My name is Tomk. I would be glad to take a look at your log and help you with solving any malware problems. Logs can take a while to research, so please be patient and I'd be grateful if you would note the following:
I will be working on your Malware issues, this may or may not, solve other issues you have with your machine.
The fixes are specific to your problem and should only be used for the issues on this machine.
Please continue to review my answers until I tell you your machine appears to be clear. Absence of symptoms does not mean that everything is clear.
It's often worth reading through these instructions and printing them for ease of reference.
If you don't know or understand something, please don't hesitate to say or ask!! It's better to be sure and safe than sorry.
Please reply to this thread. Do not start a new topic.
The legitimate conime.exe is a Windows process (not a virus). It is only used for asian languages. If you only speak (and read) english… you don't need it.
However, there is a virus that "mimics" this legitimate name. I need more information in order to determine which one you have.
Download the GMER Rootkit Scanner. Unzip it to your Desktop.
Before scanning, make sure all other running programs are closed and no other actions like a scheduled antivirus scan will occur while the scan is being performed. Do not use your computer for anything else during the scan.
Double-click gmer.exe. The program will begin to run.
**Caution**
These types of scans can produce false positives. Do NOT take any action on any "<— ROOKIT"entries unless advised!
If possible rootkit activity is found, you will be asked if you would like to perform a full scan.
Click NO
In the right panel, you will see a bunch of boxes that have been checked … leave everything checked and ensure the Show all box is un-checked.
Now click the Scan button. Once the scan is complete, you may receive another notice about rootkit activity.
Click OK.
GMER will produce a log. Click on the [Save..] button, and in the File name area, type in "GMER.txt"
Save it where you can easily find it, such as your desktop.
If you do not receive notice about possible rootkit activity remain on the Rootkit/Malware tab & make sure the 'Show All' button is unticked.
Click the Scan button and let the program do its work. GMER will produce a log. Click on the [Save..] button, and in the File name area, type in "Gmer.txt" or it will save as a .log file which cannot be uploaded to your post.
Please download DDS by sUBs from one of the following links and save it to your desktop.
Double click DDS icon to run the tool (may take up to 3 minutes to run)
When done, DDS.txt will open.
After a few moments, attach.txt will open in a second window.
Save both reports to your desktop.
Post the contents of the DDS.txt report in your next reply
Attach the Attach.txt report to your post by scroling down to the Attachments area and then clicking Browse. Browse to where you saved the file, and click Open and the click UPLOAD.
hi tomk.
i would just like to let you know that my reply with the log will take from 4days to a week as i have exams and other higher priorities coming up.
so just a warning for you there.
thanks for your help. ill get the log up asap
