What the Tech logo
Welcome! Register for a free account (or login) > How does it work?
  1. Quickly register. It will only take 60 seconds.
  2. Start a new topic. Ask your question. Wait for an email reply.
  3. Is your system infected? Begin reading the malware removal guide.
register button
Reply to this topicStart new topic
> Wireless Network Connection problems
lxl
post Mar 14 2009, 02:08 PM
Post #1
Group: Authentic Member
Operating System: Windows XP, Windows Vista
Recently, my laptop seems to be unable to go onto the internet although the icon on the system tray shows that I'm connected and signal strength is excellent.
Go to the top of the page
+Quote Post
Posts in this topic
- lxl   Wireless Network Connection problems   Mar 14 2009, 02:08 PM
- - tallin   Hi lxl, Have you right clicked on the icon and at...   Mar 14 2009, 02:46 PM
- - lxl   I have tried using the repair option before but it...   Mar 14 2009, 03:18 PM
- - tallin   When you right click on the icon in the Systems Tr...   Mar 14 2009, 03:42 PM
- - lxl   Tallin, Sorry for my wording on my last post. I m...   Mar 14 2009, 08:15 PM
- - lxl   By the way, my problem seems to be similar to dave...   Mar 17 2009, 12:28 PM
- - tallin   Hi lxl, You mention Dave34 link. I looked it up t...   Mar 17 2009, 12:45 PM
- - Ztruker   Hi lxl. Do you let Windows manage your wireless ...   Mar 18 2009, 05:33 PM
- - lxl   Tallin: I don't think it's a problem with...   Mar 18 2009, 08:25 PM
- - HFCG   Hello, In post # 1 you state that you have good si...   Mar 19 2009, 10:43 AM
- - Ztruker   Check in Services and make sure Wireless Zero Conf...   Mar 19 2009, 06:37 PM
- - lxl   I did both of the instructions above but didn...   Mar 20 2009, 10:18 PM
- - Ztruker   Try the following: Click on Start then Run, type ...   Mar 21 2009, 06:11 PM
- - lxl   Thanks you very much Ztruker. Seems to be able to...   Mar 22 2009, 07:25 PM
- - Ztruker   You're welcome. I'm glad that did the tric...   Mar 22 2009, 07:44 PM
- - lxl   Ztruker, The problem came back again and resettin...   Mar 23 2009, 09:56 PM
- - lxl   The problem came back again after I shutdown my co...   Mar 24 2009, 06:16 PM
- - Ztruker   Okay, pleas run ipconfig /all from a command promp...   Mar 24 2009, 06:55 PM
- - lxl   Here's the data: Windows IP Configuration ...   Mar 25 2009, 06:08 PM
- - Ztruker   Okay, you are definitely not connected to the wire...   Mar 25 2009, 09:09 PM
- - lxl   The weird thing is sometimes the internet works fo...   Mar 26 2009, 06:21 PM
- - Ztruker   One last possibility would be to see if there is a...   Mar 26 2009, 07:50 PM
- - lxl   Ztruker, Winsock fix didn't work. Is there a ...   Mar 26 2009, 09:19 PM
- - Ztruker   Yes, it's always possible that the NIC has a p...   Mar 27 2009, 05:18 PM
- - appleoddity   Hi Lxl.... First of all, this appears to be Window...   Mar 28 2009, 10:51 AM
- - lxl   Ztruker: The router is Air Plus G from D-link. a...   Mar 28 2009, 01:52 PM
- - Ztruker   There are several D-Link Air Plus G router models,...   Mar 28 2009, 07:10 PM
- - appleoddity   Limited or no connectivity happens if you don...   Mar 28 2009, 08:27 PM
- - lxl   I'll be right back with the make/model of my r...   Mar 29 2009, 07:30 PM
- - lxl   Sorry for the late post, the internet was working ...   Apr 7 2009, 09:16 PM
- - tuxmaster   lxl Go ahead and post something over in the Win...   Apr 9 2009, 12:04 AM
- - Ztruker   Which version? There are 4 DI-524 routers, each ha...   Apr 9 2009, 08:03 PM
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   0 Oh! Lonesome Me 16 Yesterday, 06:02 PM
Last post by: Oh! Lonesome Me
No New Posts   6 Helpless Oldie 120 Yesterday, 01:12 PM
Last post by: JonTom
No New Posts   13 Ol' Baldy 238 16th March 2010 - 03:03 PM
Last post by: Ztruker
No New Posts   8 Alex Saucedo 227 15th March 2010 - 12:13 AM
Last post by: heronfisher
RSS Time is now: 18th March 2010 - 05:07 AM
Advertisements do not imply our endorsement of that product or service. The forum is run by volunteers who donate their time and expertise. We make every attempt to ensure that the help and advice posted is accurate and will not cause harm to your computer. However, we do not guarantee that they are accurate and they are to be used at your own risk.
Member site: Alliance of Security Analysis Professionals | UNITE Against Malware
Memory Forums | Auto Repair Forum
© Geeks to Go, Inc. | All Rights Reserved | Privacy Policy
