Picture, if you will, a Circle. Any Circle.
Your task, should you choose to accept it, is to determine how many distinct areas you can divide the circle into - using only a maximum of 5 straight lines (that means no "crooked" lines are allowed).
I preach against this, it's a pentagram inside of a circle, many of the occult use this to worship, but if you follow the lines through from end to end you will have 16 sections.
