update\updspapi.dll
+ 2011-02-10 23:45 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2479628\update\update.exe
+ 2011-02-10 23:45 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2479628\spuninst.exe
+ 2011-02-10 23:46 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2478971\update\updspapi.dll
+ 2011-02-10 23:46 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2478971\update\update.exe
+ 2011-02-10 23:46 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2478971\spuninst.exe
+ 2010-12-22 12:32 . 2010-12-22 12:32 301568 c:\windows\$hf_mig$\KB2478971\SP3QFE\kerberos.dll
+ 2011-02-10 23:39 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2478960\update\updspapi.dll
+ 2011-02-10 23:39 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2478960\update\update.exe
+ 2011-02-10 23:38 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2478960\spuninst.exe
+ 2010-12-20 17:24 . 2010-12-20 17:24 730112 c:\windows\$hf_mig$\KB2478960\SP3QFE\lsasrv.dll
+ 2011-02-10 23:39 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2476687\update\updspapi.dll
+ 2011-02-10 23:39 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2476687\update\update.exe
+ 2011-02-10 23:39 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2476687\spuninst.exe
+ 2011-06-17 07:06 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2476490\update\updspapi.dll
+ 2011-06-17 07:06 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2476490\update\update.exe
+ 2011-06-17 07:06 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2476490\spuninst.exe
+ 2010-12-20 17:30 . 2010-12-20 17:30 552448 c:\windows\$hf_mig$\KB2476490\SP3QFE\oleaut32.dll
+ 2010-12-16 08:02 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2467659\update\updspapi.dll
+ 2010-12-16 08:02 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2467659\update\update.exe
+ 2010-12-16 08:02 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2467659\spuninst.exe
+ 2010-12-16 08:03 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2443105\update\updspapi.dll
+ 2010-12-16 08:03 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2443105\update\update.exe
+ 2010-12-16 08:03 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2443105\spuninst.exe
+ 2010-12-16 08:03 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB2440591\update\updspapi.dll
+ 2010-12-16 08:03 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB2440591\update\update.exe
+ 2010-12-16 08:03 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB2440591\spuninst.exe
+ 2010-12-16 08:02 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB2436673\update\updspapi.dll
+ 2010-12-16 08:02 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB2436673\update\update.exe
+ 2010-12-16 08:02 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB2436673\spuninst.exe
+ 2010-12-16 08:00 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2423089\update\updspapi.dll
+ 2010-12-16 08:00 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2423089\update\update.exe
+ 2010-12-16 08:00 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2423089\spuninst.exe
+ 2011-01-12 08:01 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2419632\update\updspapi.dll
+ 2011-01-12 08:01 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2419632\update\update.exe
+ 2011-01-12 08:01 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2419632\spuninst.exe
+ 2010-11-09 14:50 . 2010-11-09 14:50 253952 c:\windows\$hf_mig$\KB2419632\SP3QFE\odbc32.dll
+ 2010-11-09 14:50 . 2010-11-09 14:50 102400 c:\windows\$hf_mig$\KB2419632\SP3QFE\msjro.dll
+ 2010-11-09 14:50 . 2010-11-09 14:50 200704 c:\windows\$hf_mig$\KB2419632\SP3QFE\msadox.dll
+ 2010-11-09 14:50 . 2010-11-09 14:50 180224 c:\windows\$hf_mig$\KB2419632\SP3QFE\msadomd.dll
+ 2010-11-09 14:50 . 2010-11-09 14:50 565248 c:\windows\$hf_mig$\KB2419632\SP3QFE\msado15.dll
+ 2010-11-09 14:50 . 2010-11-09 14:50 143360 c:\windows\$hf_mig$\KB2419632\SP3QFE\msadco.dll
+ 2010-12-16 08:03 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2416400-IE8\update\updspapi.dll
+ 2010-12-16 08:03 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2416400-IE8\update\update.exe
+ 2010-12-16 08:03 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2416400-IE8\spuninst.exe
+ 2010-12-16 05:25 . 2010-11-06 00:27 919552 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\wininet.dll
+ 2010-12-16 05:25 . 2010-11-06 00:27 206848 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\occache.dll
+ 2010-12-16 05:25 . 2010-11-06 00:27 611840 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\mstime.dll
+ 2010-12-16 05:25 . 2010-11-06 00:27 602112 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\msfeeds.dll
+ 2010-12-16 05:25 . 2010-11-06 00:27 247808 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\ieproxy.dll
+ 2010-12-16 05:25 . 2010-11-06 00:27 184320 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\iepeers.dll
+ 2010-12-16 05:25 . 2010-11-06 00:27 743424 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\iedvtool.dll
+ 2010-12-16 05:25 . 2010-11-06 00:27 387584 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\iedkcs32.dll
+ 2010-12-16 05:25 . 2010-11-03 12:01 173568 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\ie4uinit.exe
+ 2011-02-10 23:38 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2393802\update\updspapi.dll
+ 2011-02-10 23:38 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2393802\update\update.exe
+ 2011-02-10 23:38 . 2010-07-05 13:15 231288 c:\windows\$hf_mig$\KB2393802\spuninst.exe
+ 2011-02-09 23:28 . 2010-12-09 15:15 718336 c:\windows\$hf_mig$\KB2393802\SP3QFE\ntdll.dll
+ 2010-10-14 07:08 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2387149\update\updspapi.dll
+ 2010-10-14 07:08 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2387149\update\update.exe
+ 2010-10-14 07:08 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2387149\spuninst.exe
+ 2010-10-13 22:34 . 2010-09-18 07:18 974848 c:\windows\$hf_mig$\KB2387149\SP3QFE\mfc42u.dll
+ 2010-10-13 22:34 . 2010-09-18 07:18 974848 c:\windows\$hf_mig$\KB2387149\SP3QFE\mfc42.dll
+ 2010-10-13 22:34 . 2010-09-18 07:18 953856 c:\windows\$hf_mig$\KB2387149\SP3QFE\mfc40u.dll
+ 2010-10-13 22:34 . 2010-09-18 07:18 954368 c:\windows\$hf_mig$\KB2387149\SP3QFE\mfc40.dll
+ 2010-10-14 07:00 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2360937\update\updspapi.dll
+ 2010-10-14 07:00 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2360937\update\update.exe
+ 2010-10-14 07:00 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2360937\spuninst.exe
+ 2010-10-13 22:22 . 2010-08-16 08:43 590848 c:\windows\$hf_mig$\KB2360937\SP3QFE\rpcrt4.dll
+ 2010-10-14 07:05 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2360131-IE8\update\updspapi.dll
+ 2010-10-14 07:05 . 2009-05-26 09:01 755576 c:\windows\$hf_mig$\KB2360131-IE8\update\update.exe
+ 2010-10-14 07:05 . 2009-05-26 09:01 231288 c:\windows\$hf_mig$\KB2360131-IE8\spuninst.exe
+ 2010-10-13 22:28 . 2010-09-10 05:57 919552 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\wininet.dll
+ 2010-10-13 22:28 . 2010-09-10 05:57 206848 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\occache.dll
+ 2010-10-13 22:28 . 2010-09-10 05:57 611840 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\mstime.dll
+ 2010-10-13 22:28 . 2010-09-10 05:57 602112 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\msfeeds.dll
+ 2010-10-13 22:28 . 2010-09-10 05:57 247808 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\ieproxy.dll
+ 2010-10-13 22:28 . 2010-09-10 05:57 184320 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\iepeers.dll
+ 2010-10-13 22:28 . 2010-09-10 05:57 743424 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\iedvtool.dll
+ 2010-10-13 22:28 . 2010-09-10 05:57 387584 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\iedkcs32.dll
+ 2010-10-13 22:28 . 2010-09-08 15:48 173056 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\ie4uinit.exe
+ 2010-09-15 06:33 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB2347290\update\updspapi.dll
+ 2010-09-15 06:33 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB2347290\update\update.exe
+ 2010-09-15 06:33 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB2347290\spuninst.exe
+ 2010-10-14 07:08 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2345886\update\updspapi.dll
+ 2010-10-14 07:08 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2345886\update\update.exe
+ 2010-10-14 07:08 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2345886\spuninst.exe
+ 2010-08-26 13:37 . 2010-08-26 13:37 357248 c:\windows\$hf_mig$\KB2345886\SP3QFE\srv.sys
+ 2010-12-16 08:03 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB2296199\update\updspapi.dll
+ 2010-12-16 08:03 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB2296199\update\update.exe
+ 2010-12-16 08:03 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB2296199\spuninst.exe
+ 2010-10-28 13:08 . 2010-10-28 13:08 290048 c:\windows\$hf_mig$\KB2296199\SP3QFE\atmfd.dll
+ 2010-08-03 12:24 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2286198\update\updspapi.dll
+ 2010-08-03 12:24 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2286198\update\update.exe
+ 2010-08-03 12:24 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2286198\spuninst.exe
+ 2010-10-14 07:08 . 2010-07-05 13:16 382840 c:\windows\$hf_mig$\KB2279986\update\updspapi.dll
+ 2010-10-14 07:08 . 2010-07-05 13:15 755576 c:\windows\$hf_mig$\KB2279986\update\update.exe
+ 2010-10-14 07:08 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2279986\spuninst.exe
+ 2010-09-01 11:48 . 2010-09-01 11:48 285824 c:\windows\$hf_mig$\KB2279986\SP3QFE\atmfd.dll
+ 2010-09-15 06:34 . 2009-05-26 09:01 382840 c:\windows\$hf_mig$\KB2259922\update\updspapi.dll
+ 2010-09-15 06:34 . 2009-05-26 09:01 755576 c:\windows\$hf_mig$\KB2259922\update\update.exe
+ 2010-09-15 06:34 . 2009-05-26 09:01 231288 c:\windows\$hf_mig$\KB2259922\spuninst.exe
+ 2010-07-14 07:06 . 2010-02-22 23:53 382840 c:\windows\$hf_mig$\KB2229593\update\updspapi.dll
+ 2010-07-14 07:06 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB2229593\update\update.exe
+ 2010-07-14 07:06 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB2229593\spuninst.exe
+ 2010-07-13 22:50 . 2010-06-14 14:38 744448 c:\windows\$hf_mig$\KB2229593\SP3QFE\helpsvc.exe
+ 2010-08-12 03:39 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2183461-IE8\update\updspapi.dll
+ 2010-08-12 03:39 . 2009-05-26 09:01 755576 c:\windows\$hf_mig$\KB2183461-IE8\update\update.exe
+ 2010-08-12 03:39 . 2009-05-26 09:01 231288 c:\windows\$hf_mig$\KB2183461-IE8\spuninst.exe
+ 2010-08-10 23:34 . 2010-06-24 12:24 919040 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\wininet.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 206848 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\occache.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 611840 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\mstime.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 599040 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\msfeeds.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 247808 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\ieproxy.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 184320 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\iepeers.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 743424 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\iedvtool.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 387584 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\iedkcs32.dll
+ 2010-08-10 23:34 . 2010-06-23 11:30 173056 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\ie4uinit.exe
+ 2010-08-12 03:38 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2160329\update\updspapi.dll
+ 2010-08-12 03:38 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2160329\update\update.exe
+ 2010-08-12 03:38 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2160329\spuninst.exe
+ 2010-09-15 06:29 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2141007\update\updspapi.dll
+ 2010-09-15 06:29 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2141007\update\update.exe
+ 2010-09-15 06:29 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2141007\spuninst.exe
+ 2010-06-09 07:41 . 2010-06-09 07:41 692736 c:\windows\$hf_mig$\KB2141007\SP3QFE\inetcomm.dll
+ 2010-09-15 06:33 . 2010-02-22 14:23 382840 c:\windows\$hf_mig$\KB2121546\update\updspapi.dll
+ 2010-09-15 06:33 . 2010-02-22 14:23 755576 c:\windows\$hf_mig$\KB2121546\update\update.exe
+ 2010-09-15 06:33 . 2010-02-22 14:23 231288 c:\windows\$hf_mig$\KB2121546\spuninst.exe
+ 2010-06-18 17:43 . 2010-06-18 17:43 293376 c:\windows\$hf_mig$\KB2121546\SP3QFE\winsrv.dll
+ 2010-08-12 03:44 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB2115168\update\updspapi.dll
+ 2010-08-12 03:44 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB2115168\update\update.exe
+ 2010-08-12 03:44 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB2115168\spuninst.exe
+ 2010-08-12 03:42 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB2079403\update\updspapi.dll
+ 2010-08-12 03:42 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB2079403\update\update.exe
+ 2010-08-12 03:42 . 2009-05-26 11:40 231288 c:\windows\$hf_mig$\KB2079403\spuninst.exe
+ 2012-05-09 05:31 . 2012-02-09 15:43 1748992 c:\windows\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22791_x-ww_c8dff154\GdiPlus.dll
+ 2011-04-14 11:29 . 2010-10-23 00:51 1748992 c:\windows\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22509_x-ww_c7dad023\GdiPlus.dll
+ 2010-10-13 22:34 . 2010-08-23 16:12 1054208 c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
+ 2011-04-19 02:51 . 2011-04-19 02:51 3781960 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_028bc148\mfc90u.dll
+ 2011-04-19 02:51 . 2011-04-19 02:51 3766600 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_028bc148\mfc90.dll
+ 2011-01-11 14:59 . 2011-01-11 14:59 3780936 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_d5fe2ecb\mfc90u.dll
+ 2011-01-11 14:59 . 2011-01-11 14:59 3766088 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.5570_x-ww_d5fe2ecb\mfc90.dll
+ 2009-07-12 04:02 . 2009-07-12 04:02 3780424 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_a57c1f53\mfc90u.dll
+ 2009-07-12 04:02 . 2009-07-12 04:02 3765048 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_a57c1f53\mfc90.dll
+ 2007-11-07 05:19 . 2007-11-07 05:19 1162744 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_a173767a\mfc90u.dll
+ 2007-11-07 05:19 . 2007-11-07 05:19 1156600 c:\windows\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.21022.8_x-ww_a173767a\mfc90.dll
- 2006-12-02 04:25 . 2006-12-02 04:25 1093120 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\mfc80u.dll
+ 2008-10-25 01:15 . 2008-10-25 01:15 1093120 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\mfc80u.dll
+ 2008-10-25 01:15 . 2008-10-25 01:15 1101824 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\mfc80.dll
- 2006-12-02 04:25 . 2006-12-02 04:25 1101824 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05\mfc80.dll
+ 2011-05-14 00:04 . 2011-05-14 00:04 1093120 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_150c9e8b\mfc80u.dll
+ 2011-05-14 00:04 . 2011-05-14 00:04 1101824 c:\windows\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_150c9e8b\mfc80.dll
+ 2012-08-19 07:26 . 2012-08-19 07:26 1233920 c:\windows\WinSxS\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9818.0_x-ww_8ff50c5d\msxml4.dll
+ 2009-04-18 21:30 . 2012-06-02 19:19 1933848 c:\windows\system32\wuaueng.dll
+ 2012-06-29 05:06 . 2012-01-09 21:28 1461992 c:\windows\system32\wdfcoinstaller01009.dll
+ 2009-09-15 01:00 . 2012-02-15 15:01 4547944 c:\windows\system32\usbaaplrc.dll
+ 2001-08-23 12:00 . 2012-07-02 17:49 1212416 c:\windows\system32\urlmon.dll
+ 2001-08-23 12:00 . 2012-06-08 14:26 8462848 c:\windows\system32\shell32.dll
+ 2011-12-16 02:25 . 2011-08-02 21:38 4517664 c:\windows\system32\ReinstallBackups\0013\DriverFiles\usbaaplrc.dll
+ 2011-11-26 17:44 . 2008-09-24 14:40 4122368 c:\windows\system32\ReinstallBackups\0007\DriverFiles\ALCXWDM.SYS
+ 2001-08-23 12:00 . 2011-11-03 15:28 1292288 c:\windows\system32\quartz.dll
+ 2007-07-05 21:55 . 2010-07-12 18:36 2120176 c:\windows\system32\PxSFS.DLL
+ 2001-08-23 12:00 . 2011-11-01 16:07 1288704 c:\windows\system32\ole32.dll
+ 2011-11-05 18:50 . 2011-10-08 04:50 2398016 c:\windows\system32\nvcuvid.dll
+ 2011-11-05 18:50 . 2011-10-08 04:50 2099520 c:\windows\system32\nvcuvenc.dll
+ 2008-09-18 03:55 . 2011-10-08 04:50 5595136 c:\windows\system32\nvcuda.dll
+ 2006-08-12 04:43 . 2011-10-08 04:50 2449408 c:\windows\system32\nvapi.dll
+ 2006-08-12 04:42 . 2011-10-08 04:50 4226688 c:\windows\system32\nv4_disp.dll
+ 2001-08-23 12:00 . 2012-05-04 13:16 2148352 c:\windows\system32\ntoskrnl.exe
+ 2001-08-17 13:48 . 2012-05-04 12:32 2026496 c:\windows\system32\ntkrnlpa.exe
- 2009-04-19 19:07 . 2009-07-31 15:05 1372672 c:\windows\system32\msxml6.dll
+ 2009-04-19 19:07 . 2012-06-05 15:50 1372672 c:\windows\system32\msxml6.dll
- 2001-08-23 12:00 . 2009-07-31 04:35 1172480 c:\windows\system32\msxml3.dll
+ 2001-08-23 12:00 . 2012-06-05 15:50 1172480 c:\windows\system32\msxml3.dll
+ 2009-04-18 21:30 . 2011-02-02 07:58 2067456 c:\windows\system32\mstscax.dll
+ 2001-08-23 12:00 . 2012-07-02 17:49 6008320 c:\windows\system32\mshtml.dll
+ 2003-03-19 03:20 . 2007-03-22 00:39 1060864 c:\windows\system32\MFC71.DLL
- 2003-03-19 03:20 . 2003-03-19 03:20 1060864 c:\windows\system32\mfc71.dll
+ 2012-08-31 06:18 . 2012-08-31 06:18 9813704 c:\windows\system32\Macromed\Flash\NPSWF32_11_4_402_265.dll
+ 2007-08-13 22:34 . 2012-07-02 17:49 2000384 c:\windows\system32\iertutil.dll
+ 2011-07-07 06:28 . 2011-07-07 06:28 1193320 c:\windows\system32\FM20.DLL
+ 2012-03-21 05:45 . 2012-02-15 15:01 4547944 c:\windows\system32\DRVSTORE\usbaapl_87F84F5DA3368BC69CA5BE7F6A79CAA709E36E13\usbaaplrc.dll
+ 2012-08-19 07:23 . 2012-06-27 19:18 1837296 c:\windows\system32\DRVSTORE\pccswpddri_58E92219CA3FF6890A1AA097BB664B7DC817D147\WUDFUpdate_01009.dll
+ 2011-10-24 16:32 . 2010-04-20 00:29 1461992 c:\windows\system32\DRVSTORE\netaapl_63AA05C4700EB9CAF2D048DAC1D06D764A0D4C41\wdfcoinstaller01009.dll
+ 2012-06-29 05:06 . 2012-01-09 21:28 1461992 c:\windows\system32\DRVSTORE\ccdcmb_AAFF744F7D9EE98020534E5F936B0F6CA67CDAAC\wdfcoinstaller01009.dll
+ 2009-04-19 17:48 . 2008-09-24 15:40 4122368 c:\windows\system32\drivers\alcxwdm.sys
- 2009-04-19 17:48 . 2008-09-24 14:40 4122368 c:\windows\system32\drivers\alcxwdm.sys
+ 2009-04-18 21:30 . 2012-06-02 19:19 1933848 c:\windows\system32\dllcache\wuaueng.dll
+ 2009-02-09 11:13 . 2012-07-03 13:40 1866112 c:\windows\system32\dllcache\win32k.sys
+ 2007-08-13 22:54 . 2012-07-02 17:49 1212416 c:\windows\system32\dllcache\urlmon.dll
+ 2008-06-17 19:02 . 2012-06-08 14:26 8462848 c:\windows\system32\dllcache\shell32.dll
+ 2008-12-20 22:14 . 2011-11-03 15:28 1292288 c:\windows\system32\dllcache\quartz.dll
+ 2010-07-16 12:05 . 2011-11-01 16:07 1288704 c:\windows\system32\dllcache\ole32.dll
+ 2009-04-19 19:27 . 2012-05-04 13:12 2192640 c:\windows\system32\dllcache\ntoskrnl.exe
+ 2009-04-19 19:27 . 2012-05-04 12:32 2026496 c:\windows\system32\dllcache\ntkrpamp.exe
+ 2009-02-07 23:02 . 2012-05-04 12:32 2069120 c:\windows\system32\dllcache\ntkrnlpa.exe
+ 2009-04-19 19:27 . 2012-05-04 13:16 2148352 c:\windows\system32\dllcache\ntkrnlmp.exe
- 2009-04-19 19:07 . 2009-07-31 15:05 1372672 c:\windows\system32\dllcache\msxml6.dll
+ 2009-04-19 19:07 . 2012-06-05 15:50 1372672 c:\windows\system32\dllcache\msxml6.dll
- 2009-04-19 19:26 . 2009-07-31 04:35 1172480 c:\windows\system32\dllcache\msxml3.dll
+ 2009-04-19 19:26 . 2012-06-05 15:50 1172480 c:\windows\system32\dllcache\msxml3.dll
+ 2007-08-13 22:54 . 2012-07-02 17:49 6008320 c:\windows\system32\dllcache\mshtml.dll
+ 2010-03-11 05:32 . 2010-06-18 13:36 3558912 c:\windows\system32\dllcache\moviemk.exe
- 2010-03-11 05:32 . 2009-10-23 15:28 3558912 c:\windows\system32\dllcache\moviemk.exe
+ 2011-02-02 07:58 . 2011-02-02 07:58 2067456 c:\windows\system32\dllcache\lhmstscx.dll
+ 2009-04-19 19:31 . 2012-07-02 17:49 2000384 c:\windows\system32\dllcache\iertutil.dll
+ 2009-11-07 05:06 . 2009-11-07 05:06 1130824 c:\windows\system32\dfshim.dll
+ 2011-10-25 00:21 . 2009-09-04 21:29 1892184 c:\windows\system32\D3DX9_42.dll
+ 2011-10-25 00:21 . 2009-03-09 19:27 4178264 c:\windows\system32\D3DX9_41.dll
+ 2011-10-25 00:21 . 2008-10-15 10:22 4379984 c:\windows\system32\D3DX9_40.dll
+ 2011-10-25 00:21 . 2008-07-10 16:00 3851784 c:\windows\system32\D3DX9_39.dll
+ 2011-10-25 00:21 . 2008-05-30 19:11 3850760 c:\windows\system32\D3DX9_38.dll
+ 2011-10-25 00:21 . 2008-03-05 20:56 3786760 c:\windows\system32\D3DX9_37.dll
+ 2011-10-25 00:21 . 2007-10-12 20:14 3734536 c:\windows\system32\d3dx9_36.dll
+ 2011-10-25 00:21 . 2007-07-19 23:14 3727720 c:\windows\system32\d3dx9_35.dll
- 2009-09-21 01:59 . 2007-05-16 20:45 3497832 c:\windows\system32\d3dx9_34.dll
+ 2009-09-21 01:59 . 2007-05-16 21:45 3497832 c:\windows\system32\d3dx9_34.dll
+ 2009-09-21 01:59 . 2007-03-12 21:42 3495784 c:\windows\system32\d3dx9_33.dll
- 2009-09-21 01:59 . 2007-03-12 20:42 3495784 c:\windows\system32\d3dx9_33.dll
- 2009-09-21 01:59 . 2006-11-29 17:06 3426072 c:\windows\system32\d3dx9_32.dll
+ 2009-09-21 01:59 . 2006-11-29 18:06 3426072 c:\windows\system32\d3dx9_32.dll
+ 2009-09-21 01:59 . 2006-09-28 21:05 2414360 c:\windows\system32\d3dx9_31.dll
- 2009-09-21 01:59 . 2006-09-28 20:05 2414360 c:\windows\system32\d3dx9_31.dll
+ 2009-06-13 08:31 . 2006-03-31 17:40 2388176 c:\windows\system32\d3dx9_30.dll
- 2009-06-13 08:31 . 2006-03-31 16:40 2388176 c:\windows\system32\d3dx9_30.dll
- 2009-09-21 01:59 . 2006-02-03 12:43 2332368 c:\windows\system32\d3dx9_29.dll
+ 2009-09-21 01:59 . 2006-02-03 13:43 2332368 c:\windows\system32\d3dx9_29.dll
- 2009-06-13 08:31 . 2005-12-05 22:09 2323664 c:\windows\system32\d3dx9_28.dll
+ 2009-06-13 08:31 . 2005-12-05 23:09 2323664 c:\windows\system32\d3dx9_28.dll
- 2009-09-21 01:59 . 2005-07-22 23:59 2319568 c:\windows\system32\d3dx9_27.dll
+ 2009-09-21 01:59 . 2005-07-23 00:59 2319568 c:\windows\system32\d3dx9_27.dll
- 2009-09-21 01:59 . 2005-05-26 19:34 2297552 c:\windows\system32\d3dx9_26.dll
+ 2009-09-21 01:59 . 2005-05-26 20:34 2297552 c:\windows\system32\d3dx9_26.dll
- 2009-09-21 01:59 . 2005-03-18 21:19 2337488 c:\windows\system32\d3dx9_25.dll
+ 2009-09-21 01:59 . 2005-03-18 22:19 2337488 c:\windows\system32\d3dx9_25.dll
- 2009-09-21 01:59 . 2005-02-05 23:45 2222800 c:\windows\system32\d3dx9_24.dll
+ 2009-09-21 01:59 . 2005-02-06 00:45 2222800 c:\windows\system32\d3dx9_24.dll
+ 2011-10-25 00:21 . 2009-09-04 21:29 5501792 c:\windows\system32\d3dcsx_42.dll
+ 2011-10-25 00:21 . 2009-09-04 21:29 1974616 c:\windows\system32\D3DCompiler_42.dll
+ 2011-10-25 00:21 . 2009-03-09 19:27 1846632 c:\windows\system32\D3DCompiler_41.dll
+ 2011-10-25 00:21 . 2008-10-15 10:22 2036576 c:\windows\system32\D3DCompiler_40.dll
+ 2011-10-25 00:21 . 2008-07-10 16:00 1493528 c:\windows\system32\D3DCompiler_39.dll
+ 2011-10-25 00:21 . 2008-05-30 19:11 1491992 c:\windows\system32\D3DCompiler_38.dll
+ 2011-10-25 00:21 . 2008-03-05 20:56 1420824 c:\windows\system32\D3DCompiler_37.dll
+ 2011-10-25 00:21 . 2007-10-12 20:14 1374232 c:\windows\system32\D3DCompiler_36.dll
+ 2011-10-25 00:21 . 2007-07-19 23:14 1358192 c:\windows\system32\D3DCompiler_35.dll
- 2009-09-21 01:59 . 2007-05-16 20:45 1124720 c:\windows\system32\D3DCompiler_34.dll
+ 2009-09-21 01:59 . 2007-05-16 21:45 1124720 c:\windows\system32\D3DCompiler_34.dll
- 2009-09-21 01:59 . 2007-03-12 20:42 1123696 c:\windows\system32\D3DCompiler_33.dll
+ 2009-09-21 01:59 . 2007-03-12 21:42 1123696 c:\windows\system32\D3DCompiler_33.dll
+ 2009-06-12 03:51 . 2011-09-01 00:12 1698408 c:\windows\RtlExUpd.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 1663320 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\wpfgfx_v0400.dll
+ 2012-01-19 17:08 . 2012-01-19 17:08 1369872 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\WindowsBase.dll
+ 2012-01-19 17:08 . 2012-01-19 17:08 6429992 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationFramework.dll
+ 2012-01-19 17:08 . 2012-01-19 17:08 3790112 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationCore.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 2650464 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\NlsLexicons0009.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 4881752 c:\windows\Microsoft.NET\Framework\v4.0.30319\WPF\NlsData0009.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 2199880 c:\windows\Microsoft.NET\Framework\v4.0.30319\vbc.exe
+ 2010-03-18 17:16 . 2010-03-18 17:16 2207568 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.XML.dll
+ 2012-03-15 17:17 . 2012-03-15 17:17 5029672 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Windows.Forms.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 1711496 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Windows.Forms.DataVisualization.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 6067048 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.ServiceModel.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 1026936 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Runtime.Serialization.dll
+ 2011-12-15 17:08 . 2011-12-15 17:08 3512072 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 4464480 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Data.Entity.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 2970968 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Data.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 1339736 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Core.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 1462648 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Activities.Presentation.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 1199968 c:\windows\Microsoft.NET\Framework\v4.0.30319\System.Activities.dll
+ 2010-03-18 20:26 . 2010-03-18 20:26 1163264 c:\windows\Microsoft.NET\Framework\v4.0.30319\SetupCache\Client\netfx_core_x86.msi
+ 2011-12-15 17:08 . 2011-12-15 17:08 5201168 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorlib.dll
+ 2011-12-15 17:08 . 2011-12-15 17:08 1143568 c:\windows\Microsoft.NET\Framework\v4.0.30319\mscordacwks.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 2989456 c:\windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.VisualBasic.Activities.Compiler.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 1972552 c:\windows\Microsoft.NET\Framework\v4.0.30319\csc.exe
+ 2011-12-15 17:08 . 2011-12-15 17:08 6727424 c:\windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
- 2008-07-25 15:17 . 2008-07-25 15:17 5025792 c:\windows\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.dll
+ 2012-03-20 09:23 . 2012-03-20 09:23 5025792 c:\windows\Microsoft.NET\Framework\v2.0.50727\System.Windows.Forms.dll
+ 2011-12-25 08:50 . 2011-12-25 08:50 5246976 c:\windows\Microsoft.NET\Framework\v2.0.50727\System.Web.dll
+ 2011-12-25 07:50 . 2011-12-25 07:50 3186688 c:\windows\Microsoft.NET\Framework\v2.0.50727\System.dll
- 2008-07-25 15:17 . 2008-07-25 15:17 5062656 c:\windows\Microsoft.NET\Framework\v2.0.50727\System.Design.dll
+ 2012-03-20 09:23 . 2012-03-20 09:23 5062656 c:\windows\Microsoft.NET\Framework\v2.0.50727\System.Design.dll
+ 2011-12-25 07:50 . 2011-12-25 07:50 5913360 c:\windows\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
+ 2011-12-25 07:50 . 2011-12-25 07:50 4550656 c:\windows\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll
+ 2004-07-15 12:15 . 2004-07-15 12:15 1032192 c:\windows\Microsoft.NET\Framework\v1.1.4322\VsaVb7rt.dll
+ 2012-04-26 06:32 . 2012-04-26 06:32 6385664 c:\windows\Microsoft.NET\Framework\v1.1.4322\Updates\M2656370\M2656370Uninstall.msp
+ 2004-07-15 18:29 . 2004-07-15 18:29 1339392 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.XML.dll
+ 2011-12-25 15:07 . 2011-12-25 15:07 2064384 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Windows.Forms.dll
+ 2011-12-25 15:06 . 2011-12-25 15:06 1269760 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Web.dll
+ 2011-12-25 15:06 . 2011-12-25 15:06 1232896 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.dll
+ 2004-07-15 18:29 . 2004-07-15 18:29 1703936 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Design.dll
+ 2004-07-15 18:32 . 2004-07-15 18:32 1294336 c:\windows\Microsoft.NET\Framework\v1.1.4322\System.Data.dll
+ 2011-12-25 02:54 . 2011-12-25 02:54 2514944 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorwks.dll
+ 2011-12-25 02:53 . 2011-12-25 02:53 2527232 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorsvr.dll
+ 2011-12-25 15:06 . 2011-12-25 15:06 2142208 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorlib.dll
+ 2003-02-21 11:25 . 2003-02-21 11:25 1564672 c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorcfg.dll
- 2009-09-21 01:59 . 2004-12-01 19:53 2846720 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2903.0\Microsoft.DirectX.Direct3DX.dll
+ 2009-09-21 01:59 . 2004-12-01 20:53 2846720 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2903.0\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2004-09-29 16:38 2676224 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.Direct3DX.dll
+ 2009-09-21 01:59 . 2004-09-29 17:38 2676224 c:\windows\Microsoft.NET\DirectX for Managed Code\1.0.2902.0\Microsoft.DirectX.Direct3DX.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 1369872 c:\windows\Microsoft.NET\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 3512072 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 2207568 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.XML.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 5029672 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 1711496 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Windows.Forms.DataVisualization\v4.0_4.0.0.0__31bf3856ad364e35\System.Windows.Forms.DataVisualization.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 6067048 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.ServiceModel\v4.0_4.0.0.0__b77a5c561934e089\System.ServiceModel.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 1026936 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Runtime.Serialization\v4.0_4.0.0.0__b77a5c561934e089\System.Runtime.Serialization.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 4464480 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Data.Entity\v4.0_4.0.0.0__b77a5c561934e089\System.Data.Entity.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 1339736 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 1199968 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Activities\v4.0_4.0.0.0__31bf3856ad364e35\System.Activities.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 1462648 c:\windows\Microsoft.NET\assembly\GAC_MSIL\System.Activities.Presentation\v4.0_4.0.0.0__31bf3856ad364e35\System.Activities.Presentation.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 6429992 c:\windows\Microsoft.NET\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 2970968 c:\windows\Microsoft.NET\assembly\GAC_32\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 3790112 c:\windows\Microsoft.NET\assembly\GAC_32\PresentationCore\v4.0_4.0.0.0__31bf3856ad364e35\PresentationCore.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 5201168 c:\windows\Microsoft.NET\assembly\GAC_32\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll
+ 2012-06-14 06:17 . 2012-06-14 06:17 2989456 c:\windows\Microsoft.NET\assembly\GAC_32\Microsoft.VisualBasic.Activities.Compiler\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.Activities.Compiler.dll
+ 2012-04-05 02:38 . 2012-04-05 02:38 2831360 c:\windows\Installer\e51b7f1.msp
+ 2012-04-29 01:44 . 2012-04-29 01:44 9101824 c:\windows\Installer\e51b7e7.msp
+ 2012-01-19 17:37 . 2012-01-19 17:37 8999936 c:\windows\Installer\e51b7af.msp
+ 2012-04-29 01:44 . 2012-04-29 01:44 9586176 c:\windows\Installer\e51b7a3.msp
+ 2012-04-30 18:38 . 2012-04-30 18:38 5011456 c:\windows\Installer\e51b78a.msp
+ 2012-04-05 02:38 . 2012-04-05 02:38 3620864 c:\windows\Installer\e51b75d.msp
+ 2012-04-09 20:50 . 2012-04-09 20:50 6829568 c:\windows\Installer\e51b730.msp
+ 2012-03-20 02:02 . 2012-03-20 02:02 6695936 c:\windows\Installer\e51b719.msp
+ 2012-03-15 06:24 . 2012-03-15 06:24 1795584 c:\windows\Installer\e51b702.msp
+ 2012-04-27 19:09 . 2012-04-27 19:09 5521408 c:\windows\Installer\e51b6ea.msp
+ 2012-04-29 01:43 . 2012-04-29 01:43 8459264 c:\windows\Installer\e51b6be.msp
+ 2012-02-17 12:45 . 2012-02-17 12:45 2299392 c:\windows\Installer\e51b6b4.msp
+ 2012-04-17 16:11 . 2012-04-17 16:11 7681024 c:\windows\Installer\e51b69d.msp
+ 2009-02-25 23:08 . 2009-02-25 23:08 8311808 c:\windows\Installer\d709e69.msp
+ 2011-06-21 16:01 . 2011-06-21 16:01 4991488 c:\windows\Installer\d709e52.msp
+ 2009-04-04 21:10 . 2009-04-04 21:10 1282560 c:\windows\Installer\d709e3a.msp
+ 2009-04-04 21:10 . 2009-04-04 21:10 7888384 c:\windows\Installer\d709e31.msp
+ 2009-04-04 21:10 . 2009-04-04 21:10 9926144 c:\windows\Installer\d709e26.msp
+ 2009-04-04 14:14 . 2009-04-04 14:14 1094656 c:\windows\Installer\d709d06.msp
+ 2010-09-17 11:04 . 2010-09-17 11:04 9401856 c:\windows\Installer\d3002d.msp
+ 2010-10-22 20:45 . 2010-10-22 20:45 8444928 c:\windows\Installer\d3000c.msp
+ 2011-01-17 21:06 . 2011-01-17 21:06 5518848 c:\windows\Installer\d2fff4.msp
+ 2010-10-04 21:00 . 2010-10-04 21:00 7973888 c:\windows\Installer\d2ffdd.msp
+ 2010-10-01 22:42 . 2010-10-01 22:42 5054464 c:\windows\Installer\d2ff9a.msp
+ 2010-10-04 18:59 . 2010-10-04 18:59 8300032 c:\windows\Installer\d2ff6c.msp
+ 2010-10-02 02:53 . 2010-10-02 02:53 4147712 c:\windows\Installer\d2ff2a.msp
+ 2011-07-26 01:25 . 2011-07-26 01:25 1640960 c:\windows\Installer\b2ddad1.msi
+ 2011-07-26 01:25 . 2011-07-26 01:25 1652736 c:\windows\Installer\b2ddac3.msi
+ 2011-07-26 01:25 . 2011-07-26 01:25 1652736 c:\windows\Installer\b2ddabc.msi
+ 2011-07-26 01:25 . 2011-07-26 01:25 1652736 c:\windows\Installer\b2ddab5.msi
+ 2011-07-26 01:24 . 2011-07-26 01:24 2319872 c:\windows\Installer\b2dda8f.msi
+ 2011-07-26 01:24 . 2011-07-26 01:24 1647616 c:\windows\Installer\b2dda81.msi
+ 2011-07-26 01:24 . 2011-07-26 01:24 1640960 c:\windows\Installer\b2dda73.msi
+ 2011-07-26 01:23 . 2011-07-26 01:23 2022912 c:\windows\Installer\b2dda6c.msi
+ 2011-07-26 01:23 . 2011-07-26 01:23 1713152 c:\windows\Installer\b2dda65.msi
+ 2011-07-26 01:23 . 2011-07-26 01:23 2397184 c:\windows\Installer\b2dda57.msi
+ 2011-10-31 03:54 . 2011-10-31 03:54 2748416 c:\windows\Installer\ae5f63.msp
+ 2011-10-26 20:38 . 2011-10-26 20:38 2830848 c:\windows\Installer\ae5f4f.msp
+ 2012-02-03 20:13 . 2012-02-03 20:13 4988928 c:\windows\Installer\ae5f46.msp
+ 2012-01-25 19:55 . 2012-01-25 19:55 5520384 c:\windows\Installer\ae5f2e.msp
+ 2011-10-24 16:31 . 2011-10-24 16:31 2002432 c:\windows\Installer\ab997e7.msi
+ 2011-10-24 16:29 . 2011-10-24 16:29 9474048 c:\windows\Installer\ab997c3.msi
+ 2011-10-24 05:12 . 2011-10-24 05:12 1065984 c:\windows\Installer\8518963.msi
+ 2010-08-13 21:59 . 2010-08-13 21:59 8182272 c:\windows\Installer\6f2c1ea.msp
+ 2010-08-13 22:02 . 2010-08-13 22:02 2545664 c:\windows\Installer\6f2c1cb.msp
+ 2010-08-23 21:09 . 2010-08-23 21:09 7673344 c:\windows\Installer\6f2c1c1.msp
+ 2010-10-04 20:32 . 2010-10-04 20:32 5517824 c:\windows\Installer\6f2c179.msp
+ 2010-08-18 14:19 . 2010-08-18 14:19 8400896 c:\windows\Installer\6f2c162.msp
+ 2010-08-24 13:49 . 2010-08-24 13:49 6825472 c:\windows\Installer\6f2c14e.msp
+ 2011-04-29 16:28 . 2011-04-29 16:28 1995264 c:\windows\Installer\6dfae77d.msp
+ 2011-04-27 23:51 . 2011-04-27 23:51 6825472 c:\windows\Installer\6dfae76b.msp
+ 2011-05-20 21:31 . 2011-05-20 21:31 5518848 c:\windows\Installer\6dfae754.msp
+ 2011-05-17 22:28 . 2011-05-17 22:28 6862848 c:\windows\Installer\6dfae73d.msp
+ 2011-04-29 16:33 . 2011-04-29 16:33 8173568 c:\windows\Installer\6dfae711.msp
+ 2011-01-27 18:49 . 2011-01-27 18:49 6825472 c:\windows\Installer\681ebd0.msp
+ 2011-04-05 16:52 . 2011-04-05 16:52 5519872 c:\windows\Installer\681eb77.msp
+ 2010-11-21 03:34 . 2010-11-21 03:34 1198080 c:\windows\Installer\681eb3c.msp
+ 2011-03-18 00:01 . 2011-03-18 00:01 9563648 c:\windows\Installer\681eb1d.msp
+ 2011-03-03 15:25 . 2011-03-03 15:25 5051904 c:\windows\Installer\681eb13.msp
+ 2011-01-11 21:50 . 2011-01-11 21:50 8177152 c:\windows\Installer\681eae7.msp
+ 2011-02-25 18:25 . 2011-02-25 18:25 7968256 c:\windows\Installer\681eac6.msp
+ 2011-11-01 18:34 . 2011-11-01 18:34 1552384 c:\windows\Installer\6662ca.msp
+ 2011-11-01 18:34 . 2011-11-01 18:34 4250112 c:\windows\Installer\6662c0.msp
+ 2011-11-01 18:34 . 2011-11-01 18:34 2247168 c:\windows\Installer\6662a6.msp
+ 2011-10-30 04:10 . 2011-10-30 04:10 6824960 c:\windows\Installer\66628e.msp
+ 2011-11-11 21:14 . 2011-11-11 21:14 9096192 c:\windows\Installer\666277.msp
+ 2011-11-01 18:34 . 2011-11-01 18:34 4225536 c:\windows\Installer\66625f.msp
+ 2011-10-31 17:37 . 2011-10-31 17:37 4146688 c:\windows\Installer\666248.msp
+ 2011-11-01 18:34 . 2011-11-01 18:34 2531840 c:\windows\Installer\66621d.msp
+ 2011-11-17 15:55 . 2011-11-17 15:55 5522944 c:\windows\Installer\666213.msp
+ 2011-11-11 21:15 . 2011-11-11 21:15 1795584 c:\windows\Installer\6661fc.msp
+ 2011-11-11 21:16 . 2011-11-11 21:16 8458240 c:\windows\Installer\6661cf.msp
+ 2011-09-15 22:40 . 2011-09-15 22:40 7959552 c:\windows\Installer\5cb1f61.msp
+ 2011-09-15 22:35 . 2011-09-15 22:35 1411072 c:\windows\Installer\5cb1e40.msp
+ 2012-08-07 04:16 . 2012-08-07 04:16 2295808 c:\windows\Installer\56c4c49.msi
+ 2009-11-09 04:25 . 2009-11-09 04:25 1935360 c:\windows\Installer\51ed7d.msp
+ 2011-02-16 04:04 . 2011-02-16 04:04 3883520 c:\windows\Installer\4ad44.msi
+ 2010-05-25 15:45 . 2010-05-25 15:45 8445440 c:\windows\Installer\3be8a08c.msp
+ 2010-06-11 21:55 . 2010-06-11 21:55 1827328 c:\windows\Installer\3be8a073.msp
+ 2010-07-01 02:52 . 2010-07-01 02:52 5522944 c:\windows\Installer\3be8a050.msp
+ 2010-05-24 17:54 . 2010-05-24 17:54 6704640 c:\windows\Installer\3be8a021.msp
+ 2012-09-14 01:36 . 2012-09-14 01:36 1188352 c:\windows\Installer\36558.msi
+ 2012-03-27 04:28 . 2012-03-27 04:28 5009920 c:\windows\Installer\308ad68.msp
+ 2012-03-23 18:59 . 2012-03-23 18:59 7899648 c:\windows\Installer\308ad50.msp
+ 2012-01-31 00:46 . 2012-01-31 00:46 7069184 c:\windows\Installer\308ad3a.msp
+ 2011-11-01 17:34 . 2011-11-01 17:34 1169920 c:\windows\Installer\308ad27.msp
+ 2012-01-22 14:09 . 2012-01-22 14:09 1700352 c:\windows\Installer\308ad10.msp
+ 2012-03-22 17:09 . 2012-03-22 17:09 5521920 c:\windows\Installer\308ad07.msp
+ 2011-05-21 05:49 . 2011-05-21 05:49 1160192 c:\windows\Installer\2f267750.msi
+ 2011-05-23 18:15 . 2011-05-23 18:15 3617792 c:\windows\Installer\2c19c9b0.msp
+ 2011-09-21 20:18 . 2011-09-21 20:18 4985856 c:\windows\Installer\2b069da.msp
+ 2011-09-20 19:36 . 2011-09-20 19:36 5521408 c:\windows\Installer\2b069b8.msp
+ 2011-11-03 18:31 . 2011-11-03 18:31 5525504 c:\windows\Installer\26fb604c.msp
+ 2012-08-30 07:06 . 2012-08-30 07:06 5007872 c:\windows\Installer\228aee7.msp
+ 2012-08-19 07:27 . 2012-08-19 07:27 1221632 c:\windows\Installer\1fa161.msi
+ 2012-09-13 07:00 . 2012-09-13 07:00 1648640 c:\windows\Installer\1f37fca.msi
+ 2012-08-17 03:10 . 2012-08-17 03:10 6926336 c:\windows\Installer\1e102f.msi
+ 2011-02-22 15:32 . 2011-02-22 15:32 5520384 c:\windows\Installer\1d0aeab.msp
+ 2011-12-06 20:22 . 2011-12-06 20:22 5519360 c:\windows\Installer\1b77045.msp
+ 2011-12-09 00:24 . 2011-12-09 00:24 4989952 c:\windows\Installer\1b7702e.msp
+ 2010-09-23 11:39 . 2010-09-23 11:39 4265472 c:\windows\Installer\1b74345.msp
+ 2011-05-02 04:06 . 2011-05-02 04:06 2705920 c:\windows\Installer\1b2355d8.msp
+ 2011-07-27 11:42 . 2011-07-27 11:42 4985856 c:\windows\Installer\1b2355cf.msp
+ 2011-04-28 14:54 . 2011-04-28 14:54 2720768 c:\windows\Installer\1b2355b8.msp
+ 2011-07-26 17:50 . 2011-07-26 17:50 5522432 c:\windows\Installer\1b2355a9.msp
+ 2011-03-25 13:03 . 2011-03-25 13:03 5079552 c:\windows\Installer\1b09535.msp
+ 2011-01-19 03:36 . 2011-01-19 03:36 2687488 c:\windows\Installer\1b0952c.msp
+ 2010-06-28 20:01 . 2010-06-28 20:01 7677952 c:\windows\Installer\1adaabcb.msp
+ 2010-06-29 20:01 . 2010-06-29 20:01 8404992 c:\windows\Installer\1adaabb4.msp
+ 2010-06-29 02:53 . 2010-06-29 02:53 6819840 c:\windows\Installer\1adaaba0.msp
+ 2011-08-10 21:43 . 2011-08-10 21:43 3795968 c:\windows\Installer\1a903e8.msp
+ 2011-07-26 12:17 . 2011-07-26 12:17 6824960 c:\windows\Installer\1a903c7.msp
+ 2011-08-16 16:35 . 2011-08-16 16:35 5519872 c:\windows\Installer\1a903b0.msp
+ 2011-09-07 01:46 . 2011-09-07 01:46 9006080 c:\windows\Installer\1a90399.msp
+ 2011-06-21 15:59 . 2011-06-21 15:59 1764352 c:\windows\Installer\1a90381.msp
+ 2011-08-24 10:37 . 2011-08-24 10:37 4985856 c:\windows\Installer\1a9036a.msp
+ 2011-08-10 21:42 . 2011-08-10 21:42 7070208 c:\windows\Installer\1a90352.msp
+ 2011-07-21 16:34 . 2011-07-21 16:34 3456000 c:\windows\Installer\1a9033b.msp
+ 2011-09-07 01:48 . 2011-09-07 01:48 8181248 c:\windows\Installer\1a90319.msp
+ 2011-07-27 11:39 . 2011-07-27 11:39 9892352 c:\windows\Installer\1a902e3.msp
+ 2012-05-30 11:17 . 2012-05-30 11:17 5010432 c:\windows\Installer\1a82764.msp
+ 2012-03-15 17:43 . 2012-03-15 17:43 4216320 c:\windows\Installer\1a82744.msp
+ 2012-04-23 02:37 . 2012-04-23 02:37 1182720 c:\windows\Installer\1a8273c.msp
+ 2012-04-25 23:32 . 2012-04-25 23:32 7069184 c:\windows\Installer\1a82734.msp
+ 2012-03-21 03:57 . 2012-03-21 03:57 6188544 c:\windows\Installer\1a82729.msp
+ 2012-03-27 05:38 . 2012-03-27 05:38 3443712 c:\windows\Installer\18bb8d8.msi
+ 2010-08-05 14:57 . 2010-08-05 14:57 4066304 c:\windows\Installer\1823d89.msp
+ 2010-08-09 20:44 . 2010-08-09 20:44 3778048 c:\windows\Installer\1823d4c.msp
+ 2010-08-20 17:50 . 2010-08-20 17:50 5518848 c:\windows\Installer\1823d37.msp
+ 2010-08-27 17:36 . 2010-08-27 17:36 2807296 c:\windows\Installer\1823d08.msp
+ 2010-08-25 21:06 . 2010-08-25 21:06 6479360 c:\windows\Installer\1823cf1.msp
+ 2012-05-30 11:18 . 2012-05-30 11:18 1739264 c:\windows\Installer\17c97656.msp
+ 2012-06-19 16:54 . 2012-06-19 16:54 2239488 c:\windows\Installer\17c9764e.msp
+ 2012-06-19 16:54 . 2012-06-19 16:54 5009920 c:\windows\Installer\17c97637.msp
+ 2012-04-05 02:37 . 2012-04-05 02:37 2540544 c:\windows\Installer\17c9761f.msp
+ 2012-06-29 18:33 . 2012-06-29 18:33 6063616 c:\windows\Installer\17c97607.msp
+ 2012-04-05 02:37 . 2012-04-05 02:37 3149824 c:\windows\Installer\17c975f0.msp
+ 2010-07-26 21:02 . 2010-07-26 21:02 5519360 c:\windows\Installer\178422c7.msp
+ 2010-07-11 00:14 . 2010-07-11 00:14 2850816 c:\windows\Installer\1784229b.msp
+ 2011-04-27 15:14 . 2011-04-27 15:14 5520384 c:\windows\Installer\1715817.msp
+ 2011-04-29 17:04 . 2011-04-29 17:04 5053440 c:\windows\Installer\1715800.msp
+ 2011-04-29 16:30 . 2011-04-29 16:30 1197056 c:\windows\Installer\17157e9.msp
+ 2012-03-21 05:47 . 2012-03-21 05:47 4136448 c:\windows\Installer\168e79b.msi
+ 2012-03-21 05:45 . 2012-03-21 05:45 1718784 c:\windows\Installer\168e792.msi
+ 2012-03-21 05:44 . 2012-03-21 05:44 1530368 c:\windows\Installer\168e73b.msi
+ 2012-03-06 01:34 . 2012-03-06 01:34 5519872 c:\windows\Installer\152ca47.msp
+ 2012-03-01 03:45 . 2012-03-01 03:45 4989440 c:\windows\Installer\152ca30.msp
+ 2011-08-02 22:43 . 2011-08-02 22:43 1769984 c:\windows\Installer\1411486a.msi
+ 2011-11-18 05:23 . 2011-11-18 05:23 1435136 c:\windows\Installer\1314ef6.msi
+ 2011-04-29 16:31 . 2011-04-29 16:31 9006080 c:\windows\Installer\12995224.msp
+ 2010-10-21 22:10 . 2010-10-21 22:10 3995136 c:\windows\Installer\129951f7.msp
+ 2010-02-21 05:03 . 2010-02-21 05:03 4472832 c:\windows\Installer\129951e0.msp
+ 2011-04-29 16:27 . 2011-04-29 16:27 4158464 c:\windows\Installer\1299519c.msp
+ 2010-08-13 22:00 . 2010-08-13 22:00 9404928 c:\windows\Installer\12995182.msp
+ 2009-08-05 11:49 . 2009-08-05 11:49 3457024 c:\windows\Installer\12995168.msp
+ 2010-03-24 22:54 . 2010-03-24 22:54 3126272 c:\windows\Installer\12995151.msp
+ 2010-03-24 22:54 . 2010-03-24 22:54 2516992 c:\windows\Installer\12995150.msp
+ 2010-05-20 23:57 . 2010-05-20 23:57 4989952 c:\windows\Installer\129950f8.msp
+ 2010-05-20 23:57 . 2010-05-20 23:57 5907456 c:\windows\Installer\129950f7.msp
+ 2009-10-16 11:08 . 2009-10-16 11:08 2237952 c:\windows\Installer\129950ed.msp
+ 2009-08-18 17:08 . 2009-08-18 17:08 1373696 c:\windows\Installer\129950bf.msp
+ 2010-11-21 03:33 . 2010-11-21 03:33 1980928 c:\windows\Installer\12995091.msp
+ 2011-01-11 21:53 . 2011-01-11 21:53 1763328 c:\windows\Installer\12995079.msp
+ 2012-06-26 22:03 . 2012-06-26 22:03 3875840 c:\windows\Installer\114e8a2.msp
+ 2012-07-17 14:11 . 2012-07-17 14:11 6145024 c:\windows\Installer\114e853.msp
+ 2012-07-18 19:53 . 2012-07-18 19:53 5009920 c:\windows\Installer\114e81d.msp
+ 2012-08-02 14:29 . 2012-08-02 14:29 5521920 c:\windows\Installer\114e805.msp
+ 2011-12-26 14:59 . 2011-12-26 14:59 4368896 c:\windows\Installer\10b3d298.msp
+ 2011-12-26 10:06 . 2011-12-26 10:06 5115392 c:\windows\Installer\10b3d28e.msp
+ 2011-07-26 01:28 . 2012-09-12 12:24 1172240 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\xlicons.exe
- 2009-10-01 01:42 . 2010-06-13 01:11 1172240 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\xlicons.exe
- 2009-10-01 01:42 . 2010-06-13 01:11 1165584 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\accicons.exe
+ 2011-07-26 01:28 . 2012-09-12 12:24 1165584 c:\windows\Installer\{90120000-0030-0000-0000-0000000FF1CE}\accicons.exe
+ 2007-04-19 18:09 . 2007-04-19 18:09 1061720 c:\windows\Installer\$PatchCache$\Managed\9040110900063D11C8EF10054038389C\11.0.8173\OMFC.DLL
+ 2011-06-06 16:55 . 2011-06-06 16:55 2215312 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\rt3d.dll
+ 2011-06-06 16:55 . 2011-06-06 16:55 1189004 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\JSByteCodeWin.bin
+ 2011-06-06 16:55 . 2011-06-06 16:55 6543768 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\authplay.dll
+ 2011-06-06 16:55 . 2011-06-06 16:55 1240992 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\AdobeCollabSync.exe
+ 2011-06-06 16:55 . 2011-06-06 16:55 1480600 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\AcroRd32.exe
+ 2010-03-18 17:16 . 2010-03-18 17:16 1303896 c:\windows\Installer\$PatchCache$\Managed\5C1093C35543A0E32A41B090A305076A\4.0.30319\WindowsBase_x86.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 6346600 c:\windows\Installer\$PatchCache$\Managed\5C1093C35543A0E32A41B090A305076A\4.0.30319\PresentationFramework_x86.dll
+ 2010-03-18 17:16 . 2010-03-18 17:16 3545952 c:\windows\Installer\$PatchCache$\Managed\5C1093C35543A0E32A41B090A305076A\4.0.30319\PresentationCore_x86.dll
+ 2011-01-14 11:10 . 2011-01-14 11:10 2395008 c:\windows\Installer\$PatchCache$\Managed\00004109500200000000000000F01FEC\14.0.5130\GKWORD.DLL
+ 2011-01-14 11:10 . 2011-01-14 11:10 2180992 c:\windows\Installer\$PatchCache$\Managed\00004109500200000000000000F01FEC\14.0.5130\GKPOWERPOINT.DLL
+ 2011-01-14 11:10 . 2011-01-14 11:10 3443072 c:\windows\Installer\$PatchCache$\Managed\00004109500200000000000000F01FEC\14.0.5130\GKEXCEL.DLL
+ 2010-01-11 20:07 . 2010-01-11 20:07 2594632 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\VBE6.DLL
+ 2011-07-27 09:09 . 2011-07-27 09:09 5310848 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\IPEDITOR.DLL
+ 2006-10-27 18:57 . 2006-10-27 18:57 2330968 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\STSLIST.DLL
+ 2006-10-26 23:52 . 2006-10-26 23:52 2012480 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\PPTVIEW.EXE
+ 2006-10-27 19:04 . 2006-10-27 19:04 7980848 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\PPCORE.DLL
+ 2006-10-27 00:02 . 2006-10-27 00:02 2526520 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\GRAPH.EXE
+ 2011-07-26 01:27 . 2011-07-26 01:27 1276720 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\EXCELPIA.DLL
+ 2011-08-17 13:49 . 2011-08-17 13:49 4683624 c:\windows\Installer\$PatchCache$\Managed\00002109020090400000000000F01FEC\12.0.6612\WRD12CNV.DLL
+ 2011-07-07 06:58 . 2011-07-07 06:58 1616240 c:\windows\Installer\$PatchCache$\Managed\00002109020090400000000000F01FEC\12.0.6612\OGL.DLL
+ 2011-08-03 04:14 . 2011-08-03 04:14 8579448 c:\windows\Installer\$PatchCache$\Managed\00002109020090400000000000F01FEC\12.0.6612\OARTCONV.DLL
+ 2012-08-15 05:44 . 2012-05-11 14:42 1212416 c:\windows\ie8updates\KB2722913-IE8\urlmon.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 6007808 c:\windows\ie8updates\KB2722913-IE8\mshtml.dll
+ 2012-08-15 05:44 . 2012-05-11 14:42 2000384 c:\windows\ie8updates\KB2722913-IE8\iertutil.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 1212416 c:\windows\ie8updates\KB2699988-IE8\urlmon.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 5978624 c:\windows\ie8updates\KB2699988-IE8\mshtml.dll
+ 2012-06-14 06:08 . 2012-03-01 11:01 2000384 c:\windows\ie8updates\KB2699988-IE8\iertutil.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 1212416 c:\windows\ie8updates\KB2675157-IE8\urlmon.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 5979136 c:\windows\ie8updates\KB2675157-IE8\mshtml.dll
+ 2012-04-11 12:54 . 2011-12-17 19:46 2000384 c:\windows\ie8updates\KB2675157-IE8\iertutil.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 1212416 c:\windows\ie8updates\KB2647516-IE8\urlmon.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 5978112 c:\windows\ie8updates\KB2647516-IE8\mshtml.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 2000384 c:\windows\ie8updates\KB2647516-IE8\iertutil.dll
+ 2011-12-15 05:50 . 2011-08-22 23:48 1212416 c:\windows\ie8updates\KB2618444-IE8\urlmon.dll
+ 2011-12-15 05:50 . 2011-10-03 08:35 5971456 c:\windows\ie8updates\KB2618444-IE8\mshtml.dll
+ 2011-12-15 05:50 . 2011-08-22 23:48 2000384 c:\windows\ie8updates\KB2618444-IE8\iertutil.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 1212416 c:\windows\ie8updates\KB2586448-IE8\urlmon.dll
+ 2011-10-12 11:48 . 2011-07-25 15:17 5969920 c:\windows\ie8updates\KB2586448-IE8\mshtml.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 1991680 c:\windows\ie8updates\KB2586448-IE8\iertutil.dll
+ 2011-08-11 12:00 . 2011-04-25 16:11 1211904 c:\windows\ie8updates\KB2559049-IE8\urlmon.dll
+ 2011-08-11 12:00 . 2011-05-30 22:19 5964800 c:\windows\ie8updates\KB2559049-IE8\mshtml.dll
+ 2011-08-11 12:00 . 2011-04-25 16:11 1991680 c:\windows\ie8updates\KB2559049-IE8\iertutil.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 1210880 c:\windows\ie8updates\KB2530548-IE8\urlmon.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 5962240 c:\windows\ie8updates\KB2530548-IE8\mshtml.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 1991680 c:\windows\ie8updates\KB2530548-IE8\iertutil.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 1210880 c:\windows\ie8updates\KB2497640-IE8\urlmon.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 5961216 c:\windows\ie8updates\KB2497640-IE8\mshtml.dll
+ 2011-04-15 07:09 . 2010-12-20 23:59 1991680 c:\windows\ie8updates\KB2497640-IE8\iertutil.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 1210880 c:\windows\ie8updates\KB2482017-IE8\urlmon.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 5959168 c:\windows\ie8updates\KB2482017-IE8\mshtml.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 1991680 c:\windows\ie8updates\KB2482017-IE8\iertutil.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 1210880 c:\windows\ie8updates\KB2416400-IE8\urlmon.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 5957120 c:\windows\ie8updates\KB2416400-IE8\mshtml.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 1986560 c:\windows\ie8updates\KB2416400-IE8\iertutil.dll
+ 2010-10-14 07:05 . 2010-06-24 12:22 1210368 c:\windows\ie8updates\KB2360131-IE8\urlmon.dll
+ 2010-10-14 07:05 . 2010-06-24 12:22 5951488 c:\windows\ie8updates\KB2360131-IE8\mshtml.dll
+ 2010-10-14 07:05 . 2010-06-24 12:21 1986560 c:\windows\ie8updates\KB2360131-IE8\iertutil.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 1209344 c:\windows\ie8updates\KB2183461-IE8\urlmon.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 5950976 c:\windows\ie8updates\KB2183461-IE8\mshtml.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 1985536 c:\windows\ie8updates\KB2183461-IE8\iertutil.dll
+ 2009-04-19 19:27 . 2012-05-04 13:12 2192640 c:\windows\Driver Cache\i386\ntoskrnl.exe
+ 2009-04-19 19:27 . 2012-05-04 12:32 2026496 c:\windows\Driver Cache\i386\ntkrpamp.exe
+ 2009-02-07 23:02 . 2012-05-04 12:32 2069120 c:\windows\Driver Cache\i386\ntkrnlpa.exe
+ 2009-04-19 19:27 . 2012-05-04 13:16 2148352 c:\windows\Driver Cache\i386\ntkrnlmp.exe
+ 2010-08-20 04:46 . 2011-03-03 19:19 1312120 c:\windows\Downloaded Program Files\BFHUpdater.exe
+ 2012-03-29 03:32 . 2012-03-29 03:32 4792320 c:\windows\assembly\NativeImages1_v1.1.4322\System\1.0.5000.0__b77a5c561934e089_6919b3b0\System.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 1966080 c:\windows\assembly\NativeImages1_v1.1.4322\System\1.0.5000.0__b77a5c561934e089_23290c79\System.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 5513216 c:\windows\assembly\NativeImages1_v1.1.4322\System.Xml\1.0.5000.0__b77a5c561934e089_f5c57cb3\System.Xml.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 2088960 c:\windows\assembly\NativeImages1_v1.1.4322\System.Xml\1.0.5000.0__b77a5c561934e089_479f506d\System.Xml.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 7917568 c:\windows\assembly\NativeImages1_v1.1.4322\System.Windows.Forms\1.0.5000.0__b77a5c561934e089_fb0c2361\System.Windows.Forms.dll
+ 2012-04-11 12:54 . 2012-04-11 12:54 3035136 c:\windows\assembly\NativeImages1_v1.1.4322\System.Windows.Forms\1.0.5000.0__b77a5c561934e089_b72bc8d7\System.Windows.Forms.dll
+ 2012-06-14 06:08 . 2012-06-14 06:08 7917568 c:\windows\assembly\NativeImages1_v1.1.4322\System.Windows.Forms\1.0.5000.0__b77a5c561934e089_7650c044\System.Windows.Forms.dll
+ 2012-04-11 12:54 . 2012-04-11 12:54 7917568 c:\windows\assembly\NativeImages1_v1.1.4322\System.Windows.Forms\1.0.5000.0__b77a5c561934e089_52e4e807\System.Windows.Forms.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 3035136 c:\windows\assembly\NativeImages1_v1.1.4322\System.Windows.Forms\1.0.5000.0__b77a5c561934e089_3dbafd8d\System.Windows.Forms.dll
+ 2012-06-14 06:08 . 2012-06-14 06:08 3035136 c:\windows\assembly\NativeImages1_v1.1.4322\System.Windows.Forms\1.0.5000.0__b77a5c561934e089_35acb9a5\System.Windows.Forms.dll
+ 2012-04-11 12:54 . 2012-04-11 12:54 2248704 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing\1.0.5000.0__b03f5f7f11d50a3a_c8d963f4\System.Drawing.dll
+ 2012-06-14 06:08 . 2012-06-14 06:08 2252800 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing\1.0.5000.0__b03f5f7f11d50a3a_630511c4\System.Drawing.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 2244608 c:\windows\assembly\NativeImages1_v1.1.4322\System.Drawing\1.0.5000.0__b03f5f7f11d50a3a_3eb22c97\System.Drawing.dll
+ 2012-04-11 12:54 . 2012-04-11 12:54 3395584 c:\windows\assembly\NativeImages1_v1.1.4322\System.Design\1.0.5000.0__b03f5f7f11d50a3a_da093f85\System.Design.dll
+ 2012-06-14 06:08 . 2012-06-14 06:08 3395584 c:\windows\assembly\NativeImages1_v1.1.4322\System.Design\1.0.5000.0__b03f5f7f11d50a3a_bcf5161d\System.Design.dll
+ 2012-06-14 06:08 . 2012-06-14 06:08 1470464 c:\windows\assembly\NativeImages1_v1.1.4322\System.Design\1.0.5000.0__b03f5f7f11d50a3a_8fe5d918\System.Design.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 1470464 c:\windows\assembly\NativeImages1_v1.1.4322\System.Design\1.0.5000.0__b03f5f7f11d50a3a_5c85646d\System.Design.dll
+ 2012-04-11 12:54 . 2012-04-11 12:54 1470464 c:\windows\assembly\NativeImages1_v1.1.4322\System.Design\1.0.5000.0__b03f5f7f11d50a3a_2b2c4c8b\System.Design.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 3395584 c:\windows\assembly\NativeImages1_v1.1.4322\System.Design\1.0.5000.0__b03f5f7f11d50a3a_245eafb0\System.Design.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 3391488 c:\windows\assembly\NativeImages1_v1.1.4322\mscorlib\1.0.5000.0__b77a5c561934e089_dd3850f4\mscorlib.dll
+ 2012-03-29 03:32 . 2012-03-29 03:32 8908800 c:\windows\assembly\NativeImages1_v1.1.4322\mscorlib\1.0.5000.0__b77a5c561934e089_6a8eec30\mscorlib.dll
+ 2012-06-14 06:10 . 2012-06-14 06:10 3856896 c:\windows\assembly\NativeImages_v4.0.30319_32\WindowsBase\62f103f9e662d263ec2ecacc49d4525b\WindowsBase.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 1063424 c:\windows\assembly\NativeImages_v4.0.30319_32\UIAutomationClients#\2cf35797a56eba020ed629b395ad2daa\UIAutomationClientsideProviders.ni.dll
+ 2011-10-12 12:34 . 2011-10-12 12:34 4121088 c:\windows\assembly\NativeImages_v4.0.30319_32\Temp\f8c-0\System.Activities.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 9090560 c:\windows\assembly\NativeImages_v4.0.30319_32\System\6f399163bb35597da7141ccdb7f39d16\System.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 5618176 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Xml\5ee8bf77e7b3e25cdbff6e1c299574fe\System.Xml.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 1781760 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Xaml\9b6f1bcb2cf4e6ad429cd721b942f30f\System.Xaml.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 4586496 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Form#\90c878d9bfdfa68644d6fd70d105a57d\System.Windows.Forms.DataVisualization.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 1859584 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Web.Services\1126dc2c152098ec23d4554405217184\System.Web.Services.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 2010624 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Speech\7ebd25fd0282e19eba65f4da70ab5a0b\System.Speech.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 1128960 c:\windows\assembly\NativeImages_v4.0.30319_32\System.ServiceModel#\28b09f14e54a06c091073b1d3e316fb6\System.ServiceModel.Discovery.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 1387520 c:\windows\assembly\NativeImages_v4.0.30319_32\System.ServiceModel#\18d8e3f9e290217ac0c48571557c5fc3\System.ServiceModel.Activities.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 2637312 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Runtime.Seri#\9bfda0add366eea12ea0402e60d01e84\System.Runtime.Serialization.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 1020928 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Runtime.Dura#\a40c42510e312339018486b1d7076e0a\System.Runtime.DurableInstancing.ni.dll
+ 2012-06-14 06:13 . 2012-06-14 06:13 1060864 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Printing\5874aff524c86d029d38a874be9702b2\System.Printing.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 1218560 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Management\1409dc3832b37f850569c69a795f834b\System.Management.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 1072128 c:\windows\assembly\NativeImages_v4.0.30319_32\System.IdentityModel\a90d8ca6c54f70507704d788fd0d3ded\System.IdentityModel.ni.dll
+ 2012-06-14 06:10 . 2012-06-14 06:10 1666048 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\4a668799513e369a54fdab8b3f74de92\System.Drawing.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 1172992 c:\windows\assembly\NativeImages_v4.0.30319_32\System.DirectorySer#\8d978e3524c0bd870ce63db289c4de6d\System.DirectoryServices.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 1879040 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Deployment\49fa1b6f067c7c93b309581083e5fac0\System.Deployment.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 6798336 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Data\9f5111b0b58258c3a4bbcfb8bf27374c\System.Data.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 2545152 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Data.SqlXml\6cdfd96214b74cdf4984ae8ee076f421\System.Data.SqlXml.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 1338880 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Data.Service#\65444428f83ba9e46053e46d2341655f\System.Data.Services.Client.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 2512384 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Data.Linq\867ce3db3528f36121841762a19da61d\System.Data.Linq.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 7052800 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Core\14ba6251d6ec84c9579ed3d3e10b30c1\System.Core.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 4121088 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Activities\95b5ece57120cb7363e69e5fbd4616b7\System.Activities.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 3755008 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Activities.P#\cf95f30a1bb7a5456070520d2b111436\System.Activities.Presentation.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 1544192 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Activities.C#\f0c4476258c5336a3d950e588fbeb853\System.Activities.Core.Presentation.ni.dll
+ 2012-06-14 06:13 . 2012-06-14 06:13 2904576 c:\windows\assembly\NativeImages_v4.0.30319_32\ReachFramework\a2f341812e09a99a6deab48b9b4c482f\ReachFramework.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 1641984 c:\windows\assembly\NativeImages_v4.0.30319_32\PresentationUI\0cb224b8f7bd962c1c57f9c1242c2e47\PresentationUI.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 1836544 c:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.VisualBas#\b108894c04c131e1f84cb50a5dd99142\Microsoft.VisualBasic.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 1172480 c:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.VisualBas#\434583d8e633570da52da83faea4a758\Microsoft.VisualBasic.Activities.Compiler.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 1139712 c:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.VisualBas#\10f2f34bdeaaf6f909620309efc26ba7\Microsoft.VisualBasic.Compatibility.ni.dll
+ 2012-05-09 23:32 . 2012-05-09 23:32 1082368 c:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.Transacti#\50ca1cf4491136871b732062c412bad0\Microsoft.Transactions.Bridge.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 2452480 c:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.JScript\78e5704cfbbec26947e2e1ff07f647bf\Microsoft.JScript.ni.dll
+ 2012-05-09 22:28 . 2012-05-09 22:28 1616384 c:\windows\assembly\NativeImages_v4.0.30319_32\Microsoft.CSharp\9c3ba92c4fce8efd41b59a0243415408\Microsoft.CSharp.ni.dll
+ 2012-05-09 22:36 . 2012-05-09 22:36 3325440 c:\windows\assembly\NativeImages_v2.0.50727_32\WindowsBase\6d8bef0d008389874e55c0308f0c18e5\WindowsBase.ni.dll
+ 2012-05-09 22:38 . 2012-05-09 22:38 1049600 c:\windows\assembly\NativeImages_v2.0.50727_32\UIAutomationClients#\41a81b97625c113b591ed082c95276e2\UIAutomationClientsideProviders.ni.dll
+ 2011-06-18 07:07 . 2011-06-18 07:07 3176448 c:\windows\assembly\NativeImages_v2.0.50727_32\Temp\ZAP1AA2.tmp\WindowsBase.dll
+ 2012-05-09 22:36 . 2012-05-09 22:36 7953408 c:\windows\assembly\NativeImages_v2.0.50727_32\System\e4b5afc4da43b1c576f9322f9f2e1bfe\System.ni.dll
+ 2012-05-09 22:38 . 2012-05-09 22:38 5450752 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Xml\3bba1b8b0b5ef0be238b011cc7a0575e\System.Xml.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 1356288 c:\windows\assembly\NativeImages_v2.0.50727_32\System.WorkflowServ#\bd5bd406670d483b82bd51249eee59e3\System.WorkflowServices.ni.dll
+ 2012-06-14 06:13 . 2012-06-14 06:13 1908224 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Workflow.Run#\77361ebe9ad8ff77cc9a8d7f8363eb05\System.Workflow.Runtime.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 4514304 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Workflow.Com#\1c12dfa7826b331b243b7b45daf9904d\System.Workflow.ComponentModel.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 2992640 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Workflow.Act#\514bf0e69e2c9fc8509cd23236057356\System.Workflow.Activities.ni.dll
+ 2012-06-14 06:12 . 2012-06-14 06:12 1840640 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.Services\e70343406253e43964f9fe1f42cfbd7c\System.Web.Services.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 2209280 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.Mobile\77f8cde07b131839f1841be702837e8e\System.Web.Mobile.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 2405888 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web.Extensio#\242b168aaca18197eca371ec269e23ac\System.Web.Extensions.ni.dll
+ 2012-05-09 22:38 . 2012-05-09 22:38 1917440 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Speech\5efb50c91f3c5e49be2079f625d933b7\System.Speech.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 1706496 c:\windows\assembly\NativeImages_v2.0.50727_32\System.ServiceModel#\97d635f5c656ae43d94b55e67fc4ab50\System.ServiceModel.Web.ni.dll
+ 2012-05-09 22:45 . 2012-05-09 22:45 2345472 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Runtime.Seri#\505e12638acd6fdb22e1fd2d4c6fc232\System.Runtime.Serialization.ni.dll
+ 2012-06-14 11:34 . 2012-06-14 11:34 1035776 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Printing\d380f1813e27c2a086e62f0218669d67\System.Printing.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 4950016 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Management.A#\c1b3a38c1e1528e22b8f5531d7b3700c\System.Management.Automation.ni.dll
+ 2012-05-09 22:45 . 2012-05-09 22:45 1070080 c:\windows\assembly\NativeImages_v2.0.50727_32\System.IdentityModel\e09496ddb2bf6f3b69707924f2e6b5ff\System.IdentityModel.ni.dll
+ 2012-06-14 11:34 . 2012-06-14 11:34 1592320 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Drawing\d86f2038209a4cf0d0f5b30f6375c9b2\System.Drawing.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 1116672 c:\windows\assembly\NativeImages_v2.0.50727_32\System.DirectorySer#\b55887436d2cfbe1fb32dd18d554185b\System.DirectoryServices.ni.dll
+ 2012-06-14 12:08 . 2012-06-14 12:08 1801216 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Deployment\7a53d68ad544f8e9edfdbd5a90a48fd3\System.Deployment.ni.dll
+ 2012-05-09 22:37 . 2012-05-09 22:37 6616576 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Data\12c6fe8d4dd78f9bddf847d3b2821c03\System.Data.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 2510336 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Data.SqlXml\982b508698278c6ffb3d143bbe1e8bb8\System.Data.SqlXml.ni.dll
+ 2012-05-09 23:29 . 2012-05-09 23:30 1328128 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Data.Services\2de7666b1cd0a1bc363726c9553dc39c\System.Data.Services.ni.dll
+ 2012-05-09 22:37 . 2012-05-09 22:37 2516480 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Data.Linq\44a5fc9e7c71b1fe1e2c79b03ecc3bc7\System.Data.Linq.ni.dll
+ 2012-05-09 23:29 . 2012-05-09 23:29 9924096 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Data.Entity\ca63096c1ecf977f509e2a565f4bcdac\System.Data.Entity.ni.dll
+ 2012-05-09 22:37 . 2012-05-09 22:37 2295296 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Core\38d07a5ac34b99d94fd14f42e779f625\System.Core.ni.dll
+ 2012-06-14 06:20 . 2012-06-14 06:20 2146304 c:\windows\assembly\NativeImages_v2.0.50727_32\ReachFramework\443dd7f0b84c3de54b1a72be655e307c\ReachFramework.ni.dll
+ 2012-06-14 06:20 . 2012-06-14 06:20 1657856 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationUI\48ddcafff1a5603fb3289e90330275c0\PresentationUI.ni.dll
+ 2012-05-09 22:36 . 2012-05-09 22:36 1451008 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationBuildTa#\4ff6600c1fd3415ef0b058cf28814cb6\PresentationBuildTasks.ni.dll
+ 2012-06-14 12:08 . 2012-06-14 12:08 1712128 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.VisualBas#\359fd69eb60e9844ffd497e92345178c\Microsoft.VisualBasic.ni.dll
+ 2012-05-09 22:45 . 2012-05-09 22:45 1093120 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Transacti#\42145ebf75f77cabad442f0801a81c64\Microsoft.Transactions.Bridge.ni.dll
+ 2012-05-09 23:30 . 2012-05-09 23:30 2332160 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.JScript\cfe15312373b4668398404b5822bab7d\Microsoft.JScript.ni.dll
+ 2012-06-14 12:08 . 2012-06-14 12:08 1620992 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Tas#\4e463dcf2a03c71913a61b44c32e2389\Microsoft.Build.Tasks.ni.dll
+ 2012-06-14 12:08 . 2012-06-14 12:08 1966080 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Tas#\395b4a85c7941ac4dd9d1c6f5eb444c7\Microsoft.Build.Tasks.v3.5.ni.dll
+ 2012-05-09 23:28 . 2012-05-09 23:28 1888768 c:\windows\assembly\NativeImages_v2.0.50727_32\Microsoft.Build.Eng#\5aa63a1cb41e3a5e1e8ed17072e60ec3\Microsoft.Build.Engine.ni.dll
+ 2012-05-09 22:29 . 2012-05-09 22:29 1249280 c:\windows\assembly\GAC_MSIL\WindowsBase\3.0.0.0__31bf3856ad364e35\WindowsBase.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 3186688 c:\windows\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 2048000 c:\windows\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.XML.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 2048000 c:\windows\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.XML.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 5025792 c:\windows\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 5025792 c:\windows\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
+ 2012-01-09 08:09 . 2012-01-09 08:09 1277952 c:\windows\assembly\GAC_MSIL\System.Web.Extensions\3.5.0.0__31bf3856ad364e35\System.Web.Extensions.dll
- 2009-08-21 22:32 . 2009-08-21 22:32 1277952 c:\windows\assembly\GAC_MSIL\System.Web.Extensions\3.5.0.0__31bf3856ad364e35\System.Web.Extensions.dll
+ 2012-03-07 05:25 . 2012-03-07 05:25 1564672 c:\windows\assembly\GAC_MSIL\System.Management.Automation\1.0.0.0__31bf3856ad364e35\System.Management.Automation.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 5062656 c:\windows\assembly\GAC_MSIL\System.Design\2.0.0.0__b03f5f7f11d50a3a\System.Design.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 5062656 c:\windows\assembly\GAC_MSIL\System.Design\2.0.0.0__b03f5f7f11d50a3a\System.Design.dll
- 2009-08-21 22:32 . 2009-08-21 22:32 5283840 c:\windows\assembly\GAC_MSIL\PresentationFramework\3.0.0.0__31bf3856ad364e35\PresentationFramework.dll
+ 2012-05-09 22:29 . 2012-05-09 22:29 5283840 c:\windows\assembly\GAC_MSIL\PresentationFramework\3.0.0.0__31bf3856ad364e35\PresentationFramework.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 5246976 c:\windows\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll
- 2010-06-09 07:05 . 2010-06-09 07:05 2933248 c:\windows\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 2933248 c:\windows\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll
+ 2012-05-09 22:29 . 2012-05-09 22:29 4214784 c:\windows\assembly\GAC_32\PresentationCore\3.0.0.0__31bf3856ad364e35\PresentationCore.dll
+ 2012-06-14 06:19 . 2012-06-14 06:19 4550656 c:\windows\assembly\GAC_32\mscorlib\2.0.0.0__b77a5c561934e089\mscorlib.dll
+ 2012-03-29 03:31 . 2012-03-29 03:31 1232896 c:\windows\assembly\GAC\System\1.0.5000.0__b77a5c561934e089\System.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 1339392 c:\windows\assembly\GAC\System.Xml\1.0.5000.0__b77a5c561934e089\System.XML.dll
+ 2012-03-29 03:31 . 2012-03-29 03:31 2064384 c:\windows\assembly\GAC\System.Windows.Forms\1.0.5000.0__b77a5c561934e089\System.Windows.Forms.dll
+ 2012-03-29 03:31 . 2012-03-29 03:31 1269760 c:\windows\assembly\GAC\System.Web\1.0.5000.0__b03f5f7f11d50a3a\System.Web.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 1703936 c:\windows\assembly\GAC\System.Design\1.0.5000.0__b03f5f7f11d50a3a\System.Design.dll
+ 2012-03-27 05:39 . 2012-03-27 05:39 1294336 c:\windows\assembly\GAC\System.Data\1.0.5000.0__b77a5c561934e089\System.Data.dll
+ 2012-03-27 05:38 . 2012-03-27 05:38 1564672 c:\windows\assembly\GAC\mscorcfg\1.0.5000.0__b03f5f7f11d50a3a\mscorcfg.dll
+ 2012-03-29 04:52 . 2012-03-29 04:52 1279864 c:\windows\assembly\GAC\Microsoft.Office.Interop.Excel\12.0.0.0__71e9bce111e9429c\Microsoft.Office.Interop.Excel.dll
+ 2011-07-26 01:27 . 2011-07-26 01:27 8007680 c:\windows\assembly\GAC\Microsoft.mshtml\7.0.3300.0__b03f5f7f11d50a3a\Microsoft.mshtml.dll
- 2009-10-01 01:41 . 2009-10-01 01:41 8007680 c:\windows\assembly\GAC\Microsoft.mshtml\7.0.3300.0__b03f5f7f11d50a3a\Microsoft.mshtml.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 2846720 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2903.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 2846720 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2903.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
- 2009-09-21 01:59 . 2009-09-21 01:59 2676224 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2011-12-09 03:39 . 2011-12-09 03:39 2676224 c:\windows\assembly\GAC\Microsoft.DirectX.Direct3DX\1.0.2902.0__31bf3856ad364e35\Microsoft.DirectX.Direct3DX.dll
+ 2010-08-10 23:30 . 2010-06-18 13:43 3558912 c:\windows\$hf_mig$\KB981997\SP3QFE\moviemk.exe
+ 2010-08-31 13:38 . 2010-08-31 13:38 1861888 c:\windows\$hf_mig$\KB981957\SP3QFE\win32k.sys
+ 2010-08-10 23:36 . 2010-04-27 13:50 2190080 c:\windows\$hf_mig$\KB981852\SP3QFE\ntoskrnl.exe
+ 2010-08-10 23:36 . 2010-04-27 13:14 2024448 c:\windows\$hf_mig$\KB981852\SP3QFE\ntkrpamp.exe
+ 2010-04-28 11:14 . 2010-04-28 11:14 2066944 c:\windows\$hf_mig$\KB981852\SP3QFE\ntkrnlpa.exe
+ 2010-08-10 23:36 . 2010-04-27 13:54 2146304 c:\windows\$hf_mig$\KB981852\SP3QFE\ntkrnlmp.exe
+ 2010-07-16 12:04 . 2010-07-16 12:04 1289216 c:\windows\$hf_mig$\KB979687\SP3QFE\ole32.dll
+ 2009-07-27 22:13 . 2009-07-27 22:13 8462848 c:\windows\$hf_mig$\KB971029\SP3QFE\shell32.dll
+ 2012-06-05 15:48 . 2012-06-05 15:48 1447936 c:\windows\$hf_mig$\KB2719985\SP3QFE\msxml6.dll
+ 2012-06-05 15:48 . 2012-06-05 15:48 1172480 c:\windows\$hf_mig$\KB2719985\SP3QFE\msxml3.dll
+ 2012-07-11 04:37 . 2012-06-13 13:29 1875072 c:\windows\$hf_mig$\KB2718523\SP3QFE\win32k.sys
+ 2012-05-15 13:27 . 2012-05-15 13:27 1872128 c:\windows\$hf_mig$\KB2709162\SP3QFE\win32k.sys
+ 2012-05-04 13:20 . 2012-05-04 13:20 2192640 c:\windows\$hf_mig$\KB2707511\SP3QFE\ntoskrnl.exe
+ 2012-05-04 12:41 . 2012-05-04 12:41 2026496 c:\windows\$hf_mig$\KB2707511\SP3QFE\ntkrpamp.exe
+ 2012-05-04 12:41 . 2012-05-04 12:41 2069120 c:\windows\$hf_mig$\KB2707511\SP3QFE\ntkrnlpa.exe
+ 2012-05-04 13:24 . 2012-05-04 13:24 2148352 c:\windows\$hf_mig$\KB2707511\SP3QFE\ntkrnlmp.exe
+ 2012-06-13 22:26 . 2012-05-11 14:41 1214464 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\urlmon.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 6009344 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\mshtml.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 2001408 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\iertutil.dll
+ 2012-06-08 14:24 . 2012-06-08 14:24 8463872 c:\windows\$hf_mig$\KB2691442\SP3QFE\shell32.dll
+ 2012-04-11 13:23 . 2012-04-11 13:23 1871360 c:\windows\$hf_mig$\KB2676562\SP3QFE\win32k.sys
+ 2012-04-11 13:22 . 2012-04-11 13:22 2192640 c:\windows\$hf_mig$\KB2676562\SP3QFE\ntoskrnl.exe
+ 2012-04-11 12:42 . 2012-04-11 12:42 2026496 c:\windows\$hf_mig$\KB2676562\SP3QFE\ntkrpamp.exe
+ 2012-04-11 12:42 . 2012-04-11 12:42 2069120 c:\windows\$hf_mig$\KB2676562\SP3QFE\ntkrnlpa.exe
+ 2012-04-11 13:26 . 2012-04-11 13:26 2148352 c:\windows\$hf_mig$\KB2676562\SP3QFE\ntkrnlmp.exe
+ 2012-04-11 07:33 . 2012-03-01 10:58 1214464 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\urlmon.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 5980672 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\mshtml.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 2001408 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\iertutil.dll
+ 2012-01-12 16:54 . 2012-01-12 16:54 1869056 c:\windows\$hf_mig$\KB2660465\SP3QFE\win32k.sys
+ 2012-02-16 07:52 . 2011-12-17 19:45 1214464 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\urlmon.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 5980160 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\mshtml.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 2001408 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\iertutil.dll
+ 2012-03-14 00:56 . 2012-02-03 09:26 1869184 c:\windows\$hf_mig$\KB2641653\SP3QFE\win32k.sys
+ 2011-11-23 13:29 . 2011-11-23 13:29 1868544 c:\windows\$hf_mig$\KB2639417\SP3QFE\win32k.sys
+ 2011-10-25 13:34 . 2011-10-25 13:34 2192768 c:\windows\$hf_mig$\KB2633171\SP3QFE\ntoskrnl.exe
+ 2011-10-25 12:52 . 2011-10-25 12:52 2027008 c:\windows\$hf_mig$\KB2633171\SP3QFE\ntkrpamp.exe
+ 2011-10-25 12:52 . 2011-10-25 12:52 2069376 c:\windows\$hf_mig$\KB2633171\SP3QFE\ntkrnlpa.exe
+ 2011-10-25 13:38 . 2011-10-25 13:38 2148864 c:\windows\$hf_mig$\KB2633171\SP3QFE\ntkrnlmp.exe
+ 2011-11-03 15:27 . 2011-11-03 15:27 1292288 c:\windows\$hf_mig$\KB2631813\SP3QFE\quartz.dll
+ 2011-11-01 16:05 . 2011-11-01 16:05 1289216 c:\windows\$hf_mig$\KB2624667\SP3QFE\ole32.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 1214464 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\urlmon.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 5978624 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\mshtml.dll
+ 2011-12-15 03:59 . 2011-11-04 19:19 2001408 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\iertutil.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 1214464 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\urlmon.dll
+ 2011-10-11 23:17 . 2011-10-03 08:34 5972992 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\mshtml.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 2001408 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\iertutil.dll
+ 2011-09-06 13:25 . 2011-09-06 13:25 1867904 c:\windows\$hf_mig$\KB2567053\SP3QFE\win32k.sys
+ 2011-08-10 13:56 . 2011-06-23 18:33 1214464 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\urlmon.dll
+ 2011-08-10 13:56 . 2011-07-25 15:15 5971456 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\mshtml.dll
+ 2011-08-10 13:56 . 2011-06-23 18:33 1992192 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\iertutil.dll
+ 2011-06-02 14:07 . 2011-06-02 14:07 1867904 c:\windows\$hf_mig$\KB2555917\SP3QFE\win32k.sys
+ 2011-06-16 22:25 . 2011-04-25 16:09 1213952 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\urlmon.dll
+ 2011-06-16 22:25 . 2011-05-30 22:17 5967360 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\mshtml.dll
+ 2011-06-16 22:25 . 2011-04-25 16:09 1992192 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\iertutil.dll
+ 2011-03-03 13:27 . 2011-03-03 13:27 1866880 c:\windows\$hf_mig$\KB2506223\SP3QFE\win32k.sys
+ 2011-04-14 11:29 . 2011-02-22 23:27 1212928 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\urlmon.dll
+ 2011-04-14 11:29 . 2011-02-22 23:27 5964800 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\mshtml.dll
+ 2011-04-14 11:29 . 2011-02-22 23:27 1992192 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\iertutil.dll
+ 2011-01-21 14:42 . 2011-01-21 14:42 8463360 c:\windows\$hf_mig$\KB2483185\SP3QFE\shell32.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 1211904 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\urlmon.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 5962240 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\mshtml.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 1992192 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\iertutil.dll
+ 2011-02-02 07:57 . 2011-02-02 07:57 2069504 c:\windows\$hf_mig$\KB2481109\SP3QFE\lhmstscx.dll
+ 2010-12-31 13:14 . 2010-12-31 13:14 1864064 c:\windows\$hf_mig$\KB2479628\SP3QFE\win32k.sys
+ 2010-10-26 13:27 . 2010-10-26 13:27 1862272 c:\windows\$hf_mig$\KB2436673\SP3QFE\win32k.sys
+ 2010-12-16 05:25 . 2010-11-06 00:27 1211904 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\urlmon.dll
+ 2010-12-16 05:25 . 2010-11-06 00:27 5960704 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\mshtml.dll
+ 2010-12-16 05:25 . 2010-11-06 00:27 1992192 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\iertutil.dll
+ 2011-02-09 23:28 . 2010-12-09 13:43 2192768 c:\windows\$hf_mig$\KB2393802\SP3QFE\ntoskrnl.exe
+ 2011-02-09 23:28 . 2010-12-09 13:09 2027008 c:\windows\$hf_mig$\KB2393802\SP3QFE\ntkrpamp.exe
+ 2010-12-09 23:39 . 2010-12-09 23:39 2069376 c:\windows\$hf_mig$\KB2393802\SP3QFE\ntkrnlpa.exe
+ 2011-02-09 23:28 . 2010-12-09 13:47 2148864 c:\windows\$hf_mig$\KB2393802\SP3QFE\ntkrnlmp.exe
+ 2010-10-13 22:28 . 2010-09-10 05:57 1211904 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\urlmon.dll
+ 2010-10-13 22:28 . 2010-09-10 05:57 5958656 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\mshtml.dll
+ 2010-10-13 22:28 . 2010-09-10 05:57 1987072 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\iertutil.dll
+ 2010-07-27 06:28 . 2010-07-27 06:28 8463360 c:\windows\$hf_mig$\KB2286198\SP3QFE\shell32.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 1211904 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\urlmon.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 5954560 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\mshtml.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 1987072 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\iertutil.dll
+ 2010-06-24 02:14 . 2010-06-24 02:14 1861120 c:\windows\$hf_mig$\KB2160329\SP3QFE\win32k.sys
+ 2010-06-14 07:39 . 2010-06-14 07:39 1172480 c:\windows\$hf_mig$\KB2079403\SP3QFE\msxml3.dll
- 2004-08-04 07:56 . 2009-07-14 03:43 10841088 c:\windows\system32\wmp.dll
+ 2004-08-04 07:56 . 2010-08-26 03:36 10841088 c:\windows\system32\wmp.dll
- 2009-04-19 17:48 . 2006-12-08 19:20 10528768 c:\windows\system32\RTLCPL.exe
+ 2009-04-19 17:48 . 2006-12-08 20:20 10528768 c:\windows\system32\RTLCPL.exe
+ 2011-11-26 17:44 . 2006-12-08 19:20 10528768 c:\windows\system32\ReinstallBackups\0007\DriverFiles\RTLCPL.EXE
+ 2006-08-12 04:42 . 2011-10-08 04:50 17956864 c:\windows\system32\nvoglnt.dll
+ 2006-08-12 04:43 . 2011-10-08 04:50 16744256 c:\windows\system32\nvcpl.dll
+ 2011-11-05 18:50 . 2011-10-08 04:50 17240064 c:\windows\system32\nvcompiler.dll
+ 2009-07-21 06:49 . 2012-09-12 12:11 62164608 c:\windows\system32\MRT.exe
+ 2007-08-13 22:54 . 2012-07-03 03:19 11111424 c:\windows\system32\ieframe.dll
+ 2006-08-12 04:42 . 2011-10-08 04:50 12791488 c:\windows\system32\drivers\nv4_mini.sys
- 2009-04-19 19:07 . 2009-07-14 03:43 10841088 c:\windows\system32\dllcache\wmp.dll
+ 2009-04-19 19:07 . 2010-08-26 03:36 10841088 c:\windows\system32\dllcache\wmp.dll
+ 2006-08-12 04:42 . 2011-10-08 04:50 12791488 c:\windows\system32\dllcache\nv4_mini.sys
+ 2009-04-19 19:31 . 2012-07-03 03:19 11111424 c:\windows\system32\dllcache\ieframe.dll
+ 2011-12-26 21:02 . 2011-12-26 21:02 12482048 c:\windows\Microsoft.NET\Framework\v1.1.4322\Updates\M2656353\M2656353Uninstall.msp
+ 2012-04-06 06:12 . 2012-04-06 06:12 15709696 c:\windows\Installer\e51b7cf.msp
+ 2012-01-04 06:25 . 2012-01-04 06:25 17751552 c:\windows\Installer\e51b7bd.msp
+ 2012-04-06 07:13 . 2012-04-06 07:13 16527872 c:\windows\Installer\e51b753.msp
+ 2011-12-15 17:40 . 2011-12-15 17:40 23374336 c:\windows\Installer\e51b746.msp
+ 2012-05-09 22:23 . 2012-05-09 22:23 20343808 c:\windows\Installer\e51b687.msp
+ 2009-04-04 21:09 . 2009-04-04 21:09 15190016 c:\windows\Installer\d709d23.msp
+ 2009-04-04 15:36 . 2009-04-04 15:36 21390848 c:\windows\Installer\d709d07.msp
+ 2010-10-14 21:57 . 2010-10-14 21:57 11189248 c:\windows\Installer\d30023.msp
+ 2011-12-14 04:45 . 2011-12-14 04:45 20333568 c:\windows\Installer\d1a6062.msp
+ 2005-09-24 06:35 . 2005-09-24 06:35 28551168 c:\windows\Installer\b80dee6.msp
+ 2011-07-26 01:28 . 2011-07-26 01:28 18181632 c:\windows\Installer\b2ddae1.msi
+ 2012-02-16 08:05 . 2012-02-16 08:05 20333056 c:\windows\Installer\ae5f5b.msp
+ 2010-08-18 14:12 . 2010-08-18 14:12 17516032 c:\windows\Installer\6f2c137.msp
+ 2011-04-27 23:21 . 2011-04-27 23:21 17515520 c:\windows\Installer\6dfae7a6.msp
+ 2011-02-24 13:38 . 2011-02-24 13:38 10984448 c:\windows\Installer\681eba2.msp
+ 2011-01-18 01:36 . 2011-01-18 01:36 17520128 c:\windows\Installer\681eb8b.msp
+ 2011-02-12 00:47 . 2011-02-12 00:47 12028928 c:\windows\Installer\681eb49.msp
+ 2008-04-23 08:54 . 2008-04-23 08:54 63086592 c:\windows\Installer\637a2d5.msp
+ 2011-09-15 22:37 . 2011-09-15 22:37 38176256 c:\windows\Installer\5cb1f77.msp
+ 2011-09-15 22:39 . 2011-09-15 22:39 11163136 c:\windows\Installer\5cb1f56.msp
+ 2011-09-15 22:38 . 2011-09-15 22:38 10838528 c:\windows\Installer\5cb1f49.msp
+ 2011-09-15 22:37 . 2011-09-15 22:37 16691712 c:\windows\Installer\5cb1e5d.msp
+ 2011-09-15 22:37 . 2011-09-15 22:37 34428416 c:\windows\Installer\5cb1e41.msp
+ 2012-05-12 07:59 . 2012-05-12 07:59 23771136 c:\windows\Installer\592c4aa.msp
+ 2011-12-26 13:02 . 2011-12-26 13:02 19677184 c:\windows\Installer\582ed3d.msp
+ 2012-04-04 11:17 . 2012-04-04 11:17 16613376 c:\windows\Installer\56c4c4a.msp
+ 2010-03-31 05:23 . 2010-03-31 05:23 15638528 c:\windows\Installer\51ed8b.msp
+ 2005-09-24 07:35 . 2005-09-24 07:35 28551168 c:\windows\Installer\4b295.msp
+ 2010-06-11 21:52 . 2010-06-11 21:52 45542912 c:\windows\Installer\3be8a074.msp
+ 2011-02-11 12:43 . 2011-02-11 12:43 10951168 c:\windows\Installer\35aaa1e5.msp
+ 2012-03-28 22:10 . 2012-03-28 22:10 12098048 c:\windows\Installer\308acf0.msp
+ 2011-07-12 00:43 . 2011-07-12 00:43 11641344 c:\windows\Installer\2b069e5.msp
+ 2011-07-11 21:19 . 2011-07-11 21:19 10619904 c:\windows\Installer\2b069c5.msp
+ 2011-03-28 07:27 . 2011-03-28 07:27 15456256 c:\windows\Installer\1b09542.msp
+ 2011-04-13 15:37 . 2011-04-13 15:37 19201024 c:\windows\Installer\1b09524.msp
+ 2010-05-19 17:08 . 2010-05-19 17:08 11408896 c:\windows\Installer\1adaab71.msp
+ 2011-07-26 20:33 . 2011-07-26 20:33 10984448 c:\windows\Installer\1a903de.msp
+ 2011-07-27 11:37 . 2011-07-27 11:37 11592192 c:\windows\Installer\1a9030f.msp
+ 2012-03-27 05:38 . 2012-03-27 05:38 19210240 c:\windows\Installer\18c99e1.msp
+ 2012-05-30 11:18 . 2012-05-30 11:18 11885056 c:\windows\Installer\17c9766d.msp
+ 2010-06-29 03:46 . 2010-06-29 03:46 17512960 c:\windows\Installer\178422db.msp
+ 2011-04-22 23:41 . 2011-04-22 23:41 11507712 c:\windows\Installer\12995252.msp
+ 2010-07-23 05:04 . 2010-07-23 05:04 11395072 c:\windows\Installer\12995062.msp
+ 2012-07-17 14:17 . 2012-07-17 14:17 22363136 c:\windows\Installer\114e899.msp
+ 2012-07-25 20:59 . 2012-07-25 20:59 11032064 c:\windows\Installer\114e883.msp
+ 2012-07-18 19:53 . 2012-07-18 19:53 10937344 c:\windows\Installer\114e827.msp
+ 2011-06-06 16:55 . 2011-06-06 16:55 24731544 c:\windows\Installer\$PatchCache$\Managed\68AB67CA7DA73301B744AA0100000010\10.1.0\AcroRd32.dll
+ 2011-09-16 00:42 . 2011-09-16 00:42 18115432 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.6612\WWLIB.DLL
+ 2006-10-27 19:07 . 2006-10-27 19:07 17891112 c:\windows\Installer\$PatchCache$\Managed\00002109030000000000000000F01FEC\12.0.4518\EXCEL.EXE
+ 2011-08-03 23:53 . 2011-08-03 23:53 17324928 c:\windows\Installer\$PatchCache$\Managed\00002109020090400000000000F01FEC\12.0.6612\MSO.DLL
+ 2012-08-15 05:44 . 2012-05-12 00:12 11111424 c:\windows\ie8updates\KB2722913-IE8\ieframe.dll
+ 2012-06-14 06:08 . 2012-03-02 10:01 11082752 c:\windows\ie8updates\KB2699988-IE8\ieframe.dll
+ 2012-04-11 12:54 . 2011-12-18 19:46 11082240 c:\windows\ie8updates\KB2675157-IE8\ieframe.dll
+ 2012-02-16 08:05 . 2011-11-04 19:20 11081728 c:\windows\ie8updates\KB2647516-IE8\ieframe.dll
+ 2011-12-15 05:50 . 2011-08-23 21:48 11081728 c:\windows\ie8updates\KB2618444-IE8\ieframe.dll
+ 2011-10-12 11:48 . 2011-06-23 18:36 11081728 c:\windows\ie8updates\KB2586448-IE8\ieframe.dll
+ 2011-08-11 12:00 . 2011-04-26 14:11 11081728 c:\windows\ie8updates\KB2559049-IE8\ieframe.dll
+ 2011-06-17 07:03 . 2011-02-22 23:06 11080704 c:\windows\ie8updates\KB2530548-IE8\ieframe.dll
+ 2011-04-15 07:09 . 2010-12-21 10:29 11080704 c:\windows\ie8updates\KB2497640-IE8\ieframe.dll
+ 2011-02-11 08:01 . 2010-11-06 00:26 11080704 c:\windows\ie8updates\KB2482017-IE8\ieframe.dll
+ 2010-12-16 08:03 . 2010-09-10 05:58 11080192 c:\windows\ie8updates\KB2416400-IE8\ieframe.dll
+ 2010-10-14 07:05 . 2010-06-24 21:51 11077120 c:\windows\ie8updates\KB2360131-IE8\ieframe.dll
+ 2010-08-12 03:39 . 2010-05-06 10:41 11076096 c:\windows\ie8updates\KB2183461-IE8\ieframe.dll
+ 2012-06-14 06:18 . 2012-06-14 06:18 13197824 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\54d61af44b1dedee6aea0d1bbc46b13a\System.Windows.Forms.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 17996800 c:\windows\assembly\NativeImages_v4.0.30319_32\System.ServiceModel\5be1370b1331393f73af710d0d71b02d\System.ServiceModel.ni.dll
+ 2012-05-09 23:34 . 2012-05-09 23:34 13324288 c:\windows\assembly\NativeImages_v4.0.30319_32\System.Data.Entity\65d0d6f4cdbc47ecd5cce9e959827fe8\System.Data.Entity.ni.dll
+ 2012-06-14 06:10 . 2012-06-14 06:10 17998848 c:\windows\assembly\NativeImages_v4.0.30319_32\PresentationFramewo#\5d585d5428ce69abc28238ffa9f4d3a2\PresentationFramework.ni.dll
+ 2012-06-14 06:10 . 2012-06-14 06:10 11451904 c:\windows\assembly\NativeImages_v4.0.30319_32\PresentationCore\fe068ba4be8f6cb7d6a58bccff05c75e\PresentationCore.ni.dll
+ 2012-05-09 22:27 . 2012-05-09 22:27 14412800 c:\windows\assembly\NativeImages_v4.0.30319_32\mscorlib\3953b1d8b9b57e4957bff8f58145384e\mscorlib.ni.dll
+ 2012-06-14 11:34 . 2012-06-14 11:34 12433920 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\01abbadafaf265d9f4ac9bbb247acb98\System.Windows.Forms.ni.dll
+ 2012-06-14 12:09 . 2012-06-14 12:09 11817472 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Web\dbc413807cb7360b3e26ef3ca1d54f9a\System.Web.ni.dll
+ 2012-05-09 22:45 . 2012-05-09 22:45 17403904 c:\windows\assembly\NativeImages_v2.0.50727_32\System.ServiceModel\bc254d2fa26664898ae21d45643bc194\System.ServiceModel.ni.dll
+ 2012-06-14 11:34 . 2012-06-14 11:34 10682368 c:\windows\assembly\NativeImages_v2.0.50727_32\System.Design\f73a8455f384e90f6925309336fece24\System.Design.ni.dll
+ 2012-06-14 06:20 . 2012-06-14 06:20 14329856 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationFramewo#\e4ecfaaf5417aceecb7fa8abddf06113\PresentationFramework.ni.dll
+ 2012-06-14 06:20 . 2012-06-14 06:20 12218368 c:\windows\assembly\NativeImages_v2.0.50727_32\PresentationCore\f33e2a4d9b385234406fa2d662f78875\PresentationCore.ni.dll
+ 2012-05-09 22:36 . 2012-05-09 22:36 11492352 c:\windows\assembly\NativeImages_v2.0.50727_32\mscorlib\e337c89bc9f81b69d7237aa70e935900\mscorlib.ni.dll
+ 2012-06-13 22:26 . 2012-05-11 14:41 11112960 c:\windows\$hf_mig$\KB2699988-IE8\SP3QFE\ieframe.dll
+ 2012-04-11 07:33 . 2012-03-01 10:58 11085312 c:\windows\$hf_mig$\KB2675157-IE8\SP3QFE\ieframe.dll
+ 2012-02-16 07:52 . 2011-12-17 19:45 11085312 c:\windows\$hf_mig$\KB2647516-IE8\SP3QFE\ieframe.dll
+ 2011-11-05 19:19 . 2011-11-05 19:19 11083776 c:\windows\$hf_mig$\KB2618444-IE8\SP3QFE\ieframe.dll
+ 2011-10-11 23:17 . 2011-08-22 23:47 11084288 c:\windows\$hf_mig$\KB2586448-IE8\SP3QFE\ieframe.dll
+ 2011-06-25 05:03 . 2011-06-25 05:03 11083776 c:\windows\$hf_mig$\KB2559049-IE8\SP3QFE\ieframe.dll
+ 2011-06-16 22:25 . 2011-04-25 16:09 11083776 c:\windows\$hf_mig$\KB2530548-IE8\SP3QFE\ieframe.dll
+ 2011-02-23 08:57 . 2011-02-23 08:57 11082752 c:\windows\$hf_mig$\KB2497640-IE8\SP3QFE\ieframe.dll
+ 2011-02-10 23:49 . 2010-12-20 23:58 11082752 c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\ieframe.dll
+ 2010-11-06 10:57 . 2010-11-06 10:57 11082752 c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\ieframe.dll
+ 2010-09-10 15:27 . 2010-09-10 15:27 11082240 c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\ieframe.dll
+ 2010-08-10 23:34 . 2010-06-24 12:24 11079168 c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\ieframe.dll
+ 2009-04-04 21:08 . 2009-04-04 21:08 343058432 c:\windows\Installer\d709e1a.msp
+ 2011-09-15 22:34 . 2011-09-15 22:34 428804608 c:\windows\Installer\5cb1f3d.msp
– Snapshot reset to current date –
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{ba14329e-9550-4989-b3f2-9732e92d17cc}"= "c:\program files\Vuze_Remote\prxtbVuz2.dll" [2011-05-09 176936]
[HKEY_CLASSES_ROOT\clsid\{ba14329e-9550-4989-b3f2-9732e92d17cc}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{ba14329e-9550-4989-b3f2-9732e92d17cc}]
2011-05-09 09:49 176936 —-a-w- c:\program files\Vuze_Remote\prxtbVuz2.dll
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar]
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\Webbrowser]
"{BA14329E-9550-4989-B3F2-9732E92D17CC}"= "c:\program files\Vuze_Remote\prxtbVuz2.dll" [2011-05-09 176936]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2012-04-04 843712]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
"DWQueuedReporting"="c:\progra~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" [2011-07-27 434080]
[hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
"{56F9679E-7826-4C84-81F3-532071A8BCC5}"= "c:\program files\Windows Desktop Search\MSNLNamespaceMgr.dll" [2009-05-25 304128]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Wdf01000.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WinDefend]
@="Service"
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Office.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Microsoft Office.lnk
backup=c:\windows\pss\Microsoft Office.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^NETGEAR WPN311 Smart Wizard.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\NETGEAR WPN311 Smart Wizard.lnk
backup=c:\windows\pss\NETGEAR WPN311 Smart Wizard.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^VPN Client.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\VPN Client.lnk
backup=c:\windows\pss\VPN Client.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Windows Search.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Windows Search.lnk
backup=c:\windows\pss\Windows Search.lnkCommon Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\KernelFaultCheck]
c:\windows\system32\dumprep 0 -k [X]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\UserFaultCheck]
c:\windows\system32\dumprep 0 -u [X]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\APSDaemon]
2012-02-21 01:28 59240 —-a-w- c:\program files\Common Files\Apple\Apple Application Support\APSDaemon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}]
2007-03-12 17:49 153136 —-a-w- c:\program files\Common Files\Ahead\Lib\NMBgMonitor.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
2008-04-14 00:12 15360 ——w- c:\windows\system32\ctfmon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\DivXUpdate]
2011-07-28 23:08 1259376 —-a-w- c:\program files\DivX\DivX Update\DivXUpdate.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Eraser]
2009-06-10 13:22 334224 —-a-w- c:\program files\Eraser\Eraser.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\InCD]
2007-03-12 22:53 1055792 —-a-w- c:\program files\Nero\Nero 7\InCD\InCD.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NvCplDaemon]
2011-10-08 04:50 16744256 —-a-w- c:\windows\system32\nvcpl.dll
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NvMediaCenter]
2011-10-08 04:50 203072 —-a-w- c:\windows\system32\nvmctray.dll
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\nwiz]
2011-10-08 04:50 1632360 —-a-w- c:\program files\NVIDIA Corporation\nview\nwiz.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
2011-07-05 22:36 421888 —-a-w- c:\program files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SoundMan]
2007-04-16 20:28 577536 —-a-w- c:\windows\soundman.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SunJavaUpdateSched]
2012-01-18 19:02 254696 —-a-w- c:\program files\Common Files\Java\Java Update\jusched.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Windows Defender]
2006-11-03 23:20 866584 —-a-w- c:\program files\Windows Defender\MSASCui.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
"YahooAUService"=2 (0x2)
"WMPNetworkSvc"=3 (0x3)
"WinDefend"=2 (0x2)
"Symantec AntiVirus"=2 (0x2)
"Steam Client Service"=3 (0x3)
"SmcService"=2 (0x2)
"RoxLiveShare9"=2 (0x2)
"PnkBstrA"=2 (0x2)
"ose"=3 (0x3)
"odserv"=3 (0x3)
"nvUpdatusService"=2 (0x2)
"NVSvc"=2 (0x2)
"NMSAccessU"=2 (0x2)
"NMIndexingService"=3 (0x3)
"NBService"=3 (0x3)
"LiveUpdate"=3 (0x3)
"JavaQuickStarterService"=2 (0x2)
"iPod Service"=3 (0x3)
"InCDsrv"=2 (0x2)
"idsvc"=3 (0x3)
"IDriverT"=3 (0x3)
"gusvc"=2 (0x2)
"gupdatem"=3 (0x3)
"gupdate1c9e6304563b6d2"=2 (0x2)
"CVPND"=2 (0x2)
"ccSetMgr"=2 (0x2)
"ccEvtMgr"=2 (0x2)
"Bonjour Service"=2 (0x2)
"ACS"=2 (0x2)
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecAntiVirus]
"DisableMonitoring"=dword:00000001
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"c:\\Program Files\\Yahoo!\\Messenger\\YahooMessenger.exe"=
"c:\\Program Files\\Windows Live\\Messenger\\wlcsdk.exe"=
"c:\\Program Files\\Mozilla Firefox\\firefox.exe"=
"c:\\Program Files\\Cabos\\Cabos.exe"=
"c:\\WINDOWS\\system32\\java.exe"=
"c:\\WINDOWS\\system32\\dpvsetup.exe"=
"c:\\Program Files\\VideoLAN\\VLC\\vlc.exe"=
"c:\\WINDOWS\\system32\\PnkBstrA.exe"=
"c:\\WINDOWS\\system32\\PnkBstrB.exe"=
"c:\\Program Files\\Windows Live\\Messenger\\msnmsgr.exe"=
"c:\\WINDOWS\\system32\\mmc.exe"=
"c:\\Program Files\\Google\\Google Earth\\client\\googleearth.exe"=
"c:\\Program Files\\Google\\Google Earth\\plugin\\geplugin.exe"=
"c:\\Documents and Settings\\Basilio\\Application Data\\Macromedia\\Flash Player\\www.macromedia.com\\bin\\octoshape\\octoshape.exe"=
"c:\\Program Files\\Common Files\\Ahead\\Nero Web\\SetupX.exe"=
"c:\\Program Files\\Steam\\Steam.exe"=
"c:\\Program Files\\Bonjour\\mDNSResponder.exe"=
"c:\\Program Files\\NVIDIA Corporation\\NVIDIA Updatus\\daemonu.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\swkotor\\swkotor.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\star wars battlefront ii\\GameData\\BattlefrontII.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\Rome Total War Gold\\RomeTW.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\Rome Total War Gold\\RomeTW-BI.exe"=
"c:\\Program Files\\BitPim\\bitpimw.exe"=
"c:\\Program Files\\Common Files\\Apple\\Apple Application Support\\WebKit2WebProcess.exe"=
"c:\\Program Files\\iTunes\\iTunes.exe"=
"c:\\WINDOWS\\system32\\dmremote.exe"=
"c:\\Program Files\\Pando Networks\\Media Booster\\PMB.exe"=
"c:\\Program Files\\Turbine\\The Lord of the Rings Online\\lotroclient.exe"=
"c:\\Program Files\\Symantec\\Symantec Endpoint Protection\\12.1.1000.157.105\\Bin\\Smc.exe"=
"c:\\Program Files\\Symantec\\Symantec Endpoint Protection\\12.1.1000.157.105\\Bin\\snac.exe"=
"c:\\Program Files\\Vuze\\Azureus.exe"=
"c:\\Program Files\\Skype\\Phone\\Skype.exe"=
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
"135:TCP"= 135:TCP:RPC Port
"58706:TCP"= 58706:TCP:Pando Media Booster
"58706:UDP"= 58706:UDP:Pando Media Booster
R0 sptd;sptd;c:\windows\system32\drivers\sptd.sys [11/22/2009 10:51 PM 691696]
R0 SymDS;Symantec Data Store;c:\windows\system32\drivers\SEP\0C0103E8\009D.105\x86\SymDS.sys [10/30/2011 7:23 PM 340088]
R0 SymEFA;Symantec Extended File Attributes;c:\windows\system32\drivers\SEP\0C0103E8\009D.105\x86\SymEFA.sys [10/30/2011 7:23 PM 758904]
R1 BHDrvx86;BHDrvx86;c:\documents and settings\All Users\Application Data\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Data\Definitions\BASHDefs\20120823.013\BHDrvx86.sys [8/2/2012 9:43 PM 821920]
R1 SymIRON;Symantec Iron Driver;c:\windows\system32\drivers\SEP\0C0103E8\009D.105\x86\Ironx86.sys [10/30/2011 7:23 PM 137336]
R2 cpuz135;cpuz135;c:\windows\system32\drivers\cpuz135_x32.sys [11/5/2011 12:46 PM 21992]
R2 SepMasterService;Symantec Endpoint Protection;c:\program files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\ccSvcHst.exe [10/30/2011 7:23 PM 137224]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [9/13/2012 1:52 AM 106656]
R3 IDSxpx86;IDSxpx86;c:\documents and settings\All Users\Application Data\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Data\Definitions\IPSDefs\20120912.001\IDSXpx86.sys [9/13/2012 1:52 AM 373728]
S0 rglfgg;rglfgg; [x]
S1 sensorsview;sensorsview;\??\c:\program files\SensorsViewPro41\drv\sensorsview32.sys –> c:\program files\SensorsViewPro41\drv\sensorsview32.sys [?]
S2 gupdate1c9e6304563b6d2;Google Update Service (gupdate1c9e6304563b6d2);c:\program files\Google\Update\GoogleUpdate.exe [6/5/2009 6:52 PM 133104]
S2 Skype C2C Service;Skype C2C Service;c:\documents and settings\All Users\Application Data\Skype\Toolbars\Skype C2C Service\c2c_service.exe [8/13/2012 1:33 PM 3064000]
S2 SkypeUpdate;Skype Updater;c:\program files\Skype\Updater\Updater.exe [7/3/2012 1:52 PM 160944]
S2 xdgjddwbvrch;xdgjddwbvrch;\??\c:\windows\system32\drivers\bwpszulejjafpe.sys –> c:\windows\system32\drivers\bwpszulejjafpe.sys [?]
S3 AdobeFlashPlayerUpdateSvc;Adobe Flash Player Update Service;c:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe [4/13/2012 2:57 PM 250568]
S3 audiobridge;Virtual Audio Bridge;c:\windows\system32\drivers\aubridge.sys [7/23/2007 3:04 PM 22528]
S3 DrvAgent32;DrvAgent32;c:\windows\system32\drivers\DrvAgent32.sys [11/5/2011 2:08 PM 23456]
S3 gupdatem;Google Update Service (gupdatem);c:\program files\Google\Update\GoogleUpdate.exe [6/5/2009 6:52 PM 133104]
S3 iscFlash;iscFlash;\??\c:\windows\SYSTEM32\DRIVERS\iscflash.sys –> c:\windows\SYSTEM32\DRIVERS\iscflash.sys [?]
S3 MotDev;Motorola Inc. USB Device;c:\windows\system32\drivers\motodrv.sys [4/19/2010 11:57 PM 42752]
S3 MozillaMaintenance;Mozilla Maintenance Service;c:\program files\Mozilla Maintenance Service\maintenanceservice.exe [4/25/2012 8:09 PM 114144]
S3 pbfilter;pbfilter;c:\program files\PeerBlock\pbfilter.sys [3/2/2010 11:38 PM 14424]
S3 SyDvCtrl;SyDvCtrl;c:\program files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\SyDvCtrl32.sys [10/30/2011 7:23 PM 23984]
S4 nvUpdatusService;NVIDIA Update Service Daemon;c:\program files\NVIDIA Corporation\NVIDIA Updatus\daemonu.exe [11/5/2011 2:51 PM 2253120]
S4 WinDefend;Windows Defender;c:\program files\Windows Defender\MsMpEng.exe [11/3/2006 7:19 PM 13592]
2012-09-06 c:\windows\Tasks\Adobe Flash Player Updater.job
- c:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe [2012-04-13 06:18]
2012-09-06 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2011-06-01 21:57]
2012-09-06 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2009-06-24 23:10]
2012-09-06 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2009-06-05 22:52]
2012-09-06 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-08-31 c:\windows\Tasks\MP Scheduled Scan.job
- c:\program files\Windows Defender\MpCmdRun.exe [2006-11-03 23:20]
——- Supplementary Scan ——-
uStart Page = hxxp://www.google.com/
mStart Page = hxxp://www.yahoo.com
uInternet Settings,ProxyOverride = ;*.local
IE: &Download All using 4shared Desktop - c:\program files\4shared\down_all.htm
IE: Add to Google Photos Screensa&ver - c:\windows\system32\GPhotos.scr/200
IE: Convert link target to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert link target to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert selected links to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
IE: Convert selected links to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
IE: Convert selection to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert selection to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\Office12\EXCEL.EXE/3000
IE: I&M Chat
IE: V&oice Call
IE: Vi&deo Call
Trusted Zone: nyu.edu\ezproxy.library
TCP: DhcpNameServer = 75.75.75.75 75.75.76.76
DPF: {8C28EFD7-767B-11D1-844B-0060972DC2AC} - hxxps://brioportal.adcom.its.nyu.edu:7411/Hyperion/zeroadmin/component/Brio.InsightNoHelp.en.cab
FF - ProfilePath - c:\documents and settings\Basilio\Application Data\Mozilla\Firefox\Profiles\3lkkb686.default\
FF - prefs.js: browser.search.selectedEngine - Bing
FF - prefs.js: network.proxy.type - 4
FF - user.js: yahoo.ytff.general.dontshowhpoffer - true
- - - - ORPHANS REMOVED - - - -
Notify-SEP - c:\program files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\WinLogoutNotifier.dll
MSConfigStartUp-ccApp - c:\program files\Common Files\Symantec Shared\ccApp.exe
MSConfigStartUp-eezPixTray - c:\program files\eezPix\eezPix.exe
MSConfigStartUp-MS Essential - c:\documents and settings\Basilio\Application Data\explorer.exe
MSConfigStartUp-Otanofulohoqu - c:\windows\relbgr.dll
catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2012-09-13 23:54
Windows 5.1.2600 Service Pack 3 NTFS
scanning hidden processes …
scanning hidden autostart entries …
scanning hidden files …
[HKEY_LOCAL_MACHINE\System\ControlSet002\Services\SepMasterService]
"ImagePath"="\"c:\program files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\ccSvcHst.exe\" /s \"Symantec Endpoint Protection\" /m \"c:\program files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\sms.dll\" /prefetch:1"
[HKEY_LOCAL_MACHINE\System\ControlSet002\Services\SmcService]
"ImagePath"="\"c:\program files\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Bin\Smc.exe\" /prefetch:1"
——————— LOCKED REGISTRY KEYS ———————
[HKEY_USERS\S-1-5-21-57989841-1563985344-1801674531-1003\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\{393A3D74-FF25-6470-7279-1C405D8A3A18}*]
@Allowed: (Read) (RestrictedCode)
"iappfkeicinhjilolm"=hex:69,61,6f,6e,6d,6e,66,66,6a,62,6d,6b,6c,66,6b,6e,6a,67,
00,00
"hajphhmblknjdinc"=hex:6a,61,61,6e,6b,69,64,61,61,62,69,6f,6e,6b,68,6c,6d,6c,
63,65,00,00
[HKEY_LOCAL_MACHINE\software\Microsoft\DbgagD\1*]
"value"="?\0b\02\16\03\19$?"
[HKEY_LOCAL_MACHINE\software\Symantec\Symantec Endpoint Protection\CurrentVersion]
"SymbolicLinkValue"=hex(6):5c,00,52,00,65,00,67,00,69,00,73,00,74,00,72,00,79,
00,5c,00,4d,00,61,00,63,00,68,00,69,00,6e,00,65,00,5c,00,53,00,4f,00,46,00,\
Completion time: 2012-09-13 23:58:36
ComboFix-quarantined-files.txt 2012-09-14 03:58
ComboFix2.txt 2010-06-22 12:24
ComboFix3.txt 2009-09-27 19:00
ComboFix4.txt 2009-07-23 05:41
Pre-Run: 24,119,042,048 bytes free
Post-Run: 24,730,066,944 bytes free
WindowsXP-KB310994-SP2-Pro-BootDisk-ENU.exe
[boot loader]
timeout=2
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
c:\cmdcons\BOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
UnsupportedDebug="do not select this" /debug
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
- - End Of File - - D439A736155F023DE577EA177F1D7078
You are doing great and I'm glad to hear things are doing better. We still have several steps left to go. That was a long log! :) I did see a couple of things in there I'd like to still get rid of.
1. Close any open browsers.
2. Close/disable all anti virus and anti malware programs so they do not interfere with the running of ComboFix.
3. Open notepad and copy/paste the text in the quotebox below into it:
File::
Driver::
rglfgg
xdgjddwbvrch
Save this as "CFScript.txt", and as Type: All Files (*.*) in the same location as ComboFix.exe
Refering to the picture above, drag CFScript into ComboFix.exe. ComboFix may request an update; please allow it.
When finished, it shall produce a log for you at C:\ComboFix.txt which I will require in your next reply.
Please reboot the computer after doing this (if it does not do so) and then let me know if there is any additional improvement in how it is behaving.
Thanks Doris! I just noticed this and didn't get a chance to do it yet. I'll push it through tomorrow and let you know the result! Thanks again for patiently helping me through all of this. Be back soon with an update.
Hi Doris,
I managed to do exactly as you said, and ComboFix worked well (it did require a reboot). The below is the log that it came up with!
The computer seems to be starting up normally now, when before this scan it was at about 80-90%. I don't notice anything odd or remiss, and see no odd pop-ups when I start up or power down the computer (I saw one or two before the current scan, two-three days ago). It generally seems to be running quite smoothly and normally!
By the way, I wanted to ask you, is TDSSKiller an effective anti-malware tool I can use regularly for general scans, or should I remove it from my computer as well, along with the other tools after all of this is over?
Thanks!
ComboFix 12-09-20.01 - Basilio 09/20/2012 8:24.7.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.2047.1438 [GMT -4:00]
Running from: c:\documents and settings\[removed]\Desktop\ComboFix.exe
Command switches used :: c:\documents and settings\Basilio\Desktop\CFScript.txt
AV: Symantec Endpoint Protection *Disabled/Updated* {FB06448E-52B8-493A-90F3-E43226D3305C}
FILE ::
"c:\windows\system32\drivers\bwpszulejjafpe.sys"
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
c:\documents and settings\Basilio\Application Data\PriceGong
c:\documents and settings\Basilio\Application Data\PriceGong\Data\1.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\a.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\b.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\c.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\d.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\e.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\f.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\g.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\h.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\i.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\j.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\k.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\l.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\m.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\mru.xml
c:\documents and settings\Basilio\Application Data\PriceGong\Data\n.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\o.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\p.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\q.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\r.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\s.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\t.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\u.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\v.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\w.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\wlu.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\x.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\y.txt
c:\documents and settings\Basilio\Application Data\PriceGong\Data\z.txt
((((((((((((((((((((((((((((((((((((((( Drivers/Services )))))))))))))))))))))))))))))))))))))))))))))))))
——-\Legacy_RGLFGG
——-\Legacy_XDGJDDWBVRCH
——-\Service_rglfgg
——-\Service_xdgjddwbvrch
((((((((((((((((((((((((( Files Created from 2012-08-20 to 2012-09-20 )))))))))))))))))))))))))))))))
2012-09-13 06:49 . 2012-09-13 06:49 73696 —-a-w- c:\program files\Mozilla Firefox\breakpadinjector.dll
2012-09-03 19:39 . 2012-09-03 19:39 ——– d—–w- c:\documents and settings\LocalService\Local Settings\Application Data\Adobe
2012-08-31 06:18 . 2012-04-13 18:57 696520 —-a-w- c:\windows\system32\FlashPlayerApp.exe
2012-08-31 06:18 . 2011-05-22 15:25 73416 —-a-w- c:\windows\system32\FlashPlayerCPLApp.cpl
2012-08-17 03:11 . 2012-08-17 03:11 60872 —-a-w- c:\windows\system32\S32EVNT1.DLL
2012-08-17 03:11 . 2012-08-17 03:11 127096 —-a-w- c:\windows\system32\drivers\SYMEVENT.SYS
2012-08-17 03:10 . 2012-08-17 03:10 90032 —-a-w- c:\windows\system32\drivers\SysPlant.sys
2012-08-17 03:10 . 2012-08-17 03:10 76208 —-a-w- c:\windows\system32\FwsVpn.dll
2012-08-17 03:10 . 2012-08-17 03:10 374704 —-a-w- c:\windows\system32\sysfer.dll
2012-08-17 03:10 . 2012-08-17 03:10 32208 —-a-w- c:\windows\system32\drivers\WGX.SYS
2012-08-17 03:10 . 2012-08-17 03:10 241584 —-a-w- c:\windows\system32\SymVPN.dll
2012-08-17 03:10 . 2012-08-17 03:10 10672 —-a-w- c:\windows\system32\sysferThunk.dll
2012-08-15 16:52 . 2012-08-15 16:52 4472832 —-a-w- c:\windows\system32\GPhotos.scr
2012-07-06 13:58 . 2001-08-23 12:00 78336 —-a-w- c:\windows\system32\browser.dll
2012-07-04 14:05 . 2009-04-18 21:30 139784 —-a-w- c:\windows\system32\drivers\rdpwd.sys
2012-07-03 17:46 . 2009-04-20 11:47 22344 —-a-w- c:\windows\system32\drivers\mbam.sys
2012-07-03 13:40 . 2001-08-23 12:00 1866112 —-a-w- c:\windows\system32\win32k.sys
2012-07-02 17:49 . 2010-04-18 06:10 916992 —-a-w- c:\windows\system32\wininet.dll
2012-07-02 17:49 . 2001-08-23 12:00 43520 —-a-w- c:\windows\system32\licmgr10.dll
2012-07-02 17:49 . 2001-08-23 12:00 1469440 ——w- c:\windows\system32\inetcpl.cpl
2012-07-02 12:05 . 2004-08-04 05:59 385024 —-a-w- c:\windows\system32\html.iec
2012-06-27 19:18 . 2012-08-19 07:23 19072 —-a-w- c:\windows\system32\drivers\pccsmcfd.sys
2012-09-13 06:49 . 2011-12-17 18:07 266720 —-a-w- c:\program files\mozilla firefox\components\browsercomps.dll
((((((((((((((((((((((((((((( SnapShot_2012-09-14_03.54.57 )))))))))))))))))))))))))))))))))))))))))
+ 2012-09-20 12:35 . 2012-09-20 12:35 16384 c:\windows\temp\Perflib_Perfdata_f0.dat
- 2009-10-01 19:43 . 2012-09-13 05:54 32768 c:\windows\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\index.dat
+ 2009-10-01 19:43 . 2012-09-19 07:12 32768 c:\windows\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\index.dat
+ 2009-04-18 21:34 . 2012-09-19 07:12 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat
- 2009-04-18 21:34 . 2012-09-13 05:54 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat
+ 2012-09-14 04:03 . 2012-09-19 07:12 16384 c:\windows\system32\config\systemprofile\Cookies\index.dat
- 2010-06-22 23:40 . 2012-09-13 05:54 16384 c:\windows\system32\config\systemprofile\Cookies\index.dat
+ 2012-09-16 15:09 . 2012-09-16 15:09 22016 c:\windows\Installer\38cf5.msi
@="Driver"
@="Service"
"WinDefend"=2 (0x2)
"PnkBstrA"=2 (0x2)
"ose"=3 (0x3)
"odserv"=3 (0x3)
"NVSvc"=2 (0x2)
"NBService"=3 (0x3)
"InCDsrv"=2 (0x2)
"idsvc"=3 (0x3)
"IDriverT"=3 (0x3)
"gusvc"=2 (0x2)
"gupdatem"=3 (0x3)
"CVPND"=2 (0x2)
"ccSetMgr"=2 (0x2)
"ccEvtMgr"=2 (0x2)
"ACS"=2 (0x2)
R1 BHDrvx86;BHDrvx86;c:\documents and settings\All Users\Application Data\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Data\Definitions\BASHDefs\20120905.011\BHDrvx86.sys [9/4/2012 8:12 PM 995488]
R2 Skype C2C Service;Skype C2C Service;c:\documents and settings\All Users\Application Data\Skype\Toolbars\Skype C2C Service\c2c_service.exe [8/13/2012 1:33 PM 3064000]
R3 IDSxpx86;IDSxpx86;c:\documents and settings\All Users\Application Data\Symantec\Symantec Endpoint Protection\12.1.1000.157.105\Data\Definitions\IPSDefs\20120918.001\IDSXpx86.sys [9/19/2012 3:10 AM 373728]
2012-09-16 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
2012-09-16 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
IE: &Download; All using 4shared Desktop - c:\program files\4shared\down_all.htm
IE: Add to Google Photos Screensa&ver; - c:\windows\system32\GPhotos.scr/200
IE: E&xport; to Microsoft Excel - c:\progra~1\MICROS~2\Office12\EXCEL.EXE/3000
IE: I&M; Chat
IE: V&oice; Call
IE: Vi&deo; Call
Rootkit scan 2012-09-20 08:36
00,00
63,65,00,00
——————— DLLs Loaded Under Running Processes ———————
- - - - - - - > 'explorer.exe'(724)
c:\windows\system32\WININET.dll
c:\windows\system32\webcheck.dll
c:\windows\system32\WPDShServiceObj.dll
c:\windows\system32\PortableDeviceTypes.dll
c:\windows\system32\PortableDeviceApi.dll
———————— Other Running Processes ————————
c:\program files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
c:\windows\system32\SearchIndexer.exe
c:\windows\System32\wbem\unsecapp.exe
c:\windows\system32\devldr32.exe
Completion time: 2012-09-20 08:43:18 - machine was rebooted
ComboFix-quarantined-files.txt 2012-09-20 12:43
ComboFix2.txt 2012-09-14 03:58
ComboFix3.txt 2010-06-22 12:24
ComboFix4.txt 2009-09-27 19:00
ComboFix5.txt 2012-09-20 12:22
Pre-Run: 9,694,674,944 bytes free
Post-Run: 9,553,625,088 bytes free
- - End Of File - - AB518BBB885EC46E62DEB68B2CE53FBE
TDSSKiller is a tool we use just to see what's going on and to see if you have any rootkits on your machine. It is not something you will need to keep after we are done.
Let's scan with one more tool to ensure nothing has been missed before we do our clean up of tools.
This scan make take awhile depending on how many items are on the computer. You may want to run it at a time you won't be needing the machine. It should be run from IE and I'd recommend not doing anything else while it's running.
Go here to run an online scannner from ESET.
  • Note: For browsers other than Internet Explorer, you will need to download and install esetsmartinstaller_enu.exe. Click on it and save the file to a convenient location. Double click on it to install and a new window will open.
  • Turn off the real time scanner of any existing antivirus program while performing the online scan
  • Tick the box next to YES, I accept the Terms of Use.
  • Click Start
  • When asked, allow the activex control to install
  • Click Start
  • Make sure that the option Remove found threats is unticked and the Scan Archives option is ticked.
  • Click on Advanced Settings, ensure the options Scan for potentially unwanted applications, Scan for potentially unsafe applications, and Enable Anti-Stealth Technology are ticked.
  • Click Scan
  • Wait for the scan to finish
  • Use notepad to open the logfile located at C:\Program Files\Eset\Eset Online Scanner\log.txt
  • Copy and paste that log as a reply to this topic and also let me know how things are now.
Hi Doris, I managed to run the ESET program as you requested, off of my IE browser. It found quite a few things, to my surprise. Here is the log below! As for the performance of my computer, it seems to run normally now. No slowdowns or odd popups appearing. But I guess there can be many things lurking beneath. Thanks for your help, as always. Let me know what else you would like me to do! ———— ESETSmartInstaller@High as CAB hook log: OnlineScanner.ocx - registred OK # version=7 # iexplore.exe=8.00.6001.18702 (longhorn_ie8_rtm(wmbla).090308-0339) # OnlineScanner.ocx=1.0.0.6583 # api_version=3.0.2 # EOSSerial=b29d251b1c0d9842bffb66c958bc4c1a # end=finished # remove_checked=false # archives_checked=true # unwanted_checked=true # unsafe_checked=true # antistealth_checked=true # utc_time=2012-09-25 05:53:35 # local_time=2012-09-25 01:53:35 (-0500, Eastern Daylight Time) # country="United States" # lang=1033 # osver=5.1.2600 NT Service Pack 3 # compatibility_mode=512 16777215 100 0 100763667 100763667 0 0 # compatibility_mode=1024 16777215 100 0 107447864 107447864 0 0 # compatibility_mode=6143 16777215 0 0 0 0 0 0 # compatibility_mode=8192 67108863 100 0 98861552 98861552 0 0 # scanned=210348 # found=5 # cleaned=0 # scan_time=11865 C:\Documents and Settings\Basilio\Application Data\Sun\Java\Deployment\cache\6.0\52\42057fb4-1a42658c a variant of Java/JShrink.A application (unable to clean) 00000000000000000000000000000000 I C:\Program Files\Vuze\.install4j\i4j_extf_31_5p83tu.dll a variant of Win32/Bunndle application (unable to clean) 00000000000000000000000000000000 I C:\Program Files\Vuze\.install4j\i4j_extf_32_5p83tu.dll a variant of Win32/Bunndle application (unable to clean) 00000000000000000000000000000000 I C:\System Volume Information\_restore{BC17AB69-6FCB-4B36-9FE8-A03D8344ECB5}\RP975\A0227494.exe Win32/SpeedUpMyPC application (unable to clean) 00000000000000000000000000000000 I F:\Unlocker\eBay_shortcuts_1016.exe Win32/Adware.ADON application (unable to clean) 00000000000000000000000000000000 I
